[GRASS-SVN] r49423 - grass/trunk/lib/vector/Vlib
Tue Nov 29 06:14:25 EST 2011
Author: martinl
Date: 2011-11-29 03:14:25 -0800 (Tue, 29 Nov 2011)
New Revision: 49423
   grass/trunk/lib/vector/Vlib/handler.c
vlib: Vect_set_error_handler_io() cosmetics in doxygen docs
Modified: grass/trunk/lib/vector/Vlib/handler.c
--- grass/trunk/lib/vector/Vlib/handler.c	2011-11-29 11:11:15 UTC (rev 49422)
+++ grass/trunk/lib/vector/Vlib/handler.c	2011-11-29 11:14:25 UTC (rev 49423)
@@ -47,9 +47,12 @@
   This handler:
    - close input vector map on error
    - close and delete output vector map on error
-   \param In  pointer in Map_info struct (input vector map) or NULL
-   \param Out pointer to Map_info struct (output vector map) or NULL
+  Note: It's recommended to call this routine after Vect_open_old() or
+  Vect_open_old2().
+  \param In  pointer in Map_info struct (input vector map) or NULL
+  \param Out pointer to Map_info struct (output vector map) or NULL
 void Vect_set_error_handler_io(struct Map_info *In, struct Map_info *Out)
