[GRASS-SVN] r46308 - grass/trunk/vector/v.db.connect
Sun May 15 08:54:46 EDT 2011
Author: mmetz
Date: 2011-05-15 05:54:46 -0700 (Sun, 15 May 2011)
New Revision: 46308
   grass/trunk/vector/v.db.connect/main.c
close vector
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c	2011-05-15 12:47:59 UTC (rev 46307)
+++ grass/trunk/vector/v.db.connect/main.c	2011-05-15 12:54:46 UTC (rev 46308)
@@ -164,6 +164,7 @@
 	    /* it is ok if a vector map is not connected o an attribute table */
 	    G_message(_("Map <%s> is not connected to a database"),
 			  input);
+	    Vect_close(&Map);
 	    exit(EXIT_SUCCESS);
 	else {			/* num_dblinks > 0 */
