[GRASS-SVN] r45801 - grass/branches/develbranch_6/gui/scripts
Mon Mar 28 10:21:01 EDT 2011
Author: martinl
Date: 2011-03-28 07:21:01 -0700 (Mon, 28 Mar 2011)
New Revision: 45801
   grass/branches/develbranch_6/gui/scripts/g.extension.py
sync g.extension with trunk
Modified: grass/branches/develbranch_6/gui/scripts/g.extension.py
--- grass/branches/develbranch_6/gui/scripts/g.extension.py	2011-03-28 13:47:42 UTC (rev 45800)
+++ grass/branches/develbranch_6/gui/scripts/g.extension.py	2011-03-28 14:21:01 UTC (rev 45801)
@@ -96,9 +96,7 @@
 # temp dir
 remove_tmpdir = True
-tmpdir = grass.tempfile()
-grass.try_remove(tmpdir)
-os.mkdir(tmpdir)
+tmpdir = grass.tempdir()
 def check():
     for prog in ('svn', 'make', 'install', 'gcc'):
@@ -308,10 +306,8 @@
     else:
         url = svnurl + '/gui/wxpython/' + module
         if not flags['s']:
-            grass.warning(_("Installation of wxGUI extension requires -%s flag. "
-                            "Trying to use system administrator rights.") % 's')
-            flags['s'] = True
+            grass.fatal(_("Installation of wxGUI extension requires -%s flag.") % 's')
     grass.message(_("Fetching '%s' from GRASS-Addons SVN (be patient)...") % module)
     global tmpdir
     os.chdir(tmpdir)
@@ -325,36 +321,43 @@
         grass.fatal(_("GRASS Addons '%s' not found in repository") % module)
     os.chdir(os.path.join(tmpdir, module))
+    grass.message(_("Compiling '%s'...") % module)
+    if module not in gui_list:
+        bin_dir  = os.path.join(tmpdir, module, 'bin')
+        docs_dir = os.path.join(tmpdir, module, 'docs')
+        html_dir = os.path.join(docs_dir, 'html')
+        man_dir  = os.path.join(tmpdir, module, 'man')
+        man1_dir = os.path.join(man_dir, 'man1')
+        for d in (bin_dir, docs_dir, html_dir, man_dir, man1_dir):
+            os.mkdir(d)
-    grass.message(_("Compiling '%s'...") % module)
-    if grass.call(['make',
-                   'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ ')],
-                   stdout = outdev) != 0:
+        ret = grass.call(['make',
+                          'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ '),
+                          'BIN=%s' % bin_dir,
+                          'HTMLDIR=%s' % html_dir,
+                          'MANDIR=%s' % man1_dir],
+                         stdout = outdev)
+    else:
+                          'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ ')],
+                         stdout = outdev)
+    if ret != 0:
         grass.fatal(_('Compilation failed, sorry. Please check above error messages.'))
     if no_install or module in gui_list:
         return
     grass.message(_("Installing '%s'...") % module)
-    # replace with something better
-    file = os.path.join(prefix, 'test')
-    f = open(file, "w")
-    f.close()
-    os.remove(file)
-    if not flags['s']:
-        ret = grass.call(['make',
-                          'MODULE_TOPDIR=%s' % gisbase,
-                          'INST_DIR=%s' % prefix,
-                          'install'],
-                         stdout = outdev)
-    else:
-        ret = grass.call(['sudo', 'make',
-                          'install'],
-                         stdout = outdev)
+                      'MODULE_TOPDIR=%s' % gisbase,
+                      'ARCH_DISTDIR=%s' % os.path.join(tmpdir, module),
+                      'INST_DIR=%s' % prefix,
+                      'install'],
+                     stdout = outdev)
     if ret != 0:
         grass.warning(_('Installation failed, sorry. Please check above error messages.'))
     else:
