[GRASS-SVN] r49146 - grass/trunk/imagery/i.pca
Tue Nov 8 07:45:17 EST 2011
Author: mmetz
Date: 2011-11-08 04:45:17 -0800 (Tue, 08 Nov 2011)
New Revision: 49146
   grass/trunk/imagery/i.pca/main.c
sync to r.covar, speed up
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c	2011-11-08 11:29:50 UTC (rev 49145)
+++ grass/trunk/imagery/i.pca/main.c	2011-11-08 12:45:17 UTC (rev 49146)
@@ -6,7 +6,7 @@
  * AUTHOR(S):    Original author Center for Space Research (Uni. of TX)
  *               Rewritten by Brad Douglas <rez touchofmadness com>
- * PURPOSE:      Principal Component Analysis transform of satellite data.
+ * PURPOSE:      Principal Component Analysis transform of raster data.
  * COPYRIGHT:    (C) 2004-2008 by the GRASS Development Team
@@ -34,8 +34,7 @@
 /* function prototypes */
 static CELL round_c(double);
 static int set_output_scale(struct Option *, int *, int *, int *);
-static int calc_mu(int *, double *, double *, int);
-static int calc_covariance(int *, double **, double *, double *, int);
+static int calc_mu_cov(int *, double **, double *, double *, int);
 static int write_pca(double **, double *, double *, int *, char *, int,
                      int, int, int);
@@ -139,12 +138,9 @@
 	inp_fd[i] = Rast_open_old(opt_in->answers[i], "");
-    G_verbose_message(_("Calculating covariance matrix..."));
-    if (!calc_mu(inp_fd, mu, stddev, bands))
+    if (!calc_mu_cov(inp_fd, covar, mu, stddev, bands))
 	G_fatal_error(_("No non-null values"));
-    calc_covariance(inp_fd, covar, mu, stddev, bands);
     G_math_d_copy(covar[0], eigmat[0], bands*bands);
     G_debug(1, "Calculating eigenvalues and eigenvectors...");
     G_math_eigen(eigmat, eigval, bands);
@@ -234,85 +230,32 @@
-static int calc_mu(int *fds, double *mu, double *stddev, int bands)
+static int calc_mu_cov(int *fds, double **covar, double *mu,
+                           double *stddev, int bands)
-    int i;
+    int i, j;
     int row, col;
     int rows = Rast_window_rows();
     int cols = Rast_window_cols();
     off_t count = 0;
-    double *sumsq;
     DCELL **rowbuf = (DCELL **) G_malloc(bands * sizeof(DCELL *));
+    double **sum2 = (double **)G_calloc(bands, sizeof(double *));
+    double *sumsq, *sd, *sum;
-    for (i = 0; i < bands; i++) {
-	rowbuf[i] = Rast_allocate_d_buf();
     if (stddev) {
-	G_message(_("Computing means and standard deviations..."));
 	sumsq = (double *)G_calloc(bands, sizeof(double));
+	sd = (double *)G_calloc(bands, sizeof(double));
     else {
-	G_message(_("Computing means..."));
 	sumsq = NULL;
+	sd = NULL;
-    for (row = 0; row < rows; row++) {
-	G_percent(row, rows, 2);
-	    Rast_get_d_row(fds[i], rowbuf[i], row);
-	for (col = 0; col < cols; col++) {
-	    /* ignore cells where any of the maps has null value */
-		if (Rast_is_d_null_value(&rowbuf[i][col]))
-		    break;
-	    if (i != bands)
-		continue;
-	    count++;
-		mu[i] += rowbuf[i][col];
-		if (stddev)
-		    sumsq[i] += rowbuf[i][col] * rowbuf[i][col];
-    G_percent(1, 1, 1);
-    if (count < 2)
-	return 0;
-	mu[i] = mu[i] / count;
-	if (stddev)
-	    stddev[i] = sqrt((count / (count - 1)) *
-	                     (sumsq[i] / count - mu[i] * mu[i]));
-	G_free(rowbuf[i]);
-    if (rowbuf)
-	G_free(rowbuf);
-    if (sumsq)
-	G_free(sumsq);
-    return 1;
-static int calc_covariance(int *fds, double **covar, double *mu,
-                           double *stddev, int bands)
-    int i, j;
-    int row, col;
-    int rows = Rast_window_rows();
-    int cols = Rast_window_cols();
-    off_t count = 0;
-    DCELL **rowbuf = (DCELL **) G_malloc(bands * sizeof(DCELL *));
+	sum2[i] = (double *)G_calloc(bands, sizeof(double));
+    sum = mu;
     G_message(_("Computing covariance matrix..."));
@@ -330,38 +273,54 @@
 		continue;
 	    count++;
-		DCELL dval1 = rowbuf[i][col];
-		for (j = i; j < bands; j++) {
-		    DCELL dval2 = rowbuf[j][col];
+		sum[i] += rowbuf[i][col];
+		if (stddev)
+		    sumsq[i] += rowbuf[i][col] * rowbuf[i][col];
-		    if (stddev) {
-			covar[i][j] += (dval1 - mu[i]) * (dval2 - mu[j]) /
-			               (stddev[i] * stddev[j]);
-		    else {
-			covar[i][j] += (dval1 - mu[i]) * (dval2 - mu[j]);
+		for (j = 0; j <= i; j++)
+		    sum2[i][j] += rowbuf[i][col] * rowbuf[j][col];
     G_percent(1, 1, 1);
+    if (count < 2)
+	return 0;
-	    covar[i][j] = covar[i][j] / (count - 1);
+	if (stddev) {
+	    sd[i] = sqrt(count * sumsq[i] - sum[i] * sum[i]);
+	    stddev[i] = sqrt((sumsq[i] - sum[i] * sum[i] / count) /
+	                     (count - 1));
+	for (j = 0; j <= i; j++) {
+	    if (stddev)
+		covar[i][j] = (count * sum2[i][j] - sum[i] * sum[j]) /
+		              (sd[i] * sd[j]);
+	    else
+		covar[i][j] = (sum2[i][j] - sum[i] * sum[j] / count) /
+		              (count - 1);
 	    G_debug(3, "covar[%d][%d] = %f", i, j, covar[i][j]);
 	    if (j != i)
 		covar[j][i] = covar[i][j];
+	G_free(sum2[i]);
 	G_free(rowbuf[i]);
+    for (i = 0; i < bands; i++)
+	mu[i] = sum[i] / count;
     G_free(rowbuf);
+    G_free(sum2);
+    if (sd)
+	G_free(sd);
+    if (sumsq)
+	G_free(sumsq);
-    return 0;
+    return 1;
@@ -371,164 +330,150 @@
 	  int scale, int scale_min, int scale_max)
     int i, j;
-    void *outbuf, *outptr;
-    double min = 0.;
-    double max = 0.;
-    double old_range = 0.;
+    void **outbuf = (void **) G_malloc(bands * sizeof(void *));
+    void **outptr = (void **) G_malloc(bands * sizeof(void *));
+    double *min = (double *) G_malloc(bands * sizeof(double));
+    double *max = (double *) G_malloc(bands * sizeof(double));
+    double *old_range = (double *) G_calloc(bands, sizeof(double));
     double new_range = 0.;
+    int pass;
     /* why CELL_TYPE when scaling output ? */
     int outmap_type = (scale) ? CELL_TYPE : FCELL_TYPE;
     int outcell_mapsiz = Rast_cell_size(outmap_type);
-    DCELL *d_buf;
+    int *out_fd = (int *) G_malloc(bands * sizeof(int));
+    DCELL **inbuf = (DCELL **) G_malloc(bands * sizeof(DCELL *));
+    DCELL *d_buf = (DCELL *) G_malloc(bands * sizeof(DCELL));
     /* 2 passes for rescale.  1 pass for no rescale */
     int PASSES = (scale) ? 2 : 1;
-    /* temporary row storage */
-    d_buf = Rast_allocate_d_buf();
-    /* allocate memory for output row buffer */
-    outbuf = Rast_allocate_buf(outmap_type);
-    if (!outbuf)
-	G_fatal_error(_("Unable to allocate memory for raster row"));
+    /* allocate memory for row buffers */
-	char name[100];
-	int out_fd;
-	int pass;
+	char name[GNAME_MAX];
+	/* open output raster maps */
 	sprintf(name, "%s.%d", out_basename, i + 1);
+	out_fd[i] = Rast_open_new(name, outmap_type);
-	G_message(_("Transforming <%s>..."), name);
+	inbuf[i] = Rast_allocate_d_buf();
+	outbuf[i] = Rast_allocate_buf(outmap_type);
+	min[i] = max[i] = old_range[i] = 0;
-	/* open a new file for output */
-	out_fd = Rast_open_new(name, outmap_type);
+    for (pass = 1; pass <= PASSES; pass++) {
+	int row, col;
+	int first = 1;
-	for (pass = 1; pass <= PASSES; pass++) {
-	    void *rowbuf = NULL;
-	    int row, col;
+	if (scale && (pass == PASSES)) {
+	    G_message(_("Rescaling to range %d,%d..."),
+		      scale_min, scale_max);
-	    if (scale && (pass == PASSES)) {
-		G_message(_("Rescaling <%s> to range %d,%d..."),
-			  name, scale_min, scale_max);
+		old_range[i] = max[i] - min[i];
+	    new_range = (double)(scale_max - scale_min);
+	else {
+	    G_message(_("Calculating principal components..."));
-		old_range = max - min;
-		new_range = (double)(scale_max - scale_min);
+	for (row = 0; row < rows; row++) {
-		void *rowptr;
+	    G_percent(row, rows, 2);
+	    for (i = 0; i < bands; i++) {
+		Rast_get_d_row(inp_fd[i], inbuf[i], row);
+		outptr[i] = outbuf[i];
+	    for (col = 0; col < cols; col++) {
+		/* ignore cells where any of the maps has null value */
+		    if (Rast_is_d_null_value(&inbuf[i][col]))
+			break;
+		if (i != bands) {
+			Rast_set_null_value(outptr[i], 1, outmap_type);
+			outptr[i] =
+			    G_incr_void_ptr(outptr[i], outcell_mapsiz);
+		    continue;
-		/* reset d_buf */
-		    d_buf[col] = 0.;
+		    d_buf[i] = 0.;
-		for (j = 0; j < bands; j++) {
-		    RASTER_MAP_TYPE maptype =
-			Rast_get_map_type(inp_fd[j]);
-		    /* don't assume each image is of the same type */
-		    if (rowbuf)
-			G_free(rowbuf);
-		    if (!(rowbuf = Rast_allocate_buf(maptype)))
-			G_fatal_error(_("Unable allocate memory for row buffer"));
-		    Rast_get_row(inp_fd[j], rowbuf, row, maptype);
-		    rowptr = rowbuf;
-		    outptr = outbuf;
-		    /* add into the output cell eigmat[i][j] * corresp cell
-		     * of j-th band for current j */
-			DCELL dval;
-			/* handle null cells */
-			if (Rast_is_null_value(rowptr, maptype)) {
-			    Rast_set_null_value(outptr, 1, outmap_type);
-			    outptr =
-				G_incr_void_ptr(outptr, outcell_mapsiz);
-			    rowptr =
-				G_incr_void_ptr(rowptr,
-						Rast_cell_size(maptype));
-			    continue;
+		    for (j = 0; j < bands; j++) {
 			/* corresp. cell of j-th band */
-			dval = Rast_get_d_value(rowptr, maptype);
+			DCELL dval = inbuf[j][col];
 			if (stddev)
-			    d_buf[col] += eigmat[i][j] * ((dval - mu[j]) / stddev[j]);
+			    d_buf[i] += eigmat[i][j] * ((dval - mu[j]) / stddev[j]);
 			else
-			    d_buf[col] += eigmat[i][j] * (dval - mu[j]);
+			    d_buf[i] += eigmat[i][j] * (dval - mu[j]);
-			/* the cell entry is complete */
-			if (j == (bands - 1)) {
-			    if (scale && (pass == 1)) {
-				if ((row == 0) && (col == 0))
-				    min = max = d_buf[0];
-				if (d_buf[col] < min)
-				    min = d_buf[col];
+		    /* the cell entry is complete */
+		    if (scale && (pass == 1)) {
+			if (first)
+			    min[i] = max[i] = d_buf[i];
+			if (d_buf[i] < min[i])
+			    min[i] = d_buf[i];
-				if (d_buf[col] > max)
-				    max = d_buf[col];
-			    else if (scale) {
+			if (d_buf[i] > max[i])
+			    max[i] = d_buf[i];
+		    else if (scale) {
-				if (min == max) {
-				    Rast_set_c_value(outptr, 1,
-							 CELL_TYPE);
-				else {
-				    /* map data to 0, (new_range-1) and then adding new_min */
-				    CELL tmpcell =
-					round_c((new_range *
-						 (d_buf[col] -
-						  min) / old_range) +
-						scale_min);
-				    Rast_set_c_value(outptr, tmpcell,
-							 outmap_type);
-			    else {	/* (!scale) */
-				Rast_set_d_value(outptr, d_buf[col],
-						     outmap_type);
+			if (min[i] == max[i]) {
+			    Rast_set_c_value(outptr[i], 1,
+						 CELL_TYPE);
+			else {
+			    /* map data to 0, (new_range-1) and then adding new_min */
+			    CELL tmpcell =
+				round_c((new_range * (d_buf[i] - min[i]) /
+				         old_range[i]) + scale_min);
-			outptr =
-			rowptr =
-			    G_incr_void_ptr(rowptr, Rast_cell_size(maptype));
+			    Rast_set_c_value(outptr[i], tmpcell,
+						 outmap_type);
-		}		/* for j = 0 to bands */
+		    else {	/* (!scale) */
-		if (pass == PASSES) {
-		    Rast_put_row(out_fd, outbuf, outmap_type);
+			Rast_set_d_value(outptr[i], d_buf[i],
+					     outmap_type);
+		    outptr[i] = G_incr_void_ptr(outptr[i], outcell_mapsiz);
+		first = 0;
+	    if (pass == PASSES) {
+		    Rast_put_row(out_fd[i], outbuf[i], outmap_type);
+	G_percent(1, 1, 1);
-	    /* close output file */
-		Rast_close(out_fd);
+	/* close output file */
+		Rast_close(out_fd[i]);
+		G_free(inbuf[i]);
+		G_free(outbuf[i]);
-    if (d_buf)
-	G_free(d_buf);
-    if (outbuf)
-	G_free(outbuf);
+    G_free(inbuf);
+    G_free(d_buf);
+    G_free(outbuf);
+    G_free(outptr);
+    G_free(min);
+    G_free(max);
+    G_free(old_range);
     return 0;
