[GRASS-SVN] r46418 - in grass/trunk/vector: . v.in.lidar
    svn_grass at osgeo.org
    Wed May 25 05:16:36 EDT 2011
Author: mmetz
Date: 2011-05-25 02:16:36 -0700 (Wed, 25 May 2011)
New Revision: 46418
Added:
   grass/trunk/vector/v.in.lidar/
Removed:
   grass/trunk/vector/v.in.lidar/geom.c
   grass/trunk/vector/v.in.lidar/global.h
   grass/trunk/vector/v.in.lidar/Makefile
   grass/trunk/vector/v.in.lidar/main.c
new module to import LiDAR LAS format
Modified: grass/trunk/vector/v.in.lidar/Makefile
--- grass/trunk/vector/v.in.ogr/Makefile	2011-05-22 11:51:32 UTC (rev 46356)
+++ grass/trunk/vector/v.in.lidar/Makefile	2011-05-25 09:16:36 UTC (rev 46418)
@@ -1,16 +1,16 @@
 MODULE_TOPDIR = ../..
-PGM=v.in.ogr
+PGM=v.in.lidar
-LIBES = $(GPROJLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(GDALLIBS) $(MATHLIB)
+LIBES = $(GPROJLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(LASLIBS) $(MATHLIB)
 DEPENDENCIES = $(GPROJDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
-EXTRA_INC = $(VECT_INC) $(PROJINC)
+EXTRA_INC = $(VECT_INC) $(PROJINC) $(LASINC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
 include $(MODULE_TOPDIR)/include/Make/Module.make
-ifneq ($(USE_OGR),)
+ifneq ($(USE_LIBLAS),)
 default: cmd
 endif
Deleted: grass/trunk/vector/v.in.lidar/geom.c
--- grass/trunk/vector/v.in.ogr/geom.c	2011-05-22 11:51:32 UTC (rev 46356)
+++ grass/trunk/vector/v.in.lidar/geom.c	2011-05-25 09:16:36 UTC (rev 46418)
@@ -1,477 +0,0 @@
- * MODULE:       v.in.ogr
- * AUTHOR(S):    Radim Blazek
- * PURPOSE:      Import OGR vectors
- * COPYRIGHT:    (C) 2001 by the GRASS Development Team
- *               This program is free software under the
- *               GNU General Public License (>=v2).
- *               Read the file COPYING that comes with GRASS
- *               for details.
-#include <stdlib.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/dbmi.h>
-#include <grass/vector.h>
-#include <grass/glocale.h>
-#include "ogr_api.h"
-#include "global.h"
-int split_line(struct Map_info *Map, int otype, struct line_pnts *Points,
-	       struct line_cats *Cats);
-/* Add categories to centroids inside polygon */
-int
-centroid(OGRGeometryH hGeom, CENTR * Centr, struct spatial_index *Sindex,
-	 int field, int cat, double min_area, int type)
-    int i, valid_isles, j, np, nr, ret;
-    static int first = 1;
-    static struct line_pnts *Points;
-    struct line_pnts **IPoints;
-    static struct line_cats *BCats, *Cats;
-    OGRwkbGeometryType eType;
-    OGRGeometryH hRing;
-    double size;
-    static struct ilist *List;
-    struct bound_box box;
-    G_debug(3, "centroid() cat = %d", cat);
-    if (first) {
-	Points = Vect_new_line_struct();
-	BCats = Vect_new_cats_struct();
-	Cats = Vect_new_cats_struct();
-	List = Vect_new_list();
-	first = 0;
-    else {
-	Vect_reset_line(Points);
-	Vect_reset_cats(Cats);
-	Vect_reset_cats(BCats);
-	Vect_cat_set(Cats, field, cat);
-    eType = wkbFlatten(OGR_G_GetGeometryType(hGeom));
-    if (eType == wkbPolygon) {
-	nr = OGR_G_GetGeometryCount(hGeom);
-	G_debug(3, "polygon: %d rings", nr);
-	/* SFS: 1 exterior boundary and 0 or more interior boundaries.
-	 *  So I hope that exterior is the first one, even if it is not explicitly told  */
-	/* Area */
-	hRing = OGR_G_GetGeometryRef(hGeom, 0);
-	np = OGR_G_GetPointCount(hRing);
-	for (j = 0; j < np; j++) {
-	    Vect_append_point(Points, OGR_G_GetX(hRing, j),
-			      OGR_G_GetY(hRing, j), OGR_G_GetZ(hRing, j));
-	/* Degenerate is ignored */
-	if (Points->n_points < 4)
-	    return 0;
-	/* Small areas ignored because boundaries are not imported */
-	size = G_area_of_polygon(Points->x, Points->y, Points->n_points);
-	if (size < min_area)
-	    return 0;
-	/* Isles */
-	IPoints =
-	    (struct line_pnts **)G_malloc((nr - 1) *
-					  sizeof(struct line_pnts *));
-	valid_isles = 0;
-	for (i = 1; i < nr; i++) {
-	    hRing = OGR_G_GetGeometryRef(hGeom, i);
-	    if ((np = OGR_G_GetPointCount(hRing)) > 0) {
-		IPoints[valid_isles] = Vect_new_line_struct();
-		    Vect_append_point(IPoints[valid_isles],
-				      OGR_G_GetX(hRing, j),
-				      OGR_G_GetZ(hRing, j));
-		size =
-		    G_area_of_polygon(IPoints[valid_isles]->x,
-				      IPoints[valid_isles]->y,
-				      IPoints[valid_isles]->n_points);
-		    Vect_destroy_line_struct(IPoints[valid_isles]);
-		else
-		    valid_isles++;
-	/* Find centroids */
-	if (Points->n_points >= 4) {
-	    int centr, in;
-	    double x, y;
-	    Vect_line_box(Points, &box);
-	    Vect_spatial_index_select(Sindex, &box, List);
-	    for (i = 0; i < List->n_values; i++) {
-		centr = List->value[i];
-		x = Centr[centr].x;
-		y = Centr[centr].y;
-		ret = Vect_point_in_poly(x, y, Points);
-		if (ret == 0)
-		    continue;	/* outside */
-		in = 1;
-		for (j = 0; j < valid_isles; j++) {
-		    ret = Vect_point_in_poly(x, y, IPoints[j]);
-		    if (ret == 1) {	/* centroid in inner ring */
-			in = 0;
-			break;	/* inside isle */
-		if (!in)
-		    continue;
-		G_debug(3, "Centroid %d : layer %d cat %d", centr, field,
-			cat);
-		Vect_cat_set(Centr[centr].cats, field, cat);
-	for (i = 0; i < valid_isles; i++) {
-	    Vect_destroy_line_struct(IPoints[i]);
-	G_free(IPoints);
-    /* I did not test this because I did not have files of these types */
-    else if (eType == wkbGeometryCollection || eType == wkbMultiPolygon) {
-	G_debug(3, "GeometryCollection or MultiPolygon/LineString/Point");
-	for (i = 0; i < nr; i++) {
-	    ret = centroid(hRing, Centr, Sindex, field, cat, min_area, type);
-    return 0;
-/* count polygons and isles */
-int poly_count(OGRGeometryH hGeom)
-    int i, nr, ret;
-	G_debug(3, "Polygon");
-	n_polygon_boundaries += nr;
-	G_debug(3, "GeometryCollection or MultiPolygon");
-	    ret = poly_count(hRing);
-	    if (ret == -1) {
-		G_warning(_("Cannot read part of geometry"));
-    return 0;
-/* Write geometry to output map */
-int
-geom(OGRGeometryH hGeom, struct Map_info *Map, int field, int cat,
-     double min_area, int type, int mk_centr)
-    int i, valid_isles, j, np, nr, ret, otype;
-    double x, y;
-    double size;
-    G_debug(3, "geom() cat = %d", cat);
-    if (first) {
-	first = 0;
-    if (eType == wkbPoint) {
-	if ((np = OGR_G_GetPointCount(hGeom)) == 0) {
-	    G_warning(_("Skipping empty geometry feature"));
-	    return 0;
-	Vect_append_point(Points, OGR_G_GetX(hGeom, 0), OGR_G_GetY(hGeom, 0),
-			  OGR_G_GetZ(hGeom, 0));
-	if (type & GV_CENTROID)
-	    otype = GV_CENTROID;
-	else
-	    otype = GV_POINT;
-	Vect_write_line(Map, otype, Points, Cats);
-    else if (eType == wkbLineString) {
-	    return 0;
-	for (i = 0; i < np; i++) {
-	    Vect_append_point(Points, OGR_G_GetX(hGeom, i),
-			      OGR_G_GetY(hGeom, i), OGR_G_GetZ(hGeom, i));
-	if (type & GV_BOUNDARY)
-	    otype = GV_BOUNDARY;
-	else
-	    otype = GV_LINE;
-	if (split_distance > 0 && otype == GV_BOUNDARY)
-	    split_line(Map, otype, Points, Cats);
-	else
-    else if (eType == wkbPolygon) {
-	/* Area */
-	if ((np = OGR_G_GetPointCount(hRing)) == 0) {
-	    return 0;
-	n_polygons++;
-	/* Degenerate is not ignored because it may be useful to see where it is,
-	 * but may be eliminated by min_area option */
-	    G_warning(_("Degenerate polygon ([%d] vertices)"),
-		      Points->n_points);
-	if (size < min_area) {
-	    G_debug(2, "Area size [%.1e], area not imported", size);
-	    return 0;
-	if (type & GV_LINE)
-	    otype = GV_LINE;
-	else
-	    split_line(Map, otype, Points, BCats);
-	else
-	    Vect_write_line(Map, otype, Points, BCats);
-	/* Isles */
-	IPoints =
-	valid_isles = 0;
-	    G_debug(3, "Inner ring %d", i);
-	    else {
-		if (IPoints[valid_isles]->n_points < 4)
-		    G_warning(_("Degenerate island ([%d] vertices)"),
-			      IPoints[i - 1]->n_points);
-		size =
-		    G_debug(2, "Island size [%.1e], island not imported",
-			      size);
-		else {
-			otype = GV_LINE;
-		    else
-			split_line(Map, otype, IPoints[valid_isles], BCats);
-		    else
-			Vect_write_line(Map, otype, IPoints[valid_isles],
-					BCats);
-		valid_isles++;
-	}			/* inner rings done */
-	/* Centroid */
-	/* Vect_get_point_in_poly_isl() would fail for degenerate polygon */
-	if (mk_centr) {
-		ret =
-		    Vect_get_point_in_poly_isl(Points, IPoints, valid_isles,
-					       &x, &y);
-		if (ret == -1) {
-		    G_warning(_("Cannot calculate centroid"));
-		else {
-		    Vect_append_point(Points, x, y, 0.0);
-		    if (type & GV_POINT)
-			otype = GV_POINT;
-		    else
-	    else if (Points->n_points > 0) {
-		if (Points->n_points >= 2) {
-		    /* center of 1. segment ( 2. point is not best for 3 vertices as 3. may be the same as 1.) */
-		    x = (Points->x[0] + Points->x[1]) / 2;
-		    y = (Points->y[0] + Points->y[1]) / 2;
-		else {		/* one point */
-		    x = Points->x[0];
-		    y = Points->y[0];
-		    otype = GV_POINT;
-		else
-	    else {		/* 0 points */
-		G_warning(_("No centroid written for polygon with 0 vertices"));
-	G_free(IPoints);
-	     || eType == wkbMultiPolygon
-	     || eType == wkbMultiLineString || eType == wkbMultiPoint) {
-	    ret = geom(hRing, Map, field, cat, min_area, type, mk_centr);
-	    if (ret == -1) {
-		G_warning(_("Cannot write part of geometry"));
-    else {
-	G_fatal_error(_("Unknown geometry type"));
-    return 0;
-    int i;
-    double dist = 0., seg_dist, dx, dy;
-    struct line_pnts *OutPoints;
-    /* don't write zero length boundaries */
-    Vect_line_prune(Points);
-    if (Points->n_points < 2)
-	return 0;
-    /* can't split boundaries with only 2 vertices */
-    if (Points->n_points == 2) {
-	return 0;
-    OutPoints = Vect_new_line_struct();
-    Vect_append_point(OutPoints, Points->x[0], Points->y[0], Points->z[0]);
-    Vect_append_point(OutPoints, Points->x[1], Points->y[1], Points->z[1]);
-    dx = Points->x[1] - Points->x[0];
-    dy = Points->y[1] - Points->y[0];
-    dist = sqrt(dx * dx + dy * dy);
-    /* trying to keep line length smaller than split_distance
-     * alternative, less code: write line as soon as split_distance is exceeded */
-    for (i = 2; i < Points->n_points; i++) {
-	dx = Points->x[i] - Points->x[i - 1];
-	dy = Points->y[i] - Points->y[i - 1];
-	seg_dist = sqrt(dx * dx + dy * dy);
-	dist += seg_dist;
-	if (dist > split_distance) {
-	    Vect_write_line(Map, otype, OutPoints, Cats);
-	    Vect_reset_line(OutPoints);
-	    dist = seg_dist;
-	    Vect_append_point(OutPoints, Points->x[i - 1], Points->y[i - 1],
-			      Points->z[i - 1]);
-	Vect_append_point(OutPoints, Points->x[i], Points->y[i],
-			  Points->z[i]);
-    Vect_destroy_line_struct(OutPoints);
-    return 0;
Deleted: grass/trunk/vector/v.in.lidar/global.h
--- grass/trunk/vector/v.in.ogr/global.h	2011-05-22 11:51:32 UTC (rev 46356)
+++ grass/trunk/vector/v.in.lidar/global.h	2011-05-25 09:16:36 UTC (rev 46418)
@@ -1,40 +0,0 @@
- *               Markus Neteler (spatial parm, projection support)
- *               Paul Kelly (projection support)
- * COPYRIGHT:    (C) 2003 by the GRASS Development Team
- *               for details.
- * TODO: - make fixed field length of OFTIntegerList dynamic
- *       - several other TODOs below
-#ifndef __GLOBAL_H__
-#define __GLOBAL_H__
-extern int n_polygons;
-extern int n_polygon_boundaries;
-extern double split_distance;
-/* centroid structure */
-typedef struct
-    double x, y;
-    struct line_cats *cats;
-    int valid;
-} CENTR;
-#endif /* __GLOBAL_H__ */
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2011-05-22 11:51:32 UTC (rev 46356)
+++ grass/trunk/vector/v.in.lidar/main.c	2011-05-25 09:16:36 UTC (rev 46418)
@@ -1,13 +1,12 @@
+ * MODULE:       v.in.lidar
+ * AUTHOR(S):    Markus Metz
+ *               based on v.in.ogr
+ * PURPOSE:      Import LiDAR LAS points
@@ -27,108 +26,134 @@
 #include <grass/gprojects.h>
-#include <gdal_version.h>	/* needed for OFTDate */
+#include <liblas/capi/liblas.h>
 #ifndef MAX
 #  define MIN(a,b)      ((a<b) ? a : b)
 #  define MAX(a,b)      ((a>b) ? a : b)
 #endif
-int n_polygons;
-int n_polygon_boundaries;
-double split_distance;
+ * ASPRS Standard LIDAR Point Classes
+ * Classification Value (bits 0:4) : Meaning
+ *      0 : Created, never classified
+ *      1 : Unclassified
+ *      2 : Ground
+ *      3 : Low Vegetation
+ *      4 : Medium Vegetation
+ *      5 : High Vegetation
+ *      6 : Building
+ *      7 : Low Point (noise)
+ *      8 : Model Key-point (mass point)
+ *      9 : Water
+ *     10 : Reserved for ASPRS Definition
+ *     11 : Reserved for ASPRS Definition
+ *     12 : Overlap Points
+ *  13-31 : Reserved for ASPRS Definition
-int geom(OGRGeometryH hGeom, struct Map_info *Map, int field, int cat,
-	 double min_area, int type, int mk_centr);
-int centroid(OGRGeometryH hGeom, CENTR * Centr, struct spatial_index * Sindex,
-	     int field, int cat, double min_area, int type);
-int poly_count(OGRGeometryH hGeom);
+/* Classification Bit Field Encoding
+ * Bits | Field Name     | Description
+ *  0-4 | Classification | Standard ASPRS classification as defined in the
+ *                         above classification table.
+ *    5 | Synthetic      | If set then this point was created by a technique
+ *                         other than LIDAR collection such as digitized from
+ *	                   a photogrammetric stereo model or by traversing
+ *                         a waveform.
+ *    6 | Key-point      | If set, this point is considered to be a model
+ *                         key-point and thus generally should not be withheld
+ *                         in a thinning algorithm.
+ *    7 | Withheld       | If set, this point should not be included in
+ *                         processing (synonymous with Deleted).
+struct class_table
+    int code;
+    char *name;
+static struct class_table class_val[] = {
+    {0, "Created, never classified"},
+    {1, "Unclassified"},
+    {2, "Ground"},
+    {3, "Low Vegetation"},
+    {4, "Medium Vegetation"},
+    {5, "High Vegetation"},
+    {6, "Building"},
+    {7, "Low Point (noise)"},
+    {8, "Model Key-point (mass point)"},
+    {9, "Water"},
+    {10, "Reserved for ASPRS Definition"},
+    {11, "Reserved for ASPRS Definition"},
+    {12, "Overlap Points"},
+    {13 /* 13 - 31 */, "Reserved for ASPRS Definition"},
+    {0, 0}
+static struct class_table class_type[] = {
+    {5, "Synthetic"},
+    {6, "Key-point"},
+    {7, "withheld"},
+    {0, 0}
+void print_lasinfo(LASHeaderH LAS_header, LASSRSH LAS_srs);
 int main(int argc, char *argv[])
-    int i, j, layer, arg_s_num, nogeom, ncnames;
+    int i;
     float xmin = 0., ymin = 0., xmax = 0., ymax = 0.;
-    int ncols = 0, type;
     struct GModule *module;
-    double min_area, snap;
-    struct Option *dsn_opt, *out_opt, *layer_opt, *spat_opt, *where_opt,
-	*min_area_opt;
-    struct Option *snap_opt, *type_opt, *outloc_opt, *cnames_opt;
-    struct Flag *list_flag, *no_clean_flag, *z_flag, *notab_flag,
-	*region_flag;
-    struct Flag *over_flag, *extend_flag, *formats_flag, *tolower_flag, *no_import_flag;
-    char buf[2000], namebuf[2000], tempvect[2000];
-    char *separator;
+    struct Option *in_opt, *out_opt, *spat_opt;
+    struct Option *outloc_opt;
+    struct Flag *print_flag, *notab_flag, *region_flag, *notopo_flag;
+    struct Flag *over_flag, *extend_flag, *no_import_flag;
+    char buf[2000];
     struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
     struct Key_Value *proj_info, *proj_units;
+    const char *projstr;
     struct Cell_head cellhd, loc_wind, cur_wind;
     char error_msg[8192];
     /* Vector */
-    struct Map_info Map, Tmp;
+    struct Map_info Map;
     int cat;
     /* Attributes */
     struct field_info *Fi;
     dbDriver *driver;
     dbString sql, strval;
-    int dim, with_z;
+    /* LAS */
+    LASReaderH LAS_reader;
+    LASHeaderH LAS_header;
+    LASSRSH LAS_srs;
+    LASPointH LAS_point;
+    double scale_x, scale_y, scale_z, offset_x, offset_y, offset_z;
+    int las_point_format;
+    int have_time, have_color;
+    unsigned int not_valid;
-    /* OGR */
-    OGRDataSourceH Ogr_ds = NULL;
-    OGRLayerH Ogr_layer;
-    OGRFieldDefnH Ogr_field;
-    char *Ogr_fieldname;
-    OGRFieldType Ogr_ftype;
-    OGRFeatureH Ogr_feature;
-    OGRFeatureDefnH Ogr_featuredefn;
-    OGRGeometryH Ogr_geometry, Ogr_oRing = NULL, poSpatialFilter = NULL;
-    OGRSpatialReferenceH Ogr_projection;
-    OGREnvelope oExt;
-    int OFTIntegerListlength = 40;	/* hack due to limitation in OGR */
+    struct line_pnts *Points;
+    struct line_cats *Cats;
-    char **layer_names;		/* names of layers to be imported */
-    int *layers;		/* layer indexes */
-    int nlayers;		/* number of layers to import */
-    char **available_layer_names;	/* names of layers to be imported */
-    int navailable_layers;
-    int layer_id;
-    unsigned int n_features, feature_count;
+    unsigned int n_features, feature_count, n_outside;
     int overwrite;
-    double area_size = 0.;
     G_gisinit(argv[0]);
     module = G_define_module();
     G_add_keyword(_("vector"));
     G_add_keyword(_("import"));
-    module->description = _("Converts vector daya into a GRASS vector map using OGR library.");
+    module->description = _("Converts LAS LiDAR point clouds to a GRASS vector map with libLAS.");
-    dsn_opt = G_define_option();
-    dsn_opt->key = "dsn";
-    dsn_opt->type = TYPE_STRING;
-    dsn_opt->required =YES;
-    dsn_opt->label = _("OGR datasource name");
-    dsn_opt->description = _("Examples:\n"
-			     "\t\tESRI Shapefile: directory containing shapefiles\n"
-			     "\t\tMapInfo File: directory containing mapinfo files");
+    in_opt = G_define_standard_option(G_OPT_F_INPUT);
+    in_opt->label = _("LAS input file");
+    in_opt->description = _("LiDAR input files in LAS format (*.las or *.laz)");
     out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
-    layer_opt = G_define_option();
-    layer_opt->key = "layer";
-    layer_opt->type = TYPE_STRING;
-    layer_opt->required = NO;
-    layer_opt->multiple = YES;
-    layer_opt->label =
-	_("OGR layer name. If not given, all available layers are imported");
-    layer_opt->description =
-	_("Examples:\n" "\t\tESRI Shapefile: shapefile name\n"
-	  "\t\tMapInfo File: mapinfo file name");
-    layer_opt->guisection = _("Selection");
     spat_opt = G_define_option();
     spat_opt->key = "spatial";
     spat_opt->type = TYPE_DOUBLE;
@@ -140,40 +165,6 @@
     spat_opt->description =
 	_("Format: xmin,ymin,xmax,ymax - usually W,S,E,N");
-    where_opt = G_define_standard_option(G_OPT_DB_WHERE);
-    where_opt->guisection = _("Selection");
-    min_area_opt = G_define_option();
-    min_area_opt->key = "min_area";
-    min_area_opt->type = TYPE_DOUBLE;
-    min_area_opt->required = NO;
-    min_area_opt->answer = "0.0001";
-    min_area_opt->label =
-	_("Minimum size of area to be imported (square units)");
-    min_area_opt->guisection = _("Min-area & snap");
-    min_area_opt->description = _("Smaller areas and "
-				  "islands are ignored. Should be greater than snap^2");
-    type_opt = G_define_standard_option(G_OPT_V_TYPE);
-    type_opt->options = "point,line,boundary,centroid";
-    type_opt->answer = "";
-    type_opt->description = _("Optionally change default input type");
-    type_opt->descriptions =
-	_("point;import area centroids as points;"
-	  "line;import area boundaries as lines;"
-	  "boundary;import lines as area boundaries;"
-	  "centroid;import points as centroids");
-    type_opt->guisection = _("Selection");
-    snap_opt = G_define_option();
-    snap_opt->key = "snap";
-    snap_opt->type = TYPE_DOUBLE;
-    snap_opt->required = NO;
-    snap_opt->answer = "-1";
-    snap_opt->label = _("Snapping threshold for boundaries");
-    snap_opt->guisection = _("Min-area & snap");
-    snap_opt->description = _("'-1' for no snap");
     outloc_opt = G_define_option();
     outloc_opt->key = "location";
     outloc_opt->type = TYPE_STRING;
@@ -181,36 +172,12 @@
     outloc_opt->description = _("Name for new location to create");
     outloc_opt->key_desc = "name";
-    cnames_opt = G_define_option();
-    cnames_opt->key = "cnames";
-    cnames_opt->type = TYPE_STRING;
-    cnames_opt->required = NO;
-    cnames_opt->multiple = YES;
-    cnames_opt->description =
-	_("List of column names to be used instead of original names, "
-	  "first is used for category column");
-    cnames_opt->guisection = _("Attributes");
-    list_flag = G_define_flag();
-    list_flag->key = 'l';
-    list_flag->description =
-	_("List available layers in data source and exit");
-    list_flag->suppress_required = YES;
+    print_flag = G_define_flag();
+    print_flag->key = 'p';
+    print_flag->description =
+	_("Print LAS file info and exit");
+    print_flag->suppress_required = YES;
-    formats_flag = G_define_flag();
-    formats_flag->key = 'f';
-    formats_flag->description = _("List supported formats and exit");
-    formats_flag->suppress_required = YES;
-    /* if using -c, you lose topological information ! */
-    no_clean_flag = G_define_flag();
-    no_clean_flag->key = 'c';
-    no_clean_flag->description = _("Do not clean polygons (not recommended)");
-    z_flag = G_define_flag();
-    z_flag->key = 'z';
-    z_flag->description = _("Create 3D output");
     notab_flag = G_define_flag();
     notab_flag->key = 't';
     notab_flag->description = _("Do not create attribute table");
@@ -231,18 +198,16 @@
     extend_flag->description =
 	_("Extend location extents based on new dataset");
-    tolower_flag = G_define_flag();
-    tolower_flag->key = 'w';
-    tolower_flag->description =
-	_("Change column names to lowercase characters");
-    tolower_flag->guisection = _("Attributes");
     no_import_flag = G_define_flag();
     no_import_flag->key = 'i';
     no_import_flag->description =
 	_("Create the location specified by the \"location\" parameter and exit."
           " Do not import the vector file.");
+    notopo_flag = G_define_flag();
+    notopo_flag->key = 'b';
+    notopo_flag->description = _("Do not build topology");
     /* The parser checks if the map already exists in current mapset, this is
      * wrong if location options is used, so we switch out the check and do it
      * in the module after the parser */
@@ -251,77 +216,33 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    G_begin_polygon_area_calculations();	/* Used in geom() */
+    /* Open LAS file*/
+    LAS_reader = LASReader_Create(in_opt->answer);
+    LAS_header = LASReader_GetHeader(LAS_reader);
+    LAS_srs = LASHeader_GetSRS(LAS_header);
-    OGRRegisterAll();
+    scale_x = LASHeader_GetScaleX(LAS_header);
+    scale_y = LASHeader_GetScaleY(LAS_header);
+    scale_z = LASHeader_GetScaleZ(LAS_header);
-    /* list supported formats */
-    if (formats_flag->answer) {
-	int iDriver;
+    offset_x = LASHeader_GetOffsetX(LAS_header);
+    offset_y = LASHeader_GetOffsetY(LAS_header);
+    offset_z = LASHeader_GetOffsetZ(LAS_header);
-	G_important_message(_("Available OGR Drivers:"));
+    xmin = LASHeader_GetMinX(LAS_header) * scale_x + offset_x;
+    xmax = LASHeader_GetMaxX(LAS_header) * scale_x + offset_x;
+    ymin = LASHeader_GetMinY(LAS_header) * scale_y + offset_y;
+    ymax = LASHeader_GetMaxY(LAS_header) * scale_y + offset_y;
-	for (iDriver = 0; iDriver < OGRGetDriverCount(); iDriver++) {
-	    OGRSFDriverH poDriver = OGRGetDriver(iDriver);
-	    const char *pszRWFlag;
-	    if (OGR_Dr_TestCapability(poDriver, ODrCCreateDataSource))
-		pszRWFlag = "rw";
-	    else
-		pszRWFlag = "ro";
+    /* Print LAS header */
+    if (print_flag->answer) {
+	/* print... */
+	print_lasinfo(LAS_header, LAS_srs);
-	    fprintf(stdout, " %s (%s): %s\n",
-		    OGR_Dr_GetName(poDriver),
-		    pszRWFlag, OGR_Dr_GetName(poDriver));
-	exit(EXIT_SUCCESS);
+	LASSRS_Destroy(LAS_srs);
+	LASHeader_Destroy(LAS_header);
+	LASReader_Destroy(LAS_reader);
-    if (dsn_opt->answer == NULL) {
-	G_fatal_error(_("Required parameter <%s> not set"), dsn_opt->key);
-    min_area = atof(min_area_opt->answer);
-    snap = atof(snap_opt->answer);
-    type = Vect_option_to_types(type_opt);
-    ncnames = 0;
-    if (cnames_opt->answers) {
-	i = 0;
-	while (cnames_opt->answers[i++]) {
-	    ncnames++;
-    /* Open OGR DSN */
-    Ogr_ds = NULL;
-    if (strlen(dsn_opt->answer) > 0)
-	Ogr_ds = OGROpen(dsn_opt->answer, FALSE, NULL);
-    if (Ogr_ds == NULL)
-	G_fatal_error(_("Unable to open data source <%s>"), dsn_opt->answer);
-    /* Make a list of available layers */
-    navailable_layers = OGR_DS_GetLayerCount(Ogr_ds);
-    available_layer_names =
-	(char **)G_malloc(navailable_layers * sizeof(char *));
-    if (list_flag->answer)
-	G_important_message(_("Data source contains %d layers:"),
-			    navailable_layers);
-    for (i = 0; i < navailable_layers; i++) {
-	Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
-	Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
-	available_layer_names[i] =
-	    G_store((char *)OGR_FD_GetName(Ogr_featuredefn));
-	if (list_flag->answer) {
-	    fprintf(stdout, "%s\n", available_layer_names[i]);
-	fflush(stdout);
 	exit(EXIT_SUCCESS);
@@ -336,40 +257,7 @@
-    /* Make a list of layers to be imported */
-    if (layer_opt->answer) {	/* From option */
-	nlayers = 0;
-	while (layer_opt->answers[nlayers])
-	    nlayers++;
-	layer_names = (char **)G_malloc(nlayers * sizeof(char *));
-	layers = (int *)G_malloc(nlayers * sizeof(int));
-	for (i = 0; i < nlayers; i++) {
-	    layer_names[i] = G_store(layer_opt->answers[i]);
-	    /* Find it in the source */
-	    layers[i] = -1;
-	    for (j = 0; j < navailable_layers; j++) {
-		if (strcmp(available_layer_names[j], layer_names[i]) == 0) {
-		    layers[i] = j;
-		    break;
-	    if (layers[i] == -1)
-		G_fatal_error(_("Layer <%s> not available"), layer_names[i]);
-    else {			/* use list of all layers */
-	nlayers = navailable_layers;
-	layer_names = available_layer_names;
-	    layers[i] = i;
-    /* Get first imported layer to use for extents and projection check */
-    Ogr_layer = OGR_DS_GetLayer(Ogr_ds, layers[0]);
     if (region_flag->answer) {
 	if (spat_opt->answer)
 	    G_fatal_error(_("Select either the current region flag or the spatial option, not both"));
@@ -385,7 +273,7 @@
 	/* cut out a piece of the map */
 	/* order: xmin,ymin,xmax,ymax */
-	arg_s_num = 0;
+	int arg_s_num = 0;
 	i = 0;
 	while (spat_opt->answers[i]) {
 	    if (i == 0)
@@ -405,78 +293,30 @@
     if (spat_opt->answer || region_flag->answer) {
 	G_debug(2, "cut out with boundaries: xmin:%f ymin:%f xmax:%f ymax:%f",
 		xmin, ymin, xmax, ymax);
-	/* in theory this could be an irregular polygon */
-	poSpatialFilter = OGR_G_CreateGeometry(wkbPolygon);
-	Ogr_oRing = OGR_G_CreateGeometry(wkbLinearRing);
-	OGR_G_AddPoint(Ogr_oRing, xmin, ymin, 0.0);
-	OGR_G_AddPoint(Ogr_oRing, xmin, ymax, 0.0);
-	OGR_G_AddPoint(Ogr_oRing, xmax, ymax, 0.0);
-	OGR_G_AddPoint(Ogr_oRing, xmax, ymin, 0.0);
-	OGR_G_AddGeometryDirectly(poSpatialFilter, Ogr_oRing);
-	OGR_L_SetSpatialFilter(Ogr_layer, poSpatialFilter);
-    if (where_opt->answer) {
-	/* select by attribute */
-	OGR_L_SetAttributeFilter(Ogr_layer, where_opt->answer);
     /* fetch boundaries */
-    if ((OGR_L_GetExtent(Ogr_layer, &oExt, 1)) == OGRERR_NONE) {
-	G_get_window(&cellhd);
-	cellhd.north = oExt.MaxY;
-	cellhd.south = oExt.MinY;
-	cellhd.west = oExt.MinX;
-	cellhd.east = oExt.MaxX;
-	cellhd.rows = 20;	/* TODO - calculate useful values */
-	cellhd.cols = 20;
-	cellhd.ns_res = (cellhd.north - cellhd.south) / cellhd.rows;
-	cellhd.ew_res = (cellhd.east - cellhd.west) / cellhd.cols;
-    else {
-	cellhd.north = 1.;
-	cellhd.south = 0.;
-	cellhd.west = 0.;
-	cellhd.east = 1.;
-	cellhd.top = 1.;
-	cellhd.bottom = 1.;
-	cellhd.rows = 1;
-	cellhd.rows3 = 1;
-	cellhd.cols = 1;
-	cellhd.cols3 = 1;
-	cellhd.depths = 1;
-	cellhd.ns_res = 1.;
-	cellhd.ns_res3 = 1.;
-	cellhd.ew_res = 1.;
-	cellhd.ew_res3 = 1.;
-	cellhd.tb_res = 1.;
+    G_get_window(&cellhd);
+    cellhd.north = ymax;
+    cellhd.south = ymin;
+    cellhd.west = xmin;
+    cellhd.east = xmax;
+    cellhd.rows = 20;	/* TODO - calculate useful values */
+    cellhd.cols = 20;
+    cellhd.ns_res = (cellhd.north - cellhd.south) / cellhd.rows;
+    cellhd.ew_res = (cellhd.east - cellhd.west) / cellhd.cols;
-    /* suppress boundary splitting ? */
-    if (no_clean_flag->answer) {
-	split_distance = -1.;
-    else {
-	split_distance = 0.;
-	area_size =
-	    sqrt((cellhd.east - cellhd.west) * (cellhd.north - cellhd.south));
     /* Fetch input map projection in GRASS form. */
     proj_info = NULL;
     proj_units = NULL;
-    Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer);	/* should not be freed later */
+    projstr = LASSRS_GetWKT_CompoundOK(LAS_srs);
     /* Do we need to create a new location? */
     if (outloc_opt->answer != NULL) {
 	/* Convert projection information non-interactively as we can't
 	 * assume the user has a terminal open */
-	if (GPJ_osr_to_grass(&cellhd, &proj_info,
-			     &proj_units, Ogr_projection, 0) < 0) {
+	if (GPJ_wkt_to_grass(&cellhd, &proj_info,
+			     &proj_units, projstr, 0) < 0) {
 	    G_fatal_error(_("Unable to convert input map projection to GRASS "
 			    "format; cannot create new location."));
@@ -496,14 +336,17 @@
 	int err = 0;
 	/* Projection only required for checking so convert non-interactively */
 	    G_warning(_("Unable to convert input map projection information to "
 		       "GRASS format for checking"));
 	/* Does the projection of the current location match the dataset? */
 	/* G_get_window seems to be unreliable if the location has been changed */
-	G__get_window(&loc_wind, "", "DEFAULT_WIND", "PERMANENT");
+	if (outloc_opt->answer)
+	    G__get_window(&loc_wind, "", "DEFAULT_WIND", "PERMANENT");
+	else
+	    G_get_set_window(&loc_wind);
 	/* fetch LOCATION PROJ info */
 	if (loc_wind.proj != PROJECTION_XY) {
 	    loc_proj_info = G_get_projinfo();
@@ -605,587 +448,286 @@
     db_init_string(&strval);
     /* open output vector */
-    /* open temporary vector, do the work in the temporary vector
-     * at the end copy alive lines to output vector
-     * in case of polygons this reduces the coor file size by a factor of 2 to 5
-     * only needed for polygons, but the presence of polygons can be detected
-     * only during OGR feature import, not before */
     sprintf(buf, "%s", out_opt->answer);
     /* strip any @mapset from vector output name */
     G_find_vector(buf, G_mapset());
-    sprintf(tempvect, "%s_tmp", buf);
-    G_verbose_message(_("Using temporary vector <%s>"), tempvect);
-    Vect_open_new(&Map, out_opt->answer, z_flag->answer != 0);
-    Vect_open_new(&Tmp, tempvect, z_flag->answer != 0);
+    Vect_open_new(&Map, out_opt->answer, 1);
     Vect_hist_command(&Map);
+    n_features = LASHeader_GetPointRecordsCount(LAS_header);
+    las_point_format = LASHeader_GetDataFormatId(LAS_header);
-    /* Points and lines are written immediately with categories. Boundaries of polygons are
-     * written to the vector then cleaned and centroids are calculated for all areas in cleaan vector.
-     * Then second pass through finds all centroids in each polygon feature and adds its category
-     * to the centroid. The result is that one centroids may have 0, 1 ore more categories
-     * of one ore more (more input layers) fields. */
-    with_z = 0;
-    for (layer = 0; layer < nlayers; layer++) {
-	G_message(_("Layer: %s"), layer_names[layer]);
-	layer_id = layers[layer];
+    have_time = (las_point_format == 1 || las_point_format == 3 ||
+		 las_point_format == 4 || las_point_format == 5);
-	Ogr_layer = OGR_DS_GetLayer(Ogr_ds, layer_id);
+    have_color = (las_point_format == 2 || las_point_format == 3 ||
+		   las_point_format == 5);
-	/* Add DB link */
-	if (!notab_flag->answer) {
-	    char *cat_col_name = "cat";
+    /* Add DB link */
+    if (!notab_flag->answer) {
+	char *cat_col_name = "cat";
-	    if (nlayers == 1) {	/* one layer only */
-		Fi = Vect_default_field_info(&Map, layer + 1, NULL,
-					     GV_1TABLE);
-	    else {
-					     GV_MTABLE);
+	Fi = Vect_default_field_info(&Map, 1, NULL, GV_1TABLE);
-	    if (ncnames > 0) {
-		cat_col_name = cnames_opt->answers[0];
-	    Vect_map_add_dblink(&Map, layer + 1, layer_names[layer], Fi->table,
-				cat_col_name, Fi->database, Fi->driver);
+	Vect_map_add_dblink(&Map, 1, out_opt->answer, Fi->table,
+			    cat_col_name, Fi->database, Fi->driver);
-	    ncols = OGR_FD_GetFieldCount(Ogr_featuredefn);
-	    G_debug(2, "%d columns", ncols);
-	    /* Create table */
-	    sprintf(buf, "create table %s (%s integer", Fi->table,
-		    cat_col_name);
-	    db_set_string(&sql, buf);
-	    for (i = 0; i < ncols; i++) {
-		Ogr_field = OGR_FD_GetFieldDefn(Ogr_featuredefn, i);
-		Ogr_ftype = OGR_Fld_GetType(Ogr_field);
-		G_debug(3, "Ogr_ftype: %i", Ogr_ftype);	/* look up below */
-		if (i < ncnames - 1) {
-		    Ogr_fieldname = G_store(cnames_opt->answers[i + 1]);
-		else {
-		    /* Change column names to [A-Za-z][A-Za-z0-9_]* */
-		    Ogr_fieldname = G_store(OGR_Fld_GetNameRef(Ogr_field));
-		    G_debug(3, "Ogr_fieldname: '%s'", Ogr_fieldname);
-		    G_str_to_sql(Ogr_fieldname);
-		/* avoid that we get the 'cat' column twice */
-		if (strcmp(Ogr_fieldname, "cat") == 0) {
-		    sprintf(namebuf, "%s_", Ogr_fieldname);
-		    Ogr_fieldname = G_store(namebuf);
-		/* captial column names are a pain in SQL */
-		if (tolower_flag->answer)
-		    G_str_to_lower(Ogr_fieldname);
-		if (strcmp(OGR_Fld_GetNameRef(Ogr_field), Ogr_fieldname) != 0) {
-		    G_warning(_("Column name changed: '%s' -> '%s'"),
-			      OGR_Fld_GetNameRef(Ogr_field), Ogr_fieldname);
-		/** Simple 32bit integer                     OFTInteger = 0        **/
-		/** List of 32bit integers                   OFTIntegerList = 1    **/
-		/** Double Precision floating point          OFTReal = 2           **/
-		/** List of doubles                          OFTRealList = 3       **/
-		/** String of ASCII chars                    OFTString = 4         **/
-		/** Array of strings                         OFTStringList = 5     **/
-		/** Double byte string (unsupported)         OFTWideString = 6     **/
-		/** List of wide strings (unsupported)       OFTWideStringList = 7 **/
-		/** Raw Binary data (unsupported)            OFTBinary = 8         **/
-		/**                                          OFTDate = 9           **/
-		/**                                          OFTTime = 10          **/
-		/**                                          OFTDateTime = 11      **/
-		if (Ogr_ftype == OFTInteger) {
-		    sprintf(buf, ", %s integer", Ogr_fieldname);
-		else if (Ogr_ftype == OFTIntegerList) {
-		    /* hack: treat as string */
-		    sprintf(buf, ", %s varchar ( %d )", Ogr_fieldname,
-			    OFTIntegerListlength);
-		    G_warning(_("Writing column <%s> with fixed length %d chars (may be truncated)"),
-			      Ogr_fieldname, OFTIntegerListlength);
-		else if (Ogr_ftype == OFTReal) {
-		    sprintf(buf, ", %s double precision", Ogr_fieldname);
-#if GDAL_VERSION_NUM >= 1320
-		else if (Ogr_ftype == OFTDate) {
-		    sprintf(buf, ", %s date", Ogr_fieldname);
-		else if (Ogr_ftype == OFTTime) {
-		    sprintf(buf, ", %s time", Ogr_fieldname);
-		else if (Ogr_ftype == OFTDateTime) {
-		    sprintf(buf, ", %s datetime", Ogr_fieldname);
-#endif
-		else if (Ogr_ftype == OFTString) {
-		    int fwidth;
-		    fwidth = OGR_Fld_GetWidth(Ogr_field);
-		    /* TODO: read all records first and find the longest string length */
-		    if (fwidth == 0) {
-			G_warning(_("Width for column %s set to 255 (was not specified by OGR), "
-				   "some strings may be truncated!"),
-				  Ogr_fieldname);
-			fwidth = 255;
-			    fwidth);
-		else if (Ogr_ftype == OFTStringList) {
-		    G_warning(_("Writing column %s with fixed length %d chars (may be truncated)"),
-		else {
-		    G_warning(_("Column type not supported (%s)"),
-			      Ogr_fieldname);
-		    buf[0] = 0;
-		db_append_string(&sql, buf);
-		G_free(Ogr_fieldname);
-	    db_append_string(&sql, ")");
-	    G_debug(3, db_get_string(&sql));
-	    driver =
-		db_start_driver_open_database(Fi->driver,
-					      Vect_subst_var(Fi->database,
-							     &Map));
-	    if (driver == NULL) {
-		G_fatal_error(_("Unable open database <%s> by driver <%s>"),
-			      Vect_subst_var(Fi->database, &Map), Fi->driver);
-	    if (db_execute_immediate(driver, &sql) != DB_OK) {
-		db_close_database(driver);
-		db_shutdown_driver(driver);
-		G_fatal_error(_("Unable to create table: '%s'"),
-			      db_get_string(&sql));
-	    if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
-		G_warning(_("Unable to create index for table <%s>, key <%s>"),
-			  Fi->table, cat_col_name);
-	    if (db_grant_on_table
-		(driver, Fi->table, DB_PRIV_SELECT,
-		 DB_GROUP | DB_PUBLIC) != DB_OK)
-		G_fatal_error(_("Unable to grant privileges on table <%s>"),
-			      Fi->table);
-	    db_begin_transaction(driver);
+	/* check available LAS info, depends on POINT DATA RECORD FORMAT [0-5] */
+	/* X (double),
+	 * Y (double),
+	 * Z (double),
+	 * intensity (double),
+	 * return number (int),
+	 * number of returns (int),
+	 * scan direction (int),
+	 * flight line edge (int),
+	 * classification type (char),
+	 * class (char),
+	 * time (double) (FORMAT 1, 3, 4, 5),
+	 * scan angle rank (int),
+	 * source ID (int),
+	 * user data (char), ???
+	 * red (int)  (FORMAT 2, 3, 5),
+	 * green (int) (FORMAT 2, 3, 5),
+	 * blue (int) (FORMAT 2, 3, 5)*/
+	/* Create table */
+	sprintf(buf, "create table %s (%s integer", Fi->table,
+		cat_col_name);
+	db_set_string(&sql, buf);
+	/* x, y, z */
+	sprintf(buf, ", x_coord double precision");
+	db_append_string(&sql, buf);
+	sprintf(buf, ", y_coord double precision");
+	sprintf(buf, ", z_coord double precision");
+	/* intensity */
+	sprintf(buf, ", intensity integer");
+	/* return number */
+	sprintf(buf, ", return integer");
+	/* number of returns */
+	sprintf(buf, ", n_returns integer");
+	/* scan direction */
+	sprintf(buf, ", scan_dir integer");
+	/* flight line edge */
+	sprintf(buf, ", edge integer");
+	/* classification type */
+	sprintf(buf, ", cl_type varchar(20)");
+	/* classification class */
+	sprintf(buf, ", class varchar(40)");
+	/* GPS time */
+	if (have_time) {
+	    sprintf(buf, ", gps_time double precision");
+	/* scan angle */
+	sprintf(buf, ", angle integer");
+	/* source id */
+	sprintf(buf, ", src_id integer");
+	/* user data */
+	sprintf(buf, ", usr_data integer");
+	/* colors */
+	if (have_color) {
+	    sprintf(buf, ", red integer, green integer, blue integer");
+	    sprintf(buf, ", GRASSRGB varchar(11)");
-	/* Import feature */
-	cat = 1;
-	nogeom = 0;
-	OGR_L_ResetReading(Ogr_layer);
-	n_features = feature_count = 0;
+	db_append_string(&sql, ")");
+	G_debug(3, db_get_string(&sql));
-	n_polygon_boundaries = 0;
-	n_features = OGR_L_GetFeatureCount(Ogr_layer, 1);
-	/* estimate distance for boundary splitting --> */
-	if (split_distance > -0.5) {
-	    /* count polygons and isles */
-	    G_message(_("Counting polygons for %d features..."), n_features);
-	    while ((Ogr_feature = OGR_L_GetNextFeature(Ogr_layer)) != NULL) {
-		G_percent(feature_count++, n_features, 1);	/* show something happens */
-		/* Geometry */
-		Ogr_geometry = OGR_F_GetGeometryRef(Ogr_feature);
-		if (Ogr_geometry != NULL) {
-		    poly_count(Ogr_geometry);
-		OGR_F_Destroy(Ogr_feature);
-	    /* rewind layer */
-	    feature_count = 0;
+	driver =
+	    db_start_driver_open_database(Fi->driver,
+					  Vect_subst_var(Fi->database,
+							 &Map));
+	if (driver == NULL) {
+	    G_fatal_error(_("Unable open database <%s> by driver <%s>"),
+			  Vect_subst_var(Fi->database, &Map), Fi->driver);
-	G_debug(1, "n polygon boundaries: %d", n_polygon_boundaries);
-	if (split_distance > -0.5 && n_polygon_boundaries > 50) {
-	    split_distance =
-		area_size / log(n_polygon_boundaries);
-	    /* divisor is the handle: increase divisor to decrease split_distance */
-	    split_distance = split_distance / 4.;
-	    G_debug(1, "root of area size: %f", area_size);
-	    G_verbose_message(_("Boundary splitting distance in map units: %G"),
-		      split_distance);
+	if (db_execute_immediate(driver, &sql) != DB_OK) {
+	    db_close_database(driver);
+	    db_shutdown_driver(driver);
+	    G_fatal_error(_("Unable to create table: '%s'"),
+			  db_get_string(&sql));
-	/* <-- estimate distance for boundary splitting */
-	G_important_message(_("Importing map %d features..."), n_features);
-	    /* Geometry */
-	    if (Ogr_geometry == NULL) {
-		nogeom++;
-	    else {
-		dim = OGR_G_GetCoordinateDimension(Ogr_geometry);
-		if (dim > 2)
-		    with_z = 1;
-		geom(Ogr_geometry, &Tmp, layer + 1, cat, min_area, type,
-		     no_clean_flag->answer);
+	if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
+	    G_warning(_("Unable to create index for table <%s>, key <%s>"),
+		      Fi->table, cat_col_name);
-	    /* Attributes */
-		sprintf(buf, "insert into %s values ( %d", Fi->table, cat);
-		    if (OGR_F_IsFieldSet(Ogr_feature, i)) {
-			if (Ogr_ftype == OFTInteger || Ogr_ftype == OFTReal) {
-			    sprintf(buf, ", %s",
-				    OGR_F_GetFieldAsString(Ogr_feature, i));
-			    /* should we use OGR_F_GetFieldAsDateTime() here ? */
-			else if (Ogr_ftype == OFTDate || Ogr_ftype == OFTTime
-				 || Ogr_ftype == OFTDateTime) {
-			    char *newbuf;
+	if (db_grant_on_table
+	    (driver, Fi->table, DB_PRIV_SELECT,
+	     DB_GROUP | DB_PUBLIC) != DB_OK)
+	    G_fatal_error(_("Unable to grant privileges on table <%s>"),
+			  Fi->table);
-			    db_set_string(&strval, (char *)
-								 i));
-			    db_double_quote_string(&strval);
-			    sprintf(buf, ", '%s'", db_get_string(&strval));
-			    newbuf = G_str_replace(buf, "/", "-");	/* fix 2001/10/21 to 2001-10-21 */
-			    sprintf(buf, "%s", newbuf);
-#endif
-			else if (Ogr_ftype == OFTString ||
-				 Ogr_ftype == OFTIntegerList) {
-								 i));
-		    else {
-			/* G_warning (_("Column value not set" )); */
-			    sprintf(buf, ", NULL");
-				 Ogr_ftype == OFTIntegerList ||
-				 Ogr_ftype == OFTDate) {
-#else
-#endif
-			    sprintf(buf, ", ''");
-		db_append_string(&sql, " )");
-		    G_fatal_error(_("Cannot insert new row: %s"),
-	    cat++;
-	G_percent(n_features, n_features, 1);	/* finish it */
-	    db_commit_transaction(driver);
-	    db_close_database_shutdown_driver(driver);
-	if (nogeom > 0)
-	    G_warning(_("%d %s without geometry"), nogeom,
-		      nogeom == 1 ? "feature" : "features");
+	db_begin_transaction(driver);
+    /* Import feature */
+    cat = 1;
+    not_valid = 0;
+    feature_count = 0;
+    n_outside = 0;
-    separator = "-----------------------------------------------------";
-    G_message("%s", separator);
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    G_important_message(_("Importing %d points..."), n_features);
+    while ((LAS_point = LASReader_GetNextPoint(LAS_reader)) != NULL) {
+	double x, y, z;
-    /* TODO: is it necessary to build here? probably not, consumes time */
-    /* GV_BUILD_BASE is sufficient to toggle boundary cleaning */
-    Vect_build_partial(&Tmp, GV_BUILD_BASE);
-    if (!no_clean_flag->answer &&
-	Vect_get_num_primitives(&Tmp, GV_BOUNDARY) > 0) {
-	int ret, centr, ncentr, otype, n_overlaps, n_nocat;
-	CENTR *Centr;
-	struct spatial_index si;
-	double x, y, total_area, overlap_area, nocat_area;
-	struct line_pnts *Points;
-	int nmodif;
-	G_warning(_("Cleaning polygons, result is not guaranteed!"));
-	if (snap >= 0) {
-	    G_message(_("Snap boundaries (threshold = %.3e):"), snap);
-	    Vect_snap_lines(&Tmp, GV_BOUNDARY, snap, NULL);
+	G_percent(feature_count++, n_features, 1);	/* show something happens */
+	if (!LASPoint_IsValid(LAS_point)) {
+	    not_valid++;
+	    continue;
-	/* It is not to clean to snap centroids, but I have seen data with 2 duplicate polygons
-	 * (as far as decimal places were printed) and centroids were not identical */
-	/* Disabled, because overlapping polygons result in many duplicate centroids anyway */
-	   fprintf ( stderr, separator );
-	   fprintf ( stderr, "Snap centroids (threshold 0.000001):\n" );
-	   Vect_snap_lines ( &Map, GV_CENTROID, 0.000001, NULL, stderr );
-	G_message(_("Break polygons:"));
-	Vect_break_polygons(&Tmp, GV_BOUNDARY, NULL);
-	/* It is important to remove also duplicate centroids in case of duplicate input polygons */
-	G_message(_("Remove duplicates:"));
-	Vect_remove_duplicates(&Tmp, GV_BOUNDARY | GV_CENTROID, NULL);
-	/* in non-pathological cases, the bulk of the cleaning is now done */
-	/* Vect_clean_small_angles_at_nodes() can change the geometry so that new intersections
-	 * are created. We must call Vect_break_lines(), Vect_remove_duplicates()
-	 * and Vect_clean_small_angles_at_nodes() until no more small angles are found */
-	do {
-	    G_message(_("Break boundaries:"));
-	    Vect_break_lines(&Tmp, GV_BOUNDARY, NULL);
-	    Vect_remove_duplicates(&Tmp, GV_BOUNDARY, NULL);
-	    G_message(_("Clean boundaries at nodes:"));
-	    nmodif =
-		Vect_clean_small_angles_at_nodes(&Tmp, GV_BOUNDARY, NULL);
-	} while (nmodif > 0);
-	if (type & GV_BOUNDARY) {	/* that means lines were converted boundaries */
-	    G_message(_("Change boundary dangles to lines:"));
-	    Vect_chtype_dangles(&Tmp, -1.0, NULL);
-	else {
-	    G_message(_("Remove dangles:"));
-	    Vect_remove_dangles(&Tmp, GV_BOUNDARY, -1.0, NULL);
-	    G_message(_("Change boundary bridges to lines:"));
-	    Vect_chtype_bridges(&Tmp, NULL);
-	else {
-	    G_message(_("Remove bridges:"));
-	    Vect_remove_bridges(&Tmp, NULL);
-	/* merge boundaries */
-	G_message(_("Merge boundaries:"));
-	Vect_merge_lines(&Tmp, GV_BOUNDARY, NULL, NULL);
-	/* Boundaries are hopefully clean, build areas */
-	Vect_build_partial(&Tmp, GV_BUILD_ATTACH_ISLES);
-	/* Calculate new centroids for all areas, centroids have the same id as area */
-	ncentr = Vect_get_num_areas(&Tmp);
-	G_debug(3, "%d centroids/areas", ncentr);
-	Centr = (CENTR *) G_calloc(ncentr + 1, sizeof(CENTR));
-	Vect_spatial_index_init(&si, 0);
-	for (centr = 1; centr <= ncentr; centr++) {
-	    Centr[centr].valid = 0;
-	    Centr[centr].cats = Vect_new_cats_struct();
-	    ret = Vect_get_point_in_area(&Tmp, centr, &x, &y);
-	    if (ret < 0) {
-		G_warning(_("Cannot calculate area centroid"));
+	Vect_reset_line(Points);
+	Vect_reset_cats(Cats);
+	x = LASPoint_GetX(LAS_point) * scale_x + offset_x;
+	y = LASPoint_GetY(LAS_point) * scale_y + offset_y;
+	z = LASPoint_GetZ(LAS_point) * scale_z + offset_z;
+	if (spat_opt->answer || region_flag->answer) {
+	    if (x < xmin || x > xmax || y < ymin || y > ymax) {
+		n_outside++;
 		continue;
-	    Centr[centr].x = x;
-	    Centr[centr].y = y;
-	    Centr[centr].valid = 1;
-	    box.N = box.S = y;
-	    box.E = box.W = x;
-	    box.T = box.B = 0;
-	    Vect_spatial_index_add_item(&si, centr, &box);
-	/* Go through all layers and find centroids for each polygon */
-	    G_message(_("Find centroids for layer: %s"), layer_names[layer]);
+	Vect_append_point(Points, x, y, z);
+	Vect_cat_set(Cats, 1, cat);
+	Vect_write_line(&Map, GV_POINT, Points, Cats);
-	    cat = 0;		/* field = layer + 1 */
-	    G_percent(cat, n_features, 2);
-		cat++;
-		/* Geometry */
-		    centroid(Ogr_geometry, Centr, &si, layer + 1, cat,
-			     min_area, type);
+	/* Attributes */
+	    char class_flag;
+	    int las_class_type, las_class;
+	     /* use LASPoint_Validate (LASPointH hPoint) to check for
+	      * return number, number of returns, scan direction, flight line edge,
+	      * classification, scan angle rank */
+	    sprintf(buf, "insert into %s values ( %d", Fi->table, cat);
-	/* Write centroids */
-	G_message(_("Write centroids:"));
-	n_overlaps = n_nocat = 0;
-	total_area = overlap_area = nocat_area = 0.0;
-	    double area;
-	    G_percent(centr, ncentr, 2);
-	    area = Vect_get_area_area(&Tmp, centr);
-	    total_area += area;
-	    if (!(Centr[centr].valid)) {
-		continue;
+	    /* x, y, z */
+	    sprintf(buf, ", %f", x);
+	    sprintf(buf, ", %f", y);
+	    sprintf(buf, ", %f", z);
+	    /* intensity */
+	    sprintf(buf, ", %d", LASPoint_GetIntensity(LAS_point));
+	    sprintf(buf, ", %d", LASPoint_GetReturnNumber(LAS_point));
+	    sprintf(buf, ",  %d", LASPoint_GetNumberOfReturns(LAS_point));
+	    sprintf(buf, ", %d",  LASPoint_GetScanDirection(LAS_point));
+	    sprintf(buf, ",  %d", LASPoint_GetFlightLineEdge(LAS_point));
+	    class_flag = LASPoint_GetClassification(LAS_point);
+	    /* classification type int or char ? */
+	    las_class_type = class_flag / 32;
+	    sprintf(buf, ", \"%s\"", class_type[las_class_type].name);
+	    /* classification class int or char ? */
+	    las_class = class_flag % 32;
+	    if (las_class > 13)
+		las_class = 13;
+	    sprintf(buf, ", \"%s\"", class_val[las_class].name);
+	    /* GPS time */
+	    if (have_time) {
+		sprintf(buf, ", %f", LASPoint_GetTime(LAS_point));
+	    /* scan angle */
+	    sprintf(buf, ", %d", LASPoint_GetScanAngleRank(LAS_point));
+	    /* source id */
+	    sprintf(buf, ", %d", LASPoint_GetPointSourceId(LAS_point));
+	    /* user data */
+	    sprintf(buf, ", %d", LASPoint_GetUserData(LAS_point));
+	    /* colors */
+	    if (have_color) {
+		LASColorH LAS_color = LASPoint_GetColor(LAS_point);
+		int red = LASColor_GetRed(LAS_color);
+		int green = LASColor_GetGreen(LAS_color);
+		int blue = LASColor_GetBlue(LAS_color);
-	    if (Centr[centr].cats->n_cats == 0) {
-		nocat_area += area;
-		n_nocat++;
-		continue;
+		sprintf(buf, ", %d, %d, %d", red, green, blue);
+		sprintf(buf, ", \"%03d:%03d:%03d\"", red, green, blue);
+	    db_append_string(&sql, " )");
-	    if (Centr[centr].cats->n_cats > 1) {
-		Vect_cat_set(Centr[centr].cats, nlayers + 1,
-			     Centr[centr].cats->n_cats);
-		overlap_area += area;
-		n_overlaps++;
+		G_fatal_error(_("Cannot insert new row: %s"),
-	    Vect_append_point(Points, Centr[centr].x, Centr[centr].y, 0.0);
-		otype = GV_POINT;
-	    else
-	    Vect_write_line(&Tmp, otype, Points, Centr[centr].cats);
-	if (Centr)
-	    G_free(Centr);
-	Vect_spatial_index_destroy(&si);
-	if (n_overlaps > 0) {
-	    G_warning(_("%d areas represent more (overlapping) features, because polygons overlap "
-		       "in input layer(s). Such areas are linked to more than 1 row in attribute table. "
-		       "The number of features for those areas is stored as category in layer %d"),
-		      n_overlaps, nlayers + 1);
+	cat++;
+	LASPoint_Destroy(LAS_point);
+    G_percent(n_features, n_features, 1);	/* finish it */
-	Vect_hist_write(&Map, separator);
-	Vect_hist_write(&Map, "\n");
-	sprintf(buf, _("%d input polygons\n"), n_polygons);
-	G_message(_("%d input polygons"), n_polygons);
-	Vect_hist_write(&Map, buf);
-	sprintf(buf, _("Total area: %G (%d areas)\n"), total_area, ncentr);
-	G_message(_("Total area: %G (%d areas)"), total_area, ncentr);
-	sprintf(buf, _("Overlapping area: %G (%d areas)\n"), overlap_area,
-		n_overlaps);
-	G_message(_("Overlapping area: %G (%d areas)"), overlap_area,
-		  n_overlaps);
-	sprintf(buf, _("Area without category: %G (%d areas)\n"), nocat_area,
-		n_nocat);
-	G_message(_("Area without category: %G (%d areas)"), nocat_area,
-		  n_nocat);
+	db_commit_transaction(driver);
+	db_close_database_shutdown_driver(driver);
-    /* needed?
-     * OGR_DS_Destroy( Ogr_ds );
-    /* Copy temporary vector to output vector */
-    Vect_copy_map_lines(&Tmp, &Map);
-    /* release memory occupied by topo, we may need that memory for main output */
-    Vect_set_release_support(&Tmp);
-    Vect_close(&Tmp);
-    Vect_delete(tempvect);
-    Vect_build(&Map);
+    /* close map */
+    if (!notopo_flag->answer)
+	Vect_build(&Map);
     Vect_close(&Map);
+    G_message(_("%d points imported"), n_features - not_valid - n_outside);
+    if (not_valid)
+	G_message(_("%d input points were not valid"), not_valid);
+    if (n_outside)
+	G_message(_("%d input points were outside of the selected area"), n_outside);
     /*      Extend current window based on dataset.                         */
     if (extend_flag->answer) {
-	G_get_default_window(&loc_wind);
 	loc_wind.north = MAX(loc_wind.north, cellhd.north);
 	loc_wind.south = MIN(loc_wind.south, cellhd.south);
@@ -1200,12 +742,79 @@
 				  / loc_wind.ew_res);
 	loc_wind.east = loc_wind.west + loc_wind.cols * loc_wind.ew_res;
-	G__put_window(&loc_wind, "../PERMANENT", "DEFAULT_WIND");
+	    G__put_window(&loc_wind, "../PERMANENT", "DEFAULT_WIND");
+	else
+	    G_put_window(&loc_wind);
-    if (with_z && !z_flag->answer)
-	G_warning(_("Input data contains 3D features. Created vector is 2D only, "
-		   "use -z flag to import 3D vector"));
     exit(EXIT_SUCCESS);
+    char *las_srs_proj4 = LASSRS_GetProj4(LAS_srs);
+    int las_point_format = LASHeader_GetDataFormatId(LAS_header);
+    fprintf(stdout, "\nUsing LAS Library Version '%s'\n\n",
+                    LAS_GetFullVersion());
+    fprintf(stdout, "LAS File Version:                  %d.%d\n",
+                    LASHeader_GetVersionMajor(LAS_header),
+                    LASHeader_GetVersionMinor(LAS_header));
+    fprintf(stdout, "System ID:                         '%s'\n",
+                    LASHeader_GetSystemId(LAS_header));
+    fprintf(stdout, "Generating Software:               '%s'\n",
+                    LASHeader_GetSoftwareId(LAS_header));
+    fprintf(stdout, "File Creation Day/Year:            %d/%d\n",
+                    LASHeader_GetCreationDOY(LAS_header),
+		    LASHeader_GetCreationYear(LAS_header));
+    fprintf(stdout, "Point Data Format:                 %d\n",
+                    las_point_format);
+    fprintf(stdout, "Number of Point Records:           %d\n",
+                    LASHeader_GetPointRecordsCount(LAS_header));
+    fprintf(stdout, "Number of Points by Return:        %d %d %d %d %d\n",
+                    LASHeader_GetPointRecordsByReturnCount(LAS_header, 0),
+                    LASHeader_GetPointRecordsByReturnCount(LAS_header, 1),
+                    LASHeader_GetPointRecordsByReturnCount(LAS_header, 2),
+                    LASHeader_GetPointRecordsByReturnCount(LAS_header, 3),
+                    LASHeader_GetPointRecordsByReturnCount(LAS_header, 4));
+    fprintf(stdout, "Scale Factor X Y Z:                %g %g %g\n",
+                    LASHeader_GetScaleX(LAS_header),
+                    LASHeader_GetScaleY(LAS_header),
+                    LASHeader_GetScaleZ(LAS_header));
+    fprintf(stdout, "Offset X Y Z:                      %g %g %g\n",
+                    LASHeader_GetOffsetX(LAS_header),
+                    LASHeader_GetOffsetY(LAS_header),
+                    LASHeader_GetOffsetZ(LAS_header));
+    fprintf(stdout, "Min X Y Z:                         %g %g %g\n",
+                    LASHeader_GetMinX(LAS_header),
+                    LASHeader_GetMinY(LAS_header),
+                    LASHeader_GetMinZ(LAS_header));
+    fprintf(stdout, "Max X Y Z:                         %g %g %g\n",
+                    LASHeader_GetMaxX(LAS_header),
+                    LASHeader_GetMaxY(LAS_header),
+                    LASHeader_GetMaxZ(LAS_header));
+    if (las_srs_proj4 && strlen(las_srs_proj4) > 0) {
+	fprintf(stdout, "Spatial Reference:\n");
+	fprintf(stdout, "%s\n", las_srs_proj4);
+    else {
+	fprintf(stdout, "Spatial Reference:                 None\n");
+    fprintf(stdout, "\nData Fields:\n");
+    fprintf(stdout, "  'X'\n  'Y'\n  'Z'\n  'Intensity'\n  'Return Number'\n");
+    fprintf(stdout, "  'Number of Returns'\n  'Scan Direction'\n");
+    fprintf(stdout, "  'Flighline Edge'\n  'Classification'\n  'Scan Angle Rank'\n");
+    fprintf(stdout, "  'User Data'\n  'Point Source ID'\n");
+    if (las_point_format == 1 || las_point_format == 3 || las_point_format == 4 || las_point_format == 5) {
+	fprintf(stdout, "  'GPS Time'\n");
+    if (las_point_format == 2 || las_point_format == 3 || las_point_format == 5) {
+	fprintf(stdout, "  'Red'\n  'Green'\n  'Blue'\n");
+    fprintf(stdout, "\n");
+    fflush(stdout);
+    return;
