[GRASS-SVN] r49174 - sandbox/lucadelu
Thu Nov 10 11:02:43 EST 2011
Author: lucadelu
Date: 2011-11-10 08:02:43 -0800 (Thu, 10 Nov 2011)
New Revision: 49174
   sandbox/lucadelu/r.li.setup.py
improvement
Modified: sandbox/lucadelu/r.li.setup.py
--- sandbox/lucadelu/r.li.setup.py	2011-11-10 15:40:30 UTC (rev 49173)
+++ sandbox/lucadelu/r.li.setup.py	2011-11-10 16:02:43 UTC (rev 49174)
@@ -21,10 +21,6 @@
 import sys
 import os
-#global rlisettings
-#rlisettings = {'region' : 'whole', 'rast' : '', 'vect' : '',
-	      #'conf_name' : '', 'vectorarea' : True, }
 sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython',
                                  'gui_modules'))
@@ -42,8 +38,6 @@
 from grass.script import core as grass
 from grass.script import raster as grast
-#@TODO create wizard instead of progressively increasing window
 #@NOTE: r.li.setup writes in the settings file with
 ## r.li.windows.tcl:
 #exec echo "SAMPLINGFRAME $per_x|$per_y|$per_rl|$per_cl" >> $env(TMP).set
@@ -166,14 +160,11 @@
 	self.summarypage = SummaryPage(self.wizard, self)
 	#order of pages
-	self.startpage.SetNext(self.keyboardpage)
+	self.startpage.SetNext(self.samplingareapage)
 	self.keyboardpage.SetPrev(self.startpage)
 	self.keyboardpage.SetNext(self.samplingareapage)
 	self.samplingareapage.SetPrev(self.startpage)
 	self.samplingareapage.SetNext(self.summarypage)
 	self.summarypage.SetPrev(self.samplingareapage)
 	#layout
 	self.startpage.DoLayout()
@@ -182,7 +173,6 @@
 	self.summarypage.DoLayout()
 	self.wizard.FitToPage(self.startpage)
 	#run_wizard
 	self.wizard.RunWizard(self.startpage)
@@ -196,11 +186,10 @@
         TitledPage.__init__(self, wizard, _("Select maps and define name"))
         self.parent = parent
-        self.region = ''
+        self.region = 'whole'
         self.rast = ''
         self.conf_name = ''
         self.vect = ''
-        self.vectorarea = True
         self.sizer.AddGrowableCol(2)
 	#name of output configuration file
@@ -248,30 +237,21 @@
         self.vectselect.Bind(wx.EVT_TEXT, self.OnVector)
         self.mapselect.Bind(wx.EVT_TEXT, self.OnRast)
-        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnEnterPage)
-        #self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
+        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
 	wx.FindWindowById(wx.ID_FORWARD).Enable(False)
     def OnSempling(self,event):
         """!Change map type"""
         if event.GetInt() == 0:
-            #rlisetting['region'] = 'whole'
             self.SetNext(self.parent.samplingareapage)
         elif event.GetInt() == 1:
-	    #rlisetting['region'] = 'key'
-	    #rlisetting['vectorarea'] = False
-            self.vectorarea = False
             self.region = 'key'
             self.SetNext(self.parent.keyboardpage)
         elif event.GetInt() == 2:
-	    #rlisetting['region'] = 'draw'
 	    self.region = 'draw'
-	#if rlisetting['conf_name'] != '' and rlisetting['rast'] != '' and not \
 	if self.conf_name != '' and self.rast != '' and not \
 				wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
 	    wx.FindWindowById(wx.ID_FORWARD).Enable(True)
@@ -279,8 +259,6 @@
     def OnName(self,event):
 	"""!Sets the name of configuration file"""
 	self.conf_name = self.newconftxt.GetValue()
-	#rlisetting['conf_name'] = self.newconftxt.GetValue()
-	#if rlisetting['region'] != '' and rlisetting['rast'] != '' and not \
 	if self.region != '' and self.rast != '' and not \
@@ -288,8 +266,6 @@
     def OnRast(self, event):
         """!Sets raster map"""
         self.rast = event.GetString()
-        #rlisetting['rast'] = event.GetString()
-	#if rlisetting['region'] != '' and rlisetting['conf_name'] != '' and not \
 	if self.region != '' and self.conf_name != '' and not \
@@ -297,27 +273,20 @@
     def OnVector(self, event):
         """!Sets vector map"""
         self.vect = event.GetString()
-        #rlisetting['vect'] = event.GetString()
-    def OnEnterPage(self, event=None):
-        #if rlisetting['region'] == '' or rlisetting['rast'] == '' or rlisetting['conf_name'] == '':
+    def OnExitPage(self, event=None):
 	if self.region == '' or self.conf_name == '' or self.rast == '':
         else:
         if event.GetDirection():
 	    if self.region == 'key':
-	    #if rlisetting['region'] == 'key':
-	    #elif rlisetting['region'] == 'whole':
+		self.parent.samplingareapage.SetPrev(self.parent.keyboardpage)
 	    elif self.region == 'whole':
+		self.parent.samplingareapage.SetPrev(self)
 	    elif self.region == 'draw':
-	    #elif rlisetting['region'] == 'draw':
 		gcmd.GMessage(parent = self,
                               message = _("Function not supported yet"))
                 event.Veto()
@@ -334,10 +303,6 @@
-	#print rlisetting['rast']
-	self.col_up = ''
-	self.row_up = ''
 	self.col_len = ''
 	self.row_len = ''
@@ -393,42 +358,55 @@
 	self.RowUpLefttxt.Bind(wx.EVT_KILL_FOCUS, self.OnRowLeft)
 	self.ColLentxt.Bind(wx.EVT_KILL_FOCUS, self.OnColLen)
 	self.RowLentxt.Bind(wx.EVT_KILL_FOCUS, self.OnRowLeft)
+	self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
-    def OnEnterPage(self, event):
-        """!Insert values into text controls for summary of location
-        creation options
-        rastinfo = grast.raster_info(self.parent.startpage.rast)
-        print rastinfo
     def OnColLeft(self,event):
 	self.col_up = self.ColUpLefttxt.GetValue()
-	if self.row_up != '' and self.col_len != '' and self.row_len != '' \
-		      and not wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
-	    wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+	if self.col_up == '':
+	    wx.FindWindowById(wx.ID_FORWARD).Enable(False)
+	else:
+	    wx.FindWindowById(wx.ID_FORWARD).Enable(True)
     def OnRowLeft(self,event):
 	self.row_up = self.RowUpLefttxt.GetValue()
-	if self.col_up != '' and self.col_len != '' and self.row_len != '' \
+	if self.row_up == '':
+	else:
     def OnColLen(self,event):
 	self.col_len = self.ColLentxt.GetValue()
-	if self.row_up != '' and self.col_up != '' and self.row_len != '' \
+	if self.col_len == '':
+	else:
 	self.row_len = self.RowLentxt.GetValue()
-	if self.row_up != '' and self.col_len != '' and self.col_up != '' \
+	if self.row_len == '':
+	else:
+    def OnEnterPage(self, event):
+        """!Sets the default values, for the entire map
+	self.col_up = '0'
+	self.row_up = '0'
+	if self.col_len == '' and self.row_len == '':
+	    rastinfo = grast.raster_info(self.parent.startpage.rast)
+	    self.col_len = rastinfo['cols']
+	    self.row_len = rastinfo['rows']
+	self.ColUpLefttxt.SetValue(self.col_up)
+	self.RowUpLefttxt.SetValue(self.row_up)
+	self.ColLentxt.SetValue(self.col_len)
+	self.RowLentxt.SetValue(self.row_len)
 class SamplingAreasPage(TitledPage):
@@ -437,7 +415,7 @@
     def __init__(self, wizard, parent):
         TitledPage.__init__(self, wizard, _("Insert sempling areas"))
+	self.samplingtype = 'whole'
         # toggles
@@ -458,8 +436,7 @@
         self.sizer.Add(item = self.radio2, flag = wx.ALIGN_LEFT, pos = (2, 1))
         self.sizer.Add(item = self.radio3, flag = wx.ALIGN_LEFT, pos = (3, 1))
         self.sizer.Add(item = self.radio4, flag = wx.ALIGN_LEFT, pos = (4, 1))
         # bindings
@@ -473,8 +450,13 @@
         creation options
-        print "vector area is %s" % self.parent.startpage.vectorarea
-        if self.parent.startpage.vectorarea:
+	try:
+            self.sizer.Hide(self.radio5)
+	    self.sizer.Remove(self.radio5)
+	    self.sizer.Layout()
+	except AttributeError:
+	    pass
+        if self.parent.startpage.vect != '':
             self.radio5 = wx.RadioButton(parent = self, id = wx.ID_ANY,
                                         label = _("Select areas from the "
                                         "overlayed vector map"))
@@ -484,14 +466,19 @@
     def SetVal(self, event):
         """!Choose method"""
         if event.GetId() == self.radio1.GetId():
 	    self.DrawNothing()
         elif event.GetId() == self.radio2.GetId():
+	    self.samplingtype = 'regions'
 	    self.Region()
         elif event.GetId() == self.radio3.GetId():
+	    self.samplingtype = 'units'
 	    self.KeyDraw()
         elif event.GetId() == self.radio4.GetId():
+	    self.samplingtype = 'moving'
 	    self.KeyDraw()
         elif event.GetId() == self.radio5.GetId():
+	    self.samplingtype = 'vector'
 	    self.DrawNothing()
     def Region(self):
@@ -526,7 +513,20 @@
 				      majorDimension=wx.RA_SPECIFY_COLS)
 	self.sizer.Add(self.regionBox, flag = wx.ALIGN_CENTER, pos = (6, 1))
 	self.sizer.Layout()
+	self.regionBox.Bind(wx.EVT_RADIOBOX, self.OnRegionDraw)
+    def OnRegionDraw(self):
+        if event.GetInt() == 0:
+            self.SetNext(self.parent.samplingareapage)
+        elif event.GetInt() == 1:
+            self.region = 'key'
+            self.SetNext(self.parent.keyboardpage)
+	if self.conf_name != '' and self.rast != '' and not \
+				wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
     def DrawNothing(self):
 	try:
             self.sizer.Hide(self.regionBox)
@@ -534,9 +534,7 @@
 	    self.sizer.Layout()
 	    pass
-	self.regionBox = wx.StaticText(parent = self, id = wx.ID_ANY,label = _(''))
-	self.sizer.Add(self.regionBox, flag = wx.ALIGN_CENTER, pos = (6, 1))
-	self.sizer.Layout()
 class SampleUnitsKeyPage(TitledPage):
     """!Set values from keyboard for sample units"""
@@ -553,7 +551,8 @@
 	self.distributionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
 				      label= _("Select method of sampling unit distribution"),
 				      choices=[_('Random non overlapping'),
-				      _('Systematic contiguos'), _('Stratified random'),		_('Systematic non contiguos'), _('Centered over sites')],
+				      _('Systematic contiguos'), _('Stratified random'),
+				      _('Systematic non contiguos'), _('Centered over sites')],
 	self.sizer.Add(self.typeBox, flag = wx.ALIGN_LEFT, pos = (1, 1))
 	self.sizer.Add(self.distributionBox, flag = wx.ALIGN_LEFT, pos = (2, 1))
@@ -588,54 +587,84 @@
-	#column up/left
+ 	#configuration file name
+	self.conflabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+					  label = _('Configuration file name:'))
+	self.conftxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+					  label = "")
+	self.sizer.Add(item = self.conflabel, border=5, pos=(1, 1),
+                       flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
+	self.sizer.Add(item = self.conftxt, border=5, pos=(1, 2),
+	#raster name
 	self.rastlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
 					  label = _('Raster name:'))
 	self.rasttxt = wx.StaticText(parent = self, id = wx.ID_ANY,
 					  label = "")
-	self.sizer.Add(item = self.rastlabel, border=5, pos=(1, 1),
+	self.sizer.Add(item = self.rastlabel, border=5, pos=(2, 1),
-	self.sizer.Add(item = self.rasttxt, border=5, pos=(1, 2),
+	self.sizer.Add(item = self.rasttxt, border=5, pos=(2, 2),
- 	#row up/left
-	self.conflabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Configuration file name:'))
-	self.conftxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+	#vector name
+	self.vectlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+					  label = _('Vector name:'))
+	self.vecttxt = wx.StaticText(parent = self, id = wx.ID_ANY,
 					  label = "")
-	self.sizer.Add(item = self.conflabel, border=5, pos=(2, 1),
+	self.sizer.Add(item = self.vectlabel, border=5, pos=(3, 1),
-	self.sizer.Add(item = self.conftxt, border=5, pos=(2, 2),
+	self.sizer.Add(item = self.vecttxt, border=5, pos=(3, 2),
- 	#row up/left
+ 	#region type name
 	self.regionlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Region name:'))
+					  label = _('Region type:'))
 	self.regiontxt = wx.StaticText(parent = self, id = wx.ID_ANY,
 					  label = "")
-	self.sizer.Add(item = self.regionlabel, border=5, pos=(3, 1),
+	self.sizer.Add(item = self.regionlabel, border=5, pos=(4, 1),
-	self.sizer.Add(item = self.regiontxt, border=5, pos=(3, 2),
+	self.sizer.Add(item = self.regiontxt, border=5, pos=(4, 2),
+	#sampling area
+	self.samplinglabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+					  label = _('Sempling area type:'))
+	self.samplingtxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+					  label = "")
+	self.sizer.Add(item = self.samplinglabel, border=5, pos=(6, 1),
+	self.sizer.Add(item = self.samplingtxt, border=5, pos=(6, 2),
         creation options
         self.conftxt.SetLabel(self.parent.startpage.conf_name)
         self.rasttxt.SetLabel(self.parent.startpage.rast)
+        self.vecttxt.SetLabel(self.parent.startpage.vect)
         self.regiontxt.SetLabel(self.parent.startpage.region)
+        if self.parent.startpage.region == 'key':
+	    #region keybord values
+	    self.regionkeylabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+					      label = _('Region keybord values:'))
+	    self.regionkeytxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+					      label = "")
+	    self.sizer.Add(item = self.regionkeylabel, border=5, pos=(5, 1),
+	    self.sizer.Add(item = self.regionkeytxt, border=5, pos=(5, 2),
+	    regKeyVals = "Column left up: %s - Row left up: %s\nColumn length: %s - Row length: %s\n" \
+			  % (self.parent.keyboardpage.col_up, self.parent.keyboardpage.row_up,
+			  self.parent.keyboardpage.col_len, self.parent.keyboardpage.row_len)
+	    self.regionkeytxt.SetLabel(regKeyVals)
+	self.samplingtxt.SetLabel(self.parent.samplingareapage.samplingtype)
 if __name__ == "__main__":
     import gettext
     gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
