[GRASS-SVN] r46219 - in grass-addons/raster: . r.pi/r.pi.export r.pi/r.pi.import
Mon May 9 09:24:41 EDT 2011
Author: neteler
Date: 2011-05-09 06:24:41 -0700 (Mon, 09 May 2011)
New Revision: 46219
   grass-addons/raster/Makefile
   grass-addons/raster/r.pi/r.pi.export/local_proto.h
   grass-addons/raster/r.pi/r.pi.export/main.c
   grass-addons/raster/r.pi/r.pi.import/Makefile
   grass-addons/raster/r.pi/r.pi.import/local_proto.h
   grass-addons/raster/r.pi/r.pi.import/main.c
compilation fix
Modified: grass-addons/raster/Makefile
--- grass-addons/raster/Makefile	2011-05-09 12:44:59 UTC (rev 46218)
+++ grass-addons/raster/Makefile	2011-05-09 13:24:41 UTC (rev 46219)
@@ -1,5 +1,7 @@
 MODULE_TOPDIR = ..
+# r.convert
+# r.roughness
 SUBDIRS = \
 	LandDyn \
 	mcda \
@@ -8,8 +10,6 @@
 	r.burn.frict \
 	r.clim \
 	r.colors.quantiles \
-	r.colors.tools \
-	r.convert \
 	r.denoise \
 	r.game_of_life \
 	r.inund.fluv \
@@ -25,7 +25,6 @@
 	r.pi \
 	r.prominence \
 	r.rast4d \
-	r.roughness \
 	r.soils.texture \
 	r.stream.basins \
 	r.stream.del \
Modified: grass-addons/raster/r.pi/r.pi.export/local_proto.h
--- grass-addons/raster/r.pi/r.pi.export/local_proto.h	2011-05-09 12:44:59 UTC (rev 46218)
+++ grass-addons/raster/r.pi/r.pi.export/local_proto.h	2011-05-09 13:24:41 UTC (rev 46219)
@@ -4,12 +4,18 @@
 #include <string.h>
 #include <stdlib.h>
 #include <unistd.h>
+#include <math.h>
+#include <time.h>
 #include <grass/gis.h>
 #include <grass/glocale.h>
 #include <grass/stats.h>
-#include <math.h>
-#include <time.h>
+#ifdef MAIN
+#define GLOBAL
+#else
+#define GLOBAL extern
+#endif
 #define NOTHING 0
 #define RESOLUTION 10000
@@ -17,72 +23,52 @@
 #define MIN_DOUBLE -1000000
 #define MAX_DOUBLE 1000000
-typedef struct
-    int x, y;
-    int neighbors;
-    DCELL value;
+typedef struct {
+	int x, y;
+	int neighbors;
+	DCELL value;
 } Coords;
-typedef struct
-    int x, y;
+typedef struct {
+	int x, y;
 } Point;
-typedef struct
-    int x, y;
-    int patch;
+typedef struct {
+	int x, y;
+	int patch;
 } PatchPoint;
-typedef DCELL(*f_statmethod) (DCELL *, int);
+typedef DCELL (*f_statmethod)(DCELL*, int);
 /* helpers.c */
 int Round(double d);
 int Random(int max);
 double Randomf();
 void print_buffer(int *buffer, int sx, int sy);
-void print_d_buffer(DCELL * buffer, int sx, int sy);
+void print_d_buffer(DCELL *buffer, int sx, int sy);
 void print_map(double *map, int size);
-void print_array(DCELL * buffer, int size);
+void print_array(DCELL *buffer, int size);
 void print_fragments();
 /* frag.c */
-void writeFragments(DCELL * flagbuf, int nrows, int ncols, int nbr_cnt);
+void writeFragments(DCELL *flagbuf, int nrows, int ncols, int nbr_cnt);
 /* stat_method.c */
 DCELL average(DCELL * vals, int count);
 DCELL variance(DCELL * vals, int count);
 DCELL std_deviat(DCELL * vals, int count);
 DCELL median(DCELL * vals, int count);
 DCELL min(DCELL * vals, int count);
 DCELL max(DCELL * vals, int count);
 /* global variables */
-int verbose;
+GLOBAL int verbose;
+GLOBAL Coords **fragments;
+GLOBAL Coords *cells;
+GLOBAL int fragcount;
+GLOBAL int sx, sy;
+GLOBAL int *id_map;
-Coords **fragments;
+GLOBAL int *adj_matrix;
-Coords *cells;
-int fragcount;
-int sx, sy;
-int *id_map;
-int *adj_matrix;
 #endif /* LOCAL_PROTO_H */
Modified: grass-addons/raster/r.pi/r.pi.export/main.c
--- grass-addons/raster/r.pi/r.pi.export/main.c	2011-05-09 12:44:59 UTC (rev 46218)
+++ grass-addons/raster/r.pi/r.pi.export/main.c	2011-05-09 13:24:41 UTC (rev 46219)
@@ -1,3 +1,4 @@
+#define MAIN
 #include "local_proto.h"
Modified: grass-addons/raster/r.pi/r.pi.import/Makefile
--- grass-addons/raster/r.pi/r.pi.import/Makefile	2011-05-09 12:44:59 UTC (rev 46218)
+++ grass-addons/raster/r.pi/r.pi.import/Makefile	2011-05-09 13:24:41 UTC (rev 46219)
@@ -1,5 +1,10 @@
-MODULE_TOPDIR =.. /..PGM = r.pi.import LIBES = $(STATSLIB) $(GISLIB)
-    DEPENDENCIES = $(STATSDEP) $(GISDEP)
+MODULE_TOPDIR = ../..
-include $(MODULE_TOPDIR) / include / Make / Module.make default:
-cmd
+PGM = r.pi.import
+LIBES = $(STATSLIB) $(GISLIB)
+DEPENDENCIES = $(STATSDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Modified: grass-addons/raster/r.pi/r.pi.import/local_proto.h
--- grass-addons/raster/r.pi/r.pi.import/local_proto.h	2011-05-09 12:44:59 UTC (rev 46218)
+++ grass-addons/raster/r.pi/r.pi.import/local_proto.h	2011-05-09 13:24:41 UTC (rev 46219)
@@ -4,12 +4,18 @@
 #include <string.h>
 #include <stdlib.h>
 #include <unistd.h>
+#include <math.h>
+#include <time.h>
-#include <math.h>
-#include <time.h>
+#ifdef MAIN
+#define GLOBAL
+#else
+#endif
 #define NOTHING 0
@@ -27,19 +33,12 @@
 /* helpers.c */
 double Randomf();
 /* frag.c */
@@ -49,16 +48,13 @@
 void parse(DCELL * values, char *file_name, int id_col, int val_col);
-int verbose;
+GLOBAL int sx, sy;
-Coords *cells;
-int fragcount;
-int sx, sy;
-int *adj_matrix;
Modified: grass-addons/raster/r.pi/r.pi.import/main.c
--- grass-addons/raster/r.pi/r.pi.import/main.c	2011-05-09 12:44:59 UTC (rev 46218)
+++ grass-addons/raster/r.pi/r.pi.import/main.c	2011-05-09 13:24:41 UTC (rev 46219)
@@ -1,3 +1,4 @@
+#define MAIN
