[GRASS-SVN] r46385 - grass/branches/releasebranch_6_4/ps/ps.map
Mon May 23 08:11:49 EDT 2011
Author: hamish
Date: 2011-05-23 05:11:48 -0700 (Mon, 23 May 2011)
New Revision: 46385
   grass/branches/releasebranch_6_4/ps/ps.map/description.html
   grass/branches/releasebranch_6_4/ps/ps.map/eps.c
   grass/branches/releasebranch_6_4/ps/ps.map/labels.h
   grass/branches/releasebranch_6_4/ps/ps.map/map_info.c
   grass/branches/releasebranch_6_4/ps/ps.map/ps_header.c
   grass/branches/releasebranch_6_4/ps/ps.map/r_labels.c
   grass/branches/releasebranch_6_4/ps/ps.map/r_plt.c
   grass/branches/releasebranch_6_4/ps/ps.map/r_vareas.c
merge various enhancements from devbr6
Modified: grass/branches/releasebranch_6_4/ps/ps.map/description.html
--- grass/branches/releasebranch_6_4/ps/ps.map/description.html	2011-05-23 11:35:07 UTC (rev 46384)
+++ grass/branches/releasebranch_6_4/ps/ps.map/description.html	2011-05-23 12:11:48 UTC (rev 46385)
@@ -924,7 +924,9 @@
 <EM>rgb</EM> option, count as a raster map layer for the
 purposes of the preceding paragraph.
 <P>
+The PostScript file's internal title will be set to the raster map's
+title, which in turn may be set with the <em>r.suppport</em> module.
+<P>
 This example would paint a map of the raster map layer <EM>soils</EM>.
 <PRE>
@@ -1614,7 +1616,7 @@
 The following are examples of <EM>ps.map</EM> script files.
 <P>
-<h3>Simple example</h3>
+<h4>Simple example</h4>
 The file has been named <EM>spear.basic</EM>:
 <PRE>
@@ -1634,7 +1636,7 @@
 </PRE>
-<h3>More complicated example</h3>
+<h4>More complicated example</h4>
 The file has been named <EM>spear.soils</EM>:
 <PRE>
Modified: grass/branches/releasebranch_6_4/ps/ps.map/eps.c
--- grass/branches/releasebranch_6_4/ps/ps.map/eps.c	2011-05-23 11:35:07 UTC (rev 46384)
+++ grass/branches/releasebranch_6_4/ps/ps.map/eps.c	2011-05-23 12:11:48 UTC (rev 46385)
@@ -1,5 +1,6 @@
 #include <math.h>
 #include <string.h>
+#include <grass/glocale.h>
 #include "ps_info.h"
 #include "local_proto.h"
@@ -15,7 +16,7 @@
     /* test if file is realy eps and find bbox */
     if ((fp = fopen(eps, "r")) == NULL) {
-	fprintf(stderr, "can't open eps file <%s>\n", eps);
+	G_warning(_("Can't open eps file <%s>"), eps);
 	return (0);
     /* test if first row contains '%!PS-Adobe-m.n EPSF-m.n' string */
@@ -34,7 +35,7 @@
 	    return (1);
-    fprintf(stderr, "Bounding box in eps file <%s> was not found\n", eps);
+    G_warning(_("Bounding box in eps file <%s> was not found"), eps);
     fclose(fp);
     return (0);
Modified: grass/branches/releasebranch_6_4/ps/ps.map/labels.h
--- grass/branches/releasebranch_6_4/ps/ps.map/labels.h	2011-05-23 11:35:07 UTC (rev 46384)
+++ grass/branches/releasebranch_6_4/ps/ps.map/labels.h	2011-05-23 12:11:48 UTC (rev 46385)
@@ -1,4 +1,4 @@
-#define MAXLABELS 10
+#define MAXLABELS 50
 struct labels
Modified: grass/branches/releasebranch_6_4/ps/ps.map/map_info.c
--- grass/branches/releasebranch_6_4/ps/ps.map/map_info.c	2011-05-23 11:35:07 UTC (rev 46384)
+++ grass/branches/releasebranch_6_4/ps/ps.map/map_info.c	2011-05-23 12:11:48 UTC (rev 46385)
@@ -26,6 +26,7 @@
     /* get text location */
     dy = fontsize;
     if (m_info.x > 0.0)
 	x = 72.0 * m_info.x;
     else
@@ -34,7 +35,9 @@
 	y = 72.0 * (PS.page_height - m_info.y);
     else
 	y = PS.min_y;
     margin = 0.2 * fontsize;
     if (x < PS.map_left + margin)
 	x = PS.map_left + margin;
Modified: grass/branches/releasebranch_6_4/ps/ps.map/ps_header.c
--- grass/branches/releasebranch_6_4/ps/ps.map/ps_header.c	2011-05-23 11:35:07 UTC (rev 46384)
+++ grass/branches/releasebranch_6_4/ps/ps.map/ps_header.c	2011-05-23 12:11:48 UTC (rev 46385)
@@ -5,6 +5,7 @@
 #include <stdio.h>
 #include <unistd.h>
+#include <grass/gis.h>
 static long bb_offset;
@@ -13,6 +14,12 @@
 int write_PS_header(void)
+    struct Categories cats;
+    int cats_ok;
+    if (PS.do_raster)
+	cats_ok = G_read_cats(PS.cell_name, PS.cell_mapset, &cats) >= 0;
     /* write PostScript header */
     /*fprintf(PS.fp, "%%!PS-Adobe-2.0 EPSF-1.2\n"); */
     if (eps_output)
@@ -24,9 +31,10 @@
     fprintf(PS.fp, "                                       ");
     fprintf(PS.fp, "                                       \n");
     fprintf(PS.fp, "%%%%Title: ");
-    if (PS.do_raster)
-	fprintf(PS.fp, "Map layer = %s  ", PS.cell_name);
-    fprintf(PS.fp, "Mapset = %s\n", PS.cell_mapset);
+    if (PS.do_raster && cats_ok)
+	fprintf(PS.fp, "%s\n", cats.title);
+    else
+	fprintf(PS.fp, "Mapset = %s\n", PS.cell_mapset);
     fprintf(PS.fp, "%%%%EndComments\n");
     return 0;
Modified: grass/branches/releasebranch_6_4/ps/ps.map/r_labels.c
--- grass/branches/releasebranch_6_4/ps/ps.map/r_labels.c	2011-05-23 11:35:07 UTC (rev 46384)
+++ grass/branches/releasebranch_6_4/ps/ps.map/r_labels.c	2011-05-23 12:11:48 UTC (rev 46385)
@@ -12,7 +12,7 @@
 int read_labels(char *name, char *mapset)
-    char fullname[100];
+    char fullname[GNAME_MAX+GMAPSET_MAX+5];
     char buf[1024];
     char *key, *data;
Modified: grass/branches/releasebranch_6_4/ps/ps.map/r_plt.c
--- grass/branches/releasebranch_6_4/ps/ps.map/r_plt.c	2011-05-23 11:35:07 UTC (rev 46384)
+++ grass/branches/releasebranch_6_4/ps/ps.map/r_plt.c	2011-05-23 12:11:48 UTC (rev 46385)
@@ -1,5 +1,6 @@
 #include <string.h>
 #define KEY(x)(strcmp(key,x)==0)
@@ -106,7 +107,7 @@
 int read_eps(double e, double n)
-    char buf[1024];
+    char buf[1024], eps_file[GPATH_MAX];
     char *eps;
     double scale, rotate;
     int have_eps;
@@ -140,10 +141,21 @@
 	if (KEY("epsfile")) {
 	    G_chop(data);
-	    eps = G_store(data);
+	    /* expand "$GISBASE" if present */
+	    if (strncmp(data, "$GISBASE", 8) != 0)
+		strcpy(eps_file, data);
+	    else {
+		strcpy(eps_file, G_gisbase());
+		data += 8;
+		strcat(eps_file, data);
+	    eps = G_store(eps_file);
 	    /* test if file is accessible */
-		error(key, data, "Can't open eps file");
+		error(key, data, _("Can't open eps file"));
 	    have_eps = 1;
 	    fclose(fp);
Modified: grass/branches/releasebranch_6_4/ps/ps.map/r_vareas.c
--- grass/branches/releasebranch_6_4/ps/ps.map/r_vareas.c	2011-05-23 11:35:07 UTC (rev 46384)
+++ grass/branches/releasebranch_6_4/ps/ps.map/r_vareas.c	2011-05-23 12:11:48 UTC (rev 46385)
@@ -34,7 +34,7 @@
 int read_vareas(char *name, char *mapset)
     char fullname[GNAME_MAX + GMAPSET_MAX + 5];
-    char buf[1024];
     char *key, *data;
     double width;
     int itmp, vec;
@@ -172,7 +172,17 @@
 	if (KEY("pat") || KEY("pattern")) {
 	    G_chop(data);
-	    vector.layer[vec].pat = G_store(data);
+	    else {
+		data += 8;
+	    vector.layer[vec].pat = G_store(eps_file);
 	    continue;
