[GRASS-SVN] r46432 - grass/trunk/lib/segment
Sat May 28 11:45:33 EDT 2011
Author: mmetz
Date: 2011-05-28 08:45:33 -0700 (Sat, 28 May 2011)
New Revision: 46432
   grass/trunk/lib/segment/format.c
segment lib: add LFS check
Modified: grass/trunk/lib/segment/format.c
--- grass/trunk/lib/segment/format.c	2011-05-28 15:36:51 UTC (rev 46431)
+++ grass/trunk/lib/segment/format.c	2011-05-28 15:45:33 UTC (rev 46432)
@@ -18,6 +18,7 @@
 #include <unistd.h>
 #include <limits.h>
 #include <grass/gis.h>
+#include <grass/glocale.h>
 #include <grass/segment.h>
@@ -119,6 +120,33 @@
 	return -3;
+    if (sizeof(off_t) == 4 && sizeof(double) >= 8) {
+	double d_size;
+	off_t o_size;
+	spr = ncols / scols;
+	if (ncols % scols)
+	    spr++;
+	/* calculate total number of segments */
+	d_size = (double) spr * ((nrows + srows - 1) / srows);
+	/* multiply with segment size */
+	d_size *= srows * scols * len;
+	/* add header */
+	d_size += 5 * sizeof(int);
+	o_size = (off_t) d_size;
+	/* this test assumes that all off_t values can be exactly
+	 * represented as double if sizeof(off_t) = 4 and sizeof(double) >= 8 */
+	if ((double) o_size != d_size) {
+	    G_warning(_("Segment format: file size too large"));
+	    G_warning(_("Please recompile with Large File Support (LFS)"));
+	    return -1;
     if (lseek(fd, 0L, SEEK_SET) == (off_t) -1) {
 	G_warning("Segment_format: %s", strerror(errno));
 	return -1;
