[GRASS-SVN] r48886 - grass/trunk/lib/vector/Vlib
Thu Oct 20 17:32:52 EDT 2011
Author: martinl
Date: 2011-10-20 14:32:52 -0700 (Thu, 20 Oct 2011)
New Revision: 48886
   grass/trunk/lib/vector/Vlib/ascii.c
vlib: Vect_write_ascii() - process also areas
      #1470 (v.out.ascii with sql where option exports only centroids and not areas)
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c	2011-10-20 19:24:36 UTC (rev 48885)
+++ grass/trunk/lib/vector/Vlib/ascii.c	2011-10-20 21:32:52 UTC (rev 48886)
@@ -24,6 +24,8 @@
 #define BUFFSIZE 128
 static int srch(const void *, const void *);
+static int check_cat(const struct line_cats *, const struct cat_list *,
+		     const int *, int);
   \brief Read data in GRASS ASCII vector format
@@ -300,10 +302,10 @@
 		     int field, const struct cat_list *Clist, const char* where,
 		     const char **columns, int header)
-    int type, ctype, i, cat, n_lines;
+    int type, ctype, i, cat, n_lines, line, left, right, found;
     double *xptr, *yptr, *zptr, x, y;
     static struct line_pnts *Points;
-    struct line_cats *Cats;
+    struct line_cats *Cats, *ACats;
     char *xstring, *ystring, *zstring;
     struct Cell_head window;
     struct ilist *fcats;
@@ -353,6 +355,7 @@
     Points = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
+    ACats = Vect_new_cats_struct();
     fcats = Vect_new_list();
     /* by default, read_next_line will NOT read Dead lines */
@@ -361,7 +364,9 @@
     Vect_rewind(Map);
+    line = 0;
     while (TRUE) {
+	line++;
 	type = Vect_read_next_line(Map, Points, Cats);
 	if (type == -1 ) {      /* failure */
 	    if (columns) {
@@ -383,26 +388,22 @@
 	if (format == GV_ASCII_FORMAT_POINT && !(type & GV_POINTS))
 	    continue;
-	/* check category */
-	if (Clist) {
-	    Vect_cat_get(Cats, Clist->field, &cat);
-	    if (!Vect_cat_in_cat_list(cat, Clist))
-		continue;
-	if (cats) {
-	    for (i = 0; i < Cats->n_cats; i++) {
-		if ((int *)bsearch((void *) &(Cats->cat[i]), cats, ncats, sizeof(int),
-				   srch)) {
-		    /* found */
-		    break;
+	found = FALSE;
+	if (type == GV_BOUNDARY && Vect_level(Map) > 1) {
+	    Vect_get_line_areas(Map, line, &left, &right);
+	    if (left > 0) {
+		Vect_get_area_cats(Map, left, ACats);
+		found = check_cat(ACats, Clist, cats, ncats);
-	    if (i == Cats->n_cats)
-		continue;
+	    if (!found && right > 0) {
+		Vect_get_area_cats(Map, right, ACats);
+	if (!found && !check_cat(Cats, Clist, cats, ncats))
+	    continue;
 	if (ver < 5) {
 	    Vect_cat_get(Cats, 1, &cat);
@@ -672,6 +673,7 @@
     Vect_destroy_line_struct(Points);
     Vect_destroy_cats_struct(Cats);
+    Vect_destroy_cats_struct(ACats);
     return n_lines;
@@ -706,3 +708,30 @@
     fprintf(dascii, "ZONE:         %d\n", Vect_get_zone(Map));
     fprintf(dascii, "MAP THRESH:   %f\n", Vect_get_thresh(Map));
+/* check category */
+int check_cat(const struct line_cats *Cats, const struct cat_list *Clist,
+	      const int *cats, int ncats)
+    int i, cat;
+    if (Clist) {
+	Vect_cat_get(Cats, Clist->field, &cat);
+	if (!Vect_cat_in_cat_list(cat, Clist))
+	    return FALSE;
+    if (cats) {
+	for (i = 0; i < Cats->n_cats; i++) {
+	    if ((int *)bsearch((void *) &(Cats->cat[i]), cats, ncats, sizeof(int),
+			       srch)) {
+		/* found */
+		break;
+	if (i == Cats->n_cats)
+	    return FALSE;
+    return TRUE;
