[GRASS-SVN] r45705 - grass/branches/develbranch_6/vector/v.in.dwg
Fri Mar 18 04:51:52 EDT 2011
Author: neteler
Date: 2011-03-18 01:51:52 -0700 (Fri, 18 Mar 2011)
New Revision: 45705
   grass/branches/develbranch_6/vector/v.in.dwg/main.c
fix of bug #1317
Modified: grass/branches/develbranch_6/vector/v.in.dwg/main.c
--- grass/branches/develbranch_6/vector/v.in.dwg/main.c	2011-03-18 08:51:41 UTC (rev 45704)
+++ grass/branches/develbranch_6/vector/v.in.dwg/main.c	2011-03-18 08:51:52 UTC (rev 45705)
@@ -216,7 +216,7 @@
     if (db_execute_immediate(driver, &sql) != DB_OK) {
 	db_close_database(driver);
 	db_shutdown_driver(driver);
-	G_fatal_error(_("Unable to create table: '%s'", db_get_string(&sql));
+	G_fatal_error(_("Unable to create table: '%s'", db_get_string(&sql)));
     if (db_create_index2(driver, Fi->table, "cat") != DB_OK)
