[GRASS-SVN] r49234 - grass/branches/releasebranch_6_4/vector/v.net
Mon Nov 14 03:27:31 EST 2011
Author: mmetz
Date: 2011-11-14 00:27:31 -0800 (Mon, 14 Nov 2011)
New Revision: 49234
   grass/branches/releasebranch_6_4/vector/v.net/description.html
update manual
Modified: grass/branches/releasebranch_6_4/vector/v.net/description.html
--- grass/branches/releasebranch_6_4/vector/v.net/description.html	2011-11-14 08:20:46 UTC (rev 49233)
+++ grass/branches/releasebranch_6_4/vector/v.net/description.html	2011-11-14 08:27:31 UTC (rev 49234)
@@ -1,10 +1,29 @@
 <h2>DESCRIPTION</h2>
-<em>v.net</em> is used for vector network maps maintenance.
-It reports about the current network graph status.
-It also permits to globally insert missing nodes and to connect
-unconnected nodes to the graph within a given distance threshold.
+<em>v.net</em> is used for network preparation and maintenance.
+It permits to insert missing nodes or arcs and to connect unconnected
+nodes to the network within a given distance threshold.
+It can also report the current network graph status.
+<p>
+In terms of network analysis, a network consists of nodes connected by
+arcs. In a vector map prepared for network analysis, nodes are represented
+by the grass-internal geometry type <em>node</em> and arcs by the geometry
+type <em>line</em>. If a <em>line</em> consists of several vertices and
+segments (the typical case), only its starting and ending vertex are
+regarded as network nodes. Further more, explicit starting and ending
+nodes for e.g. least cost path search or subnetwork allocation are
+represented by the geometry type point which must be identical with the
+start or end vertex (network node) of a line.
+<p>
+In general, network analysis will find the least costly (shortest or
+fastest) path from point A to point B by follwing the existing lines.
+This implies that the points A, B must lie at the start or end point of a
+line with is part of the network. If no line is starting or ending at a
+given point, this point is not part of the network, i.e. the point is
+unconnected and unreachable.
 <h3>NOTES</h3>
 If vector editing is required to modify the graph, <em>v.digit</em>
@@ -19,16 +38,16 @@
 Create nodes globally for all line ends and intersections:
 <br>
 <div class="code"><pre>
-v.net in=streams out=streams_node
+v.net input=roads output=roads_node operation=nodes
 </pre></div>
 <p>
 Merge in nodes from a separate map within given threshold:
 <br>
-echo "1|601653.5|4922869.2|start
-2|593330.8|4924096.6|end" | v.in.ascii cat=1 x=2 y=3 out=startend col="cat integer, \
-                         east double precision, north double precision, label varchar(43)"
+echo "1|601955.1|4916944.9|start
+2|594385.6|4921565.2|end" | v.in.ascii in=- cat=1 x=2 y=3 out=startend col="cat integer, \
+                         east double precision, north double precision, label varchar(6)"
 #create lines map connecting points to network (on layer 2)
 v.net myroads points=startend out=myroads_net op=connect thresh=200
