[GRASS-SVN] r48173 - in grass/trunk/lib: python temporal
Tue Sep 6 15:01:01 EDT 2011
Author: huhabla
Date: 2011-09-06 12:01:01 -0700 (Tue, 06 Sep 2011)
New Revision: 48173
Added:
   grass/trunk/lib/temporal/Makefile
   grass/trunk/lib/python/raster3d.py
   grass/trunk/lib/python/temporal.py
   grass/trunk/lib/python/vector.py
   grass/trunk/lib/temporal/raster3d_metadata_table.sql
   grass/trunk/lib/temporal/stds_tables_template.sql
   grass/trunk/lib/temporal/test.temporal.py
Makefile to store sql scripts. Basic structures for spatio-temporal datasets implemented. Vector info implemented in python grass library.
Modified: grass/trunk/lib/python/raster3d.py
--- grass/trunk/lib/python/raster3d.py	2011-09-06 16:35:21 UTC (rev 48172)
+++ grass/trunk/lib/python/raster3d.py	2011-09-06 19:01:01 UTC (rev 48173)
@@ -33,7 +33,7 @@
 # run "r3.info -rstgip ..." and parse output
 def raster3d_info(map):
-    """!Return information about a raster map (interface to
+    """!Return information about a raster3d map (interface to
     `r3.info'). Example:
     \code
Modified: grass/trunk/lib/python/temporal.py
--- grass/trunk/lib/python/temporal.py	2011-09-06 16:35:21 UTC (rev 48172)
+++ grass/trunk/lib/python/temporal.py	2011-09-06 19:01:01 UTC (rev 48173)
@@ -9,6 +9,7 @@
 @code
 from grass.script import temporal as grass
+grass.create_temporal_database()
 @endcode
@@ -19,32 +20,36 @@
 @author Soeren Gebbert
+import os
 import sqlite3
 import os
 from datetime import datetime, date, time
+import getpass
 import core
 import raster
+import vector
 import raster3d
-import getpass
 def get_grass_location_db_path():
     grassenv = core.gisenv()
     dbpath = os.path.join(grassenv["GISDBASE"], grassenv["LOCATION_NAME"])
-    print os.path.join(dbpath, "grass.db")
     return os.path.join(dbpath, "grass.db")
 def get_sql_template_path():
-    return "./"
+    base = os.getenv("GISBASE")
+    base_etc  = os.path.join(base, "etc")
+    return os.path.join(base_etc, "sql")
 def create_temporal_database():
     """This function creates the grass location database structure for raster, vector and raster3d maps
     as well as for the space-time datasets strds, str3ds and stvds"""
+    database = get_grass_location_db_path()
     # Check if it already exists
-    if os.path.exists(get_grass_location_db_path()):
+    if os.path.exists(database):
         return False
     # Read all SQL scripts and templates
@@ -82,7 +87,7 @@
     sqlite3.complete_statement(str3ds_metadata_sql)
     # Connect to database
-    connection = sqlite3.connect(get_grass_location_db_path())
+    connection = sqlite3.connect(database)
     cursor = connection.cursor()
     # Execute the SQL statements
@@ -212,12 +217,15 @@
 class sql_database_interface(dict_sql_serializer):
     """This is the sql database interface to sqlite3"""
-    def __init__(self, table=None, ident=None):
+    def __init__(self, table=None, ident=None, database=None):
         dict_sql_serializer.__init__(self)
         self.table = table # Name of the table, set in the subclass
-	self.database = get_grass_location_db_path()
+        if database == None:
+            self.database = get_grass_location_db_path()
+        else:
+            self.database = database
         self.ident = ident
     def connect(self):
@@ -454,6 +462,48 @@
+class stds_base(dataset_identifer):
+    def __init__(self, table=None, ident=None, name=None, mapset=None, semantic_type=None, creator=None, creation_time=None,\
+		    modification_time=None, temporal_type=None, revision=1):
+        dataset_identifer.__init__(self, table, ident, name, mapset, creator, creation_time,\
+	            modification_time, temporal_type, revision)
+	self.set_semantic_type(semantic_type)
+    def set_semantic_type(self, semantic_type):
+	"""Set the sematnic type of the space time dataset"""
+	self.D["semantic_type"] = semantic_type
+    def get_semantic_type(self):
+	"""Get the semantic_type of the space time dataset
+	   @return None if not found"""
+	if self.D.has_key("semantic_type"):
+	    return self.D["semantic_type"]
+        else:
+	    return None
+class strds_base(stds_base):
+    def __init__(self, ident=None, name=None, mapset=None,semantic_type=None,  creator=None, creation_time=None,\
+        stds_base.__init__(self, "strds_base", ident, name, mapset, semantic_type, creator, creation_time,\
+class str3ds_base(stds_base):
+        stds_base.__init__(self, "str3ds_base", ident, name, mapset, semantic_type, creator, creation_time,\
+class stvds_base(stds_base):
+    def __init__(self, ident=None, name=None, mapset=None, semantic_type=None,  creator=None, creation_time=None,\
+        stds_base.__init__(self, "stvds_base", ident, name, mapset, semantic_type, creator, creation_time,\
 class absolute_timestamp(sql_database_interface):
     """This is the absolute time base class for all maps and spacetime datasets"""
     def __init__(self, table=None, ident=None, start_time=None, end_time=None, timezone=None):
@@ -709,6 +759,40 @@
+class stds_absolute_time(absolute_timestamp):
+    def __init__(self, table=None, ident=None, start_time=None, end_time=None, granularity=None, timezone=None):
+        absolute_timestamp.__init__(self, table, ident, start_time, end_time, timezone)
+	self.set_granularity(granularity)
+    def set_granularity(self, granularity):
+	"""Set the granularity of the space time dataset"""
+	self.D["granularity"] = granularity
+    def get_granularity(self):
+	"""Get the granularity of the space time dataset
+	if self.D.has_key("granularity"):
+	    return self.D["granularity"]
+        else:
+	    return None
+class strds_absolute_time(stds_absolute_time):
+    def __init__(self, ident=None, start_time=None, end_time=None, granularity=None, timezone=None):
+        stds_absolute_time.__init__(self, "strds_absolute_time", ident, start_time, end_time, granularity, timezone)
+class str3ds_absolute_time(stds_absolute_time):
+        stds_absolute_time.__init__(self, "str3ds_absolute_time", ident, start_time, end_time, granularity, timezone)
+class stvds_absolute_time(stds_absolute_time):
+        stds_absolute_time.__init__(self, "stvds_absolute_time", ident, start_time, end_time, granularity, timezone)
 class relative_timestamp(sql_database_interface):
     """This is the relative time base class for all maps and spacetime datasets"""
     def __init__(self, table=None, ident=None, interval=None):
@@ -799,9 +883,43 @@
 class vector_relative_time(relative_timestamp):
     def __init__(self, ident=None, interval=None):
         relative_timestamp.__init__(self, "vector_relative_time", ident, interval)
+class stds_relative_time(relative_timestamp):
+    def __init__(self, table=None, ident=None, interval=None, granularity=None):
+        relative_timestamp.__init__(self, table, ident, interval)
+        else:
+	    return None
+class strds_relative_time(stds_relative_time):
+    def __init__(self, ident=None, interval=None, granularity=None):
+        stds_relative_time.__init__(self, "strds_relative_time", ident, interval, granularity)
+class str3ds_relative_time(stds_relative_time):
+        stds_relative_time.__init__(self, "str3ds_relative_time", ident, interval, granularity)
+class stvds_relative_time(stds_relative_time):
+        stds_relative_time.__init__(self, "stvds_relative_time", ident, interval, granularity)
 class spatial_extent(sql_database_interface):
     """This is the spatial extent base class for all maps and spacetime datasets"""
     def __init__(self, table=None, ident=None, north=None, south=None, east=None, west=None, top=None, bottom=None):
@@ -914,17 +1032,29 @@
 class raster_spatial_extent(spatial_extent):
-    def __init__(self, ident=None, interval=None, north=None, south=None, east=None, west=None, top=None, bottom=None):
+    def __init__(self, ident=None, north=None, south=None, east=None, west=None, top=None, bottom=None):
         spatial_extent.__init__(self, "raster_spatial_extent", ident, north, south, east, west, top, bottom)
 class raster3d_spatial_extent(spatial_extent):
         spatial_extent.__init__(self, "raster3d_spatial_extent", ident, north, south, east, west, top, bottom)
 class vector_spatial_extent(spatial_extent):
         spatial_extent.__init__(self, "vector_spatial_extent", ident, north, south, east, west, top, bottom)
+class strds_spatial_extent(spatial_extent):
+        spatial_extent.__init__(self, "strds_spatial_extent", ident, north, south, east, west, top, bottom)
+class str3ds_spatial_extent(spatial_extent):
+        spatial_extent.__init__(self, "str3ds_spatial_extent", ident, north, south, east, west, top, bottom)
+class stvds_spatial_extent(spatial_extent):
+        spatial_extent.__init__(self, "stvds_spatial_extent", ident, north, south, east, west, top, bottom)
 class raster_metadata_base(sql_database_interface):
@@ -1218,9 +1348,6 @@
 	    self.relative_time.print_self()
 	self.spatial_extent.print_self()
 	self.metadata.print_self()
-    def load_from_file(self):
-        raise IOError("This method must be implemented in the subclasses")
     def is_time_absolute(self):
 	if self.base.D.has_key("temporal_type"):
@@ -1258,7 +1385,8 @@
 	self.spatial_extent = raster_spatial_extent(ident=ident)
 	self.metadata = raster_metadata(ident=ident)
+    def load(self):
+        """Load all info from an existing raster map into the internal structure"""
         # Get the data from an existing raster map
         kvp = raster.raster_info(self.ident)
@@ -1294,7 +1422,6 @@
         self.metadata.set_cols(cols)
         self.metadata.set_rows(rows)
         self.metadata.set_number_of_cells(ncells)
@@ -1312,7 +1439,8 @@
 	self.spatial_extent = raster3d_spatial_extent(ident=ident)
 	self.metadata = raster3d_metadata(ident=ident)
+    def load(self):
+        """Load all info from an existing raster3d map into the internal structure"""
         kvp = raster3d.raster3d_info(self.ident)
@@ -1336,7 +1464,7 @@
         self.metadata.set_nsres(kvp["nsres"])
         self.metadata.set_ewres(kvp["ewres"])
-        self.metadata.set_ewres(kvp["tbres"])
+        self.metadata.set_tbres(kvp["tbres"])
         self.metadata.set_datatype(kvp["datatype"])
         self.metadata.set_min(kvp["min"])
         self.metadata.set_max(kvp["max"])
@@ -1352,3 +1480,43 @@
         self.metadata.set_depths(rows)
+class vector_dataset(abstract_dataset):
+    def __init__(self, ident):
+	self.reset(ident)
+    def reset(self, ident):
+	"""Reset the internal structure and set the identifier"""
+	self.ident = ident
+	self.base = vector_base(ident=ident)
+	self.absolute_time = vector_absolute_time(ident=ident)
+	self.relative_time = vector_relative_time(ident=ident)
+	self.spatial_extent = vector_spatial_extent(ident=ident)
+	self.metadata = vector_metadata(ident=ident)
+    def load(self):
+        """Load all info from an existing vector map into the internal structure"""
+        # Get the data from an existing raster map
+        kvp = vector.vector_info(self.ident)
+        # Fill base information
+        self.base.set_name(self.ident.split("@")[0])
+        self.base.set_mapset(self.ident.split("@")[1])
+        self.base.set_creator(str(getpass.getuser()))
+        # Fill spatial extent
+        self.spatial_extent.set_north(kvp["north"])
+        self.spatial_extent.set_south(kvp["south"])
+        self.spatial_extent.set_west(kvp["west"])
+        self.spatial_extent.set_east(kvp["east"])
+        self.spatial_extent.set_top(kvp["top"])
+        self.spatial_extent.set_bottom(kvp["bottom"])
+        # Fill metadata .. no metadata yet
Modified: grass/trunk/lib/python/vector.py
--- grass/trunk/lib/python/vector.py	2011-09-06 16:35:21 UTC (rev 48172)
+++ grass/trunk/lib/python/vector.py	2011-09-06 19:01:01 UTC (rev 48173)
@@ -163,6 +163,48 @@
     return ret
+# run "v.info -get ..." and parse output
+def vector_info(map):
+    """!Return information about a vector map (interface to
+    `v.info'). Example:
+    \code
+    >>> grass.vector_info('random_points')
+    {'comment': '', 'projection': 'x,y', 'creator': 'soeren', 'holes': 0,
+     'primitives': 20, 'kernels': 0, 'scale': '1:1', 'title': '',
+     'west': 0.046125489999999998, 'top': 2376.133159, 'boundaries': 0,
+     'location': 'XYLocation', 'nodes': 0, 'east': 0.97305646000000001,
+     'source_date': 'Mon Aug 29 10:55:57 2011', 'north': 0.9589993,
+     'format': 'native', 'faces': 0, 'centroids': 0,
+     'digitization_threshold': '0.000000', 'islands': 0, 'level': 2,
+     'mapset': 'test', 'areas': 0, 'name': 'random_points',
+     'database': '/home/soeren/grassdata', 'bottom': 22.186596999999999,
+     'lines': 0, 'points': 20, 'map3d': True, 'volumes': 0, 'num_dblinks': 0,
+     'organization': '', 'south': 0.066047099999999997}
+    \endcode
+    @param map map name
+    @return parsed vector info
+    s = read_command('v.info', flags = 'get', map = map)
+    kv = parse_key_val(s)
+    for k in ['north', 'south', 'east', 'west', 'top', 'bottom']:
+	kv[k] = float(kv[k])
+    for k in ['level', 'num_dblinks']:
+	kv[k] = int(kv[k])
+    for k in ['nodes', 'points', 'lines', 'boundaries', 'centroids', 'areas', 'islands', \
+              'faces', 'kernels', 'volumes', 'holes', 'primitives']:
+    if 'map3d' in kv:
+        kv['map3d'] = bool(kv['map3d'])
+    return kv
 # interface for v.db.select
 def vector_db_select(map, layer = 1, **kwargs):
Added: grass/trunk/lib/temporal/Makefile
--- grass/trunk/lib/temporal/Makefile	                        (rev 0)
+++ grass/trunk/lib/temporal/Makefile	2011-09-06 19:01:01 UTC (rev 48173)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+include $(MODULE_TOPDIR)/include/Make/Other.make
+SQLDIR = $(ETC)/sql
+SQLFILES:= $(wildcard *.sql)
+default: copy_sql_files
+copy_sql_files: $(SQLDIR)
+	for i in $(SQLFILES); do $(INSTALL_DATA) $$i $(SQLDIR)/; done
+$(SQLDIR):
+	$(MKDIR) $@
\ No newline at end of file
Modified: grass/trunk/lib/temporal/raster3d_metadata_table.sql
--- grass/trunk/lib/temporal/raster3d_metadata_table.sql	2011-09-06 16:35:21 UTC (rev 48172)
+++ grass/trunk/lib/temporal/raster3d_metadata_table.sql	2011-09-06 19:01:01 UTC (rev 48173)
@@ -13,7 +13,7 @@
 CREATE TABLE  raster3d_metadata (
   id VARCHAR NOT NULL,                  -- The id (PFK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary foreign key
   str3ds_register VARCHAR, -- The name of the table storing all space-time raster3d datasets in which this map is registered
-  maptype VARCHAR NOT NULL,
+  datatype VARCHAR NOT NULL,
   cols INTEGER NOT NULL,
   rows INTEGER NOT NULL,
   depths INTEGER NOT NULL,
@@ -36,7 +36,7 @@
             A1.revision, A1.creator,
 	    A2.start_time, A2.end_time,
             A3.north, A3.south, A3.east, A3.west,
-	    A4.maptype, A4.cols, A4.rows, A4.depths,
+	    A4.datatype, A4.cols, A4.rows, A4.depths,
             A4.nsres, A4.ewres, A4.tbres,
             A4.min, A4.max,
 	    A4.str3ds_register,
@@ -52,7 +52,7 @@
 	    A2.interval,
             A4.min, A4.max,
 	    A4.str3ds_register,
Modified: grass/trunk/lib/temporal/stds_tables_template.sql
--- grass/trunk/lib/temporal/stds_tables_template.sql	2011-09-06 16:35:21 UTC (rev 48172)
+++ grass/trunk/lib/temporal/stds_tables_template.sql	2011-09-06 19:01:01 UTC (rev 48173)
@@ -16,8 +16,8 @@
   creator VARCHAR NOT NULL,            -- Name of the creator
   temporal_type VARCHAR NOT NULL,      -- The temporal type of the dataset "absolute" or "relative"
   semantic_type VARCHAR NOT NULL,      -- The semantic data description used for aggregation/decomposition algorithm selection
-  creation_time TIMESTAMP NOT NULL,     -- The time of creation of the space-time dataset
-  modification_time TIMESTAMP NOT NULL, -- The time of the last modification of the space-time dataset
+  creation_time TIMESTAMP NOT NULL,    -- The time of creation of the space-time dataset
+  modification_time TIMESTAMP NOT NULL,-- The time of the last modification of the space-time dataset
   revision SMALLINT NOT NULL,          -- The revision number
   PRIMARY KEY (id)
@@ -32,8 +32,8 @@
 CREATE TABLE  STDS_absolute_time (
   id VARCHAR NOT NULL,            -- Id of the space-time dataset, this is the primary foreign key
-  start_time TIMESTAMP,            -- Start of the valid time, can be NULL if no map is registered
-  end_time TIMESTAMP,              -- End of the valid time, can be NULL if no map is registered
+  start_time TIMESTAMP,           -- Start of the valid time, can be NULL if no map is registered
+  end_time TIMESTAMP,             -- End of the valid time, can be NULL if no map is registered
   granularity VARCHAR,            -- The granularity "NNN seconds, NNN minutes, NNN hours, NNN days, NNN weeks, NNN months, NNN years"
   timezone SMALLINT,              -- The time zone number
   PRIMARY KEY (id),
Modified: grass/trunk/lib/temporal/test.temporal.py
--- grass/trunk/lib/temporal/test.temporal.py	2011-09-06 16:35:21 UTC (rev 48172)
+++ grass/trunk/lib/temporal/test.temporal.py	2011-09-06 19:01:01 UTC (rev 48173)
@@ -1,5 +1,6 @@
-from temporal import *
 import os
+from grass.script.temporal import *
+import grass.script as grass
@@ -20,7 +21,7 @@
 	    base.print_self()
 	for i in range(2):
-	    base = raster3d_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", creator="soeren")
+	    base = raster3d_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", creator="soeren")
 	    base.insert()
 	    base.select()
 	    base.print_self()
@@ -31,7 +32,7 @@
 	    base.print_self()
 	for i in range(2):
-	    base = vector_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", creator="soeren")
+	    base = vector_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", creator="soeren")
 	    base.insert()
 	    base.select()
 	    base.print_self()
@@ -41,6 +42,39 @@
 	    base.select()
 	    base.print_self()
+	for i in range(2):
+	    base = strds_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", creator="soeren", semantic_type="event", temporal_type="absolute", revision=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_creator("rene")
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = str3ds_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", semantic_type="event", creator="soeren")
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = stvds_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", semantic_type="event", creator="soeren")
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
 def test_absolute_timestamp():
 	for i in range(2):
 	    base = raster_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), timezone=1)
@@ -74,7 +108,40 @@
 	    base.update()
 	    base.select()
 	    base.print_self()
+	    base = strds_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), granularity="1 day", timezone=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_start_time(datetime(2010,01,01))
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = str3ds_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), granularity="1 day", timezone=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = stvds_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), granularity="1 day", timezone=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
 def test_spatial_extent():
 	for i in range(2):
 	    base = raster_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
@@ -108,7 +175,40 @@
 	    base.update()
 	    base.select()
 	    base.print_self()
+	    base = strds_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_north(120+i)
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = str3ds_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = stvds_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
 def test_relative_timestamp():
 	for i in range(2):
 	    base = raster_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i)
@@ -142,28 +242,61 @@
 	    base.update()
 	    base.select()
 	    base.print_self()
+	    base = strds_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i, granularity=5.5)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_interval(i+1)
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = str3ds_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i, granularity=5.5)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = stvds_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i, granularity=5.5)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
 def test_map_metadata():
 	for i in range(2):
-	    base = raster_metadata(ident="soil" + str(i) + "@PERMANENT", strds_register="PERMANENT_soil_strds-register", maptype="CELL", \
+	    base = raster_metadata(ident="soil" + str(i) + "@PERMANENT", strds_register="PERMANENT_soil_strds-register", datatype="CELL", \
 			    cols=500, rows=400, number_of_cells=200000,nsres=1, ewres=1, min=0, max=33)
 	    base.insert()
 	    base.select()
 	    base.print_self()
 	    base.clear()
-	    base.set_maptype("FCELL")
+	    base.set_datatype("FCELL")
 	    base.update()
 	    base.select()
 	    base.print_self()
 	for i in range(2):
-	    base = raster3d_metadata(ident="soil" + str(i) + "@PERMANENT", str3ds_register="PERMANENT_soil_str3ds-register", maptype="FCELL", \
+	    base = raster3d_metadata(ident="soil" + str(i) + "@PERMANENT", str3ds_register="PERMANENT_soil_str3ds-register", datatype="FCELL", \
 			    cols=500, rows=400, depths=20, number_of_cells=200000,nsres=1, ewres=1, tbres=10, min=0, max=33)
 	    base.insert()
 	    base.select()
 	    base.print_self()
 	    base.clear()
-	    base.set_maptype("DCELL")
+	    base.set_datatype("DCELL")
 	    base.update()
 	    base.select()
 	    base.print_self()
@@ -244,10 +377,10 @@
 	for i in range(10):
 	    base = vector_metadata(ident="water" + str(i) + "@PERMANENT", stvds_register="PERMANENT_water_stvds_register")
 	    base.insert()
-	    base = raster_metadata(ident="water" + str(i) + "@PERMANENT", strds_register="PERMANENT_water_strds-register", maptype="CELL", \
+	    base = raster_metadata(ident="water" + str(i) + "@PERMANENT", strds_register="PERMANENT_water_strds-register", datatype="CELL", \
 	    base.insert()
-	    base = raster3d_metadata(ident="water" + str(i) + "@PERMANENT", str3ds_register="PERMANENT_water_str3ds-register", maptype="FCELL", \
+	    base = raster3d_metadata(ident="water" + str(i) + "@PERMANENT", str3ds_register="PERMANENT_water_str3ds-register", datatype="FCELL", \
 	    base.insert()
@@ -256,10 +389,10 @@
 	    base.set_stvds_register("PERMANENT_water_stvds_register")
 	    base.update()
 	    base = raster_metadata(ident="water" + str(i) + "@PERMANENT")
 	    base.update()
 	    base = raster3d_metadata(ident="water" + str(i) + "@PERMANENT")
 	    base.update()
 	for i in range(10):
@@ -342,33 +475,98 @@
 def test_raster_dataset():
+    grass.raster.mapcalc("test = sin(x()) + cos(y())", overwrite = True)
+    name = "test"
+    mapset =  grass.gisenv()["MAPSET"]
     print "Create a raster object"
-    rds = raster_dataset("a at test")
+    rds = raster_dataset(name + "@" + mapset)
-    rds.load_from_file()
+    rds.load()
-    print "Is in db: ", rds.base.is_in_db()
+    print "Is in db: ", rds.is_in_db()
     rds.base.set_ttype("absolue")
     rds.absolute_time.set_start_time(datetime(year=2000, month=1, day=1))
     rds.absolute_time.set_end_time(datetime(year=2010, month=1, day=1))
     # Remove the entry if it is in the db
-    rds.base.delete()
+    rds.delete()
     rds.insert()
     rds.print_self()
     print rds.temporal_relation(rds)
+def test_raster3d_dataset():
+    grass.raster3d.mapcalc3d("test = sin(x()) + cos(y()) + sin(z())", overwrite = True)
+    name = "test"
+    print "Create a raster3d object"
+    r3ds = raster3d_dataset(name + "@" + mapset)
+    r3ds.load()
+    print "Is in db: ", r3ds.is_in_db()
+    r3ds.print_self()
+    r3ds.base.set_ttype("absolue")
+    r3ds.absolute_time.set_start_time(datetime(year=2000, month=1, day=1))
+    r3ds.absolute_time.set_end_time(datetime(year=2010, month=1, day=1))
+    # Remove the entry if it is in the db
+    r3ds.delete()
+    r3ds.insert()
+    r3ds.print_self()
+    print r3ds.temporal_relation(r3ds)
+def test_vector_dataset():
+    grass.run_command("v.random", output="test", n=20, column="height", zmin=0, \
+                      zmax=100, flags="z", overwrite = True)
+    name = "test"
+    print "Create a vector object"
+    vds = vector_dataset(name + "@" + mapset)
+    vds.load()
+    print "Is in db: ", vds.is_in_db()
+    vds.print_self()
+    vds.base.set_ttype("absolue")
+    vds.absolute_time.set_start_time(datetime(year=2000, month=1, day=1))
+    vds.absolute_time.set_end_time(datetime(year=2010, month=1, day=1))
+    vds.delete()
+    vds.insert()
+    vds.print_self()
+    print vds.temporal_relation(vds)
 #test_dict_sql_serializer()
-#test_dataset_identifer()
-#test_absolute_timestamp()
-#test_relative_timestamp()
-#test_spatial_extent()
+test_dataset_identifer()
+test_absolute_timestamp()
+test_relative_timestamp()
+test_spatial_extent()
 #test_map_metadata()
 #test_base_absolute_time_extent_metadata()
 #test_absolut_time_temporal_relations()
-test_raster_dataset()
+#test_raster_dataset()
+#test_raster3d_dataset()
+#test_vector_dataset()
