[GRASS-SVN] r48384 - grass/trunk/vector/v.voronoi
Tue Sep 20 10:10:08 EDT 2011
Author: mmetz
Date: 2011-09-20 07:10:08 -0700 (Tue, 20 Sep 2011)
New Revision: 48384
   grass/trunk/vector/v.voronoi/main.c
v.voronoi: add messages
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c	2011-09-20 14:05:12 UTC (rev 48383)
+++ grass/trunk/vector/v.voronoi/main.c	2011-09-20 14:10:08 UTC (rev 48384)
@@ -363,7 +363,7 @@
     Vect_close(&In);
-    /* cleaning */
+    /* cleaning part 1: count errors */
     Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
     err_boundaries = err_centr_out = err_centr_dupl = err_nocentr = 0;
     nlines = Vect_get_num_lines(&Out);
@@ -403,9 +403,11 @@
 	    err_nocentr++;
+    /* cleaning part 2: snap */
     if (err_nocentr || err_centr_dupl || err_centr_out) {
 	int nmod;
+	G_important_message(_("Output needs topological cleaning"));
 	Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
 	do {
 	    Vect_break_lines(&Out, GV_BOUNDARY, NULL);
@@ -435,7 +437,9 @@
+    /* cleaning part 3: remove remaining incorrect boundaries */
     if (err_boundaries) {
+	G_important_message(_("Removing incorrect boundaries from output"));
 	for (line = 1; line <= nlines; line++) {
@@ -458,6 +462,7 @@
+    /* build clean topology */
     Vect_build_partial(&Out, GV_BUILD_NONE);
     Vect_build(&Out);
     Vect_close(&Out);
