[GRASS-SVN] r49293 - in grass/trunk: lib/python raster/r.info
Sat Nov 19 06:59:58 EST 2011
Author: hamish
Date: 2011-11-19 03:59:58 -0800 (Sat, 19 Nov 2011)
New Revision: 49293
   grass/trunk/lib/python/raster.py
   grass/trunk/raster/r.info/main.c
   grass/trunk/raster/r.info/r.info.html
Consolidate r.info flags as a basis of further discussion. flags have been
grouped into (g) raster array definition (eval-safe), (e) extended metadata
(eval-unsafe), (r) array analysis (currently only range, but something like
compression yes|no could plausibly be put in there too). Separate -h history
flag is retained.
Modified: grass/trunk/lib/python/raster.py
--- grass/trunk/lib/python/raster.py	2011-11-18 19:37:23 UTC (rev 49292)
+++ grass/trunk/lib/python/raster.py	2011-11-19 11:59:58 UTC (rev 49293)
@@ -13,7 +13,7 @@
 @endcode
-(C) 2008-2009 by the GRASS Development Team
+(C) 2008-2011 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
 for details.
@@ -47,7 +47,7 @@
               "Raster map <%(map)s> not found in current mapset." % { 'map' : map, 'map' : map}))
     return False
-# run "r.info -rgstmpud ..." and parse output
+# run "r.info -gre ..." and parse output
 def raster_info(map):
     """!Return information about a raster map (interface to
@@ -73,7 +73,7 @@
         else:
             return float(s)
-    s = read_command('r.info', flags = 'rgstmpud', map = map)
+    s = read_command('r.info', flags = 'gre', map = map)
     kv = parse_key_val(s)
     for k in ['min', 'max']:
 	kv[k] = float_or_null(kv[k])
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c	2011-11-18 19:37:23 UTC (rev 49292)
+++ grass/trunk/raster/r.info/main.c	2011-11-19 11:59:58 UTC (rev 49293)
@@ -7,7 +7,7 @@
 * PURPOSE:      Outputs basic information about a user-specified raster map layer.
-* COPYRIGHT:    (C) 2005 by the GRASS Development Team
+* COPYRIGHT:    (C) 2005-2011 by the GRASS Development Team
 *               This program is free software under the GNU General Public
 *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -60,8 +60,7 @@
     struct Reclass reclass;
     struct GModule *module;
     struct Option *opt1;
-    struct Flag *rflag, *sflag, *tflag, *gflag, *hflag, *mflag;
-    struct Flag *uflag, *dflag, *timestampflag;
+    struct Flag *gflag, *rflag, *eflag, *hflag;
     /* Initialize GIS Engine */
     G_gisinit(argv[0]);
@@ -75,47 +74,26 @@
     opt1 = G_define_standard_option(G_OPT_R_MAP);
+    gflag = G_define_flag();
+    gflag->key = 'g';
+    gflag->description = _("Print raster array information only");
     rflag = G_define_flag();
     rflag->key = 'r';
     rflag->description = _("Print range only");
-    sflag = G_define_flag();
-    sflag->key = 's';
-    sflag->description =
-	_("Print raster map resolution (NS-res, EW-res) only");
+    eflag = G_define_flag();
+    eflag->key = 'e';
+    eflag->description = _("Print extended metadata information only");
-    tflag = G_define_flag();
-    tflag->key = 't';
-    tflag->description = _("Print raster map type only");
-    gflag = G_define_flag();
-    gflag->key = 'g';
-    gflag->description = _("Print map region only");
     hflag = G_define_flag();
     hflag->key = 'h';
     hflag->description = _("Print raster history instead of info");
-    uflag = G_define_flag();
-    uflag->key = 'u';
-    uflag->description = _("Print raster map data units only");
-    dflag = G_define_flag();
-    dflag->key = 'd';
-    dflag->description = _("Print raster map vertical datum only");
-    mflag = G_define_flag();
-    mflag->key = 'm';
-    mflag->description = _("Print map title only");
-    timestampflag = G_define_flag();
-    timestampflag->key = 'p';
-    timestampflag->description =
-	_("Print raster map timestamp (day.month.year hour:minute:seconds) only");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     name = G_store(opt1->answer);
     if ((mapset = G_find_raster2(name, "")) == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), name);
@@ -146,9 +124,8 @@
     out = stdout;
-    if (!rflag->answer && !sflag->answer && !tflag->answer &&
-	!gflag->answer && !hflag->answer && !timestampflag->answer &&
-	!mflag->answer && !uflag->answer && !dflag->answer) {
+    if (!gflag->answer && !rflag->answer &&
+	!eflag->answer && !hflag->answer) {
 	divider('+');
 	compose_line(out, "Layer:    %-29.29s  Date: %s", name,
@@ -321,30 +298,8 @@
 	fprintf(out, "\n");
-    else {	/* r,s,t,g,h, or m flag */
+    else {	/* g,r,e, or h flags */
-	if (rflag->answer) {
-	    if (data_type == CELL_TYPE) {
-		if (2 == Rast_read_range(name, "", &crange)) {
-		    fprintf(out, "min=NULL\n");
-		    fprintf(out, "max=NULL\n");
-		else {
-		    fprintf(out, "min=%i\n", (CELL) zmin);
-		    fprintf(out, "max=%i\n", (CELL) zmax);
-	    else if (data_type == FCELL_TYPE) {
-		fprintf(out, "min=%.7g\n", zmin);
-		fprintf(out, "max=%.7g\n", zmax);
-	    else {
-		fprintf(out, "min=%.15g\n", zmin);
-		fprintf(out, "max=%.15g\n", zmax);
 	if (gflag->answer) {
 	    G_format_northing(cellhd.north, tmp1, -1);
 	    G_format_northing(cellhd.south, tmp2, -1);
@@ -355,29 +310,47 @@
 	    G_format_easting(cellhd.west, tmp2, -1);
 	    fprintf(out, "east=%s\n", tmp1);
 	    fprintf(out, "west=%s\n", tmp2);
-	if (sflag->answer) {
 	    G_format_resolution(cellhd.ns_res, tmp3, cellhd.proj);
 	    fprintf(out, "nsres=%s\n", tmp3);
 	    G_format_resolution(cellhd.ew_res, tmp3, cellhd.proj);
 	    fprintf(out, "ewres=%s\n", tmp3);
-	if (tflag->answer) {
 	    fprintf(out, "datatype=%s\n",
 		    (data_type == CELL_TYPE ? "CELL" :
 		     (data_type == DCELL_TYPE ? "DCELL" :
 		      (data_type == FCELL_TYPE ? "FCELL" : "??"))));
-	if (mflag->answer) {
+	if (rflag->answer) {
+	    if (data_type == CELL_TYPE) {
+		if (2 == Rast_read_range(name, "", &crange)) {
+		    fprintf(out, "min=NULL\n");
+		    fprintf(out, "max=NULL\n");
+		else {
+		    fprintf(out, "min=%i\n", (CELL) zmin);
+		    fprintf(out, "max=%i\n", (CELL) zmax);
+	    else if (data_type == FCELL_TYPE) {
+		fprintf(out, "min=%.7g\n", zmin);
+		fprintf(out, "max=%.7g\n", zmax);
+	    else {
+		fprintf(out, "min=%.15g\n", zmin);
+		fprintf(out, "max=%.15g\n", zmax);
+	if (eflag->answer) {
 	    fprintf(out, "title=%s (%s)\n", cats_ok ? cats.title :
 		    "??", hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??");
-	if (timestampflag->answer) {
+	    fprintf(out, "units=%s\n", units ? units : "\"none\"");
+	    fprintf(out, "vertical_datum=%s\n", vdatum ? vdatum : "\"none\"");
 	    if (time_ok && (first_time_ok || second_time_ok)) {
 		G_format_timestamp(&ts, timebuff);
@@ -391,11 +364,6 @@
-	if (uflag->answer)
-	    fprintf(out, "units=%s\n", units ? units : "(none)");
-	if (dflag->answer)
-	    fprintf(out, "vertical_datum=%s\n", vdatum ? vdatum : "(none)");
 	if (hflag->answer) {
 	    if (hist_ok) {
 		fprintf(out, "Data Source:\n");
Modified: grass/trunk/raster/r.info/r.info.html
--- grass/trunk/raster/r.info/r.info.html	2011-11-18 19:37:23 UTC (rev 49292)
+++ grass/trunk/raster/r.info/r.info.html	2011-11-19 11:59:58 UTC (rev 49293)
@@ -77,20 +77,27 @@
 subset of the available information by passing various flags to the module:
 <div class="code"><pre>
-r.info -rst slope
-min=0.000000
-max=52.520164
+GRASS> r.info -g slope
+north=4928030
+south=4913690
+east=609000
+west=589980
 nsres=30
 ewres=30
 datatype=FCELL
-r.info -g slope
-north=4928030
-south=4913690
-east=609000
-west=589980
+GRASS> r.info -r slope
+min=0.000000
+max=52.520164
+GRASS> r.info -e slope
+title=slope in degrees (slope)
+units="none"
+vertical_datum="none"
+timestamp="none"
 </pre></div>
 <h2>SEE ALSO</h2>
 <em><a href="g.mapsets.html">g.mapsets</a>,</em>
@@ -102,9 +109,11 @@
 <em><a href="r.univar.html">r.univar</a>,</em>
 <em><a href="r.what.html">r.what</a></em>
 <h2>AUTHOR</h2>
 Michael O'Shea,
 <a href="http://www.cecer.army.mil/">U.S. Army Construction Engineering Research Laboratory</a>
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
