[GRASS-SVN] r49251 - sandbox/lucadelu
Mon Nov 14 18:25:50 EST 2011
Author: lucadelu
Date: 2011-11-14 15:25:50 -0800 (Mon, 14 Nov 2011)
New Revision: 49251
   sandbox/lucadelu/r.li.setup.py
improvements
Modified: sandbox/lucadelu/r.li.setup.py
--- sandbox/lucadelu/r.li.setup.py	2011-11-14 21:17:51 UTC (rev 49250)
+++ sandbox/lucadelu/r.li.setup.py	2011-11-14 23:25:50 UTC (rev 49251)
@@ -42,6 +42,12 @@
 ## r.li.windows.tcl:
 #exec echo "SAMPLINGFRAME $per_x|$per_y|$per_rl|$per_cl" >> $env(TMP).set
+def checkValue(value):
+    if value == '':
+        wx.FindWindowById(wx.ID_FORWARD).Enable(False)
+    else:
+        wx.FindWindowById(wx.ID_FORWARD).Enable(True)
 class RLiSetupFrame(wx.Frame):
     def __init__(self, parent, id = wx.ID_ANY,
 		style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
@@ -158,19 +164,24 @@
 	self.keyboardpage = KeybordPage(self.wizard, self)
 	self.samplingareapage = SamplingAreasPage(self.wizard, self)
 	self.summarypage = SummaryPage(self.wizard, self)
+	self.samplingunitskey = SampleUnitsKeyPage(self.wizard, self)
 	#order of pages
 	self.startpage.SetNext(self.samplingareapage)
 	self.keyboardpage.SetPrev(self.startpage)
 	self.keyboardpage.SetNext(self.samplingareapage)
 	self.samplingareapage.SetPrev(self.startpage)
-	self.samplingareapage.SetNext(self.summarypage)
+	self.samplingareapage.SetNext(self.samplingunitskey)
+	self.samplingunitskey.SetPrev(self.samplingareapage)
+	self.samplingunitskey.SetNext(self.summarypage)
 	self.summarypage.SetPrev(self.samplingareapage)
 	#layout
 	self.startpage.DoLayout()
 	self.keyboardpage.DoLayout()
 	self.samplingareapage.DoLayout()
 	self.summarypage.DoLayout()
+	self.samplingunitskey.DoLayout()
 	self.wizard.FitToPage(self.startpage)
 	#run_wizard
@@ -251,9 +262,14 @@
             self.SetNext(self.parent.keyboardpage)
         elif event.GetInt() == 2:
 	    self.region = 'draw'
-	    wx.FindWindowById(wx.ID_FORWARD).Enable(False)
-	if self.conf_name != '' and self.rast != '' and not \
-				wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
+	    #to remove when I know how to connect or create a monitor
+	    gcmd.GMessage(parent = self,
+                              message = _("Function not supported yet"))
+            #event.Veto()
+            return
+	    #wx.FindWindowById(wx.ID_FORWARD).Enable(False)
+	if self.conf_name != '' and self.rast != '' and not self.region == 'draw' \
+                        and not wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
     def OnName(self,event):
@@ -275,6 +291,7 @@
         self.vect = event.GetString()
     def OnExitPage(self, event=None):
+        """!Function during exiting"""
 	if self.region == '' or self.conf_name == '' or self.rast == '':
         else:
@@ -363,34 +380,34 @@
     def OnColLeft(self,event):
 	"""!Sets the name of configuration file"""
 	self.col_up = self.ColUpLefttxt.GetValue()
-	if self.col_up == '':
-	else:
-	    wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+        checkValue(self.col_up)
     def OnRowLeft(self,event):
 	self.row_up = self.RowUpLefttxt.GetValue()
-	if self.row_up == '':
-	else:
+	checkValue(self.row_up)
+	#if self.row_up == '':
+	#else:
+	    #wx.FindWindowById(wx.ID_FORWARD).Enable(True)
     def OnColLen(self,event):
 	self.col_len = self.ColLentxt.GetValue()
-	if self.col_len == '':
-	else:
+	checkValue(self.col_len)
+	#if self.col_len == '':
+	#else:
 	self.row_len = self.RowLentxt.GetValue()
-	if self.row_len == '':
-	else:
+	checkValue(self.row_len)
+	#if self.row_len == '':
+	#else:
     def OnEnterPage(self, event):
         """!Sets the default values, for the entire map
@@ -412,7 +429,7 @@
     Set name of configuration file, choose raster and optionally vector/sites
     def __init__(self, wizard, parent):
         TitledPage.__init__(self, wizard, _("Insert sempling areas"))
 	self.samplingtype = 'whole'
@@ -454,7 +471,7 @@
             self.sizer.Hide(self.radio5)
 	    self.sizer.Remove(self.radio5)
 	    self.sizer.Layout()
-	except AttributeError:
+	except AttributeError, TypeError:
 	    pass
         if self.parent.startpage.vect != '':
             self.radio5 = wx.RadioButton(parent = self, id = wx.ID_ANY,
@@ -482,12 +499,12 @@
 	    self.DrawNothing()
     def Region(self):
-	#show this only if radio2 it is selected
+	"""show this only if radio2 it is selected"""
 	try:
             self.sizer.Hide(self.regionBox)
 	    self.sizer.Remove(self.regionBox)
 	    self.sizer.Layout()
 	    pass
 	self.regionBox = wx.GridBagSizer(vgap = 1, hgap = 2)
 	self.regionLabel = wx.StaticText(parent = self, id = wx.ID_ANY,
@@ -499,12 +516,12 @@
 	self.sizer.Layout()
     def KeyDraw(self):
-	#show this only if radio3 and radio4 it is selected
+	"""Show this only if radio3 and radio4 it is selected"""
 	try:
 	    self.sizer.Layout()
 	    pass
 	self.regionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
 				      label= _("Choose a method"),
@@ -516,23 +533,28 @@
 	self.regionBox.Bind(wx.EVT_RADIOBOX, self.OnRegionDraw)
-    def OnRegionDraw(self):
+    def OnRegionDraw(self,event):
+        """Function called by KeyDraw to find what method is choosed"""
         if event.GetInt() == 0:
-            self.region = 'whole'
-            self.SetNext(self.parent.samplingareapage)
+            self.regionbox = 'keybord'
+            self.SetNext(self.parent.samplingunitskey)
         elif event.GetInt() == 1:
-            self.region = 'key'
-            self.SetNext(self.parent.keyboardpage)
+            self.regionbox = 'drawmouse'
+            return
+            #self.SetNext(self.parent.draw)
     def DrawNothing(self):
 	try:
 	    self.sizer.Layout()
 	    pass
