[GRASS-SVN] r48660 - grass/trunk/raster/r.series
Thu Oct 6 07:40:48 EDT 2011
Author: huhabla
Date: 2011-10-06 04:40:48 -0700 (Thu, 06 Oct 2011)
New Revision: 48660
   grass/trunk/raster/r.series/main.c
   grass/trunk/raster/r.series/test.r.series.sh
Modified tests and verbose message handling.
Modified: grass/trunk/raster/r.series/main.c
--- grass/trunk/raster/r.series/main.c	2011-10-06 11:13:11 UTC (rev 48659)
+++ grass/trunk/raster/r.series/main.c	2011-10-06 11:40:48 UTC (rev 48660)
@@ -222,11 +222,11 @@
 	    p = &inputs[num_inputs++];
-	    G_verbose_message(_("Reading raster map <%s>..."), p->name);
 	    p->name = G_store(name);
 	    p->buf = Rast_allocate_d_buf();
 	    if (!flag.lazy->answer)
 		p->fd = Rast_open_old(p->name, "");
+	    G_verbose_message(_("Reading raster map <%s>..."), p->name);
 	if (num_inputs < 1)
@@ -247,11 +247,11 @@
     	for (i = 0; i < num_inputs; i++) {
 	    struct input *p = &inputs[i];
 	    p->name = parm.input->answers[i];
Modified: grass/trunk/raster/r.series/test.r.series.sh
--- grass/trunk/raster/r.series/test.r.series.sh	2011-10-06 11:13:11 UTC (rev 48659)
+++ grass/trunk/raster/r.series/test.r.series.sh	2011-10-06 11:40:48 UTC (rev 48660)
@@ -17,45 +17,46 @@
 # valid raster maps listed in this file.
 cat > $TMP_FILE << EOF
 prec_1
 prec_2
 prec_3
-invalid_name
+prec_4
-prec_4
 prec_5
 prec_6
 EOF
 # The first @test with map input and @precision=3
-r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_mean method=average
-r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_max method=maximum
-r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_min method=minimum
-r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_count method=count
-r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_range method=range
-r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_sum method=sum
+r.series -z --o --v input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_mean method=average
+r.series    --o --v input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_max method=maximum
+r.series -z --o --v input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_min method=minimum
+r.series    --o --v input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_count method=count
+r.series -z --o --v input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_range method=range
+r.series    --o --v input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_sum method=sum
-#r.out.ascii --o input=test_1_prec_mean output=test_1_prec_mean.ref dp=3
-#r.out.ascii --o input=test_1_prec_max output=test_1_prec_max.ref dp=3
-#r.out.ascii --o input=test_1_prec_min output=test_1_prec_min.ref dp=3
-#r.out.ascii --o input=test_1_prec_count output=test_1_prec_count.ref dp=3
-#r.out.ascii --o input=test_1_prec_range output=test_1_prec_range.ref dp=3
-#r.out.ascii --o input=test_1_prec_sum output=test_1_prec_sum.ref dp=3
+r.out.ascii --o input=test_1_prec_mean output=test_1_prec_mean.ref dp=3
+r.out.ascii --o input=test_1_prec_max output=test_1_prec_max.ref dp=3
+r.out.ascii --o input=test_1_prec_min output=test_1_prec_min.ref dp=3
+r.out.ascii --o input=test_1_prec_count output=test_1_prec_count.ref dp=3
+r.out.ascii --o input=test_1_prec_range output=test_1_prec_range.ref dp=3
+r.out.ascii --o input=test_1_prec_sum output=test_1_prec_sum.ref dp=3
 # The second @test with file input and @precision=3
-r.series --o file=$TMP_FILE output=test_2_prec_mean method=average
-r.series --o file=$TMP_FILE output=test_2_prec_max method=maximum
-r.series --o file=$TMP_FILE output=test_2_prec_min method=minimum
-r.series --o file=$TMP_FILE output=test_2_prec_count method=count
-r.series --o file=$TMP_FILE output=test_2_prec_range method=range
-r.series --o file=$TMP_FILE output=test_2_prec_sum method=sum
+r.series -z --o --v file=$TMP_FILE output=test_2_prec_mean method=average
+r.series    --o --v file=$TMP_FILE output=test_2_prec_max method=maximum
+r.series -z --o --v file=$TMP_FILE output=test_2_prec_min method=minimum
+r.series    --o --v file=$TMP_FILE output=test_2_prec_count method=count
+r.series -z --o --v file=$TMP_FILE output=test_2_prec_range method=range
+r.series    --o --v file=$TMP_FILE output=test_2_prec_sum method=sum
-#r.out.ascii --o input=test_2_prec_mean output=test_2_prec_mean.ref dp=3
-#r.out.ascii --o input=test_2_prec_max output=test_2_prec_max.ref dp=3
-#r.out.ascii --o input=test_2_prec_min output=test_2_prec_min.ref dp=3
-#r.out.ascii --o input=test_2_prec_count output=test_2_prec_count.ref dp=3
-#r.out.ascii --o input=test_2_prec_range output=test_2_prec_range.ref dp=3
-#r.out.ascii --o input=test_2_prec_sum output=test_2_prec_sum.ref dp=3
\ No newline at end of file
+r.out.ascii --o input=test_2_prec_mean output=test_2_prec_mean.ref dp=3
+r.out.ascii --o input=test_2_prec_max output=test_2_prec_max.ref dp=3
+r.out.ascii --o input=test_2_prec_min output=test_2_prec_min.ref dp=3
+r.out.ascii --o input=test_2_prec_count output=test_2_prec_count.ref dp=3
+r.out.ascii --o input=test_2_prec_range output=test_2_prec_range.ref dp=3
+r.out.ascii --o input=test_2_prec_sum output=test_2_prec_sum.ref dp=3
