[GRASS-SVN] r49432 - grass/trunk/gui/wxpython/wxplot
Wed Nov 30 06:26:38 EST 2011
Author: martinl
Date: 2011-11-30 03:26:38 -0800 (Wed, 30 Nov 2011)
New Revision: 49432
   grass/trunk/gui/wxpython/wxplot/base.py
   grass/trunk/gui/wxpython/wxplot/histogram.py
   grass/trunk/gui/wxpython/wxplot/scatter.py
wxGUI: fix wxplot modules (after major code reorganization)
Modified: grass/trunk/gui/wxpython/wxplot/base.py
--- grass/trunk/gui/wxpython/wxplot/base.py	2011-11-30 11:11:59 UTC (rev 49431)
+++ grass/trunk/gui/wxpython/wxplot/base.py	2011-11-30 11:26:38 UTC (rev 49432)
@@ -167,11 +167,11 @@
             except:
                 continue
                 # if r.info cannot parse map, skip it
             self.raster[r] = UserSettings.Get(group = plottype, key = 'raster') # some default settings
             rdict[r] = {} # initialize sub-dictionaries for each raster in the list
-            if ret['units'] == '(none)' or ret['units'] == '' or ret['units'] == None:
+            if ret['units'] in ('(none)', '"none"', '', None):
                 rdict[r]['units'] = ''
             else:
                 self.raster[r]['units'] = ret['units']
Modified: grass/trunk/gui/wxpython/wxplot/histogram.py
--- grass/trunk/gui/wxpython/wxplot/histogram.py	2011-11-30 11:11:59 UTC (rev 49431)
+++ grass/trunk/gui/wxpython/wxplot/histogram.py	2011-11-30 11:26:38 UTC (rev 49432)
@@ -26,6 +26,7 @@
 from wxplot.base       import BasePlotFrame
 from icons.icon        import Icons
 from wxplot.dialogs    import HistRasterDialog, PlotStatsFrame
+from core.gcmd         import RunCommand, GException, GError
 class Histogram2Frame(BasePlotFrame):
     def __init__(self, parent, id, pos, style, size, rasterList = []):
@@ -141,14 +142,14 @@
         if self.histtype == 'area': freqflag = 'an'
         try:
-            ret = gcmd.RunCommand("r.stats",
-                                  parent = self,
-                                  input = raster,
-                                  flags = freqflag,
-                                  nsteps = self.bins,
-                                  fs = ',',
-                                  quiet = True,
-                                  read = True)
+            ret = RunCommand("r.stats",
+                             parent = self,
+                             input = raster,
+                             flags = freqflag,
+                             nsteps = self.bins,
+                             fs = ',',
+                             quiet = True,
+                             read = True)
             if not ret:
                 return datalist
@@ -164,9 +165,9 @@
                 datalist.append((cellval,histval))
             return datalist
-        except gcmd.GException, e:
-            gcmd.GError(parent = self,
-                        message = e.value)
+        except GException, e:
+            GError(parent = self,
+                   message = e.value)
             return None
     def CreatePlotList(self):
Modified: grass/trunk/gui/wxpython/wxplot/scatter.py
--- grass/trunk/gui/wxpython/wxplot/scatter.py	2011-11-30 11:11:59 UTC (rev 49431)
+++ grass/trunk/gui/wxpython/wxplot/scatter.py	2011-11-30 11:26:38 UTC (rev 49432)
@@ -26,6 +26,7 @@
 from gui_core.toolbars import BaseToolbar
 from wxplot.dialogs    import ScatterRasterDialog, PlotStatsFrame
 class ScatterFrame(BasePlotFrame):
     """!Mainframe for displaying bivariate scatter plot of two raster maps. Uses wx.lib.plot.
@@ -163,14 +164,14 @@
             freqflag = 'n'
         try:
-                                  parent = self,
-                                  input = '%s,%s' % rpair,
-                                  flags = freqflag,
-                                  fs = ',',
-                                  quiet = True,
-                                  read = True)
+                             parent = self,
+                             input = '%s,%s' % rpair,
+                             flags = freqflag,
+                             fs = ',',
+                             quiet = True,
+                             read = True)
             if not ret:
                 return datalist
@@ -188,9 +189,9 @@
                 datalist.append((rast1,rast2))
             return datalist
             return None
