[GRASS-SVN] r49185 - grass/trunk/include
Fri Nov 11 13:00:50 EST 2011
Author: martinl
Date: 2011-11-11 10:00:50 -0800 (Fri, 11 Nov 2011)
New Revision: 49185
Removed:
   grass/trunk/include/vbuildlib.h
remove unused header
Deleted: grass/trunk/include/vbuildlib.h
--- grass/trunk/include/vbuildlib.h	2011-11-11 17:47:20 UTC (rev 49184)
+++ grass/trunk/include/vbuildlib.h	2011-11-11 18:00:50 UTC (rev 49185)
@@ -1,63 +0,0 @@
-#ifndef GRASS_VBUILDLIB_H
-#define GRASS_VBUILDLIB_H
-/* Prototypes from src/mapdev/v.build */
-/* area.c */
-int build_all_areas(struct Map_info *, struct Map_info *);
-int build_area(struct Map_info *, int);
-int check_area(struct Map_info *, int, double, double);
-/* ascii_io.c */
-char codes(int);
-int Wr_P_node_asc(int, struct P_node *, FILE *);
-int Wr_P_line_asc(int, struct P_line *, FILE *);
-int Wr_P_area_asc(int, struct P_area *, FILE *);
-int Wr_P_att_asc(int, struct P_att *, FILE *);
-int Wr_P_isle_asc(int, struct P_isle *, FILE *);
-int Wr_Plus_head_asc(struct Plus_head *, FILE *);
-/* atts_file.c */
-int clean_atts_file(char *);
-int cp_file(char *, char *);
-/* b_a_plus.c */
-int main(int, char *[]);
-/* find_nodes.c */
-int find_nodes(double, double, int, struct P_node *, double);
-/* import_line.c */
-int import_line(struct Map_info *, int, struct new_node *, struct line_pnts *,
-		long);
-/* init_plus_s.c */
-int init_plus_struct(struct Plus_head *);
-int init_map_struct(struct Map_info *);
-/* isle.c */
-int matchup_isles(struct Map_info *);
-int matchup_isle(struct Map_info *, register int);
-/* labels.c */
-int read_atts(struct Map_info *, char *);
-/* main.c */
-int debugf(char *, ...);
-/* open_files.c */
-int open_dig_files(char *, FILE **, struct Map_info *, struct Plus_head *);
-/* read_digit.c */
-int read_digit(struct Map_info *, struct Plus_head *);
-int init_extents(void);
-int init_extents_from_head(struct dig_head *);
-int update_head_from_ext(struct dig_head *);
-/* write_ascii.c */
-int write_plus_asc(struct Map_info *, FILE *, FILE *);
-int write_nodes_asc(struct Map_info *, FILE *, FILE *, struct Plus_head *);
-int write_lines_asc(struct Map_info *, FILE *, FILE *, struct Plus_head *);
-int write_areas_asc(struct Map_info *, FILE *, FILE *, struct Plus_head *);
-int write_atts_asc(struct Map_info *, FILE *, FILE *, struct Plus_head *);
-int write_isles_asc(struct Map_info *, FILE *, FILE *, struct Plus_head *);
-#endif
