[GRASS-SVN] r48427 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Fri Sep 23 13:39:38 EDT 2011
Author: martinl
Date: 2011-09-23 10:39:38 -0700 (Fri, 23 Sep 2011)
New Revision: 48427
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
wxGUI/dbm: don't use Python reserved words as variable names
	   (merge r48426 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2011-09-23 17:37:20 UTC (rev 48426)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2011-09-23 17:39:38 UTC (rev 48427)
@@ -1148,25 +1148,25 @@
     def OnDataItemDelete(self, event):
         """!Delete selected item(s) from the list (layer/category pair)"""
-        list = self.FindWindowById(self.layerPage[self.layer]['data'])
-        item = list.GetFirstSelected()
+        dlist = self.FindWindowById(self.layerPage[self.layer]['data'])
+        item = dlist.GetFirstSelected()
         table    = self.mapDBInfo.layers[self.layer]["table"]
         key      = self.mapDBInfo.layers[self.layer]["key"]
         indeces = []
         # collect SQL statements
         while item != -1:
-            index = list.itemIndexMap[item]
+            index = dlist.itemIndexMap[item]
             indeces.append(index)
-            cat = list.itemCatsMap[index]
+            cat = dlist.itemCatsMap[index]
             self.listOfSQLStatements.append('DELETE FROM %s WHERE %s=%d' % \
                                                 (table, key, cat))
-            item = list.GetNextSelected(item)
+            item = dlist.GetNextSelected(item)
         if UserSettings.Get(group='atm', key='askOnDeleteRec', subkey='enabled'):
             deleteDialog = wx.MessageBox(parent=self,
                                          message=_("Selected data records (%d) will permanently deleted "
@@ -1177,33 +1177,33 @@
             if deleteDialog != wx.YES:
                 self.listOfSQLStatements = []
                 return False
         # restore maps
         i = 0
-        indexTemp = copy.copy(list.itemIndexMap)
-        list.itemIndexMap = []
-        dataTemp = copy.deepcopy(list.itemDataMap)
-        list.itemDataMap = {}
-        catsTemp = copy.deepcopy(list.itemCatsMap)
-        list.itemCatsMap = {}
+        indexTemp = copy.copy(dlist.itemIndexMap)
+        dlist.itemIndexMap = []
+        dataTemp = copy.deepcopy(dlist.itemDataMap)
+        dlist.itemDataMap = {}
+        catsTemp = copy.deepcopy(dlist.itemCatsMap)
+        dlist.itemCatsMap = {}
         i = 0
         for index in indexTemp:
             if index in indeces:
                 continue
-            list.itemIndexMap.append(i)
-            list.itemDataMap[i] = dataTemp[index]
-            list.itemCatsMap[i] = catsTemp[index]
+            dlist.itemIndexMap.append(i)
+            dlist.itemDataMap[i] = dataTemp[index]
+            dlist.itemCatsMap[i] = catsTemp[index]
             i += 1
-        list.SetItemCount(len(list.itemIndexMap))
+        dlist.SetItemCount(len(dlist.itemIndexMap))
         # deselect items
         while item != -1:
-            list.SetItemState(item, 0, wx.LIST_STATE_SELECTED | wx.LIST_STATE_FOCUSED)
+            dlist.SetItemState(item, 0, wx.LIST_STATE_SELECTED | wx.LIST_STATE_FOCUSED)
         # submit SQL statements
         self.ApplyCommands()
@@ -1212,21 +1212,21 @@
     def OnDataItemDeleteAll(self, event):
         """!Delete all items from the list"""
                                          message=_("All data records (%d) will permanently deleted "
                                                    "from table. Do you want to delete them?") % \
-                                             (len(list.itemIndexMap)),
+                                             (len(dlist.itemIndexMap)),
                                          caption=_("Delete records"),
                                          style=wx.YES_NO | wx.CENTRE)
                 return
-        list.DeleteAllItems()
-        list.SetItemCount(0)
+        dlist.DeleteAllItems()
+        dlist.SetItemCount(0)
         self.listOfSQLStatements.append('DELETE FROM %s' % table)
