Author: neteler
Date: 2011-05-01 12:57:21 -0700 (Sun, 01 May 2011)
New Revision: 46152
grass/trunk/imagery/i.landsat.acca/algorithm.c
ejtizado: Corrected error from Irish_2006 (r45029); typo
Modified: grass/trunk/imagery/i.landsat.acca/algorithm.c
--- grass/trunk/imagery/i.landsat.acca/algorithm.c 2011-05-01 19:41:38 UTC (rev 46151)
+++ grass/trunk/imagery/i.landsat.acca/algorithm.c 2011-05-01 19:57:21 UTC (rev 46152)
@@ -134,8 +134,11 @@
/* WARNING: re-use of the variable 'value' with new meaning */
/* step 14 */
+ /* To correct Irish2006: idesert has to be bigger than 0.5 to start pass 2 processing (see Irish2000)
+ because then we have no desert condition (thanks to Matthias Eder, Germany) */
if (cloud_signature ||
- (idesert <= .5 && signa[COVER] > 0.004 && signa[KMEAN] < 295.)) {
+ (idesert > .5 && signa[COVER] > 0.004 && signa[KMEAN] < 295.)) {
G_message(_("Histogram cloud signature:"));
value[MEAN] = quantile(0.5, hist_cold) + K_BASE;
@@ -166,7 +169,12 @@
shift *= value[DSTD];
if ((value[KUPPER] + shift) > max) {
- value[KLOWER] += (max - value[KUPPER]);
+ if ((value[KLOWER] + shift) > max) {
+ value[KLOWER] += (max - value[KUPPER]);
+ else {
+ value[KLOWER] += shift;
value[KUPPER] = max;
else {
@@ -177,7 +185,7 @@
G_message(_("Maximum temperature:"));
G_message(_("* Cold cloud: %.2lf K"), value[KUPPER]);
- G_message(_("* Warn cloud: %.2lf K"), value[KLOWER]);
+ G_message(_("* Warm cloud: %.2lf K"), value[KLOWER]);
else {
if (signa[KMEAN] < 295.) {
