[GRASS-SVN] r48442 - grass/trunk/gui/wxpython/docs
Sat Sep 24 07:34:29 EDT 2011
Author: martinl
Date: 2011-09-24 04:34:29 -0700 (Sat, 24 Sep 2011)
New Revision: 48442
   grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
   grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html
   grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html
   grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html
   grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html
   grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizer.html
   grass/trunk/gui/wxpython/docs/wxGUI.html
   grass/trunk/gui/wxpython/docs/wxGUI_layer_manager.jpg
wxGUI: add `meta page` desc for manual pages
       update Layer Manager screenshot
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2011-09-24 01:07:21 UTC (rev 48441)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2011-09-24 11:34:29 UTC (rev 48442)
@@ -1,3 +1,5 @@
+<!-- meta page description: wxGUI Attribute Table Manager -->
+<!-- meta page index: wxGUI -->
 <h2>DESCRIPTION</h2>
 <em>Attribute table manager</em> allows to:
Modified: grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html
--- grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html	2011-09-24 01:07:21 UTC (rev 48441)
+++ grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html	2011-09-24 11:34:29 UTC (rev 48442)
@@ -1,3 +1,5 @@
+<!-- meta page description: wxGUI GCP Manager -->
 The <b>GCP Manager</b> is a <em><a href="wxGUI.html">wxGUI</a></em>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html	2011-09-24 01:07:21 UTC (rev 48441)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html	2011-09-24 11:34:29 UTC (rev 48442)
@@ -1,3 +1,5 @@
+<!-- meta page description: wxGUI Graphical Modeler -->
 <b>Note:</b> <em>wxGUI Modeler is currently under development.</em>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html	2011-09-24 01:07:21 UTC (rev 48441)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html	2011-09-24 11:34:29 UTC (rev 48442)
@@ -1,3 +1,5 @@
+<!-- meta page description: wxGUI 3D View Mode -->
 Note: <b>wxNviz is currently under development. Not
Modified: grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html
--- grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html	2011-09-24 01:07:21 UTC (rev 48441)
+++ grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html	2011-09-24 11:34:29 UTC (rev 48442)
@@ -1,3 +1,5 @@
+<!-- meta page description: wxGUI Cartographic Composer -->
 <b>Note:</b> <em>wxGUI Cartographic Composer is currently under
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizer.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizer.html	2011-09-24 01:07:21 UTC (rev 48441)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizer.html	2011-09-24 11:34:29 UTC (rev 48442)
@@ -1,3 +1,5 @@
+<!-- meta page description: wxGUI Vector Digitizer -->
 The <b>Vector digitizer</b> is
@@ -214,12 +216,9 @@
 <p>
 If the digitizer crashes for some reason you can repair the vector map
-which was left open with the <em>v.build</em> module.
+which was left open with
+the <em><a href="v.build.html">v.build</a></em> module.
-<p>
-<b>Please note that vector digitizer is under active development and
-distributed as &quot;Experimental Prototype&quot;.</b>
 <h2>SEE ALSO</h2>
 <em>
@@ -247,7 +246,10 @@
 <h2>AUTHORS</h2>
-<a href="http://geo.fsv.cvut.cz/gwiki/Landa">Martin Landa</a>, <a href="http://www.fbk.eu">FBK-irst</a> (2007-2008), Trento, Italy, and <a href="http://www.cvut.cz">Czech Technical University in Prague</a>, Czech Republic<br>
+<a href="http://geo.fsv.cvut.cz/gwiki/Landa">Martin
+Landa</a>, <a href="http://www.fbk.eu">FBK-irst</a> (2007-2008),
+Trento, Italy, and <a href="http://www.cvut.cz">Czech Technical
+University in Prague</a>, Czech Republic<br>
 <p>
 <i>$Date$</i>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html	2011-09-24 01:07:21 UTC (rev 48441)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html	2011-09-24 11:34:29 UTC (rev 48442)
@@ -1,6 +1,7 @@
+<!-- meta page description: wxGUI -->
-wxGUI is native <em>Graphical User Interface</em> (GUI) for GRASS GIS.
+<b>wxGUI</b> is native Graphical User Interface (GUI) for GRASS GIS.
 <p>
 If the wxGUI is not the default user interface, it can defined as default by
@@ -402,8 +403,7 @@
   <dt><img src="icons/erase.png">&nbsp;
     <em>Erase display</em></dt>
   <dd>Erases the currently selected map display to a white background.
-    see <em><a href="d.erase.html">d.erase</a>, <a href="d.frame.html">d.frame
-	-e</a></em>.</dd>
+    see <em><a href="d.erase.html">d.erase</a></em>.</dd>
   <dt><img src="icons/pointer.png">&nbsp;
     <em>Pointer</em></dt>
@@ -497,16 +497,14 @@
       <dd>Interactive measurement of lengths defined with the mouse. The
         length of each segment and the cumulative length of all segments
         measuered is displayed in the command output window frame. Lengths are
-        measured in the current measurement unit,
-        see <em><a href="d.measure.html">d.measure</a></em>.</dd>
+        measured in the current measurement unit.</dd>
       <dt><img src="icons/layer-raster-profile.png">&nbsp;
         <em>Profile tool</em></dt>
       <dd>Interactively create profile of a raster map. Profile transect is
 	drawn with the mouse in map display. The profile may be of the
 	displayed map or a different map. Up to three maps can be profiled
-	simultaneously,
-	see <em><a href="gm_profile.html">Profile Tool help page</a></em>.</dd>
+	simultaneously.</dd>
       <dt><img src="icons/layer-raster-histogram.png">&nbsp;
         <em>Histogram tool</em></dt>
Modified: grass/trunk/gui/wxpython/docs/wxGUI_layer_manager.jpg
(Binary files differ)
