[GRASS-SVN] r49405 - in grass/trunk: include/defs lib/vector/Vlib ps/ps.map vector/v.category vector/v.clean vector/v.convert vector/v.kcv vector/v.net.path vector/v.type visualization/nviz/src
Mon Nov 28 03:33:09 EST 2011
Author: martinl
Date: 2011-11-28 00:33:09 -0800 (Mon, 28 Nov 2011)
New Revision: 49405
Removed:
   grass/trunk/lib/vector/Vlib/error.c
   grass/trunk/include/defs/vector.h
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/ps/ps.map/do_vectors.c
   grass/trunk/ps/ps.map/r_vareas.c
   grass/trunk/ps/ps.map/r_vlines.c
   grass/trunk/ps/ps.map/r_vpoints.c
   grass/trunk/vector/v.category/main.c
   grass/trunk/vector/v.clean/main.c
   grass/trunk/vector/v.convert/old2new.c
   grass/trunk/vector/v.kcv/main.c
   grass/trunk/vector/v.net.path/main.c
   grass/trunk/vector/v.type/main.c
   grass/trunk/visualization/nviz/src/query_vect.c
vlib: remove Vect_get/set_fatal_error() - replaced by G_fatal_error() / G_warning()
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/include/defs/vector.h	2011-11-28 08:33:09 UTC (rev 49405)
@@ -209,10 +209,6 @@
 void Vect_set_release_support(struct Map_info *);
 void Vect_set_category_index_update(struct Map_info *);
-/* Set/get fatal error behaviour */
-int Vect_set_fatal_error(int);
-int Vect_get_fatal_error();
 /* Open/close/rewind/set_constraints for map */
 int Vect_check_input_output_name(const char *, const char *, int);
 int Vect_legal_filename(const char *);
Deleted: grass/trunk/lib/vector/Vlib/error.c
--- grass/trunk/lib/vector/Vlib/error.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/lib/vector/Vlib/error.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -1,51 +0,0 @@
-   \file lib/vector/Vlib/error.c
-   \brief Vector library - error management
-   Higher level functions for reading/writing/manipulating vectors.
-   (C) 2001-2009 by the GRASS Development Team
-   This program is free software under the GNU General Public License
-   (>=v2).  Read the file COPYING that comes with GRASS for details.
-   \author Original author CERL, probably Dave Gerdes or Mike Higgins.
-   \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
-#include <string.h>
-#include <grass/vector.h>
-static int fatal_err = GV_FATAL_EXIT;
-   \brief Set behaviour if fatal error occurs in some functions
-   - GV_FATAL_EXIT(default): print error message and exit,
-   - GV_FATAL_PRINT: print error message and return error,
-   - GV_FATAL_RETURN: return error
-   \param  err error type
-   \return 0
-int Vect_set_fatal_error(int err)
-    fatal_err = err;
-    return 0;
-   \brief Get behaviour for fatal error
-   \todo Remove or move to GIS Library?
-   \return GV_FATAL_EXIT(default): print error message and exit,
-   \return GV_FATAL_PRINT: print error message and return error,
-   \return GV_FATAL_RETURN: return error
-int Vect_get_fatal_error(void)
-    return (fatal_err);
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/lib/vector/Vlib/open.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -82,20 +82,6 @@
 #endif
-static void fatal_error(int ferror, char *errmsg)
-    switch (ferror) {
-    case GV_FATAL_EXIT:
-	G_fatal_error(errmsg);
-	break;
-    case GV_FATAL_PRINT:
-	G_warning(errmsg);
-	break;
-    case GV_FATAL_RETURN:
-	break;
  * \brief Predetermine level at which a vector map will be opened for
  * reading.
@@ -151,9 +137,9 @@
 		   int update, int head_only)
     char buf[GNAME_MAX + 10], buf2[GMAPSET_MAX + 10], xname[GNAME_MAX],
-	xmapset[GMAPSET_MAX], errmsg[2000];
+	xmapset[GMAPSET_MAX];
     FILE *fp;
-    int level, level_request, ferror;
+    int level, level_request;
     int format, ret;
     int ogr_mapset;
     const char *fmapset;
@@ -166,9 +152,6 @@
     /* TODO: Open header for update ('dbln') */
-    ferror = Vect_get_fatal_error();
-    Vect_set_fatal_error(GV_FATAL_EXIT);
     level_request = Open_level;
     Open_level = 0;
@@ -215,12 +198,11 @@
 	fmapset = G_find_vector2(Map->name, Map->mapset);
 	if (fmapset == NULL) {
 	    if (mapset && strcmp(mapset, G_mapset()) == 0)
-		sprintf(errmsg, _("Vector map <%s> not found in current mapset"),
-			Vect_get_name(Map));
+		G_fatal_error(_("Vector map <%s> not found in current mapset"),
+			      Vect_get_name(Map));
 	    else
-		sprintf(errmsg, _("Vector map <%s> not found"),
-			Vect_get_full_name(Map));
-	    fatal_error(ferror, errmsg);
+		G_fatal_error(_("Vector map <%s> not found"),
+			      Vect_get_full_name(Map));
 	    return -1;
 	Map->mapset = G_store(fmapset);
@@ -257,9 +239,8 @@
 	    G_debug(1, "Vector format: %d (non-native)", format);
 	    if (format < 0) {
-		sprintf(errmsg, _("Unable to open vector map <%s>"),
+		G_fatal_error(_("Unable to open vector map <%s>"),
 		return -1;
@@ -272,12 +253,8 @@
     /* read vector head (ignored for OGR mapset) */
     if (!ogr_mapset && Vect__read_head(Map) != 0) {
-	sprintf(errmsg,
-		_("Unable to open vector map <%s> on level %d. "
-		  "Try to rebuild vector topology by v.build."),
-		Vect_get_full_name(Map), level_request);
-	G_warning(_("Unable to read header file of vector map <%s>"),
+	G_fatal_error(_("Unable to read header file of vector map <%s>"),
     /* projection is not written to head but zone ??? */
@@ -362,11 +339,9 @@
 	if (level_request == 2 && level < 2) {
 	    if (!ogr_mapset) {
 		/* for direct OGR read access is built pseudo-topology on the fly */
-		sprintf(errmsg,
+		G_warning(_("Unable to open vector map <%s> on level %d. "
+			    "Try to rebuild vector topology by v.build."),
+			  Vect_get_full_name(Map), level_request);
 		return -1;
@@ -383,11 +358,9 @@
 		dig_spidx_free(&(Map->plus));
 		dig_cidx_free(&(Map->plus));
-	    sprintf(errmsg,
 	    return -1;
 	if (ogr_mapset && !head_only && level_request != 1) {
@@ -450,11 +423,9 @@
     if (update && !ogr_mapset) {		/* native only */
 	Map->hist_fp = G_fopen_modify(buf, GV_HIST_ELEMENT);
 	if (Map->hist_fp == NULL) {
-	    sprintf(errmsg,
-		    _("Unable to open history file for vector map <%s>"),
-	    return (-1);
+	    G_warning(_("Unable to open history file for vector map <%s>"),
+	    return -1;
 	G_fseek(Map->hist_fp, (off_t) 0, SEEK_END);
 	Vect_hist_write(Map,
@@ -689,8 +660,8 @@
 int Vect_open_new(struct Map_info *Map, const char *name, int with_z)
-    int ret, ferror;
-    char errmsg[2000], buf[500];
+    int ret;
+    char buf[500];
     char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
     G_debug(2, "Vect_open_new(): name = %s", name);
@@ -700,23 +671,18 @@
     /* init header */
     Vect__init_head(Map);
-    /* error handling */
     if (G_name_is_fully_qualified(name, xname, xmapset)) {
 	if (strcmp(xmapset, G_mapset()) != 0) {
-	    sprintf(errmsg, _("%s is not in the current mapset (%s)"), name,
-		    G_mapset());
+	    G_fatal_error(_("<%s> is not the current mapset (%s)"), name,
+			  G_mapset());
+	    return -1;
 	name = xname;
     /* check for [A-Za-z][A-Za-z0-9_]* in name */
     if (Vect_legal_filename(name) < 0) {
-	sprintf(errmsg, _("Vector map name is not SQL compliant"));
+	G_fatal_error(_("Vector map name is not SQL compliant"));
 	return -1;
@@ -732,8 +698,7 @@
 	Map->format = GV_FORMAT_OGR_DIRECT;
 	fp = G_fopen_old("", "OGR", G_mapset());
 	if (!fp) {
-	    sprintf(errmsg, _("Unable to open OGR file"));
+	    G_warning(_("Unable to open OGR file"));
 	key_val = G_fread_key_value(fp);
 	fclose(fp);
@@ -758,8 +723,7 @@
 	    ret = Vect_delete(name);
 	    if (ret == -1) {
-		sprintf(errmsg, _("Unable to delete vector map <%s>"), name);
+		G_warning(_("Unable to delete vector map <%s>"), name);
 		return -1;
@@ -774,9 +738,8 @@
     Map->plus.spidx_with_z = Map->plus.with_z = Map->head.with_z = (with_z != 0);
     if ((*Open_new_array[Map->format][1]) (Map, name, with_z) < 0) {
-	sprintf(errmsg, _("Unable to create vector map <%s>"),
+	G_fatal_error(_("Unable to create vector map <%s>"),
+		      name);
 	return -1;
@@ -785,9 +748,8 @@
 	sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
 	Map->hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
-	    sprintf(errmsg, _("Unable to open history file of vector map <%s>"),
+	    G_warning(_("Unable to open history file of vector map <%s>"),
+		      name);
 	    return -1;
Modified: grass/trunk/ps/ps.map/do_vectors.c
--- grass/trunk/ps/ps.map/do_vectors.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/ps/ps.map/do_vectors.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -34,7 +34,6 @@
 		  vector.layer[n].name, vector.layer[n].mapset);
 	Vect_set_open_level(2);
-	Vect_set_fatal_error(GV_FATAL_PRINT);
 	if (2 >
 	    Vect_open_old(&Map, vector.layer[n].name,
 			  vector.layer[n].mapset)) {
@@ -139,7 +138,6 @@
 	if (2 >
Modified: grass/trunk/ps/ps.map/r_vareas.c
--- grass/trunk/ps/ps.map/r_vareas.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/ps/ps.map/r_vareas.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -48,7 +48,6 @@
     sprintf(fullname, "%s in %s", name, mapset);
     if (2 > Vect_open_old(&Map, name, mapset)) {
 	error(fullname, "", "can't open vector map");
 	gobble_input();
Modified: grass/trunk/ps/ps.map/r_vlines.c
--- grass/trunk/ps/ps.map/r_vlines.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/ps/ps.map/r_vlines.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -54,7 +54,6 @@
 	gobble_input();
Modified: grass/trunk/ps/ps.map/r_vpoints.c
--- grass/trunk/ps/ps.map/r_vpoints.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/ps/ps.map/r_vpoints.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -54,7 +54,6 @@
 	gobble_input();
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/vector/v.category/main.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -206,7 +206,6 @@
 	option == O_SUM) {
 	with_z = In.head.with_z;
 	if (0 > Vect_open_new(&Out, out_opt->answer, with_z)) {
 	    Vect_close(&In);
 	    exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/vector/v.clean/main.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -273,15 +273,13 @@
     Vect_open_old2(&In, opt.in->answer, "", opt.field->answer);
     with_z = Vect_is_3d(&In);
     if (0 > Vect_open_new(&Out, opt.out->answer, with_z)) {
 	Vect_close(&In);
 	exit(EXIT_FAILURE);
     if (opt.err->answer) {
 	if (0 > Vect_open_new(&Err, opt.err->answer, with_z)) {
 	    Vect_close(&In);
Modified: grass/trunk/vector/v.convert/old2new.c
--- grass/trunk/vector/v.convert/old2new.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/vector/v.convert/old2new.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -32,7 +32,6 @@
     /* open new output file */
     if (Vect_open_new(&Mapout, out, WITHOUT_Z) < 0) {
 	fclose(Digin);
 	exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.kcv/main.c
--- grass/trunk/vector/v.kcv/main.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/vector/v.kcv/main.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -46,7 +46,7 @@
     int line, nlines, nlinks;
     double east, north, (*rng) (), max, myrand();
-    int i, j, n, nsites, np, *p, dcmp();
+    int i, j, nsites, np, *p, dcmp();
     int *pnt_part;
     struct Map_info In, Out;
     static struct line_pnts *Points;
@@ -132,7 +132,6 @@
 	G_fatal_error(_("More partitions than points (%d)"), nsites);
     Vect_open_new(&Out, out_opt->answer, Vect_is_3d(&In));
     Vect_copy_head_data(&In, &Out);
@@ -192,7 +191,7 @@
      * number of sites will not always be a multiple of the number of
      * partitions. make_histo() returns the maximum bin size.
-    n = make_histo(&p, np, nsites);
+    make_histo(&p, np, nsites);
     nlines = Vect_get_num_lines(&In);
     pnt_part = (int *)G_calloc(nlines + 1, sizeof(int));
Modified: grass/trunk/vector/v.net.path/main.c
--- grass/trunk/vector/v.net.path/main.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/vector/v.net.path/main.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -129,7 +129,6 @@
     Vect_open_old(&In, input_opt->answer, "");
     if (1 > Vect_open_new(&Out, output_opt->answer, Vect_is_3d(&In))) {
 	Vect_close(&In);
Modified: grass/trunk/vector/v.type/main.c
--- grass/trunk/vector/v.type/main.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/vector/v.type/main.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -125,7 +125,6 @@
     Vect_open_old2(&In, in_opt->answer, "", field_opt->answer);
     field = Vect_get_field_number(&In, field_opt->answer);
     if (0 > Vect_open_new(&Out, out_opt->answer, Vect_is_3d(&In))) {
 	Vect_close(&In);
 	exit(EXIT_FAILURE);
Modified: grass/trunk/visualization/nviz/src/query_vect.c
--- grass/trunk/visualization/nviz/src/query_vect.c	2011-11-28 04:58:36 UTC (rev 49404)
+++ grass/trunk/visualization/nviz/src/query_vect.c	2011-11-28 08:33:09 UTC (rev 49405)
@@ -36,7 +36,6 @@
     level = Vect_open_old(&Map, name, mapset);
     if (level < 2) {
 	return ("Could not open map on level 2.\n");
