[GRASS-SVN] r49156 - grass/branches/releasebranch_6_4/gui/wxpython
Wed Nov 9 11:04:59 EST 2011
Author: martinl
Date: 2011-11-09 08:04:59 -0800 (Wed, 09 Nov 2011)
New Revision: 49156
Removed:
   grass/branches/releasebranch_6_4/gui/wxpython/build_ext.py
wxGUI: remove unused file
Deleted: grass/branches/releasebranch_6_4/gui/wxpython/build_ext.py
--- grass/branches/releasebranch_6_4/gui/wxpython/build_ext.py	2011-11-09 15:47:39 UTC (rev 49155)
+++ grass/branches/releasebranch_6_4/gui/wxpython/build_ext.py	2011-11-09 16:04:59 UTC (rev 49156)
@@ -1,62 +0,0 @@
-# Build wxGUI extensions (vdigit and nviz)
-import os
-import sys
-def __read_variables(file, dict={}):
-    """!Read variables from file (e.g. Platform.make)
-    @param file file descriptor
-    @param dict dictionary to store (variable, value)
-    for line in file.readlines():
-        if len(line) < 1:
-            continue # skip empty lines
-        if line[0] == '#':
-            continue # skip comments
-        try:
-            var, val = line.split('=', 1)
-        except ValueError:
-            continue
-        dict[var.strip()] = val.strip()
-def update_opts(flag, macros, inc_dirs, lib_dirs, libs, extras):
-    """!Update Extension options"""
-    global variables
-    line = variables[flag]
-    fw_next = False
-    for val in line.split(' '):
-        key = val[:2]
-        if fw_next:
-            extras.append(val)
-            fw_next = False
-        elif key == '-I': # includes
-            inc_dirs.append(val[2:])
-        elif key == '-D': # macros
-            if '=' in val[2:]:
-                macros.append(tuple(val[2:].split('=')))
-            else:
-                macros.append((val[2:], None))
-        elif key == '-L': # libs dir
-            lib_dirs.append(val[2:])
-        elif key == '-l':
-            libs.append(val[2:])
-        elif key == '-F': # frameworks dir
-        elif val == '-framework':
-            fw_next = True
-try:
-    Platform_make = open(os.path.join('..', '..', '..',
-                                      'include', 'Make', 'Platform.make'))
-    Grass_make = open(os.path.join('..', '..', '..',
-                                   'include', 'Make', 'Grass.make'))
-except IOError, e:
-    print 'Unable to compile wxGUI vdigit extension.\n\n', e
-    sys.exit(1)
-variables = {}
-__read_variables(Platform_make, variables)
-__read_variables(Grass_make, variables)
