[GRASS-SVN] r49403 - grass/trunk/scripts/r.fillnulls
Sun Nov 27 23:10:01 EST 2011
Author: hamish
Date: 2011-11-27 20:10:01 -0800 (Sun, 27 Nov 2011)
New Revision: 49403
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
sync to changed r.to.vect parameter name
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2011-11-28 03:57:31 UTC (rev 49402)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2011-11-28 04:10:01 UTC (rev 49403)
@@ -124,7 +124,7 @@
     # Use this outline (raster border) for interpolating the fill data:
     vecttmp = "vecttmp_fillnulls_" + unique
     grass.message(_("Creating interpolation points..."))
-    if grass.run_command('r.to.vect', input = input, output = vecttmp, feature = 'point'):
+    if grass.run_command('r.to.vect', input = input, output = vecttmp, type = 'point'):
 	grass.fatal(_("abandoned. Removing temporary maps, restoring user mask if needed:"))
     # count number of points to control segmax parameter for interpolation:
