[GRASS-SVN] r49040 - grass/trunk/gui/wxpython/gui_modules
Tue Nov 1 11:21:15 EDT 2011
Author: martinl
Date: 2011-11-01 08:21:15 -0700 (Tue, 01 Nov 2011)
New Revision: 49040
   grass/trunk/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: better check for substituting variables
	       (merge r49039 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2011-11-01 15:19:41 UTC (rev 49039)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2011-11-01 15:21:15 UTC (rev 49040)
@@ -394,12 +394,14 @@
         error string"""
         errList = list()
+        variables = self.GetVariables().keys()
         pattern = re.compile(r'(.*)(%.+\s?)(.*)')
         for action in self.GetItems(objType = ModelAction):
-            cmd = action.GetLog(string = False, substitute = self.GetVariables())
+            cmd = action.GetLog(string = False)
             task = menuform.GUI(show = None).ParseCommand(cmd = cmd)
             errList += map(lambda x: cmd[0] + ': ' + x, task.get_cmd_error())
             # check also variables
             for opt in cmd[1:]:
                 if '=' not in opt:
@@ -408,35 +410,33 @@
                 sval = pattern.search(value)
                 if sval:
                     var = sval.group(2).strip()[1:] # ignore '%'
-                    report = True
-                    for item in filter(lambda x: isinstance(x, ModelLoop), action.GetBlock()):
-                        if var in item.GetText():
-                            report = False
-                            break
-                    if report:
-                        errList.append(_("%s: undefined variable '%s'") % (cmd[0], var))
+                    if var not in variables:
+                        report = True
+                        for item in filter(lambda x: isinstance(x, ModelLoop), action.GetBlock()):
+                            if var in item.GetText():
+                                report = False
+                                break
+                        if report:
+                            errList.append(_("%s: undefined variable '%s'") % (cmd[0], var))
+            errList += self._substituteFile(action, checkOnly = True)
         return errList
-    def RunAction(self, item, params, log, onDone, statusbar = None):
-        """!Run given action
+    def _substituteFile(self, item, params = None, checkOnly = False):
+        """!Subsitute variables in command file inputs
-        @param item action item
-        @param params parameters dict
-        @param log logging window
-        @param onDone on-done method
-        @param statusbar wx.StatusBar instance or None
+        @param checkOnly tuble - True to check variable, don't touch files
+        @return list of undefined variables
-        name = item.GetName()
-        if name in params:
-            paramsOrig = item.GetParams(dcopy = True)
-            item.MergeParams(params[name])
+        errList = list()
-        if statusbar:
-            statusbar.SetStatusText(_('Running model...'), 0)
+        if not hasattr(self, "fileInput"):
+            self.fileInput = dict()
         # collect ascii inputs
-        self.fileInput = dict()
+        cmdFileInput = list()
         for p in item.GetParams()['params']:
             if p.get('element', '') == 'file' and \
                     p.get('prompt', '') == 'input' and \
@@ -444,9 +444,9 @@
                 filename = p.get('value', p.get('default', ''))
                 if filename and \
                         mimetypes.guess_type(filename)[0] == 'text/plain':
-                    self.fileInput[filename] = None
+                    cmdFileInput.append(filename)
-        for finput in self.fileInput:
+        for finput in cmdFileInput:
             # read lines
             fd = open(finput, "r")
             try:
@@ -458,29 +458,62 @@
             write = False
             for variable in variables:
-                pattern= re.compile('%' + variable)
+                pattern = re.compile('%' + variable)
                 value = ''
                 if params and 'variables' in params:
                     for p in params['variables']['params']:
                         if variable == p.get('name', ''):
-                            value = p.get('value', '')
+                            if p.get('type', 'string') == 'string':
+                                value = p.get('value', '')
+                            else:
+                                value = str(p.get('value', ''))
                             break
                 if not value:
                     value = variables[variable].get('value', '')
                 data = pattern.sub(value, data)
-                write = True
+                if not checkOnly:
+                    write = True
-            if write:
-                fd = open(finput, "w")
-                try:
-                    fd.write(data)
-                finally:
-                    fd.close()
-            else:
-                self.fileInput[finput] = None
+            pattern = re.compile(r'(.*)(%.+\s?)(.*)')
+            sval = pattern.search(data)
+            if sval:
+                var = sval.group(2).strip()[1:] # ignore '%'
+                cmd = item.GetLog(string = False)[0]
+                errList.append(_("%s: undefined variable '%s'") % (cmd, var))
+            if not checkOnly:
+                if write:
+                    fd = open(finput, "w")
+                    try:
+                        fd.write(data)
+                    finally:
+                        fd.close()
+                else:
+                    self.fileInput[finput] = None
+        return errList
+    def RunAction(self, item, params, log, onDone, statusbar = None):
+        """!Run given action
+        @param item action item
+        @param params parameters dict
+        @param log logging window
+        @param onDone on-done method
+        @param statusbar wx.StatusBar instance or None
+        name = item.GetName()
+        if name in params:
+            paramsOrig = item.GetParams(dcopy = True)
+            item.MergeParams(params[name])
+        if statusbar:
+            statusbar.SetStatusText(_('Running model...'), 0)
+        self._substituteFile(item, params)
         log.RunCmd(command = item.GetLog(string = False, substitute = params),
                    onDone = onDone)
