[GRASS-SVN] r49116 - grass/trunk/display/d.vect
Sat Nov 5 18:12:38 EDT 2011
Author: martinl
Date: 2011-11-05 15:12:38 -0700 (Sat, 05 Nov 2011)
New Revision: 49116
   grass/trunk/display/d.vect/lines.c
d.vect: centroids are read by Vect_read_next_line()
Modified: grass/trunk/display/d.vect/lines.c
--- grass/trunk/display/d.vect/lines.c	2011-11-05 22:11:44 UTC (rev 49115)
+++ grass/trunk/display/d.vect/lines.c	2011-11-05 22:12:38 UTC (rev 49116)
@@ -165,50 +165,6 @@
 		  &n_faces);
-    if (Vect_maptype(Map) == GV_FORMAT_OGR) {
-	/* centroids are stored in topology for OGR layers */
-	if (Vect_level(Map) >= 2) {
-	    if (type & GV_CENTROID &&
-		Vect_get_num_primitives(Map, GV_CENTROID) > 0) {
-		int nlines;
-		struct bound_box box;
-		struct boxlist *list;
-		list = Vect_new_boxlist(FALSE); /* bboxes not needed */
-		Vect_get_constraint_box(Map, &box);
-		nlines = Vect_select_lines_by_box(Map, &box, GV_CENTROID, list);
-		G_debug(3, "ncentroids (ogr) = %d", nlines);
-		for (line = 0; line < nlines; line++) {
-		    ltype = Vect_read_line(Map, Points, Cats, list->id[line]);
-		    draw_line(type, ltype, line,
-			      Points, Cats,
-			      color, fcolor, chcat,
-			      symbol_name, size, sqrt_flag,
-			      id_flag, cats_color_flag,
-			      default_width, width_scale,
-			      zcolors,
-			      cvarr_rgb, colors,
-			      cvarr_width, nrec_width,
-			      cvarr_size, nrec_size,
-			      cvarr_rot, nrec_rot,
-			      Clist, Symb,
-			      line_color, fill_color,
-			      primary_color,
-			      &n_points, &n_lines, &n_centroids, &n_boundaries,
-			      &n_faces);
-		Vect_destroy_boxlist(list);
-	else {
-	    G_warning(_("Topology level required for drawing centroids "
-			"for OGR layers"));
     if (n_points > 0)
 	G_verbose_message(_("%d points plotted"), n_points);
     if (n_lines > 0)
