[GRASS-SVN] r48778 - grass/trunk/lib/python/temporal
Thu Oct 13 08:42:15 EDT 2011
Author: huhabla
Date: 2011-10-13 05:42:15 -0700 (Thu, 13 Oct 2011)
New Revision: 48778
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
New function to print the temporal relationship matrix
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2011-10-13 12:23:08 UTC (rev 48777)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2011-10-13 12:42:15 UTC (rev 48778)
@@ -107,6 +107,38 @@
         return granularity, temporal_type, semantic_type, title, description
+    def print_temporal_relation_matrix(self, dbif=None):
+        """Print the temporal relation matrix of all registered maps to stdout
+           The temproal relation matrix includes the temporal relations between
+           all registered maps. The relations are strings stored in a list of lists.
+           @param dbif: The database interface to be used
+        connect = False
+        if dbif == None:
+            dbif = sql_database_interface()
+            dbif.connect()
+            connect = True
+        matrix = []
+        maps = self.get_registered_maps_as_objects(where=None, order="start_time", dbif=dbif)
+        for map in maps:
+            print map.get_id(),
+        print " "
+        for mapA in maps:
+            for mapB in maps:
+                print mapA.temporal_relation(mapB),
+            print " "
+        if connect == True:
+            dbif.close()
     def get_temporal_relation_matrix(self, dbif=None):
         """Return the temporal relation matrix of all registered maps as listof lists
