[GRASS-SVN] r49420 - in grass/trunk: doc/vector/v.example imagery/i.pca include include/vect lib/gis lib/vector/Vlib raster/r.carve raster/r.param.scale raster/r.slope.aspect vector/v.buffer vector/v.build vector/v.build.polylines vector/v.category vector/v.clean vector/v.drape vector/v.extract vector/v.extrude vector/v.generalize vector/v.hull vector/v.kernel vector/v.lidar.correction vector/v.lidar.edgedetection vector/v.lidar.growing vector/v.net vector/v.net.alloc vector/v.net.allpairs vector/v.net.bridge vector/v.net.centrality vector/v.net.components vector/v.net.connectivity vector/v.net.distance vector/v.net.flow vector/v.net.iso vector/v.net.path vector/v.net.salesman vector/v.net.spanningtree vector/v.net.steiner vector/v.net.timetable vector/v.net.visibility vector/v.outlier vector/v.overlay vector/v.patch vector/v.reclass vector/v.segment vector/v.select vector/v.surf.bspline vector/v.surf.rst vector/v.to.3d vector/v.to.points vector/v.transform vector/v.type
Tue Nov 29 06:08:36 EST 2011
Author: martinl
Date: 2011-11-29 03:08:36 -0800 (Tue, 29 Nov 2011)
New Revision: 49420
   grass/trunk/doc/vector/v.example/main.c
   grass/trunk/imagery/i.pca/main.c
   grass/trunk/include/gis.h
   grass/trunk/include/vect/dig_defines.h
   grass/trunk/lib/gis/legal_name.c
   grass/trunk/lib/vector/Vlib/legal_vname.c
   grass/trunk/raster/r.carve/main.c
   grass/trunk/raster/r.param.scale/interface.c
   grass/trunk/raster/r.slope.aspect/main.c
   grass/trunk/vector/v.buffer/main.c
   grass/trunk/vector/v.build.polylines/main.c
   grass/trunk/vector/v.build/main.c
   grass/trunk/vector/v.category/main.c
   grass/trunk/vector/v.clean/main.c
   grass/trunk/vector/v.drape/main.c
   grass/trunk/vector/v.extract/main.c
   grass/trunk/vector/v.extrude/main.c
   grass/trunk/vector/v.generalize/main.c
   grass/trunk/vector/v.hull/main.c
   grass/trunk/vector/v.kernel/main.c
   grass/trunk/vector/v.lidar.correction/main.c
   grass/trunk/vector/v.lidar.edgedetection/main.c
   grass/trunk/vector/v.lidar.growing/main.c
   grass/trunk/vector/v.net.alloc/main.c
   grass/trunk/vector/v.net.allpairs/main.c
   grass/trunk/vector/v.net.bridge/main.c
   grass/trunk/vector/v.net.centrality/main.c
   grass/trunk/vector/v.net.components/main.c
   grass/trunk/vector/v.net.connectivity/main.c
   grass/trunk/vector/v.net.distance/main.c
   grass/trunk/vector/v.net.flow/main.c
   grass/trunk/vector/v.net.iso/main.c
   grass/trunk/vector/v.net.path/main.c
   grass/trunk/vector/v.net.salesman/main.c
   grass/trunk/vector/v.net.spanningtree/main.c
   grass/trunk/vector/v.net.steiner/main.c
   grass/trunk/vector/v.net.timetable/main.c
   grass/trunk/vector/v.net.visibility/main.c
   grass/trunk/vector/v.net/main.c
   grass/trunk/vector/v.outlier/main.c
   grass/trunk/vector/v.overlay/main.c
   grass/trunk/vector/v.patch/main.c
   grass/trunk/vector/v.reclass/main.c
   grass/trunk/vector/v.segment/main.c
   grass/trunk/vector/v.select/main.c
   grass/trunk/vector/v.surf.bspline/main.c
   grass/trunk/vector/v.surf.rst/main.c
   grass/trunk/vector/v.to.3d/main.c
   grass/trunk/vector/v.to.points/main.c
   grass/trunk/vector/v.transform/main.c
   grass/trunk/vector/v.type/main.c
replace GR_FATAL_* (rasters), GV_FATAL_* (vectors) by G_FATAL_*
Modified: grass/trunk/doc/vector/v.example/main.c
--- grass/trunk/doc/vector/v.example/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/doc/vector/v.example/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -69,7 +69,7 @@
        3) if input was found in current mapset, check if input != output.
-    Vect_check_input_output_name(old->answer, new->answer, GV_FATAL_EXIT);
+    Vect_check_input_output_name(old->answer, new->answer, G_FATAL_EXIT);
     if ((mapset = (char *)G_find_vector2(old->answer, "")) == NULL)
 	G_fatal_error(_("Vector map <%s> not found"), old->answer);
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/imagery/i.pca/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -134,7 +134,7 @@
 	char tmpbuf[128];
 	sprintf(tmpbuf, "%s.%d", opt_out->answer, i + 1);
-	G_check_input_output_name(opt_in->answers[i], tmpbuf, GR_FATAL_EXIT);
+	G_check_input_output_name(opt_in->answers[i], tmpbuf, G_FATAL_EXIT);
 	inp_fd[i] = Rast_open_old(opt_in->answers[i], "");
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/include/gis.h	2011-11-29 11:08:36 UTC (rev 49420)
@@ -246,10 +246,10 @@
 #define DEFAULT_FG_COLOR "black"
 #define DEFAULT_BG_COLOR "white"
-/* for raster maps */
-#define GR_FATAL_EXIT    0
-#define GR_FATAL_PRINT   1
-#define GR_FATAL_RETURN  2
+/* error codes */
+#define G_FATAL_EXIT    0
+#define G_FATAL_PRINT   1
+#define G_FATAL_RETURN  2
 /* for vector maps */
Modified: grass/trunk/include/vect/dig_defines.h
--- grass/trunk/include/vect/dig_defines.h	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/include/vect/dig_defines.h	2011-11-29 11:08:36 UTC (rev 49420)
@@ -4,14 +4,6 @@
   Defines for diglib (part of vector library)
-/*! \brief Exit/print/return on error
-  \todo To be moved to gislib
-#define GV_FATAL_EXIT    0
-#define GV_FATAL_PRINT   1
-#define GV_FATAL_RETURN  2
 /*! \brief Name of vector directory */
 #define GV_DIRECTORY    "vector"
 /*! \brief Format description, data location (OGR) */
Modified: grass/trunk/lib/gis/legal_name.c
--- grass/trunk/lib/gis/legal_name.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/lib/gis/legal_name.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -57,7 +57,7 @@
  * \param input input map name
  * \param output output map name
- * \param error error type: GR_FATAL_EXIT, GR_FATAL_PRINT, GR_FATAL_RETURN
+ * \param error error type: G_FATAL_EXIT, G_FATAL_PRINT, G_FATAL_RETURN
  * \return 0 OK
  * \return 1 error
@@ -70,16 +70,16 @@
     if (output == NULL)
 	return 0;		/* don't die on undefined parameters */
     if (G_legal_filename(output) == -1) {
-	if (error == GR_FATAL_EXIT) {
+	if (error == G_FATAL_EXIT) {
 	    G_fatal_error(_("Output raster map name <%s> is not valid map name"),
 			  output);
-	else if (error == GR_FATAL_PRINT) {
+	else if (error == G_FATAL_PRINT) {
 	    G_warning(_("Output raster map name <%s> is not valid map name"),
 		      output);
 	    return 1;
-	else {			/* GR_FATAL_RETURN */
+	else {			/* G_FATAL_RETURN */
 	    return 1;
@@ -87,14 +87,14 @@
     mapset = G_find_raster2(input, "");
     if (mapset == NULL) {
 	    G_fatal_error(_("Raster map <%s> not found"), input);
 	    G_warning(_("Raster map <%s> not found"), input);
 	    return 1;
 	    return 1;
@@ -111,16 +111,16 @@
 	if (strcmp(in, output) == 0) {
 		G_fatal_error(_("Output raster map <%s> is used as input"),
 			      output);
 		G_warning(_("Output raster map <%s> is used as input"),
 			  output);
 		return 1;
 		return 1;
Modified: grass/trunk/lib/vector/Vlib/legal_vname.c
--- grass/trunk/lib/vector/Vlib/legal_vname.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/lib/vector/Vlib/legal_vname.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -80,7 +80,7 @@
    \param input input name
    \param output output name
-   \param error error type GV_FATAL_EXIT, GV_FATAL_PRINT, GV_FATAL_RETURN
+   \param error error type G_FATAL_EXIT, G_FATAL_PRINT, G_FATAL_RETURN
    \return 0 OK
    \return 1 error
@@ -93,11 +93,11 @@
     char nm[GNAME_MAX], ms[GMAPSET_MAX];
     if (Vect_legal_filename(output) == -1) {
-	if (error == GV_FATAL_EXIT) {
 	    G_fatal_error(_("Output vector map name <%s> is not valid map name"),
 			  output);
-	else if (error == GV_FATAL_PRINT) {
 	    G_warning(_("Output vector map name <%s> is not valid map name"),
 		      output);
 	    return 1;
@@ -117,10 +117,10 @@
 	mapset = G_find_vector2(input, "");
 	    G_fatal_error(_("Vector map <%s> not found"), input);
 	    G_warning(_("Vector map <%s> not found"), input);
 	    return 1;
@@ -140,11 +140,11 @@
 		G_fatal_error(_("Output vector map <%s> is used as input"),
 			      output);
 		G_warning(_("Output vector map <%s> is used as input"),
 			  output);
 		return 1;
Modified: grass/trunk/raster/r.carve/main.c
--- grass/trunk/raster/r.carve/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/raster/r.carve/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -114,10 +114,10 @@
 	exit(EXIT_FAILURE);
     G_check_input_output_name(parm.inrast->answer, parm.outrast->answer,
-			      GR_FATAL_EXIT);
+			      G_FATAL_EXIT);
     if (parm.outvect->answer)
-	Vect_check_input_output_name(parm.invect->answer,
-				     parm.outvect->answer, GR_FATAL_EXIT);
+      Vect_check_input_output_name(parm.invect->answer, parm.outvect->answer,
+				   G_FATAL_EXIT);
     /* setup lat/lon projection and distance calculations */
     init_projection(&win, &parm.wrap);
Modified: grass/trunk/raster/r.param.scale/interface.c
--- grass/trunk/raster/r.param.scale/interface.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/raster/r.param.scale/interface.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -166,7 +166,7 @@
     /* make sure input and output names are valid */
-    G_check_input_output_name(rast_in_name, rast_out_name, GR_FATAL_EXIT);
+    G_check_input_output_name(rast_in_name, rast_out_name, G_FATAL_EXIT);
     if ((wsize / 2 != (wsize - 1) / 2) || (wsize > MAX_WSIZE))
 	G_fatal_error(_("Inappropriate window size (too big or even)"));
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/raster/r.slope.aspect/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -299,15 +299,15 @@
     dyy_name = parm.dyy->answer;
     dxy_name = parm.dxy->answer;
-    G_check_input_output_name(elev_name, slope_name, GR_FATAL_EXIT);
-    G_check_input_output_name(elev_name, aspect_name, GR_FATAL_EXIT);
-    G_check_input_output_name(elev_name, pcurv_name, GR_FATAL_EXIT);
-    G_check_input_output_name(elev_name, tcurv_name, GR_FATAL_EXIT);
-    G_check_input_output_name(elev_name, dx_name, GR_FATAL_EXIT);
-    G_check_input_output_name(elev_name, dy_name, GR_FATAL_EXIT);
-    G_check_input_output_name(elev_name, dxx_name, GR_FATAL_EXIT);
-    G_check_input_output_name(elev_name, dyy_name, GR_FATAL_EXIT);
-    G_check_input_output_name(elev_name, dxy_name, GR_FATAL_EXIT);
+    G_check_input_output_name(elev_name, slope_name, G_FATAL_EXIT);
+    G_check_input_output_name(elev_name, aspect_name, G_FATAL_EXIT);
+    G_check_input_output_name(elev_name, pcurv_name, G_FATAL_EXIT);
+    G_check_input_output_name(elev_name, tcurv_name, G_FATAL_EXIT);
+    G_check_input_output_name(elev_name, dx_name, G_FATAL_EXIT);
+    G_check_input_output_name(elev_name, dy_name, G_FATAL_EXIT);
+    G_check_input_output_name(elev_name, dxx_name, G_FATAL_EXIT);
+    G_check_input_output_name(elev_name, dyy_name, G_FATAL_EXIT);
+    G_check_input_output_name(elev_name, dxy_name, G_FATAL_EXIT);
     if (sscanf(parm.zfactor->answer, "%lf", &zfactor) != 1 || zfactor <= 0.0) {
 	G_fatal_error(_("%s=%s - must be a positive number"),
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.buffer/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -298,6 +298,13 @@
 		    "option or clean manually with v.clean tool=break; "
 		    "v.category step=0; v.extract -d type=area"));
+    Vect_set_error_handler_io(&In, &Out);
+    Vect_check_input_output_name(in_opt->answer, out_opt->answer, G_FATAL_EXIT);
+    Vect_set_open_level(2); /* topology required */
+    Vect_open_old2(&In, in_opt->answer, "", field_opt->answer);
     if (field_opt->answer)
 	field = Vect_get_field_number(&In, field_opt->answer);
     else
@@ -335,23 +342,12 @@
 	G_verbose_message(_("The tolerance in map units = %g"), unit_tolerance);
-    Vect_check_input_output_name(in_opt->answer, out_opt->answer,
-				 GV_FATAL_EXIT);
+    Vect_open_new(&Out, out_opt->answer, WITHOUT_Z);
     Points = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
     BCats = Vect_new_cats_struct();
-    Vect_set_open_level(2); /* topology required */
-    if (1 > Vect_open_old2(&In, in_opt->answer, "", field_opt->answer))
-	G_fatal_error(_("Unable to open vector map <%s>"), in_opt->answer);
-    if (0 > Vect_open_new(&Out, out_opt->answer, WITHOUT_Z)) {
-	Vect_close(&In);
-	G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
+    G_fatal_error("x");
     /* open tmp vector for buffers, needed for cleaning */
     sprintf(bufname, "%s_tmp_%d", out_opt->answer, getpid());
     if (0 > Vect_open_new(&Buf, bufname, 0)) {
Modified: grass/trunk/vector/v.build/main.c
--- grass/trunk/vector/v.build/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.build/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -80,7 +80,7 @@
     if (err_opt->answer) {
 	Vect_check_input_output_name(map_opt->answer, err_opt->answer,
-				     GV_FATAL_EXIT);
+				     G_FATAL_EXIT);
     /* build topology */
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.build.polylines/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -136,7 +136,7 @@
 	exit(EXIT_FAILURE);
     Vect_check_input_output_name(input->answer, output->answer,
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     /* Open binary vector map at level 2 */
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.category/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -179,7 +179,7 @@
 	    G_fatal_error(_("Output vector wasn't entered"));
-				     GV_FATAL_EXIT);
+				     G_FATAL_EXIT);
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.clean/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -135,10 +135,10 @@
     otype = Vect_option_to_types(opt.type);
     Vect_check_input_output_name(opt.in->answer, opt.out->answer,
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     if (opt.err->answer) {
 	Vect_check_input_output_name(opt.in->answer, opt.err->answer,
-				     GV_FATAL_EXIT);
+				     G_FATAL_EXIT);
     atools = 20;
Modified: grass/trunk/vector/v.drape/main.c
--- grass/trunk/vector/v.drape/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.drape/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -214,7 +214,7 @@
     /* check input/output vector maps */
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     Vect_open_old2(&In, in_opt->answer, "", layer_opt->answer);
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.extract/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -170,7 +170,7 @@
     input = opt.input->answer;
     output = opt.output->answer;
     Vect_check_input_output_name(input, output,
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     if (flag.d->answer)
 	dissolve = TRUE;
Modified: grass/trunk/vector/v.extrude/main.c
--- grass/trunk/vector/v.extrude/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.extrude/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -142,7 +142,7 @@
     centroid = 0;
     /* set input vector map name and mapset */
     /* vector setup */
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.generalize/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -285,7 +285,7 @@
     Vect_check_input_output_name(map_in->answer, map_out->answer,
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.hull/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -74,7 +74,7 @@
     sitefile = input->answer;
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     Vect_set_open_level(1);
     if (Vect_open_old2(&Map, sitefile, "", field->answer) < 0)
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.kernel/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -251,9 +251,9 @@
     if (net_opt->answer) {
-				     GV_FATAL_EXIT);
+				     G_FATAL_EXIT);
 	Vect_check_input_output_name(net_opt->answer, out_opt->answer,
-				     GV_FATAL_EXIT);
+				     G_FATAL_EXIT);
     G_get_window(&window);
Modified: grass/trunk/vector/v.lidar.correction/main.c
--- grass/trunk/vector/v.lidar.correction/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.lidar.correction/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -171,7 +171,7 @@
     /* Checking vector names */
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     /* Open input vector */
     if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL)
Modified: grass/trunk/vector/v.lidar.edgedetection/main.c
--- grass/trunk/vector/v.lidar.edgedetection/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.lidar.edgedetection/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -207,7 +207,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL) {
 	G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
Modified: grass/trunk/vector/v.lidar.growing/main.c
--- grass/trunk/vector/v.lidar.growing/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.lidar.growing/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -120,7 +120,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net/main.c
--- grass/trunk/vector/v.net/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -74,7 +74,7 @@
 	if (act != TOOL_ARCS) {
 	    /* check input-output */
 	    Vect_check_input_output_name(opt.input->answer,
-					 opt.output->answer, GV_FATAL_EXIT);
+					 opt.output->answer, G_FATAL_EXIT);
 	if (act == TOOL_CONNECT || act == TOOL_ARCS) {
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.alloc/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -120,7 +120,7 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    Vect_check_input_output_name(map->answer, output->answer, GV_FATAL_EXIT);
+    Vect_check_input_output_name(map->answer, output->answer, G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net.allpairs/main.c
--- grass/trunk/vector/v.net.allpairs/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.allpairs/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -119,7 +119,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net.bridge/main.c
--- grass/trunk/vector/v.net.bridge/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.bridge/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -105,7 +105,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net.centrality/main.c
--- grass/trunk/vector/v.net.centrality/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.centrality/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -201,7 +201,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net.components/main.c
--- grass/trunk/vector/v.net.components/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.components/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -134,7 +134,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net.connectivity/main.c
--- grass/trunk/vector/v.net.connectivity/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.connectivity/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -124,7 +124,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.distance/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -148,7 +148,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net.flow/main.c
--- grass/trunk/vector/v.net.flow/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.flow/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -135,7 +135,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net.iso/main.c
--- grass/trunk/vector/v.net.iso/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.iso/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -141,7 +141,7 @@
     catlist = Vect_new_cat_list();
     Vect_str_to_cat_list(term_opt->answer, catlist);
     /* Iso costs */
     aiso = 1;
Modified: grass/trunk/vector/v.net.path/main.c
--- grass/trunk/vector/v.net.path/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.path/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -124,7 +124,7 @@
 	geo = 0;
     Vect_check_input_output_name(input_opt->answer, output_opt->answer,
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     Vect_open_old(&In, input_opt->answer, "");
Modified: grass/trunk/vector/v.net.salesman/main.c
--- grass/trunk/vector/v.net.salesman/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.salesman/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -188,7 +188,7 @@
     else
 	geo = 0;
     Vect_open_old(&Map, map->answer, "");
Modified: grass/trunk/vector/v.net.spanningtree/main.c
--- grass/trunk/vector/v.net.spanningtree/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.spanningtree/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -93,7 +93,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net.steiner/main.c
--- grass/trunk/vector/v.net.steiner/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.steiner/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -422,7 +422,7 @@
     else
 	geo = 0;
Modified: grass/trunk/vector/v.net.timetable/main.c
--- grass/trunk/vector/v.net.timetable/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.timetable/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -346,7 +346,7 @@
     Prev = Vect_new_line_struct();
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.net.visibility/main.c
--- grass/trunk/vector/v.net.visibility/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.net.visibility/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -70,7 +70,7 @@
 	exit(EXIT_FAILURE);
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.outlier/main.c
--- grass/trunk/vector/v.outlier/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.outlier/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -146,7 +146,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.overlay/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -155,9 +155,9 @@
 		      operator_opt->answer);
     Vect_check_input_output_name(in_opt[0]->answer, out_opt->answer,
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     Vect_check_input_output_name(in_opt[1]->answer, out_opt->answer,
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.patch/main.c
--- grass/trunk/vector/v.patch/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.patch/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -110,7 +110,7 @@
     i = 0;
     while (old->answers[i]) {
 	in_name = old->answers[i++];
-	Vect_check_input_output_name(in_name, new->answer, GV_FATAL_EXIT);
+	Vect_check_input_output_name(in_name, new->answer, G_FATAL_EXIT);
 	Vect_open_old_head(&InMap, in_name, "");
Modified: grass/trunk/vector/v.reclass/main.c
--- grass/trunk/vector/v.reclass/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.reclass/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -106,7 +106,7 @@
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
Modified: grass/trunk/vector/v.segment/main.c
--- grass/trunk/vector/v.segment/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.segment/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -79,7 +79,7 @@
     PlPoints = Vect_new_line_struct();
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     if (strcmp(file_opt->answer, "-")) {
 	/* open input file */
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.select/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -90,7 +90,7 @@
 	itype[iopt] = Vect_option_to_types(parm.type[iopt]);
 	Vect_check_input_output_name(parm.input[iopt]->answer, parm.output->answer,
-				     GV_FATAL_EXIT);
+				     G_FATAL_EXIT);
 	Vect_open_old2(&(In[iopt]), parm.input[iopt]->answer, "", parm.field[iopt]->answer);
Modified: grass/trunk/vector/v.surf.bspline/main.c
--- grass/trunk/vector/v.surf.bspline/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.surf.bspline/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -315,7 +315,7 @@
 			   "Try with a raster output or other driver."), dvr);
-				     GV_FATAL_EXIT);
+				     G_FATAL_EXIT);
 	grid = FALSE;
 	if (0 > Vect_open_new(&Out, out_opt->answer, WITH_Z))
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.surf.rst/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -407,10 +407,10 @@
 			  overfile);
     /*    if (treefile)
-       Vect_check_input_output_name(input, treefile, GV_FATAL_EXIT);
+       Vect_check_input_output_name(input, treefile, G_FATAL_EXIT);
        if (overfile)
-       Vect_check_input_output_name(input, overfile, GV_FATAL_EXIT);
+       Vect_check_input_output_name(input, overfile, G_FATAL_EXIT);
     if ((elev == NULL) && (pcurv == NULL) && (tcurv == NULL)
 	&& (mcurv == NULL)
Modified: grass/trunk/vector/v.to.3d/main.c
--- grass/trunk/vector/v.to.3d/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.to.3d/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -65,7 +65,7 @@
     Vect_check_input_output_name(opt.input->answer, opt.output->answer,
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     /* open input vector, topology not needed */
Modified: grass/trunk/vector/v.to.points/main.c
--- grass/trunk/vector/v.to.points/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.to.points/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -237,7 +237,7 @@
 	vertex_type = 0;
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
     /* Open input lines */
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.transform/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -195,7 +195,7 @@
     strcpy(Current.name, vold->answer);
     strcpy(Trans.name, vnew->answer);
-    Vect_check_input_output_name(vold->answer, vnew->answer, GV_FATAL_EXIT);
+    Vect_check_input_output_name(vold->answer, vnew->answer, G_FATAL_EXIT);
     if (!table->answer && columns->answer) {
 	G_fatal_error(_("Table name is not defined. Please use '%s' parameter."),
Modified: grass/trunk/vector/v.type/main.c
--- grass/trunk/vector/v.type/main.c	2011-11-29 11:05:53 UTC (rev 49419)
+++ grass/trunk/vector/v.type/main.c	2011-11-29 11:08:36 UTC (rev 49420)
@@ -63,7 +63,7 @@
 	exit(EXIT_FAILURE);
-    Vect_check_input_output_name(in_opt->answer, out_opt->answer, GV_FATAL_EXIT);
     switch (from_opt->answer[0]) {
     case 'p':
@@ -115,7 +115,7 @@
 	G_fatal_error(_("Incompatible types"));
-				 GV_FATAL_EXIT);
+				 G_FATAL_EXIT);
