[GRASS-SVN] r48376 - in grass/trunk: lib/python lib/temporal temporal temporal/t.create temporal/t.time.abs temporal/t.time.rel
Mon Sep 19 18:45:23 EDT 2011
Author: huhabla
Date: 2011-09-19 15:45:22 -0700 (Mon, 19 Sep 2011)
New Revision: 48376
Added:
   grass/trunk/temporal/t.time.abs/
   grass/trunk/temporal/t.time.abs/Makefile
   grass/trunk/temporal/t.time.abs/t.time.abs.html
   grass/trunk/temporal/t.time.abs/t.time.abs.py
   grass/trunk/temporal/t.time.abs/test.t.time.abs.sh
   grass/trunk/temporal/t.time.rel/
   grass/trunk/temporal/t.time.rel/Makefile
   grass/trunk/temporal/t.time.rel/t.time.rel.html
   grass/trunk/temporal/t.time.rel/t.time.rel.py
   grass/trunk/temporal/t.time.rel/test.t.time.rel.sh
   grass/trunk/lib/python/tgis_abstract_datasets.py
   grass/trunk/lib/python/tgis_space_time_datasets.py
   grass/trunk/lib/python/tgis_temporal_extent.py
   grass/trunk/lib/temporal/stds_map_register_table_template.sql
   grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql
   grass/trunk/temporal/Makefile
   grass/trunk/temporal/t.create/t.create.py
New temporal modules to set absolute and relative valid time for raster, vector and raster3d maps.
Modified: grass/trunk/lib/python/tgis_abstract_datasets.py
--- grass/trunk/lib/python/tgis_abstract_datasets.py	2011-09-19 20:27:59 UTC (rev 48375)
+++ grass/trunk/lib/python/tgis_abstract_datasets.py	2011-09-19 22:45:22 UTC (rev 48376)
@@ -26,7 +26,11 @@
 class abstract_dataset(object):
     """This is the base class for all datasets (raster, vector, raster3d, strds, stvds, str3ds)"""
+    def reset(self, ident):
+	"""Reset the internal structure and set the identifier"""
+	raise IOError("This method must be implemented in the subclasses")
     def get_type(self):
         """Return the type of this class"""
@@ -305,15 +309,21 @@
             self.unregister(dbif)
             # Remove the strds register table
-            sql = "DROP TABLE " + self.get_stds_register()
-            #print sql
-            dbif.cursor.execute(sql)
+            if self.get_stds_register():
+                sql = "DROP TABLE " + self.get_stds_register()
+                #print sql
+                try:
+                    dbif.cursor.execute(sql)
+                except:
+                    core.error("Unable to remove space time dataset register table " + self.get_stds_register())
             core.verbose("Delete " + self.get_type() + " dataset <" + self.get_id() + "> from temporal database")
             # Delete yourself from the database, trigger functions will take care of dependencies
             self.base.delete(dbif)
+        self.reset(None)
         if connect == True:
             dbif.close()
@@ -360,18 +370,16 @@
             dbif.connect()
             connect = True
-        # Select all data from the database
-        self.select(dbif)
         rows = None
-        # Remove the map from all registered space time datasets
-        if self.get_stds_register() != None:
-            # Select all stds tables in which this map is registered
-            sql = "SELECT id FROM " + self.get_stds_register()
-            #print sql
-            rows = dbif.cursor.fetchall()
+        try:
+            if self.get_stds_register() != None:
+                # Select all stds tables in which this map is registered
+                sql = "SELECT id FROM " + self.get_stds_register()
+                rows = dbif.cursor.fetchall()
+        except:
+            core.error("Unable to select space time dataset register table " + self.get_stds_register())
         if connect == True:
             dbif.close()
@@ -411,10 +419,6 @@
         """Set the name of the map register table"""
-    def reset(self, ident):
-	"""Reset the internal structure and set the identifier"""
-	raise IOError("This method must be implemented in the subclasses")
     def set_initial_values(self, granularity, temporal_type, semantic_type, \
                            title=None, description=None):
@@ -447,21 +451,26 @@
         if self.get_map_register():
             sql = "SELECT id FROM " + self.get_map_register()
-            # Unregister each registered map in the table
-            if rows:
-                for row in rows:
-                    # Unregister map
-                    map = self.get_new_map_instance(row["id"])
-                    self.unregister_map(map, dbif)
+            try:
+                # Unregister each registered map in the table
+                if rows:
+                    for row in rows:
+                        # Unregister map
+                        map = self.get_new_map_instance(row["id"])
+                        self.unregister_map(map, dbif)
-            # Drop remove the map register table
-            sql = "DROP TABLE " + self.get_map_register()
+                # Drop remove the map register table
+                sql = "DROP TABLE " + self.get_map_register()
+            except:
+                core.error("Unable to unregister maps from register table <" + self.get_map_register() + ">")
+                raise
         # Remove the primary key, the foreign keys will be removed by trigger
+        self.reset(None)
         if connect == True:
             dbif.close()
@@ -533,7 +542,12 @@
             sql = sql.replace("TABLE_NAME", uuid_rand )
             sql = sql.replace("MAP_ID", map_id)
             sql = sql.replace("STDS", self.get_type())
-            dbif.cursor.executescript(sql)
+            try:
+                dbif.cursor.executescript(sql)
+            except:
+                core.error("Unable to create the space time " + map.get_type() +\
+                " dataset register table for " + map.get_type() + " map <" + map.get_id())
+                raise
             map_register_table = uuid_rand + "_" + self.get_type() + "_register"
             # Set the stds register table name and put it into the DB
@@ -553,11 +567,16 @@
             sql_script = ""
-            sql_script += "BEGIN TRANSACTION;\n"
+            #sql_script += "BEGIN TRANSACTION;\n"
             sql_script += sql
-            sql_script += "\n"
-            sql_script += "END TRANSACTION;"
-            dbif.cursor.executescript(sql_script)
+            #sql_script += "\n"
+            #sql_script += "END TRANSACTION;"
+            try:
+                dbif.cursor.executescript(sql_script)
+            except:
+                core.error("Unable to create the " + map.get_type() +\
+                " map register table for space time " + map.get_type() + " dataset <" + map.get_id())
+                raise
             # Trigger have been disabled due to peformance issues while registration
             ## We need raster specific trigger
Modified: grass/trunk/lib/python/tgis_space_time_datasets.py
--- grass/trunk/lib/python/tgis_space_time_datasets.py	2011-09-19 20:27:59 UTC (rev 48375)
+++ grass/trunk/lib/python/tgis_space_time_datasets.py	2011-09-19 22:45:22 UTC (rev 48376)
@@ -442,6 +442,11 @@
                 core.fatal("Unable to register " + map.get_type() + " map <" + map.get_id() + ">. The map has no valid time and the start time is not set.")
             # Load the data from the grass file database
             map.load()
+            if sp.get_temporal_type() == "absolute":
+                map.set_time_to_absolute()
+            else:
+                map.set_time_to_relative()
             #  Put it into the temporal database
             map.insert(dbif)
         else:
@@ -451,7 +456,7 @@
         # Set the valid time
         if start:
-            assign_valid_time_to_map(sp.get_temporal_type(), map, start, increment, count, dbif)
+            assign_valid_time_to_map(ttype=sp.get_temporal_type(), map=map, start=start, end=None, increment=increment, mult=count, dbif=dbif)
         # Finally Register map in the space time dataset
         sp.register_map(map, dbif)
@@ -534,8 +539,96 @@
     if connect == True:
         dbif.close()
-def assign_valid_time_to_map(ttype, map, start, increment=None, mult=1, dbif = None):
+def assign_valid_time_to_maps(type, maps, ttype, start, end=None, increment=None, dbif = None):
+    """Use this method to assign valid time (absolute or relative) to raster,
+       raster3d and vector datasets.
+       It takes care of the correct update of the space time datasets from all
+       registered maps.
+       Valid end time and increment are mutual exclusive.
+       @type The type of the maps raster, raster3d or vector
+       @maps A comma separated list of map names
+       @start The start date and time of the first raster map (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative 5.0)
+       @start The end date and time of the first raster map (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative 5.0)
+       @increment Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)
+    if end and increment:
+        core.fatal("Valid end time and increment are mutual exclusive")
+    # List of space time datasets to be updated
+    splist = {}
+    # We may need the mapset
+    mapset =  core.gisenv()["MAPSET"]
+    if dbif == None:
+        dbif = sql_database_interface()
+        dbif.connect()
+        connect = True
+    if maps.find(",") == -1:
+        maplist = (maps,)
+    else:
+        maplist = tuple(maps.split(","))
+    count = 0
+    for mapname in maplist:
+        mapname = mapname.strip()
+        # Check if the map name contains the mapset as well
+        if mapname.find("@") < 0:
+            mapid = mapname + "@" + mapset
+        else:
+            mapid = mapname
+        if type == "raster":
+            map = raster_dataset(mapid)
+        if type == "raster3d":
+            map = raster3d_dataset(mapid)
+        if type == "vector":
+            map = vector_dataset(mapid)
+        if map.is_in_db(dbif) == False:
+            # Load the data from the grass file database
+            map.load()
+            if ttype == "absolute":
+            else:
+            #  Put it into the temporal database
+            map.insert(dbif)
+        else:
+            map.select(dbif)
+            sprows = map.get_registered_datasets(dbif)
+            # Make an entry in the dataset list, using a dict make sure that
+            # each dataset is listed only once
+            if sprows != None:
+                for dataset in sprows:
+                    splist[dataset["id"]] = True
+        # Set the valid time
+        assign_valid_time_to_map(ttype=ttype, map=map, start=start, end=end, increment=increment, mult=count, dbif=dbif)
+        count += 1
+    # Update all the space time datasets in which registered maps are changed there valid time
+    for name in splist.keys():
+        sp = map.get_new_stds_instance(name)
+        sp.select(dbif)
+        sp.update_from_registered_maps(dbif)
+    if connect == True:
+        dbif.close()
+def assign_valid_time_to_map(ttype, map, start, end, increment=None, mult=1, dbif = None):
     """Assign the valid time to a map dataset
        @ttype The temporal type which should be assigned and which the time format is of
@@ -544,7 +637,7 @@
        @multi A multiplier for the increment
     connect = False
     if dbif == None:
@@ -560,7 +653,10 @@
             time_format = "%Y-%m-%d"
         start_time = datetime.strptime(start, time_format)
-        end_time = None
+        if end:
+            end_time = datetime.strptime(end, time_format)
+        else:
+            end_time = None
         # Add the increment
         if increment:
Modified: grass/trunk/lib/python/tgis_temporal_extent.py
--- grass/trunk/lib/python/tgis_temporal_extent.py	2011-09-19 20:27:59 UTC (rev 48375)
+++ grass/trunk/lib/python/tgis_temporal_extent.py	2011-09-19 22:45:22 UTC (rev 48376)
@@ -419,7 +419,7 @@
         """Print information about this class in human readable style"""
         #      0123456789012345678901234567890
         print " +-------------------- Relative time -----------------------------------------+"
-        print " |  Interval:................... " + str(self.get_interval())
+        print " | Interval:................... " + str(self.get_interval())
     def print_shell_info(self):
         """Print information about this class in shell style"""
Modified: grass/trunk/lib/temporal/stds_map_register_table_template.sql
--- grass/trunk/lib/temporal/stds_map_register_table_template.sql	2011-09-19 20:27:59 UTC (rev 48375)
+++ grass/trunk/lib/temporal/stds_map_register_table_template.sql	2011-09-19 22:45:22 UTC (rev 48376)
@@ -39,6 +39,11 @@
 --           (SELECT max(end_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
 --			(SELECT id FROM SPACETIME_NAME_GRASS_MAP_register)
 --           ) WHERE id = "SPACETIME_ID";
+--    UPDATE STDS_relative_time SET interval =
+--           (SELECT max(interval) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
+--       		(SELECT id FROM SPACETIME_NAME_GRASS_MAP_register)
+--           ) WHERE id = "SPACETIME_ID";
 --    -- Update the spatial extent
 --    UPDATE STDS_spatial_extent SET north =
 --           (SELECT max(north) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
Modified: grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql
--- grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql	2011-09-19 20:27:59 UTC (rev 48375)
+++ grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql	2011-09-19 22:45:22 UTC (rev 48376)
@@ -27,6 +27,10 @@
+UPDATE STDS_relative_time SET interval =
+       (SELECT max(interval) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
+    		(SELECT id FROM SPACETIME_NAME_GRASS_MAP_register)
+       ) WHERE id = "SPACETIME_ID";
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile	2011-09-19 20:27:59 UTC (rev 48375)
+++ grass/trunk/temporal/Makefile	2011-09-19 22:45:22 UTC (rev 48376)
@@ -5,6 +5,8 @@
 	t.list \
 	t.info \
 	t.remove \
+	t.time.abs \
+	t.time.rel \
 	tr.register \
 	tr3.register \
 	tv.register \
Modified: grass/trunk/temporal/t.create/t.create.py
--- grass/trunk/temporal/t.create/t.create.py	2011-09-19 20:27:59 UTC (rev 48375)
+++ grass/trunk/temporal/t.create/t.create.py	2011-09-19 22:45:22 UTC (rev 48376)
@@ -120,6 +120,7 @@
     if sp.is_in_db(dbif) and grass.overwrite() == True:
         grass.info("Overwrite space time " + sp.get_new_map_instance(None).get_type() + " dataset <" + name + "> and unregister all maps.")
         sp.delete(dbif)
+        sp = sp.get_new_instance(id)
     grass.info("Create space time " + sp.get_new_map_instance(None).get_type() + " dataset.")
Added: grass/trunk/temporal/t.time.abs/Makefile
--- grass/trunk/temporal/t.time.abs/Makefile	                        (rev 0)
+++ grass/trunk/temporal/t.time.abs/Makefile	2011-09-19 22:45:22 UTC (rev 48376)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.time.abs
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.time.abs/t.time.abs.html
Added: grass/trunk/temporal/t.time.abs/t.time.abs.py
--- grass/trunk/temporal/t.time.abs/t.time.abs.py	                        (rev 0)
+++ grass/trunk/temporal/t.time.abs/t.time.abs.py	2011-09-19 22:45:22 UTC (rev 48376)
@@ -0,0 +1,79 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:	t.time.abs
+# AUTHOR(S):	Soeren Gebbert
+# PURPOSE:	Set the absolute valid time interval for raster maps
+# COPYRIGHT:	(C) 2011 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (version 2). Read the file COPYING that comes with GRASS
+#		for details.
+#%module
+#% description: Set the absolute valid time interval for maps of type raster, vector and raster3d
+#% keywords: time
+#% keywords: absolute
+#% keywords: raster
+#% keywords: vector
+#% keywords: raster3d
+#%end
+#%option
+#% key: maps
+#% type: string
+#% description: Name(s) of existing raster map(s)
+#% required: yes
+#% multiple: yes
+#%end
+#%option
+#% key: start
+#% type: string
+#% description: The valid start date and time of the first raster map. Time format is "yyyy-mm-dd HH:MM:SS" or only "yyyy-mm-dd"
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: end
+#% type: string
+#% description: The valid end date and time of the first raster map. Time format is "yyyy-mm-dd HH:MM:SS" or only "yyyy-mm-dd". End time and increment are mutual exclusive.
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: increment
+#% type: string
+#% description: Time increment between maps for valid time interval creation. Interval format: NNN seconds, minutes, hours, days, weeks, months, years
+#% required: no
+#% multiple: no
+#%end
+import grass.script as grass
+def main():
+    # Get the options
+    maps = options["maps"]
+    start = options["start"]
+    end = options["end"]
+    increment = options["increment"]
+    # Make sure the temporal database exists
+    grass.create_temporal_database()
+    # Set valid absolute time to maps
+    grass.assign_valid_time_to_maps(type="raster", maps=maps, ttype="absolute", \
+                                    start=start, end=end, increment=increment, dbif=None)
+if __name__ == "__main__":
+    options, flags = grass.core.parser()
+    main()
Property changes on: grass/trunk/temporal/t.time.abs/t.time.abs.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.time.abs/test.t.time.abs.sh
--- grass/trunk/temporal/t.time.abs/test.t.time.abs.sh	                        (rev 0)
+++ grass/trunk/temporal/t.time.abs/test.t.time.abs.sh	2011-09-19 22:45:22 UTC (rev 48376)
@@ -0,0 +1,39 @@
+# We test the absolute valid time interval creation with t.time.abs
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs1 gran="1 months" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs2 gran="1 months" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs3 gran="1 months" title="A test" descr="A test"
+t.time.abs --v maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="1 months"
+t.info type=raster dataset=prec_1
+t.info type=raster dataset=prec_2
+t.info type=raster dataset=prec_3
+tr.register --v dataset=precip_abs1 maps=prec_1,prec_2,prec_3
+tr.register --v dataset=precip_abs2 maps=prec_1,prec_2,prec_3
+tr.register --v dataset=precip_abs3 maps=prec_1,prec_2,prec_3
+# Check if the space time datasets are updated correctly
+t.time.abs --v maps=prec_1,prec_2,prec_3 start="2011-01-01" increment="1 months"
+t.info type=strds dataset=precip_abs1
+t.time.abs --v maps=prec_4,prec_5 start="2001-01-01" end="2002-01-01"
+t.info type=raster dataset=prec_4
+t.info type=raster dataset=prec_5
+t.time.abs --v maps=prec_6 start="2001-01-01 00:00:00" end="2001-01-01 12:00:00"
+t.info type=raster dataset=prec_6
+t.remove --v type=raster dataset=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove --v type=strds dataset=precip_abs1,precip_abs2,precip_abs3
\ No newline at end of file
Added: grass/trunk/temporal/t.time.rel/Makefile
--- grass/trunk/temporal/t.time.rel/Makefile	                        (rev 0)
+++ grass/trunk/temporal/t.time.rel/Makefile	2011-09-19 22:45:22 UTC (rev 48376)
@@ -0,0 +1,7 @@
+PGM = t.time.rel
Added: grass/trunk/temporal/t.time.rel/t.time.rel.html
Added: grass/trunk/temporal/t.time.rel/t.time.rel.py
--- grass/trunk/temporal/t.time.rel/t.time.rel.py	                        (rev 0)
+++ grass/trunk/temporal/t.time.rel/t.time.rel.py	2011-09-19 22:45:22 UTC (rev 48376)
@@ -0,0 +1,70 @@
+# MODULE:	t.time.rel
+# PURPOSE:	Set the relative valid time interval for raster maps
+#		for details.
+#%module
+#% description: Set the relative valid time interval for maps of type raster, vector and raster3d
+#% keywords: time
+#% keywords: relative
+#%end
+#%option
+#% key: maps
+#% type: string
+#% required: yes
+#% multiple: yes
+#%end
+#%option
+#% key: start
+#% type: double
+#% description: The valid time value in [days]
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: increment
+#% type: double
+#% description: Time increment between maps for valid time interval creation [days]
+#% required: no
+#% multiple: no
+#%end
+def main():
+    # Get the options
+    # Set valid relative time to maps
+    grass.assign_valid_time_to_maps(type="raster", maps=maps, ttype="relative", \
+                                    start=start, end=None, increment=increment, dbif=None)
+    main()
Property changes on: grass/trunk/temporal/t.time.rel/t.time.rel.py
Added: grass/trunk/temporal/t.time.rel/test.t.time.rel.sh
--- grass/trunk/temporal/t.time.rel/test.t.time.rel.sh	                        (rev 0)
+++ grass/trunk/temporal/t.time.rel/test.t.time.rel.sh	2011-09-19 22:45:22 UTC (rev 48376)
@@ -0,0 +1,39 @@
+# We test the relative valid time interval creation with t.time.rel
+t.create --v --o type=strds temporaltype=relative dataset=precip_rel1 gran=2 title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=relative dataset=precip_rel2 gran=2 title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=relative dataset=precip_rel3 gran=2 title="A test" descr="A test"
+t.time.rel --v maps=prec_1,prec_2,prec_3 start=5 increment=2
+tr.register --v dataset=precip_rel1 maps=prec_1,prec_2,prec_3
+tr.register --v dataset=precip_rel2 maps=prec_1,prec_2,prec_3
+tr.register --v dataset=precip_rel3 maps=prec_1,prec_2,prec_3
+t.time.rel --v maps=prec_1,prec_2,prec_3 start=0 increment=1000
+t.info type=strds dataset=precip_rel1
+t.time.rel --v maps=prec_4,prec_5 start=5000
+t.time.rel --v maps=prec_6 start=6000
+t.remove --v type=strds dataset=precip_rel1,precip_rel2,precip_rel3
