[GRASS-SVN] r48300 - sandbox/martinl/v.topo.to.postgis
Thu Sep 15 06:20:20 EDT 2011
Author: martinl
Date: 2011-09-15 03:20:19 -0700 (Thu, 15 Sep 2011)
New Revision: 48300
   sandbox/martinl/v.topo.to.postgis/main.c
   sandbox/martinl/v.topo.to.postgis/topo.c
v.topo.to.postgis: add summary
Modified: sandbox/martinl/v.topo.to.postgis/main.c
--- sandbox/martinl/v.topo.to.postgis/main.c	2011-09-15 09:11:40 UTC (rev 48299)
+++ sandbox/martinl/v.topo.to.postgis/main.c	2011-09-15 10:20:19 UTC (rev 48300)
@@ -88,8 +88,35 @@
     Vect_topo_to_pg(&Map, conn,
 		    G_check_overwrite(argc, argv));
-    /* close the connection to the database and cleanup */
-    PQfinish(conn);
+    if (conn) {
+	int i, j, nFields;
+	dbString stmt;
+	PGresult *res;
+	db_init_string(&stmt);
+	db_set_string(&stmt, "SELECT TopologySummary('");
+	db_append_string(&stmt, name);
+	db_append_string(&stmt, "')");
+	fprintf(stdout, "---------- SUMMARY ----------\n");
+	res = PQexec(conn, db_get_string(&stmt));
+	if (PQresultStatus(res) != PGRES_TUPLES_OK) {
+	    PQclear(res);
+	    PQfinish(conn);
+	    G_fatal_error(_("%s command failed: %s"), "TopologySummary",
+			  PQerrorMessage(conn));
+	nFields = PQnfields(res);
+	for (i = 0; i < PQntuples(res); i++) {
+	    for (j = 0; j < nFields; j++)
+		fprintf(stdout, "%-15s", PQgetvalue(res, i, j));
+	G_done_msg(" ");
+	/* close the connection to the database and cleanup */
+	PQfinish(conn);
     exit(EXIT_SUCCESS);
Modified: sandbox/martinl/v.topo.to.postgis/topo.c
--- sandbox/martinl/v.topo.to.postgis/topo.c	2011-09-15 09:11:40 UTC (rev 48299)
+++ sandbox/martinl/v.topo.to.postgis/topo.c	2011-09-15 10:20:19 UTC (rev 48300)
@@ -139,9 +139,9 @@
     *res = PQexec(conn, db_get_string(stmt));
     if (PQresultStatus(*res) != status) {
 	PQclear(*res);
+	PQfinish(conn);
 	G_fatal_error(_("%s command failed: %s"), cmd,
-	PQfinish(conn);
