[GRASS-SVN] r48127 - grass/trunk/scripts/db.in.ogr
Mon Sep 5 03:03:13 EDT 2011
Author: mmetz
Date: 2011-09-05 00:03:13 -0700 (Mon, 05 Sep 2011)
New Revision: 48127
   grass/trunk/scripts/db.in.ogr/db.in.ogr.py
db.in.gr: fix remove vector part
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py	2011-09-05 06:49:51 UTC (rev 48126)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py	2011-09-05 07:03:13 UTC (rev 48127)
@@ -110,7 +110,8 @@
 	grass.fatal(_("Something went wrong. Should not happen"))
     else:
 	# remove the vector part
-	grass.try_remove(vectfile)
+	grass.run_command('v.db.connect', quiet = True, map = output, layer = '1', flags = 'd')
+	grass.run_command('g.remove', quiet = True, vect = output)
     # get rid of superfluous auto-added cat column (and cat_ if present)
     grass.run_command('db.dropcolumn', quiet = True, flags = 'f', table = output,
