[GRASS-SVN] r49191 - grass-addons/grass7/raster/r.agent
Sun Nov 13 10:23:07 EST 2011
Author: mic
Date: 2011-11-13 07:23:07 -0800 (Sun, 13 Nov 2011)
New Revision: 49191
Added:
   grass-addons/grass7/raster/r.agent/libold/
   grass-addons/grass7/raster/r.agent/tests.py
prepare refactoring
Added: grass-addons/grass7/raster/r.agent/tests.py
--- grass-addons/grass7/raster/r.agent/tests.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.agent/tests.py	2011-11-13 15:23:07 UTC (rev 49191)
@@ -0,0 +1,76 @@
+#!/usr/bin/env python
+# MODULE:       r.agent.aco
+# AUTHOR(S):    michael lustenberger inofix.ch
+# PURPOSE:      r.agent.aco is used to organize ant-like agents in a raster
+#               based playground. As decribed by the Ant Colony Optimization
+#               algorithm, the ants wander around looking for attractors,
+#               marking their paths if they find any.
+# COPYRIGHT:    (C) 2011 by Michael Lustenberger and the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+def dotest(function, argv):
+    """Global wrapper for the individual test suits."""
+    while True:
+        n = function.func_doc
+        o = str(argv)
+        if not n:
+            n = str(function)
+        t = str(raw_input("execute this now: '"+n+" - "+o+"'? [y/n/abort] "))
+        if t == "y":
+            if argv != None:
+                function(*argv)
+            else:
+                function()
+            break
+        elif t == "n":
+            break
+        elif t == "abort":
+            exit()
+def testError(expr, msg):
+    """Test suite for Class: Error"""
+    try:
+        raise error.DataError(expr, msg)
+    except error.DataError:
+        print "catched! all fine."
+def testPlayground():
+    """Test suite for Class: Playground"""
+    pg = playground.Playground()
+def testWorld():
+    """Test suite for Class: World"""
+    w = world.World()
+if __name__ == "__main__":
+    """Main method for testing when run as a script."""
+    import sys
+    from libagent import error
+    from libagent import playground
+    from libagent import world
+    alltests = {"error":[testError, ["Error Test Suite", "(this error is good)"]],
+                "playground":[testPlayground, []],
+                "world":[testWorld, []]}
+    if len(sys.argv) == 1:
+        for test,details in alltests.iteritems():
+            dotest(details[0], details[1])
+    else:
+        sys.argv.pop(0)
+        for t in sys.argv:
+            if t in alltests:
+                dotest(*alltests[t])
+            else:
+                print("Test does not exist: ", t)
Property changes on: grass-addons/grass7/raster/r.agent/tests.py
___________________________________________________________________
Added: svn:executable
