[GRASS-SVN] r45697 - grass/trunk/raster/r.reclass
Thu Mar 17 22:02:04 EDT 2011
Author: hamish
Date: 2011-03-17 19:02:03 -0700 (Thu, 17 Mar 2011)
New Revision: 45697
   grass/trunk/raster/r.reclass/main.c
export floats and doubles with correct precision (#335, merge from devbr6)
Modified: grass/trunk/raster/r.reclass/main.c
--- grass/trunk/raster/r.reclass/main.c	2011-03-17 23:00:39 UTC (rev 45696)
+++ grass/trunk/raster/r.reclass/main.c	2011-03-18 02:02:03 UTC (rev 45697)
@@ -28,7 +28,7 @@
     struct Categories cats;
     struct FPRange range;
     DCELL min, max;
-    int fp;
+    RASTER_MAP_TYPE map_type;
     char buf[1024];
     RULE *rules, *tail;
     int any;
@@ -92,7 +92,7 @@
     tty = isatty(fileno(srcfp));
     Rast_init_cats("", &cats);
-    fp = Rast_map_is_fp(parm.input->answer, old_mapset);
+    map_type = Rast_map_type(parm.input->answer, old_mapset);
     Rast_read_fp_range(parm.input->answer, old_mapset, &range);
     Rast_get_fp_range_min_max(&range, &min, &max);
     rules = tail = NULL;
@@ -101,11 +101,14 @@
     if (tty) {
 	fprintf(stdout,
 		_("Enter rule(s), \"end\" when done, \"help\" if you need it\n"));
-	if (fp)
-	    fprintf(stdout, _("fp: Data range is %.25f to %.25f\n"),
+	if (map_type == FCELL_TYPE)
+	    fprintf(stdout, _("FCELL: Data range is %.7g to %.7g\n"),
 		    (double)min, (double)max);
+	else if (map_type == DCELL_TYPE)
+	    fprintf(stdout, _("DCELL: Data range is %.15g to %.15g\n"),
+		    (double)min, (double)max);
 	else
-	    fprintf(stdout, _("Data range is %ld to %ld\n"), (long)min,
+	    fprintf(stdout, _("CELL: Data range is %ld to %ld\n"), (long)min,
 		    (long)max);
