[GRASS-SVN] r48014 - grass/trunk/gui/wxpython/gui_modules
Thu Sep 1 03:11:55 EDT 2011
Author: annakrat
Date: 2011-09-01 00:11:55 -0700 (Thu, 01 Sep 2011)
New Revision: 48014
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
wxNviz: enable status bar combobox
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-08-31 23:08:57 UTC (rev 48013)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-09-01 07:11:55 UTC (rev 48014)
@@ -217,7 +217,7 @@
         self.statusbarWin['projection'].SetToolTip(wx.ToolTip (_("Reproject coordinates displayed "
        "in the statusbar. Projection can be "
        "defined in GUI preferences dialog "
-        "(tab 'Display')")))
+        "(tab 'Projection')")))
         self.statusbarWin['projection'].Hide()
         # mask
@@ -382,7 +382,10 @@
                                           self.OnRotate, wx.ITEM_CHECK,7),)) # 7 is position
         self.toolbars['map'].ChangeToolsDesc(mode2d = False)
         # update status bar
-        self.statusbarWin['toggle'].Enable(False)
+        choice = globalvar.MAP_DISPLAY_STATUSBAR_MODE
+        self.statusbarWin['toggle'].SetItems((choice[0], choice[1], choice[2],
+                                              choice[8], choice[9]))
+        self.statusbarWin['toggle'].SetSelection(0)
         # erase map window
         self.MapWindow.EraseMap()
@@ -440,7 +443,10 @@
         """!Restore 2D view"""
         self.toolbars['map'].RemoveTool(self.toolbars['map'].rotate)
         # update status bar
-        self.statusbarWin['toggle'].Enable(True)
+        self.statusbarWin['toggle'].SetItems(globalvar.MAP_DISPLAY_STATUSBAR_MODE)
+        self.statusbarWin['toggle'].SetSelection(UserSettings.Get(group = 'display',
+        key = 'statusbarMode',
+        subkey = 'selection'))
         self.statusbar.SetStatusText(_("Please wait, unloading data..."), 0)
         self._layerManager.goutput.WriteCmdLog(_("Switching back to 2D view mode..."),
                                                switchPage = False)
@@ -842,6 +848,9 @@
                                                         precision, region['center_northing']))
             return
+        if self.IsPaneShown('3d'):
+            self.MapWindow.GoTo(e, n)
+            return
         dn = (region['nsres'] * region['rows']) / 2.
         region['n'] = region['center_northing'] + dn
@@ -870,15 +879,16 @@
         self.statusbarWin['goto'].Hide()
         self.mapScaleValue = self.ppm = None
-        if self.statusbarWin['toggle'].GetSelection() == 0: # Coordinates
+        if self.statusbarWin['toggle'].GetStringSelection() == choice[0]: # Coordinates
             self.statusbar.SetStatusText("", 0)
             # enable long help
             self.StatusbarEnableLongHelp()
-        elif self.statusbarWin['toggle'].GetSelection() in (1, 2): # Extent
-            sel = self.statusbarWin['toggle'].GetSelection()
-            if sel == 1:
+        elif self.statusbarWin['toggle'].GetStringSelection() in (choice[1], choice[2]): # Extent
+            sel = self.statusbarWin['toggle'].GetStringSelection()
+            if sel == choice[1]:
                 region = self.Map.region
             else:
                 region = self.Map.GetRegion() # computation region
@@ -910,7 +920,7 @@
                                                  precision = precision)
                             e, n = utils.Deg2DMS(coord2[0], coord2[1], string = False,
-                            if sel == 1:
                                 self.statusbar.SetStatusText("%s - %s, %s - %s" %
                                                              (w, e, s, n), 0)
                             else:
@@ -923,7 +933,7 @@
                         else:
                             w, s = coord1
                             e, n = coord2
-                            if sel == 1:
                                 self.statusbar.SetStatusText("%.*f - %.*f, %.*f - %.*f" %
                                                          (precision, w, precision, e,
                                                           precision, s, precision, n), 0)
@@ -941,7 +951,7 @@
                                          string = False, precision = precision)
                     e, n = utils.Deg2DMS(region["e"], region["n"],
-                    if sel == 1:
                                                      (w, e, s, n), 0)
                     else:
@@ -952,7 +962,7 @@
                 else:
                     w, s = region["w"], region["s"]
                     e, n = region["e"], region["n"]
-                    if sel == 1:
@@ -965,32 +975,32 @@
             # enable long help
-        elif self.statusbarWin['toggle'].GetSelection() == 3: # Show comp. extent
+        elif self.statusbarWin['toggle'].GetStringSelection() == choice[3]: # Show comp. extent
             self.statusbarWin['region'].Show()
             # disable long help
             self.StatusbarEnableLongHelp(False)
-        elif self.statusbarWin['toggle'].GetSelection() == 4: # Align extent
+        elif self.statusbarWin['toggle'].GetStringSelection() == choice[4]: # Align extent
             self.statusbarWin['alignExtent'].Show()
             # disable long help
-        elif self.statusbarWin['toggle'].GetSelection() == 5: # Display resolution
+        elif self.statusbarWin['toggle'].GetStringSelection() == choice[5]: # Display resolution
             self.statusbarWin['resolution'].Show()
             # disable long help
-        elif self.statusbarWin['toggle'].GetSelection() == 6: # Display geometry
+        elif self.statusbarWin['toggle'].GetStringSelection() == choice[6]: # Display geometry
             self.statusbar.SetStatusText("rows=%d; cols=%d; nsres=%.2f; ewres=%.2f" %
                                          (self.Map.region["rows"], self.Map.region["cols"],
                                           self.Map.region["nsres"], self.Map.region["ewres"]), 0)
             # enable long help
-        elif self.statusbarWin['toggle'].GetSelection() == 7: # Map scale
+        elif self.statusbarWin['toggle'].GetStringSelection() == choice[7]: # Map scale
             # TODO: need to be fixed...
             ### screen X region problem
             ### user should specify ppm
@@ -1039,7 +1049,7 @@
             # disable long help
-        elif self.statusbarWin['toggle'].GetSelection() == 8: # go to
+        elif self.statusbarWin['toggle'].GetStringSelection() == choice[8]: # go to
             self.statusbar.SetStatusText("")
             region = self.Map.GetCurrentRegion()
             precision = int(UserSettings.Get(group = 'projection', key = 'format',
@@ -1080,7 +1090,7 @@
             # disable long help
-        elif self.statusbarWin['toggle'].GetSelection() == 9: # projection
+        elif self.statusbarWin['toggle'].GetStringSelection() == choice[9]: # projection
             epsg = UserSettings.Get(group = 'projection', key = 'statusbar', subkey = 'epsg')
             if epsg:
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-08-31 23:08:57 UTC (rev 48013)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-09-01 07:11:55 UTC (rev 48014)
@@ -703,7 +703,23 @@
     def ResetViewHistory(self):
         """!Reset view history"""
         self.viewhistory = list()
+    def GoTo(self, e, n):
+        """!Focus on given point"""
+        w = self.Map.region['w']
+        s = self.Map.region['s']
+        e -= w
+        n -= s
+        focus = self.iview['focus']
+        focus['x'], focus['y'] = e, n
+        self.saveHistory = True
+        #update properties
+        evt = wxUpdateView(zExag = False)
+        wx.PostEvent(self, evt)
+        self.render['quick'] = False
+        self.Refresh(False)
     def OnQuerySurface(self, event):
         """!Query surface on given position"""
         size = self.GetClientSizeTuple()
