[GRASS-SVN] r48774 - grass/trunk/gui/wxpython/gui_modules
Thu Oct 13 08:06:52 EDT 2011
Author: martinl
Date: 2011-10-13 05:06:52 -0700 (Thu, 13 Oct 2011)
New Revision: 48774
   grass/trunk/gui/wxpython/gui_modules/gdialogs.py
   grass/trunk/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: dynamic series more user friendly
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-10-13 11:44:36 UTC (rev 48773)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-10-13 12:06:52 UTC (rev 48774)
@@ -904,7 +904,7 @@
                  'active' : self.chkbox.IsChecked() }
 class MapLayersDialog(wx.Dialog):
-    def __init__(self, parent, title,
+    def __init__(self, parent, title, modeler = False,
                  style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
         """!Dialog for selecting map layers (raster, vector)"""
         wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY, title = title,
@@ -922,6 +922,12 @@
         self.fullyQualified = wx.CheckBox(parent = self, id = wx.ID_ANY,
                                           label = _("Use fully-qualified map names"))
         self.fullyQualified.SetValue(True)
+        self.dseries = None
+        if modeler:
+            self.dseries = wx.CheckBox(parent = self, id = wx.ID_ANY,
+                                       label = _("Dynamic series (%s)") % 'g.mlist')
+            self.dseries.SetValue(False)
         # buttons
         btnCancel = wx.Button(parent = self, id = wx.ID_CANCEL)
@@ -939,6 +945,10 @@
                       flag = wx.EXPAND | wx.ALL, border = 5)
         mainSizer.Add(item = self.fullyQualified, proportion = 0,
                       flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 5)
+        if self.dseries:
+            mainSizer.Add(item = self.dseries, proportion = 0,
+                          flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 5)
         mainSizer.Add(item = btnSizer, proportion = 0,
                       flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border = 5)
@@ -954,12 +964,12 @@
         bodySizer.AddGrowableRow(3)
         # layer type
-        bodySizer.Add(item = wx.StaticText(parent = self, label = _("Map layer type:")),
+        bodySizer.Add(item = wx.StaticText(parent = self, label = _("Map type:")),
                       flag = wx.ALIGN_CENTER_VERTICAL,
                       pos = (0,0))
         self.layerType = wx.Choice(parent = self, id = wx.ID_ANY,
-                                   choices = ['raster', 'vector'], size = (100,-1))
+                                   choices = [_('raster'), _('3D raster'), _('vector')], size = (100,-1))
         self.layerType.SetSelection(0)
         bodySizer.Add(item = self.layerType,
                       pos = (0,1))
@@ -983,7 +993,7 @@
                       pos = (1,1), span = (1, 2))
         # map name filter
-        bodySizer.Add(item = wx.StaticText(parent = self, label = _("Filter:")),
+        bodySizer.Add(item = wx.StaticText(parent = self, label = _("Pattern:")),
                       pos = (2,0))
@@ -1030,7 +1040,7 @@
     def OnChangeParams(self, event):
         """!Filter parameters changed by user"""
         # update list of layer to be loaded
-        self.LoadMapLayers(self.layerType.GetStringSelection()[:4],
+        self.LoadMapLayers(self.GetLayerType(cmd = True),
                            self.mapset.GetStringSelection())
         event.Skip()
@@ -1119,9 +1129,39 @@
         return layerNames
-    def GetLayerType(self):
-        """!Get selected layer type"""
-        return self.layerType.GetStringSelection()
+    def GetLayerType(self, cmd = False):
+        """!Get selected layer type
+        @param cmd True for g.mlist
+        if not cmd:
+            return self.layerType.GetStringSelection()
+        sel = self.layerType.GetSelection()
+        if sel == 0:
+            ltype = 'rast'
+        elif sel == 1:
+            ltype = 'rast3d'
+        else:
+            ltype = 'vect'
+        return ltype
+    def GetDSeries(self):
+        """!Used by modeler only
+        @return g.mlist command
+        if not self.dseries or not self.dseries.IsChecked():
+            return ''
+        cond = 'map in `g.mlist type=%s ' % self.GetLayerType(cmd = True)
+        patt = self.filter.GetValue()
+        if patt:
+            cond += 'pattern=%s ' % patt
+        cond += 'mapset=%s`' % self.mapset.GetStringSelection()
+        return cond
 class ImportDialog(wx.Dialog):
     """!Dialog for bulk import of various data (base class)"""
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2011-10-13 11:44:36 UTC (rev 48773)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2011-10-13 12:06:52 UTC (rev 48774)
@@ -4215,12 +4215,16 @@
     def OnSeries(self, event):
         """!Define map series as condition"""
-        dialog = MapLayersDialog(parent = self, title = _("Define series of maps"))
+        dialog = MapLayersDialog(parent = self, title = _("Define series of maps"), modeler = True)
         if dialog.ShowModal() != wx.ID_OK:
             dialog.Destroy()
             return
-        self.condText.SetValue('map in %s' % map(lambda x: str(x), dialog.GetMapLayers()))
+        cond = dialog.GetDSeries()
+        if not cond:
+            cond = 'map in %s' % map(lambda x: str(x), dialog.GetMapLayers())
+        self.condText.SetValue(cond)
         dialog.Destroy()
