[GRASS-SVN] r48482 - grass/branches/develbranch_6/locale/po
Mon Sep 26 16:17:21 EDT 2011
Author: neteler
Date: 2011-09-26 13:17:21 -0700 (Mon, 26 Sep 2011)
New Revision: 48482
   grass/branches/develbranch_6/locale/po/grasslibs_de.po
Robert Nuske: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grasslibs_de.po
--- grass/branches/develbranch_6/locale/po/grasslibs_de.po	2011-09-26 20:17:00 UTC (rev 48481)
+++ grass/branches/develbranch_6/locale/po/grasslibs_de.po	2011-09-26 20:17:21 UTC (rev 48482)
@@ -2,11 +2,11 @@
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2004, 2008, 2010, 2011 GRASS Development Team
-# Stephan Holl <stephan.holl intevation.de>, 2007.
-# Stephan Holl <holl gdf-hannover.de>, 2004, 2005, 2006.
 # Markus Neteler <neteler itc.it>, 2004.
+# Stephan Holl <holl gdf-hannover.de>, 2004, 2005, 2006.
+# Stephan Holl <stephan.holl intevation.de>, 2007.
 # Markus Neteler <neteler osgeo.org>, 2008.
-# Robert Nuske <rnuske gwdg.de>, 2009, 2010.
+# Robert Nuske <rnuske gwdg.de>, 2009, 2010, 2011.
 # Robert Nuske <robert.nuske nw-fva.de>, 2011.
 # Helmut Kudrnovsky <hellik web.de>, 2011.
 msgid ""
@@ -14,8 +14,8 @@
 "Project-Id-Version: grasslibs_de\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2011-09-04 18:52+0200\n"
-"PO-Revision-Date: 2011-05-08 20:58+0100\n"
-"Last-Translator: Markus Neteler <neteler osgeo.org>\n"
+"PO-Revision-Date: 2011-09-26 21:41+0200\n"
+"Last-Translator: Robert Nuske <rnuske nw-fva.de>\n"
 "Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=ISO-8859-15\n"
@@ -31,7 +31,7 @@
 #: ../lib/raster/rem_io.c:167
 #, c-format
 msgid "Unable to allocate memory\n"
-msgstr "Kann keinen Speicher belegen\n"
+msgstr "Kann keinen Speicher allokieren.\n"
 #: ../lib/raster/rem_io.c:217
 #, c-format
@@ -64,7 +64,7 @@
 #: ../lib/raster/io_sock.c:72
 #, c-format
 msgid "Failed to get socket name for monitor <%s>."
-msgstr "Konnte für das Grafikfenster <%s> kein Socketnamen bekommen."
+msgstr "Konnte für das Grafikfenster <%s> kein Socket-Namen bekommen."
 #: ../lib/raster/io_sock.c:81
 #, c-format
@@ -89,7 +89,7 @@
 #: ../lib/raster/io_sock.c:111
 msgid "Connect attempt timed out."
-msgstr "Verbindeversuche abgebrochen."
+msgstr "Verbindungsversuch abgebrochen."
 #: ../lib/raster/io_sock.c:112
 msgid "Probably an error with the server."
@@ -111,10 +111,8 @@
 #: ../lib/symbol/read.c:259
 #, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Falscher Symbolname: '%s' (sollte sein: Gruppe/Name oder Gruppe/Name at Mapset)."
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Falscher Symbolname: '%s' (sollte sein: Gruppe/Name oder Gruppe/Name at Mapset)."
 #: ../lib/symbol/read.c:283
 #, c-format
@@ -129,7 +127,7 @@
 #: ../lib/cairodriver/Draw_bitmap.c:47
 msgid "Cairo_draw_bitmap: Failed to create source"
-msgstr "Cairo_draw_bitmap: Erzeugen der Quelle fehlgeschlagen"
+msgstr "Cairo_draw_bitmap: Erzeugen der Quelle fehlgeschlagen."
 #: ../lib/proj/get_proj.c:150
 #, c-format
@@ -147,7 +145,7 @@
 #: ../lib/proj/get_proj.c:296
 msgid "Option input overflowed option table"
-msgstr "Eingabe Option finden keinen Platz mehr in der Optionstabelle."
+msgstr "Eingegebene Option findet keinen Platz mehr in der Optionstabelle."
 #: ../lib/proj/get_proj.c:327
 #, c-format
@@ -156,19 +154,19 @@
 #: ../lib/proj/get_proj.c:403
 msgid "Input Projection Parameters"
-msgstr "Eingabeparameter der Projektion"
+msgstr "Eingabe der Projektionsparameter"
 #: ../lib/proj/get_proj.c:406
 msgid "Input Unit Factor"
-msgstr "Einheitenfaktor der Eingabe"
+msgstr "Eingabe des Einheitenfaktors"
 #: ../lib/proj/get_proj.c:416
 msgid "Output Projection Parameters"
-msgstr "Ausgabeparameter der Projektion"
+msgstr "Ausgabe der Projektionsparameter"
 #: ../lib/proj/get_proj.c:419
 msgid "Output Unit Factor"
-msgstr "Einheitenfaktor der Ausgabe"
+msgstr "Ausgabe des Einheitenfaktors"
 #: ../lib/proj/datum.c:251
 msgid "Unable to open temporary file"
@@ -178,7 +176,7 @@
 #: ../lib/gis/get_ell_name.c:45 ../lib/gis/get_datum_name.c:58
 #, c-format
 msgid "Hit RETURN to cancel request\n"
-msgstr "Drücke RETURN um Anfrage abzubrechen\n"
+msgstr "Drücke RETURN um Anfrage abzubrechen.\n"
 #: ../lib/proj/datum.c:419 ../lib/proj/datum.c:484
 #, c-format
@@ -188,7 +186,7 @@
 #: ../lib/proj/datum.c:432 ../lib/proj/datum.c:498
 #, c-format
 msgid "Error in datum table file <%s>, line %d"
-msgstr "Fehler in der Datei mit Datums-Tabelle <%s>, Zeile %d."
+msgstr "Fehler in der Datums-Tabelle <%s>, Zeile %d."
 #: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
 #, c-format
@@ -198,24 +196,24 @@
 #: ../lib/proj/ellipse.c:75
 #, c-format
 msgid "Invalid ellipsoid <%s> in file"
-msgstr "Ungültiger Ellipsoid <%s> in Datei."
+msgstr "Ungültiges Ellipsoid <%s> in der Datei."
 #: ../lib/proj/ellipse.c:98
 msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr "Kein zweiter Ellipsoid Bezeichner (rf, es oder b) in Datei."
+msgstr "Kein zweiter Ellipsoid-Parameter (rf, es oder b) in der Datei."
 #: ../lib/proj/ellipse.c:102
 msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr "Ungültiger Ellipsoid Bezeichner (a, rf, es oder b) in Datei."
+msgstr "Ungültiger Ellipsoid-Parameter (a, rf, es oder b) in der Datei."
 #: ../lib/proj/ellipse.c:115
 msgid "No ellipsoid info given in file"
-msgstr "Keine Ellipsoid-Informationen in Datei."
+msgstr "Keine Informationen zum Ellipsoid in der Datei."
 #: ../lib/proj/ellipse.c:215 ../lib/gis/get_ellipse.c:283
 #, c-format
 msgid "Unable to open ellipsoid table file <%s>"
-msgstr "Kann die Ellipsoid-Tabelle in datei <%s> nicht öffnen."
+msgstr "Kann die Ellipsoid-Tabelle <%s> nicht öffnen."
 #: ../lib/proj/ellipse.c:268 ../lib/gis/get_ellipse.c:338
 #, c-format
@@ -233,22 +231,17 @@
 #: ../lib/proj/convert.c:115
 msgid "Unable get PROJ.4-style parameter string"
-msgstr "Kann PROJ.4-Style Parameter Zeichenkette nicht bekommen."
+msgstr "Kann Zeichenkette im PROJ.4-Stil nicht bekommen."
 #: ../lib/proj/convert.c:127
 #, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR kann PROJ.4-Style Parameter Zeichenkette '%s' nicht integrieren (OGR "
-"Fehler-Code war %d)."
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR kann die Zeichenkette im PROJ.4-Stil '%s' nicht interpretieren (OGR Fehler-Code %d)."
 #: ../lib/proj/convert.c:133
 #, c-format
 msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-"OGR kann WKT-Style Parameter Zeichenkette nicht bekommen (OGR Fehler-Code "
-"war %d)."
+msgstr "OGR kann die Zeichenkette im WKT-Stil nicht bekommen (OGR Fehler-Code %d)."
 #: ../lib/proj/convert.c:390
 msgid "No projection name! Projection parameters likely to be meaningless."
@@ -257,33 +250,25 @@
 #: ../lib/proj/convert.c:426
 #, c-format
 msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr "Datum <%s> nicht erkannt von GRASS und keine Parameter gefunden."
+msgstr "Datum <%s> von GRASS nicht erkannt und keine Parameter gefunden."
 #: ../lib/proj/convert.c:442
 #, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"Datum <%s> wurde von GRASS erkannt, doch es wurden keine Parameter gefunden. "
-"Sie sollten dies genauer untersuchen."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "Datum <%s> wurde von GRASS erkannt, doch es wurden keine Parameter gefunden. Sie sollten dies genauer untersuchen."
 #: ../lib/proj/convert.c:446
 #, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"Ungültige Transformationsnummer %d; gültiger Wertebereich 1 bis %d. Lasse "
-"Datumstransformationsparameter unbestimmt."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Ungültige Transformationsnummer %d; gültiger Wertebereich 1 bis %d. Datumstransformationsparameter bleiben unbestimmt."
 #: ../lib/gis/sample.c:71
 msgid "Unknown interpolation type"
-msgstr "Unbekannter Interpolationstyp"
+msgstr "Unbekannter Interpolationstyp."
 #: ../lib/gis/sample.c:284
 msgid "\"no data\" label found; setting to zero"
-msgstr "\"NO DATA\"-Label gefunden; setzte es auf null"
+msgstr "\"no data\"-Label gefunden; setzte es auf Null."
 #: ../lib/gis/sample.c:299
 msgid "Problem reading raster map"
@@ -312,7 +297,7 @@
 "Please identify the type desired:\n"
 msgstr ""
 "\n"
-"Bitte identifizieren Sie den entsprechenden Typ:\n"
+"Bitte identifizieren Sie den gewünschten Typ:\n"
 #: ../lib/gis/make_colr.c:53
 #, c-format
@@ -322,7 +307,7 @@
 #: ../lib/gis/make_colr.c:54
 #, c-format
 msgid "    2:  Red, green, and blue color ramps\n"
-msgstr "    2:  Rote, grüne und blaue Farbrampen\n"
+msgstr "    2:  Rote, grüne und blaue Farbverläufe\n"
 #: ../lib/gis/make_colr.c:55
 #, c-format
@@ -337,7 +322,7 @@
 #: ../lib/gis/make_colr.c:57
 #, c-format
 msgid "    5:  Aspect\n"
-msgstr "    5:  Farbe speziell für Hangneigungskarten\n"
+msgstr "    5:  Exposition\n"
 #: ../lib/gis/make_colr.c:58
 #, c-format
@@ -357,7 +342,7 @@
 #: ../lib/gis/make_colr.c:61
 #, c-format
 msgid "RETURN  quit\n"
-msgstr "RETURN  um abzubrechen\n"
+msgstr "RETURN  um abzubrechen.\n"
 #: ../lib/gis/make_colr.c:91
 #, c-format
@@ -366,12 +351,12 @@
 "%s invalid; Try again > "
 msgstr ""
 "\n"
-"%s ist ungültig; Bitte nocheinmal probieren > "
+"%s ist ungültig. Versuchen Sie es erneut > "
 #: ../lib/gis/find_file.c:74
 #, c-format
 msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr "'%s/%s' wurde in mehreren Mapsets gefunden (auch gefunden in <%s>)."
+msgstr "'%s/%s' wurde in mehreren Mapsets gefunden (auch in <%s>)."
 #: ../lib/gis/find_file.c:82
 #, c-format
@@ -389,12 +374,8 @@
 msgstr "Kann keine quant-Regeln für Karte %s schreiben."
 #: ../lib/gis/set_window.c:76
-msgid ""
-"G_set_window(): projection/zone differs from that of currently open raster "
-"maps"
-msgstr ""
-"G_set_window(): Projektion/Zone unterscheidet sich von den gerade geöffneten "
-"Rasterdateien."
+msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window(): Projektion/Zone unterscheidet sich von gerade geöffneten Rasterkarten."
 #: ../lib/gis/quant_io.c:89
 #, c-format
@@ -409,54 +390,47 @@
 #: ../lib/gis/quant_io.c:168
 #, c-format
 msgid "quantization file [%s] in mapset [%s] %s"
-msgstr "Quantisierungsdatei [%s] in Mapset [%s] %s"
+msgstr "Quantisierungsdatei [%s] in Mapset [%s] %s."
 #: ../lib/gis/put_row.c:215
 #, c-format
 msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-msgstr ""
-"G_put_map_row: %s ist keine Interger-Karte! Benutzen Sie G_put_[f/d]"
-"_raster_row()!"
+msgstr "G_put_map_row: %s ist keine Integer-Karte! Benutzen Sie G_put_[f/d]_raster_row()!"
 #: ../lib/gis/put_row.c:251
 #, c-format
 msgid "%s: map [%s] not open for write - request ignored"
-msgstr ""
-"%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
+msgstr "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
 #: ../lib/gis/put_row.c:259
 #, c-format
 msgid "%s: map [%s] not open for random write - request ignored"
-msgstr ""
-"%s Karte [%s] ist nicht zum zufälligen Schreiben geöffnet - Anfrage wird "
-"ignoriert."
+msgstr "%s Karte [%s] ist nicht zum zufälligen Schreiben geöffnet - Anfrage wird ignoriert."
 #: ../lib/gis/put_row.c:266
 #, c-format
 msgid "%s: map [%s] not open for sequential write - request ignored"
-msgstr ""
-"%s: Karte [%s] ist nicht für sequentielles Schreiben geöffnet - Anfrage wird "
-"ignoriert."
+msgstr "%s: Karte [%s] ist nicht für sequentielles Schreiben geöffnet - Anfrage wird ignoriert."
 #: ../lib/gis/put_row.c:270
 #, c-format
 msgid "%s: unopened file descriptor - request ignored"
-msgstr "%s: Ungeöffneter Datei-Deskripor - Anfrage ignoriert."
+msgstr "%s: Ungeöffneter Dateideskriptor - Anfrage ignoriert."
 #: ../lib/gis/put_row.c:310
 #, c-format
 msgid "map [%s] - unable to write row %d"
-msgstr "Karte [%s] - Kann Zeile %d nicht schreiben. "
+msgstr "Karte [%s] - Kann Zeile %d nicht schreiben."
 #: ../lib/gis/put_row.c:393
 #, c-format
 msgid "xdr_float failed for index %d of row %d"
-msgstr "xdr_float fehlgeschlagen für Index %d in Zeile %d"
+msgstr "xdr_float fehlgeschlagen für Index %d in Zeile %d."
 #: ../lib/gis/put_row.c:419
 #, c-format
 msgid "xdr_double failed for index %d of row %d"
-msgstr "xdr_double fehlerhaft für Index %d der Zeile %d"
+msgstr "xdr_double fehlgeschlagen für Index %d der Zeile %d."
 #: ../lib/gis/put_row.c:754
 #, c-format
@@ -466,17 +440,17 @@
 #: ../lib/gis/put_row.c:776 ../lib/gis/put_row.c:781
 #, c-format
 msgid "error writing null row %d"
-msgstr "Fehler beim Schreiben der Null-Zeile %d."
+msgstr "Fehler beim Schreiben der NULL-Zeile %d."
 #: ../lib/gis/cats.c:381
 #, c-format
 msgid "category support for [%s] in mapset [%s] %s"
-msgstr "Kategorie Unterstützung für [%s] im Mapset [%s] %s"
+msgstr "Kategorie-Unterstützung für [%s] im Mapset [%s] %s."
 #: ../lib/gis/cats.c:417
 #, c-format
 msgid "category support for vector map [%s] in mapset [%s] %s"
-msgstr "Kategorie Unterstützung für die Vektorkarte [%s] in Mapset [%s] %s"
+msgstr "Kategorie-Unterstützung für Vektorkarte [%s] in Mapset [%s] %s."
 #: ../lib/gis/view.c:177
 #, c-format
@@ -496,27 +470,22 @@
 #: ../lib/gis/view.c:546
 #, c-format
 msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-" Das in \"%s\" abgespeicherte Fenster ist komplett außerhalb des derzeitigen "
-"GRASS Fensters."
+msgstr " Das in \"%s\" abgespeicherte Fenster ist komplett außerhalb des derzeitigen GRASS Fensters."
 #: ../lib/gis/view.c:550
 #, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem "
-"derzeitigen GRASS-Fenster."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem derzeitigen GRASS-Fenster."
 #: ../lib/gis/get_projname.c:31
 #, c-format
 msgid "%s not found"
-msgstr "%s nicht gefunden"
+msgstr "%s nicht gefunden."
 #: ../lib/gis/get_projname.c:34
 #, c-format
 msgid "ERROR in reading %s"
-msgstr "FEHLER beim Lesen von %s"
+msgstr "FEHLER beim Lesen von %s."
 #: ../lib/gis/get_projname.c:38 ../lib/gis/get_ell_name.c:31
 #: ../lib/gis/get_datum_name.c:69
@@ -546,17 +515,17 @@
 "invalid projection\n"
 msgstr ""
 "\n"
-"Ungültige Projektion\n"
+"Ungültige Projektion.\n"
 #: ../lib/gis/mapset_msc.c:60
 #, c-format
 msgid "Unable to make mapset element %s (%s): %s"
-msgstr "Kann das Mapset Element %s (%s) nicht erzeugen: %s"
+msgstr "Kann das Mapset Element %s (%s) nicht erzeugen: %s."
 #: ../lib/gis/mapset_msc.c:64
 #, c-format
 msgid "Unable to access mapset element %s (%s): %s"
-msgstr "Kann auf das Mapset Element %s (%s) nicht zugreifen: %s"
+msgstr "Kann auf das Mapset Element %s (%s) nicht zugreifen: %s."
 #: ../lib/gis/null_val.c:68
 msgid "EmbedGivenNulls: wrong data type!"
@@ -585,30 +554,30 @@
 #: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:247
 #, c-format
 msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr "Repariere subtilen Rundungsfehler der Eingabe des Nordgrenze (%g>%g)."
+msgstr "Repariere subtilen Rundungsfehler der Eingabe der Nordgrenze (%g>%g)."
 #: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:252
 msgid "Illegal latitude for North"
-msgstr "Ungültige geographische Breite für Norden."
+msgstr "Ungültige geographische Breite für Nord."
 #: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:258
 #, c-format
 msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr "Repariere subtilen Rundungsfehler der Eingabe des Südgrenze (%g>%g)."
+msgstr "Repariere subtilen Rundungsfehler der Eingabe der Südgrenze (%g>%g)."
 #: ../lib/gis/adj_cellhd.c:95 ../lib/gis/adj_cellhd.c:263
 msgid "Illegal latitude for South"
-msgstr "Ungültige geographische Breite für Süden."
+msgstr "Ungültige geographische Breite für Süd."
 #: ../lib/gis/adj_cellhd.c:107 ../lib/gis/adj_cellhd.c:275
 #, c-format
 msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr "Repariere subtilen Rundungsfehler der Eingabe des Westgrenze (%g>%g)."
+msgstr "Repariere subtilen Rundungsfehler der Eingabe der Westgrenze (%g>%g)."
 #: ../lib/gis/adj_cellhd.c:118 ../lib/gis/adj_cellhd.c:286
 #, c-format
 msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr "Repariere subtilen Rundungsfehler der Eingabe des Ostgrenze (%g>%g)."
+msgstr "Repariere subtilen Rundungsfehler der Eingabe der Ostgrenze (%g>%g)."
 #: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
 msgid "North must be north of South"
@@ -660,7 +629,7 @@
 #: ../lib/gis/parser.c:341
 msgid "Example: income < 1000 and inhab >= 10000"
-msgstr "Beispiel: Einkommen < 1000 and Einwohner >= 10000"
+msgstr "Beispiel: Einkommen < 1000 AND Einwohner >= 10000"
 #: ../lib/gis/parser.c:349
 msgid "Table name"
@@ -696,7 +665,7 @@
 #: ../lib/gis/parser.c:423 ../lib/gis/parser.c:448
 msgid "Name of input raster map(s)"
-msgstr "Name der Eingaberasterkarte(n)"
+msgstr "Name der Eingabe-Rasterkarte(n)"
 #: ../lib/gis/parser.c:431
 msgid "Name for output raster map"
@@ -716,19 +685,19 @@
 #: ../lib/gis/parser.c:481
 msgid "Name of elevation raster map(s)"
-msgstr "Name der Höhenrasterkarte(n)"
+msgstr "Name der Höhenkarte(n)"
 #: ../lib/gis/parser.c:491 ../lib/gis/parser.c:516
 msgid "Name of input raster3d map"
-msgstr "Name der 3D Eingabe-Rasterkarte"
+msgstr "Name der Eingabe-3D-Rasterkarte"
 #: ../lib/gis/parser.c:500 ../lib/gis/parser.c:525
 msgid "Name of input raster3d map(s)"
-msgstr "Name der 3D Eingabe-Rasterkarte(n)"
+msgstr "Name der Eingabe-3D-Rasterkarte(n)"
 #: ../lib/gis/parser.c:508
 msgid "Name for output raster3d map"
-msgstr "Name der 3D Ausgabe-Rasterkarte"
+msgstr "Name der Ausgabe-3D-Rasterkarte"
 #: ../lib/gis/parser.c:535 ../lib/gis/parser.c:560
 msgid "Name of input vector map"
@@ -740,23 +709,19 @@
 #: ../lib/gis/parser.c:552
 msgid "Name for output vector map"
-msgstr "Name für die Ausgabe-Vektorkarte"
+msgstr "Name der Ausgabe-Vektorkarte"
 #: ../lib/gis/parser.c:578 ../lib/gis/parser.c:587
 msgid "Feature type"
-msgstr "Art des Objekts"
+msgstr "Objektart"
 #: ../lib/gis/parser.c:594
 msgid "Layer number"
 msgstr "Layer-Nummer"
 #: ../lib/gis/parser.c:596
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-"Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
-"sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
 #: ../lib/gis/parser.c:605
 msgid "Category value"
@@ -772,11 +737,11 @@
 #: ../lib/gis/parser.c:619
 msgid "Feature id"
-msgstr "Objekt ID"
+msgstr "Objekt-ID"
 #: ../lib/gis/parser.c:626
 msgid "Feature ids"
-msgstr "Objekt IDs"
+msgstr "Objekt-IDs"
 #: ../lib/gis/parser.c:637
 msgid "Name to input file"
@@ -813,15 +778,11 @@
 #: ../lib/gis/parser.c:925
 msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --"
-"verbose."
+msgstr "Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --verbose."
 #: ../lib/gis/parser.c:939
 msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"quiet."
+msgstr "Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --quiet."
 #: ../lib/gis/parser.c:969
 #, c-format
@@ -859,7 +820,7 @@
 msgstr ""
 "\n"
-"Benutzung:\n"
+"Aufruf:\n"
 #: ../lib/gis/parser.c:1152
@@ -878,7 +839,7 @@
 #: ../lib/gis/parser.c:1177 ../lib/gis/parser.c:1507 ../lib/gis/parser.c:1663
 msgid "Verbose module output"
-msgstr "Detaillierter Ausgabemodus"
+msgstr "Ausführlicher Ausgabemodus"
 #: ../lib/gis/parser.c:1178 ../lib/gis/parser.c:1514 ../lib/gis/parser.c:1666
 msgid "Quiet module output"
@@ -1052,7 +1013,7 @@
 #: ../lib/gis/parser.c:2662
 #, c-format
 msgid "     key: %s\n"
-msgstr "     Key: %s\n"
+msgstr "     Schlüssel: %s\n"
 #: ../lib/gis/parser.c:2664
 #, c-format
@@ -1067,7 +1028,7 @@
 #: ../lib/gis/parser.c:2667
 #, c-format
 msgid "required: %s\n"
-msgstr "benötigt werden: %s\n"
+msgstr "benötigt: %s\n"
 #: ../lib/gis/parser.c:2669
 #, c-format
@@ -1115,7 +1076,7 @@
 #: ../lib/gis/color_read.c:116
 #, c-format
 msgid "color support for [%s] in mapset [%s] %s"
-msgstr "Farbunterstützung für Datei [%s] in Mapset [%s] %s"
+msgstr "Farbunterstützung für [%s] in Mapset [%s] %s"
 #: ../lib/gis/timestamp.c:282
 #, c-format
@@ -1144,14 +1105,12 @@
 #: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1049
 #, c-format
 msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-"Die Leseanfrage der Rasterkarte <%s@%s> für Zeile %d ist außerhalb der "
-"Region."
+msgstr "Die Leseanfrage der Rasterkarte <%s@%s> für Zeile %d ist außerhalb der Region."
 #: ../lib/gis/get_row.c:324
 #, c-format
 msgid "cell_values_float: xdr_float failed for index %d"
-msgstr "cell_values_double: xdr_float ist fehlerhaft für Index %d."
+msgstr "cell_values_double: xdr_float ist fehlgeschlagen für Index %d."
 #: ../lib/gis/get_row.c:365
 #, c-format
@@ -1171,7 +1130,7 @@
 #: ../lib/gis/get_row.c:1031 ../lib/gis/get_row.c:1036
 #, c-format
 msgid "Error reading null row %d"
-msgstr "Fehler beim Lesen der Null-Zeile %d."
+msgstr "Fehler beim Lesen der NULL-Zeile %d."
 #: ../lib/gis/get_row.c:1115
 msgid "Unable to realloc buffer"
@@ -1224,7 +1183,7 @@
 #: ../lib/gis/spawn.c:614 ../lib/gis/spawn.c:623
 #, c-format
 msgid "G_spawn: unable to duplicate descriptor %d to %d"
-msgstr "G_spawn: Kann den Deskriptor %d nicht zu %d dublizieren."
+msgstr "G_spawn: Kann den Deskriptor %d nicht zu %d duplizieren."
 #: ../lib/gis/spawn.c:656
 msgid "Unable to create a new process"
@@ -1256,12 +1215,12 @@
 #: ../lib/gis/open_misc.c:45
 #, c-format
 msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr "G__open_misc(read): mapset <%s> passt nicht zu xmapset <%s>"
+msgstr "G__open_misc(read): mapset <%s> passt nicht zu xmapset <%s>."
 #: ../lib/gis/open_misc.c:67
 #, c-format
 msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
-msgstr "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
+msgstr "G__open_misc(write): xmapset <%s> != G_mapset() <%s>."
 #: ../lib/gis/home.c:39
 msgid "unable to determine user's home directory"
@@ -1289,12 +1248,12 @@
 "Please specify ellipsoid name\n"
 msgstr ""
 "\n"
-"Bitte geben Sie ein Ellipsoid an\n"
+"Bitte geben Sie ein Ellipsoid an.\n"
 #: ../lib/gis/get_ell_name.c:44
 #, c-format
 msgid "Enter 'list' for the list of available ellipsoids\n"
-msgstr "Geben Sie 'list' für eine Liste der verfügbaren Ellipsoiden ein.\n"
+msgstr "Geben Sie 'list' für eine Liste der verfügbaren Ellipsoide ein.\n"
 #: ../lib/gis/get_ell_name.c:67
 #, c-format
@@ -1303,7 +1262,7 @@
 "invalid ellipsoid\n"
 msgstr ""
 "\n"
-"Ungültiger Ellipsoid\n"
+"Ungültiger Ellipsoid.\n"
 #: ../lib/gis/get_window.c:67 ../lib/gis/get_window.c:85
 #, c-format
@@ -1335,12 +1294,12 @@
 #: ../lib/gis/list.c:115
 #, c-format
 msgid "no %s files available in current mapset\n"
-msgstr "Keine %s Dateien im aktuellen Mapset vorhanden\n"
+msgstr "Keine %s Dateien im aktuellen Mapset vorhanden.\n"
 #: ../lib/gis/list.c:118
 #, c-format
 msgid "no %s files available in mapset <%s>\n"
-msgstr "Keine %s Dateien in Mapset <%s> vorhanden\n"
+msgstr "Keine %s Dateien in Mapset <%s> vorhanden.\n"
 #: ../lib/gis/list.c:133
 #, c-format
@@ -1359,7 +1318,7 @@
 #: ../lib/gis/histogram.c:57
 #, c-format
 msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "Ein Histogramm für [%s in %s] fehlt (Führen Sie r.support aus)."
+msgstr "Histogramm für [%s in %s] fehlt (Führen Sie r.support aus)."
 #: ../lib/gis/histogram.c:65
 #, c-format
@@ -1383,7 +1342,7 @@
 #: ../lib/gis/ask.c:390
 #, c-format
 msgid "Enter a new %s file name"
-msgstr "Bitte geben Sie einen neuen %s Dateinamen ein."
+msgstr "Geben Sie einen neuen %s Dateinamen ein."
 #: ../lib/gis/ask.c:396
 #, c-format
@@ -1398,8 +1357,7 @@
 #: ../lib/gis/ask.c:421
 #, c-format
 msgid "Enter 'list' for a list of existing %s files\n"
-msgstr ""
-"Geben Sie 'list' für eine Liste der bereits existierenden %s Dateien ein.\n"
+msgstr "Geben Sie 'list' für eine Liste der bereits existierenden %s Dateien ein.\n"
 #: ../lib/gis/ask.c:424
 #, c-format
@@ -1428,7 +1386,7 @@
 "** %s - not found **\n"
 msgstr ""
 "\n"
-"** %s - leider nicht gefunden **\n"
+"** %s - nicht gefunden **\n"
 #: ../lib/gis/ask.c:459 ../lib/gis/ask.c:544
 #, c-format
@@ -1464,7 +1422,7 @@
 "** %s - exists, select another name **\n"
 msgstr ""
 "\n"
-"** %s - existiert bereits, bitte wählen Sie einen anderen Namen **\n"
+"** %s - existiert bereits, wählen Sie einen anderen Namen **\n"
 #: ../lib/gis/ask.c:561
 msgid "ask: can't happen"
@@ -1483,7 +1441,7 @@
 #: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
 #, c-format
 msgid "Output raster map name <%s> is not valid map name"
-msgstr "Name der Ausgabe-Rasterkarte <%s> ist kein gültiger Kartenname."
+msgstr "Ausgabe-Rasterkarte <%s> ist kein gültiger Kartenname."
 #: ../lib/gis/legal_name.c:94 ../lib/gis/legal_name.c:97
 #: ../lib/gis/opencell.c:1011 ../lib/gpde/N_arrays_io.c:56
@@ -1493,12 +1451,12 @@
 #: ../lib/ogsf/Gs3.c:767 ../lib/ogsf/Gs3.c:837 ../lib/ogsf/Gp3.c:54
 #, c-format
 msgid "Raster map <%s> not found"
-msgstr "Rasterkarte <%s> wurde nicht gefunden"
+msgstr "Rasterkarte <%s> wurde nicht gefunden."
 #: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
 #, c-format
 msgid "Output raster map <%s> is used as input"
-msgstr "Ausgabe-Rasterkarte <%s> als Eingabe verwendet"
+msgstr "Ausgabe-Rasterkarte <%s> als Eingabe verwendet."
 #: ../lib/gis/reclass.c:145
 #, c-format
@@ -1508,8 +1466,7 @@
 #: ../lib/gis/reclass.c:148
 #, c-format
 msgid "Illegal reclass format in header file for [%s in %s]"
-msgstr ""
-"Ungültiges Reklassifizierungs-Format in der Header-Datei von [%s in %s]."
+msgstr "Ungültiges Reklassifizierungs-Format in der Header-Datei von [%s in %s]."
 #: ../lib/gis/reclass.c:238
 msgid "Illegal reclass request"
@@ -1550,7 +1507,7 @@
 #: ../lib/gis/mapset.c:57 ../lib/gis/gisinit.c:66
 #, c-format
 msgid "MAPSET %s not found"
-msgstr "MAPSET %s nicht gefunden"
+msgstr "MAPSET %s nicht gefunden."
 #: ../lib/gis/error.c:257
 msgid "WARNING: "
@@ -1563,7 +1520,7 @@
 #: ../lib/gis/get_projinfo.c:33 ../lib/gis/get_projinfo.c:60
 #, c-format
 msgid "<%s> file not found for location <%s>"
-msgstr "Datei <%s> ist nicht in der Location <%s> zu finden"
+msgstr "Datei <%s> ist nicht in der Location <%s> zu finden."
 #: ../lib/gis/get_projinfo.c:39 ../lib/gis/get_projinfo.c:66
 #, c-format
@@ -1590,7 +1547,7 @@
 "to null file %s"
 msgstr ""
 "closecell: Kann  %s\n"
-"nicht in die NULLdatei %s bewegen."
+"nicht in die NULL-Datei %s verschieben."
 #: ../lib/gis/closecell.c:250
 #, c-format
@@ -1604,7 +1561,7 @@
 "to cell file %s"
 msgstr ""
-"nicht in die Datei %s verschieben."
+"nicht in die cell-Datei %s verschieben."
 #: ../lib/gis/closecell.c:355
 msgid "unable to write quant file!"
@@ -1612,28 +1569,24 @@
 #: ../lib/gis/closecell.c:406
 msgid "unable to write f_format file for CELL maps"
-msgstr "Kann f_format Datei nicht schreiben."
+msgstr "Kann f_format Datei für cell-Karten nicht schreiben."
 #: ../lib/gis/unix_socks.c:102
 msgid "Unable to get GIS_LOCK enviroment variable value"
-msgstr "Kann den Inhalt der Umgebungsvariable GIS_LOCK nicht erhalten."
+msgstr "Kann den Inhalt der Umgebungsvariable GIS_LOCK nicht lesen."
 #: ../lib/gis/distance.c:160
 #, c-format
-msgid ""
-"G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%"
-"f)(%f,%f)"
-msgstr ""
-"G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) "
-"S=(%f,%f)(%f,%f)"
+msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgstr "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
 #: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
 msgid "Unable to seek"
-msgstr "Suchen unmöglich"
+msgstr "Suchen unmöglich."
 #: ../lib/gis/seek.c:56
 msgid "Seek offset out of range"
-msgstr "Suchabstand außerhalb des Wertebereichs"
+msgstr "Suchabstand außerhalb des Wertebereichs."
 #: ../lib/gis/alloc.c:43
 #, c-format
@@ -1662,33 +1615,23 @@
 #: ../lib/gis/opencell.c:188
 #, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%"
-"s> which does not exist"
-msgstr ""
-"Kann die Rasterkarte <%s@%s> nicht öffnen, weil es eine Reklassifizierung "
-"der Rasterkarte <%s@%s> ist, die nicht existiert."
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "Kann die Rasterkarte <%s@%s> nicht öffnen, weil es eine Reklassifizierung der Rasterkarte <%s@%s> ist, welche nicht existiert."
 #: ../lib/gis/opencell.c:212
 #, c-format
 msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr "Rasterkarte <%s@%s>: Formatfeld in header Datei ungültig."
+msgstr "Rasterkarte <%s@%s>: Formatfeld in Header-Datei ungültig."
 #: ../lib/gis/opencell.c:219
 #, c-format
-msgid ""
-"Raster map <%s@%s> is in different projection than current region. Found "
-"raster map <%s@%s>, should be <%s>."
-msgstr ""
-"Rasterkarte <%s@%s> ist in einer anderen Projektion als die aktuelle Region. "
-"Habe Rasterkarte <%s@%s> gefunden sollte <%s> sein."
+msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+msgstr "Rasterkarte <%s@%s> ist in einer anderen Projektion als die aktuelle Region. Habe Rasterkarte <%s@%s> gefunden, sollte <%s> sein."
 #: ../lib/gis/opencell.c:226
 #, c-format
 msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-"Rasterkarte <%s@%s> ist in einer anderen Zone (%d) als die aktuelle Region (%"
-"d)."
+msgstr "Rasterkarte <%s@%s> ist in einer anderen Zone (%d) als die aktuelle Region (%d)."
 #: ../lib/gis/opencell.c:233
 #, c-format
@@ -1698,9 +1641,7 @@
 #: ../lib/gis/opencell.c:262
 #, c-format
 msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
-"Karte <%s@%s> ist eine GDAL-Verknüpfung, aber GRASS wurde ohne GDAL-"
-"Unterstützung kompiliert."
+msgstr "Karte <%s@%s> ist eine GDAL-Verknüpfung, aber GRASS wurde ohne GDAL-Unterstützung kompiliert."
 #: ../lib/gis/opencell.c:642
 #, c-format
@@ -1719,24 +1660,20 @@
 #: ../lib/gis/opencell.c:666 ../lib/gis/opencell.c:767
 msgid "G__open_raster_new(): no temp files available"
-msgstr "G__open_raster_new(): keine temp-Datei vorhanden"
+msgstr "G__open_raster_new(): keine temp-Datei vorhanden."
 #: ../lib/gis/opencell.c:736
-msgid ""
-"Unable to write embedded null values for raster map open for random access"
-msgstr ""
-"Kann eingebettete NULL-Werte nicht schreiben für Rasterkarten geöffnet für "
-"den direkten Zugriff."
+msgid "Unable to write embedded null values for raster map open for random access"
+msgstr "Kann eingebettete NULL-Werte nicht schreiben für Rasterkarten geöffnet für den direkten Zugriff."
 #: ../lib/gis/opencell.c:941
 msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
-"G_set_fp_type(): kann nur mit FCELL_TYPE oder DCELL_TYPE aufgerufen werden."
+msgstr "G_set_fp_type(): kann nur mit FCELL_TYPE oder DCELL_TYPE aufgerufen werden."
 #: ../lib/gis/opencell.c:976 ../lib/gis/opencell.c:1064
 #, c-format
 msgid "Unable to find '%s' in '%s'"
-msgstr "Kann '%s' in '%s' nicht finden"
+msgstr "Kann '%s' in '%s' nicht finden."
 #: ../lib/gis/opencell.c:1009
 #, c-format
@@ -1746,7 +1683,7 @@
 #: ../lib/gis/opencell.c:1070
 #, c-format
 msgid "Unable to find '%s'"
-msgstr "Kann '%s' nicht finden"
+msgstr "Kann '%s' nicht finden."
 #: ../lib/gis/opencell.c:1075
 #, c-format
@@ -1764,11 +1701,8 @@
 msgstr "Rasterkarte <%s> ist nicht xdr: byte_order: %s"
 #: ../lib/gis/opencell.c:1179
-msgid ""
-"G_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
-"G_set_quant_rules() kann nur für zum Lesen geöffnete Rasterkarten aufgerufen "
-"werden."
+msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+msgstr "G_set_quant_rules() kann nur für zum Lesen geöffnete Rasterkarten aufgerufen werden."
 #: ../lib/gis/mask_info.c:40
 #, c-format
@@ -1790,7 +1724,7 @@
 "Please specify datum name\n"
 msgstr ""
 "\n"
-"Bitte geben Sie ein Datum an\n"
+"Bitte geben Sie ein Datum an.\n"
 #: ../lib/gis/get_datum_name.c:55
 #, c-format
@@ -1800,7 +1734,7 @@
 #: ../lib/gis/get_datum_name.c:57
 #, c-format
 msgid "or 'custom' if you wish to enter custom parameters\n"
-msgstr "oder 'custom' wenn Sie eigene Parameter eigeben wollen\n"
+msgstr "oder 'custom' wenn Sie eigene Parameter eingeben wollen.\n"
 #: ../lib/gis/get_datum_name.c:97
 #, c-format
@@ -1814,7 +1748,7 @@
 #: ../lib/gis/location.c:44
 #, c-format
 msgid "LOCATION << %s >> not available"
-msgstr "LOCATION  << %s >>  ist nicht verfügbar."
+msgstr "LOCATION  << %s >>  ist nicht vorhanden."
 #: ../lib/gis/myname.c:50
 msgid "This location has no description."
@@ -1828,7 +1762,7 @@
 #: ../lib/gis/open.c:62
 #, c-format
 msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr "G__open(read): mapset <%s> passt nicht zu xmapset <%s>"
+msgstr "G__open(read): mapset <%s> passt nicht zu xmapset <%s>."
 #: ../lib/gis/open.c:84
 #, c-format
@@ -1878,17 +1812,17 @@
 #: ../lib/gis/get_ellipse.c:358 ../lib/gis/get_ellipse.c:384
 #, c-format
 msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "Ungültig a: Feld '%s' in Datei '%s' in <%s>"
+msgstr "Ungültiges a: Feld '%s' in Datei '%s' in <%s>."
 #: ../lib/gis/get_ellipse.c:371
 #, c-format
 msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "Ungültiger Ellipsoid: '%s' in Datei %s in <%s>."
+msgstr "Ungültiges Ellipsoid: '%s' in Datei %s in <%s>."
 #: ../lib/gis/get_ellipse.c:388
 #, c-format
 msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr "Ungültig es: Feld '%s' in Datei %s in <%s>."
+msgstr "Ungültiges es: Feld '%s' in Datei %s in <%s>."
 #: ../lib/gis/get_ellipse.c:402
 #, c-format
@@ -2035,22 +1969,22 @@
 #: ../lib/gis/format.c:157
 #, c-format
 msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr "Initiales Einlesens der komprimierten Datei [%s in %s] fehlgeschlagen."
+msgstr "Initiales Einlesen der komprimierten Datei [%s in %s] fehlgeschlagen."
 #: ../lib/gis/range.c:192
 #, c-format
 msgid "can't read f_range file for [%s in %s]"
-msgstr "Kann f_range Datei für [%s in %s] nicht lesen."
+msgstr "Kann f_range-Datei für [%s in %s] nicht lesen."
 #: ../lib/gis/range.c:308
 #, c-format
 msgid "can't read range file for [%s in %s]"
-msgstr "Kann range Datei für [%s in %s] nicht lesen."
+msgstr "Kann range-Datei für [%s in %s] nicht lesen."
 #: ../lib/gis/range.c:359 ../lib/gis/range.c:412
 #, c-format
 msgid "can't write range file for [%s in %s]"
-msgstr "Kann range Datei für [%s in %s] nicht schreiben."
+msgstr "Kann range-Datei für [%s in %s] nicht schreiben."
 #: ../lib/gis/ls.c:96
 #, c-format
@@ -2072,7 +2006,7 @@
 #: ../lib/gis/color_rules.c:112
 msgid "R/G/B not in range 0-255"
-msgstr "R/G/B nicht im Wertebereich 0-255"
+msgstr "R/G/B nicht im Wertebereich 0-255."
 #: ../lib/gis/color_rules.c:114
 msgid "invalid color name"
@@ -2080,7 +2014,7 @@
 #: ../lib/gis/color_rules.c:116
 msgid "percentage not in range 0-100"
-msgstr "Prozent nicht im Wertebereich 0-100"
+msgstr "Prozent nicht im Wertebereich 0-100."
 #: ../lib/gis/color_rules.c:118
 msgid "invalid value"
@@ -2108,7 +2042,7 @@
 #: ../lib/gis/get_cellhd.c:71 ../lib/gis/get_cellhd.c:100
 #, c-format
 msgid "Unable to read header file for raster map <%s@%s>."
-msgstr "Kann den Header der Rasterkarte <%s@%s> nicht lesen."
+msgstr "Kann Header-Datei der Rasterkarte <%s@%s> nicht lesen."
 #: ../lib/gis/get_cellhd.c:74
 #, c-format
@@ -2118,7 +2052,7 @@
 #: ../lib/gis/get_cellhd.c:78
 #, c-format
 msgid "which is missing."
-msgstr "welches fehlt."
+msgstr "welche fehlt."
 #: ../lib/gis/get_cellhd.c:80
 #, c-format
@@ -2128,14 +2062,12 @@
 #: ../lib/gis/get_cellhd.c:88
 #, c-format
 msgid "Unable to open header file for raster map <%s@%s>"
-msgstr "Kann den Header der Rasterkarte <%s@%s> nicht öffnen."
+msgstr "Kann Header-Datei der Rasterkarte <%s@%s> nicht öffnen."
 #: ../lib/gis/get_cellhd.c:105
 #, c-format
 msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-msgstr ""
-" Es ist eine Reklassifikation der Rasterkarte <%s@%s>, deren header Datei "
-"ungültig ist."
+msgstr " Es ist eine Reklassifikation der Rasterkarte <%s@%s>, deren Header Datei ungültig ist."
 #: ../lib/gis/get_cellhd.c:109
 #, c-format
@@ -2143,29 +2075,22 @@
 msgstr " Ungültiges Format."
 #: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-"Version der Bibliothek ist inkompatible mit Modul. Sie müssen GRASS erneut "
-"bauen oder verschiedene Installationen entwirren."
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "Version der Bibliothek ist inkompatible mit Modul. Sie müssen GRASS erneut bauen oder verschiedene Installationen entwirren."
 #: ../lib/gis/gisinit.c:63
 #, c-format
 msgid "MAPSET %s - permission denied"
-msgstr "MAPSET %s - Zugriff verweigert"
+msgstr "MAPSET %s - Zugriff verweigert."
 #: ../lib/gis/gisinit.c:110
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-"System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() "
-"aufzurufen."
+msgstr "System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() aufzurufen."
 #: ../lib/gis/history.c:132 ../lib/g3d/g3dhistory.c:42
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
-msgstr ""
-"Kann die History-Informationen der Karte [%s] in Mapset [%s] nicht bekommen."
+msgstr "Kann die History-Informationen der Karte [%s] in Mapset [%s] nicht lesen."
 #: ../lib/gis/history.c:180
 #, c-format
@@ -2174,18 +2099,16 @@
 #: ../lib/gis/history.c:263
 msgid "Not enough room in history file to record command line."
-msgstr ""
-"Nicht genügend Platz in der History-Datei um die Kommandozeile zu speichern."
+msgstr "Nicht genügend Platz in der History-Datei, um die Kommandozeile zu speichern."
 #: ../lib/gis/history.c:285
 msgid "Not enough room in history file for command line (truncated)."
-msgstr ""
-"Nicht genügend Platz in der History-Datei für die Kommandozeile (gekürzt)."
+msgstr "Nicht genügend Platz in der History-Datei für die Kommandozeile (gekürzt)."
 #: ../lib/driver/main.c:90
 #, c-format
 msgid "Graphics driver [%s] started"
-msgstr "Grafiktreiber [%s] gestartet"
+msgstr "Grafiktreiber [%s] gestartet."
 #: ../lib/driver/command.c:508
 #, c-format
@@ -2199,14 +2122,12 @@
 #: ../lib/driver/parse_ftcap.c:32
 #, c-format
 msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s: Kann die Font Definitionsdatei nicht lesen; verwende die "
-"Standardeinstellung."
+msgstr "%s: Kann die Font-Definitionsdatei nicht lesen. Verwende die Standardeinstellung."
 #: ../lib/driver/parse_ftcap.c:38
 #, c-format
 msgid "%s: No font definition file"
-msgstr "%s: Keine Font Definitionsdatei."
+msgstr "%s: Keine Font-Definitionsdatei."
 #: ../lib/display/tran_colr.c:129 ../lib/display/tran_colr.c:131
 #, c-format
@@ -2215,12 +2136,8 @@
 #: ../lib/vector/diglib/plus_node.c:217
 #, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"Versuche den Winkel der Linie, die nicht an den Knoten angebunden ist, zu "
-"lesen: Knoten %d, Linie %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Versuche den Winkel der Linie, die nicht an den Knoten angebunden ist, zu lesen: Knoten %d, Linie %d"
 #: ../lib/vector/diglib/plus.c:288
 msgid "Unable read topology for nodes"
@@ -2260,23 +2177,23 @@
 #: ../lib/vector/diglib/plus.c:345 ../lib/vector/diglib/plus.c:371
 msgid "Unable to write head to plus file"
-msgstr "Kann head nicht in die 'plus' Datei schreiben."
+msgstr "Kann head nicht in die plus-Datei schreiben."
 #: ../lib/vector/diglib/plus.c:350
 msgid "Unable to write nodes to plus file"
-msgstr "Kann Knoten nicht in die 'plus' Datei schreiben."
+msgstr "Kann Knoten nicht in die plus-Datei schreiben."
 #: ../lib/vector/diglib/plus.c:355
 msgid "Unable to write lines to plus file"
-msgstr "Kann Linien nicht in die 'plus' Datei schreiben."
+msgstr "Kann Linien nicht in die plus-Datei schreiben."
 #: ../lib/vector/diglib/plus.c:360
 msgid "Unable to write areas to plus file"
-msgstr "Kann Flächen nicht in die 'plus' Datei schreiben."
+msgstr "Kann Flächen nicht in die plus-Datei schreiben."
 #: ../lib/vector/diglib/plus.c:365
 msgid "Unable to write isles to plus file"
-msgstr "Kann Inseln nicht in die 'plus' Datei schreiben."
+msgstr "Kann Inseln nicht in die plus-Datei schreiben."
 #: ../lib/vector/diglib/plus_area.c:207 ../lib/vector/diglib/plus_area.c:675
 #: ../lib/vector/diglib/plus_area.c:683
@@ -2291,41 +2208,39 @@
 #: ../lib/vector/diglib/plus_area.c:299
 msgid "Attempt to delete isle from dead area"
-msgstr "Versuche Insel von einer toten Fläche zu löschen"
+msgstr "Versuche Insel von einer toten Fläche zu löschen."
 #: ../lib/vector/diglib/plus_area.c:316
 #, c-format
 msgid "Attempt to delete not registered isle %d from area %d"
-msgstr "Versuche nicht registrierte Insel %d der Fläche %d zu löschen"
+msgstr "Versuche nicht registrierte Insel %d der Fläche %d zu löschen."
 #: ../lib/vector/diglib/plus_area.c:354
 msgid "Attempt to delete dead area"
-msgstr "Versuche tote Fläche zu löschen"
+msgstr "Versuche tote Fläche zu löschen."
 #: ../lib/vector/diglib/plus_area.c:394
 #, c-format
 msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Toter Zentroid %d für Fläche registriert (Bug in der Vektorbibliothek)."
+msgstr "Toter Zentroid %d für Fläche registriert (Bug in der Vektorbibliothek)."
 #: ../lib/vector/diglib/plus_area.c:418
 #, c-format
 msgid "Attempt to delete area %d info from dead isle %d"
-msgstr "Versuche Fläche %d von toter Insel %d zu löschen"
+msgstr "Versuche Fläche %d von toter Insel %d zu löschen."
 #: ../lib/vector/diglib/plus_area.c:773
 #, c-format
 msgid "Attempt to delete isle %d info from dead area %d"
-msgstr "Versuche Insel %d von toter Fläche %d zu löschen"
+msgstr "Versuche Insel %d von toter Fläche %d zu löschen."
 #: ../lib/vector/diglib/file.c:157
 msgid "Writing to file loaded to memory not supported"
-msgstr ""
-"Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
+msgstr "Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
 #: ../lib/vector/diglib/file.c:200
 msgid "Unable to load file to memory, file not open"
-msgstr "Kann Datei nicht in den Speicher laden, Datei ist nicht offen."
+msgstr "Kann Datei nicht in den Speicher laden. Datei ist nicht offen."
 #: ../lib/vector/diglib/file.c:215
 msgid "Vector memory mode not supported, using 'AUTO'"
@@ -2343,7 +2258,7 @@
 #: ../lib/vector/diglib/spindex.c:314
 msgid "Attempt to delete sidx for dead area"
-msgstr "Versuche sidx einer toten Fläche zu löschen"
+msgstr "Versuche sidx einer toten Fläche zu löschen."
 #: ../lib/vector/diglib/spindex.c:327
 #, c-format
@@ -2362,41 +2277,36 @@
 #: ../lib/vector/Vlib/write_nat.c:640
 msgid "Attempt to delete dead feature"
-msgstr "Versuche ein totes Objekt zu löschen"
+msgstr "Versuche totes Objekt zu löschen."
 #: ../lib/vector/Vlib/write_nat.c:885
 msgid "Attempt to restore alive feature"
-msgstr "Versuche lebendes Objekt wiederherzustellen"
+msgstr "Versuche lebendes Objekt wiederherzustellen."
 #: ../lib/vector/Vlib/legal_vname.c:48
 #, c-format
 msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. Darf nicht '.' oder 'NULL' enthalten."
+msgstr "Ungültiger Name der Vektorkarte <%s>. Darf nicht '.' oder 'NULL' enthalten."
 #: ../lib/vector/Vlib/legal_vname.c:55
 #, c-format
 msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. Muss mit einem Buchstaben beginnen."
+msgstr "Ungültiger Name der Vektorkarte <%s>. Muss mit einem Buchstaben beginnen."
 #: ../lib/vector/Vlib/legal_vname.c:63
 #, c-format
 msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr "Ungültiger Name der Vektorkarte <%s>. Zeichen '%c' nicht erlaubt."
+msgstr "Ungültiger Name der Vektorkarte <%s>. Zeichen '%c' ist nicht erlaubt."
 #: ../lib/vector/Vlib/legal_vname.c:70
 #, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. SQL-Schlüsselwort darf nicht als "
-"Vektorkartenname benutzt werden."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Ungültiger Name der Vektorkarte <%s>. SQL-Schlüsselwort darf nicht als Vektorkartenname benutzt werden."
 #: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
 #, c-format
 msgid "Output vector map name <%s> is not valid map name"
-msgstr "Name der Ausgabe-Vektorkarte <%s> ist kein gültiger Kartenname."
+msgstr "Ausgabe-Vektorkarte <%s> ist kein gültiger Kartenname."
 #: ../lib/vector/Vlib/legal_vname.c:118 ../lib/vector/Vlib/legal_vname.c:121
 #: ../lib/vector/Vlib/map.c:328 ../lib/vector/Vlib/open.c:168
@@ -2408,17 +2318,17 @@
 #: ../lib/vector/Vlib/legal_vname.c:142 ../lib/vector/Vlib/legal_vname.c:146
 #, c-format
 msgid "Output vector map <%s> is used as input"
-msgstr "Ausgabe-Vektorkarte <%s> als Eingabe verwendet"
+msgstr "Ausgabe-Vektorkarte <%s> als Eingabe verwendet."
 #: ../lib/vector/Vlib/read_ogr.c:120 ../lib/vector/Vlib/read_ogr.c:306
 #: ../lib/vector/Vlib/build_ogr.c:309
 #, c-format
 msgid "OGR feature type %d not supported"
-msgstr "OGR Objekttyp %d wird nicht unterstützt."
+msgstr "OGR Objektart %d wird nicht unterstützt."
 #: ../lib/vector/Vlib/read_ogr.c:178
 msgid "OGR feature without ID"
-msgstr "OGR Objekt ohne ID"
+msgstr "OGR Objekt ohne ID."
 #: ../lib/vector/Vlib/read_ogr.c:378 ../lib/vector/Vlib/read_ogr.c:386
 #, c-format
@@ -2437,9 +2347,7 @@
 #: ../lib/vector/Vlib/cats.c:407
 #, c-format
 msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Kann die Kategorie-Zeichenkette '%s' (von '%s') nicht in eine "
-"Kategoriespanne konvertieren."
+msgstr "Kann die Kategorie-Zeichenkette '%s' (von '%s') nicht in eine Kategoriespanne konvertieren."
 #: ../lib/vector/Vlib/sindex.c:97
 msgid "not implemented"
@@ -2451,12 +2359,8 @@
 msgstr "Kann Eintrag %d nicht aus dem räumlichen Index löschen."
 #: ../lib/vector/Vlib/sindex.c:127
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topo level 2"
-msgstr ""
-"Kann räumlichen Index nicht aus der Topologie erzeugen. Vektorkarte ist "
-"nicht auf dem topo level 2 geöffnet."
+msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+msgstr "Kann keinen räumlichen Index aus der Topologie erzeugen. Vektorkarte ist nicht auf dem topo level 2 geöffnet."
 #: ../lib/vector/Vlib/sindex.c:168
 msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
@@ -2464,7 +2368,7 @@
 #: ../lib/vector/Vlib/sindex.c:180
 msgid "BUG (Vect_build_sidx_from_topo): line does not exist"
-msgstr "BUG (Vect_build_sidx_from_topo): Linie exitiert nicht."
+msgstr "BUG (Vect_build_sidx_from_topo): Linie existiert nicht."
 #: ../lib/vector/Vlib/sindex.c:199
 msgid "BUG (Vect_build_sidx_from_topo): area does not exist"
@@ -2488,21 +2392,18 @@
 #: ../lib/vector/Vlib/intersect.c:322
 msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
-msgstr "Fehler in Vect_segment_intersection() (kollineare vertikale Segmente)."
+msgstr "Vect_segment_intersection() FEHLER (kollineare vertikale Segmente)"
 #: ../lib/vector/Vlib/intersect.c:448
 msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-"Fehler in Vect_segment_intersection() (kollineare nicht vertikale Segmente)."
+msgstr "Vect_segment_intersection() FEHLER (kollineare nicht vertikale Segmente)"
 #: ../lib/vector/Vlib/intersect.c:1099 ../lib/vector/Vlib/intersect.c:1105
 #: ../lib/vector/Vlib/intersect.c:1107 ../lib/vector/Vlib/intersect.c:1155
 #: ../lib/vector/Vlib/intersect.c:1164 ../lib/vector/Vlib/intersect.c:1185
 #: ../lib/vector/Vlib/intersect.c:1202
 msgid "Error while adding point to array. Out of memory"
-msgstr ""
-"Fehler beim Hinzufügen eines Punktes zum Array. Nicht genügend "
-"Arbeitsspeicher."
+msgstr "Fehler beim Hinzufügen eines Punktes zum Array. Nicht genügend Arbeitsspeicher."
 #: ../lib/vector/Vlib/level.c:38
 msgid "Map structure was never initialized"
@@ -2515,7 +2416,7 @@
 #: ../lib/vector/Vlib/array.c:99
 #, c-format
 msgid "%d errors in category string."
-msgstr "%d Fehler in Kategorie Zeichenkette."
+msgstr "%d Fehler in Kategorie-Zeichenkette."
 #: ../lib/vector/Vlib/array.c:145 ../lib/vector/Vlib/array.c:269
 msgid "Mixed area and other type requested for vector array"
@@ -2524,7 +2425,7 @@
 #: ../lib/vector/Vlib/array.c:155 ../lib/vector/Vlib/array.c:178
 #: ../lib/vector/Vlib/array.c:306 ../lib/vector/Vlib/array.c:339
 msgid "Not enough space in vector array"
-msgstr "Nicht genung Platz im Vektor-Array."
+msgstr "Nicht genug Platz im Vektor-Array."
 #: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:244
 #: ../lib/vector/Vlib/map.c:365 ../lib/vector/Vlib/map.c:471
@@ -2533,7 +2434,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:79
 #, c-format
 msgid "Database connection not defined for layer %d"
-msgstr "Die Datenbankverbindung für den Layer <%d> nicht definiert."
+msgstr "Die Datenbankverbindung für den Layer <%d> ist nicht definiert."
 #: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:272
 #: ../lib/vector/Vlib/map.c:406 ../lib/vector/Vlib/map.c:622
@@ -2544,13 +2445,12 @@
 #: ../lib/sites/sites.c:372
 #, c-format
 msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Kann die Datenbank <%s> mit dem Treiber <%s> nicht öffnen."
+msgstr "Kann die Datenbank <%s> nicht mit dem Treiber <%s> öffnen."
 #: ../lib/vector/Vlib/array.c:294
 #, c-format
 msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr ""
-"Kann den Datensatz in der Tabelle <%s> nicht selektieren (key %s, where %s)."
+msgstr "Kann den Datensatz in der Tabelle <%s> nicht selektieren (key %s, where %s)."
 #: ../lib/vector/Vlib/geos.c:53 ../lib/vector/Vlib/read.c:99
 msgid "vector map is not opened"
@@ -2558,12 +2458,8 @@
 #: ../lib/vector/Vlib/geos.c:56
 #, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): Objekt ID %d ist nicht sinnvoll (Max. Objekte in "
-"Vektorkarte <%s>: %d)."
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
 #: ../lib/vector/Vlib/geos.c:61
 msgid "only native format supported"
@@ -2577,29 +2473,27 @@
 #: ../lib/vector/Vlib/geos.c:91
 #, c-format
 msgid "Vect_read_area_geos(): unable to read area id %d"
-msgstr "Vect_read_area_geos(): Fläche mit ID %d kann nicht gelesen werden."
+msgstr "Vect_read_area_geos(): Kann Flächen-ID %d nicht lesen."
 #: ../lib/vector/Vlib/geos.c:105
 #, c-format
 msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-"Vect_read_area_geos(): Insel mit ID %d der Fläche mit ID %d kann nicht "
-"gelesen werden."
+msgstr "Vect_read_area_geos(): Kann Insel-ID %d der Fläche mit ID %d nicht lesen."
 #: ../lib/vector/Vlib/geos.c:203
 #, c-format
 msgid "Unable to read line offset %ld"
-msgstr "Kann Linien-Offset %ld nicht lesen"
+msgstr "Kann Linien-Offset %ld nicht lesen."
 #: ../lib/vector/Vlib/geos.c:410
 #, c-format
 msgid "Attempt to read points of nonexistent area id %d"
-msgstr "Versuche Punkte nicht existenter Fläche id %d zu lesen."
+msgstr "Versuche Punkte nicht existenter Fläche mit ID %d zu lesen."
 #: ../lib/vector/Vlib/geos.c:470
 #, c-format
 msgid "Unable to read feature id %d"
-msgstr "Kann Objekt %d nicht lesen."
+msgstr "Kann die Objekt-ID %d nicht lesen."
 #: ../lib/vector/Vlib/snap.c:118
 msgid "Snap vertices Pass 1: select points"
@@ -2637,7 +2531,7 @@
 #: ../lib/vector/Vlib/graph.c:143
 msgid "Unable to add network arc"
-msgstr "Kann Netzwerkverbindung 'network arc' nicht hinzufügen."
+msgstr "Kann 'network arc' nicht hinzufügen."
 #: ../lib/vector/Vlib/graph.c:231 ../lib/vector/Vlib/net.c:521
 #, c-format
@@ -2651,7 +2545,7 @@
 #: ../lib/vector/Vlib/build.c:141
 msgid "Topology was built"
-msgstr "Die Topologie wurde erstellt"
+msgstr "Die Topologie wurde erstellt."
 #: ../lib/vector/Vlib/build.c:153
 #, c-format
@@ -2716,7 +2610,7 @@
 #: ../lib/vector/Vlib/build.c:217
 #, c-format
 msgid "Number of duplicate centroids: %d"
-msgstr "Anzahl mehrfacher Zentroide: %d"
+msgstr "Anzahl duplizierter Zentroide: %d"
 #: ../lib/vector/Vlib/build.c:221
 #, c-format
@@ -2734,20 +2628,20 @@
 #: ../lib/vector/Vlib/build.c:256
 #, c-format
 msgid "Unable to open topo file for write <%s>"
-msgstr "Kann Topologiedatei nicht zum Schreiben von <%s> öffnen."
+msgstr "Kann Topologie-Datei nicht zum Schreiben von <%s> öffnen."
 #: ../lib/vector/Vlib/build.c:264
 msgid "Error writing out topo file"
-msgstr "Fehler beim Schreiben der Topologiedatei"
+msgstr "Fehler beim Schreiben der Topologie-Datei."
 #: ../lib/vector/Vlib/build.c:407
 #, c-format
 msgid "Unable open spatial index file for write <%s>"
-msgstr "Kann datei des räumlichen Index nicht zum Schreiben von <%s> öffnen"
+msgstr "Kann Datei des räumlichen Index nicht zum Schreiben von <%s> öffnen."
 #: ../lib/vector/Vlib/build.c:415
 msgid "Error writing out spatial index file"
-msgstr "Fehler beim Schreiben des räumlichen Index aufgetreten "
+msgstr "Fehler beim Schreiben des räumlichen Index."
 #: ../lib/vector/Vlib/field.c:93
 msgid "Layer number must be 1 or greater"
@@ -2755,9 +2649,7 @@
 #: ../lib/vector/Vlib/field.c:98
 msgid "Unable to add database link, map is not opened in WRITE mode"
-msgstr ""
-"Kann Datenbankverknüpfung nicht hinzufügen. Die Karte ist nicht im "
-"Schreibmodus geöffnet."
+msgstr "Kann Datenbankverknüpfung nicht hinzufügen. Die Karte ist nicht im Schreibmodus geöffnet."
 #: ../lib/vector/Vlib/field.c:104
 msgid "Unable to add database link"
@@ -2801,12 +2693,8 @@
 msgstr "Kann den OGR DBMI-Treiber nicht öffnen."
 #: ../lib/vector/Vlib/field.c:551
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Alle FID Tests fehlgeschlagen. Weder 'FID' noch 'ogc_fid', 'ogr_fid', 'gid' "
-"sind in der OGR DB Tabelle vorhanden."
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Alle FID Tests fehlgeschlagen. Weder 'FID' noch 'ogc_fid', 'ogr_fid', 'gid' sind in der OGR DB Tabelle vorhanden."
 #: ../lib/vector/Vlib/field.c:606
 #, c-format
@@ -2816,17 +2704,16 @@
 #: ../lib/vector/Vlib/field.c:639
 #, c-format
 msgid "Error in rule on row %d in %s"
-msgstr "Fehler in Regel in Zeile %d in %s."
+msgstr "Fehler in der Regel in Zeile %d in %s."
 #: ../lib/vector/Vlib/field.c:709
 #, c-format
 msgid "Unable to open vector database definition file '%s'"
-msgstr "Kann Datei '%s' mit Definition der Vektor Datenbank nicht öffnen."
+msgstr "Kann Datei '%s' mit Definition der Vektor-Datenbank nicht öffnen."
 #: ../lib/vector/Vlib/field.c:804
 msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-"Bug: Versuch eine Karte zu aktualisieren, die nicht im aktuellen Mapset ist."
+msgstr "Bug: Versuch eine Karte zu aktualisieren, die nicht im aktuellen Mapset ist."
 #: ../lib/vector/Vlib/area.c:53
 msgid "Attempt to read points of nonexistent area"
@@ -2835,54 +2722,50 @@
 #: ../lib/vector/Vlib/area.c:125
 #, c-format
 msgid "Unable to read line %d"
-msgstr "Kann Linie %d nicht lesen"
+msgstr "Kann Linie %d nicht lesen."
 #: ../lib/vector/Vlib/area.c:164 ../lib/vector/Vlib/area.c:193
 #: ../lib/vector/Vlib/area.c:257 ../lib/vector/Vlib/area.c:286
 #, c-format
 msgid "Attempt to read topo for dead area (%d)"
-msgstr "Versuche topo einer toten Fläche (%d) zu lesen."
+msgstr "Versuche Topologie einer toten Fläche (%d) zu lesen."
 #: ../lib/vector/Vlib/area.c:313
 #, c-format
 msgid "Attempt to read topo for dead isle (%d)"
-msgstr "Versuche topo einer toten Insel (%d) zu lesen."
+msgstr "Versuche Topologie einer toten Insel (%d) zu lesen."
 #: ../lib/vector/Vlib/header.c:95 ../lib/vector/Vlib/header.c:143
 #, c-format
 msgid "Unable to open header file of vector <%s>"
-msgstr "Kann header Datei der Vektorkarte <%s> nicht öffnen."
+msgstr "Kann Header-Datei der Vektorkarte <%s> nicht öffnen."
 #: ../lib/vector/Vlib/header.c:151
 #, c-format
 msgid "Corrupted row in head: %s"
-msgstr "Kaputte Zeile im header: %s"
+msgstr "Kaputte Zeile im Header: %s"
 #: ../lib/vector/Vlib/header.c:187
 #, c-format
 msgid "Unknown keyword %s in vector head"
-msgstr "Unbekanntes Schlüsselwort %s in Vektor header."
+msgstr "Unbekanntes Schlüsselwort %s in Vektor Header."
 #: ../lib/vector/Vlib/read.c:102
 #, c-format
-msgid ""
-"Vect_read_line(): feature id %d is not reasonable (max features in vector "
-"map <%s>: %d)"
-msgstr ""
-"Vect_read_line(): Objekt ID %d ist nicht sinnvoll (Max. Objekte in "
+msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
 #: ../lib/vector/Vlib/build_nat.c:93
 msgid "Unable to add area (map closed, topo saved)"
-msgstr "Kann Fläche nicht hinzufügen (Karte geschlossen, topo gespeichert)."
+msgstr "Kann Fläche nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
 #: ../lib/vector/Vlib/build_nat.c:102
 msgid "Unable to add isle (map closed, topo saved)"
-msgstr "Kann Insel nicht hinzufügen (Karte geschlossen, topo gespeichert)."
+msgstr "Kann Insel nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
 #: ../lib/vector/Vlib/build_nat.c:112
 msgid "Area of size = 0.0 ignored"
-msgstr "Flächen mit der Größe 0.0 ignoriert."
+msgstr "Flächen mit Größe 0.0 ignoriert."
 #: ../lib/vector/Vlib/build_nat.c:148
 msgid "Request to find area outside nonexistent isle"
@@ -2931,7 +2814,7 @@
 #: ../lib/vector/Vlib/merge_lines.c:192
 #, c-format
 msgid "%d boundaries merged"
-msgstr "%d Flächengrenzen zusammengefasst"
+msgstr "%d Flächengrenzen zusammengelegt"
 #: ../lib/vector/Vlib/merge_lines.c:193
 #, c-format
@@ -2944,8 +2827,7 @@
 #: ../lib/vector/Vlib/buffer2.c:598 ../lib/vector/Vlib/buffer2.c:609
 msgid "Next edge was visited but it is not the first one !!! breaking loop"
-msgstr ""
-"Nächste Kante besucht, aber sie ist nicht die Erste !!! Beende Schleife."
+msgstr "Nächste Kante besucht, aber sie ist nicht die Erste!!! Beende Schleife."
 #: ../lib/vector/Vlib/buffer2.c:657
 msgid "side != 0 feature not implemented"
@@ -2957,7 +2839,7 @@
 #: ../lib/vector/Vlib/buffer2.c:905 ../lib/vector/Vlib/buffer2.c:952
 msgid "Line was not closed"
-msgstr "Linie wurde nicht geschlossen"
+msgstr "Linie wurde nicht geschlossen."
 #: ../lib/vector/Vlib/buffer2.c:918 ../lib/vector/Vlib/buffer2.c:969
 msgid "Vect_get_point_in_poly() failed"
@@ -3025,7 +2907,7 @@
 #: ../lib/vector/Vlib/map.c:459
 #, c-format
 msgid "Unable to open header file for vector map <%s>"
 #: ../lib/vector/Vlib/map.c:481
 #, c-format
@@ -3064,21 +2946,13 @@
 #: ../lib/vector/Vlib/open_nat.c:145
 #, c-format
-msgid ""
-"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
-"Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte "
-"Überschuss)."
+msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+msgstr "Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte zuviel)."
 #: ../lib/vector/Vlib/open_nat.c:149
 #, c-format
-msgid ""
-"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
-msgstr ""
-"Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte "
-"Fehlend)."
+msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte fehlen)."
 #: ../lib/vector/Vlib/net.c:121
 msgid "Building graph..."
@@ -3086,7 +2960,7 @@
 #: ../lib/vector/Vlib/net.c:163
 msgid "Unable to build network graph"
-msgstr "Kann den Netzwerk-Graphen nicht erzeugen."
+msgstr "Kann den Netzwerk-Graph nicht erzeugen."
 #: ../lib/vector/Vlib/net.c:169
 msgid "Forward costs column not specified"
@@ -3100,14 +2974,13 @@
 #: ../lib/vector/Vlib/net.c:360
 #, c-format
 msgid "Column <%s> not found in table <%s>"
-msgstr "Spalte <%s> in Tabelle <%s> nicht gefunden."
+msgstr "Spalte <%s> nicht in Tabelle <%s> gefunden."
 #: ../lib/vector/Vlib/net.c:196 ../lib/vector/Vlib/net.c:213
 #: ../lib/vector/Vlib/net.c:366
 #, c-format
 msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-"Spaltentype der Spalte <%s> wird nicht unterstützt (muss numerisch sein)."
+msgstr "Spaltentyp der Spalte <%s> wird nicht unterstützt (muss numerisch sein)."
 #: ../lib/vector/Vlib/net.c:226
 msgid "Registering arcs..."
@@ -3115,21 +2988,13 @@
 #: ../lib/vector/Vlib/net.c:254
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"Datenbankeintrag für Linie %d (cat = %d, vorwärts/beide Richtung(en)) nicht "
-"gefunden (vorwärts/beide Richtung(en) der Linie übersprungen)."
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "Datenbankeintrag für Linie %d (cat = %d, vorwärts/beide Richtung(en)) nicht gefunden (vorwärts/beide Richtung(en) der Linie übersprungen)."
 #: ../lib/vector/Vlib/net.c:273
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found"
-"(direction of line skipped)"
-msgstr ""
-"Datenbankeintrag für Linie %d (cat = %d, rückwärts Richtung) nicht gefunden "
-"(rückwärts Richtung der Linie übersprungen)."
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "Datenbankeintrag für Linie %d (cat = %d, rückwärts Richtung) nicht gefunden (Richtung der Linie übersprungen)."
 #: ../lib/vector/Vlib/net.c:322
 msgid "Cannot add network arc"
@@ -3142,9 +3007,7 @@
 #: ../lib/vector/Vlib/net.c:402
 #, c-format
 msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"Datenbankeintrag für Knoten %d (cat = %d) nicht gefunden (Kosten auf 0 "
-"gesetzt)."
+msgstr "Datenbankeintrag für Knoten %d (cat = %d) nicht gefunden (Kosten auf 0 gesetzt)."
 #: ../lib/vector/Vlib/net.c:429
 msgid "Flattening the graph..."
@@ -3152,11 +3015,11 @@
 #: ../lib/vector/Vlib/net.c:438
 msgid "Graph was built"
-msgstr "Graph wurde erstellt"
+msgstr "Graph wurde erstellt."
 #: ../lib/vector/Vlib/net.c:602
 msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr "Falsche Linienrichtung in Vect_net_get_line_cost()"
+msgstr "Falsche Linienrichtung in Vect_net_get_line_cost()."
 #: ../lib/vector/Vlib/overlay.c:74
 msgid "unknown operator"
@@ -3164,7 +3027,7 @@
 #: ../lib/vector/Vlib/overlay.c:123
 msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr "Overlay: Typ Linie/Grenze wird nicht von dem Operator AND unterstützt."
+msgstr "Overlay: Typ Linie/Grenze wird nicht vom Operator AND unterstützt."
 #: ../lib/vector/Vlib/overlay.c:126
 msgid "Overlay: area x area types not supported by AND operator"
@@ -3176,7 +3039,7 @@
 #: ../lib/vector/Vlib/poly.c:649
 msgid "conditions failed"
-msgstr "Bedingungen fehlgeschlagen"
+msgstr "Bedingungen fehlgeschlagen."
 #: ../lib/vector/Vlib/break_lines.c:374
 #, c-format
@@ -3211,40 +3074,28 @@
 #: ../lib/vector/Vlib/write.c:219
 #, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht auf topologischem "
-"Level geöffnet."
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht auf topologischem Level geöffnet."
 #: ../lib/vector/Vlib/write.c:225
 #, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht im Schreibmodus "
-"geöffnet."
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
 #: ../lib/vector/Vlib/write.c:239
 #, c-format
 msgid "Unable to delete feature %d from vector map <%s>"
-msgstr "Kann Objekt %d der Vektorkarte <%s> nicht löschen"
+msgstr "Kann Objekt %d der Vektorkarte <%s> nicht löschen."
 #: ../lib/vector/Vlib/write.c:265
 #, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht auf "
-"topologischem Level geöffnet."
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht auf topologischem Level geöffnet."
 #: ../lib/vector/Vlib/write.c:271
 #, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im "
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
 #: ../lib/vector/Vlib/write.c:285
 #, c-format
@@ -3254,19 +3105,16 @@
 #: ../lib/vector/Vlib/close.c:134
 #, c-format
 msgid "Unable to close vector <%s>"
-msgstr "Kann die Vektorkarte <%s> nicht schliessen."
+msgstr "Kann die Vektorkarte <%s> nicht schließen."
 #: ../lib/vector/Vlib/open.c:100
 #, c-format
 msgid "Programmer requested unknown open level %d"
-msgstr "Programmierer forderte unbekanntes open_level %d an"
+msgstr "Programmierer forderte unbekanntes open_level %d an."
 #: ../lib/vector/Vlib/open.c:179
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht zum "
-"Aktualisierung geöffnet werden."
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht zum Aktualisierung geöffnet werden."
 #: ../lib/vector/Vlib/open.c:199 ../lib/ogsf/Gv3.c:63 ../lib/ogsf/Gp3.c:115
 #, c-format
@@ -3276,26 +3124,22 @@
 #: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
 #: ../lib/vector/Vlib/open.c:299
 #, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"Kann die Vektorkarte <%s> nicht auf Level %d öffnen. Versuchen Sie die "
-"Topologie mit v.build neu anzulegen."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "Kann die Vektorkarte <%s> nicht auf Level %d öffnen. Versuchen Sie die Topologie mit v.build neu anzulegen."
 #: ../lib/vector/Vlib/open.c:214
 msgid "Unable to read head file"
-msgstr "Kann head Datei nicht lesen."
+msgstr "Kann Header-Datei nicht lesen."
 #: ../lib/vector/Vlib/open.c:236
 #, c-format
 msgid "Unable to open topology file for vector map <%s>"
-msgstr "Kann die Topologiedatei der Vektorkarte <%s> nicht öffnen."
+msgstr "Kann Topologie-Datei der Vektorkarte <%s> nicht öffnen."
 #: ../lib/vector/Vlib/open.c:262
 #, c-format
 msgid "Unable to open category index file for vector map <%s>"
-msgstr "Kann die Kategorieindexdatei der Vektorkarte <%s> nicht öffnen."
+msgstr "Kann die Kategorieindex-Datei der Vektorkarte <%s> nicht öffnen."
 #: ../lib/vector/Vlib/open.c:353 ../lib/vector/Vlib/open.c:576
 #, c-format
@@ -3319,9 +3163,7 @@
 #: ../lib/vector/Vlib/open.c:731
 msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"Größe der 'coor' Datei unterscheidet sich von dem in der Topologiedatei "
-"gespeicherten Wert."
+msgstr "Größe der 'coor' Datei unterscheidet sich von dem in der Topologie-Datei gespeicherten Wert."
 #: ../lib/vector/Vlib/open.c:742
 #, c-format
@@ -3349,29 +3191,20 @@
 #: ../lib/vector/Vlib/open_ogr.c:147
 #, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
-"Objekt Indexformat Version %d.%d wird nicht unterstützt von dieser Version. "
-"Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "Objekt Indexformat Version %d.%d wird von dieser Version nicht unterstützt. Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
 #: ../lib/vector/Vlib/open_ogr.c:152
 #, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-"Ihre GRASS Version unterstützt nicht vollständig Objekt Indexformat %d.%d "
-"der Vektoren. Versuchen Sie die Topologie zu erneuern oder GRASS zu "
-"aktualisieren."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Ihre GRASS Version unterstützt nicht vollständig das Objekt-Indexformat %d.%d der Vektoren. Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
 #: ../lib/vector/Vlib/level_two.c:251 ../lib/vector/Vlib/level_two.c:276
 #: ../lib/vector/Vlib/level_two.c:300 ../lib/vector/Vlib/level_two.c:319
 #: ../lib/vector/Vlib/level_two.c:337 ../lib/vector/Vlib/level_two.c:356
 #, c-format
 msgid "Vector map <%s> is not open on level >= 2"
-msgstr "Vektorkarte <%s> ist nicht auf einem Level >= 2 geöffnet."
+msgstr "Vektorkarte <%s> ist nicht auf Level >= 2 geöffnet."
 #: ../lib/vector/Vlib/cindex.c:31
 msgid "Category index is not up to date"
@@ -3397,17 +3230,17 @@
 #: ../lib/vector/Vlib/cindex.c:460
 #, c-format
 msgid "Unable to open cidx file <%s> for write"
-msgstr "Kann cidx datei <%s> nicht zum Schreiben öffnen."
+msgstr "Kann cidx Datei <%s> nicht zum Schreiben öffnen."
 #: ../lib/vector/Vlib/cindex.c:468
 #, c-format
 msgid "Error writing out category index file <%s>"
-msgstr "Fehler beim Schreiben der Kategorie-Indexdatei <%s>."
+msgstr "Fehler beim Schreiben der Kategorieindex-Datei <%s>."
 #: ../lib/vector/Vlib/cindex.c:511
 #, c-format
 msgid "Unable to open category index file for vector map <%s@%s>"
-msgstr "Kann die Kategorieindexdatei der Vektorkarte <%s@%s> nicht öffnen."
+msgstr "Kann die Kategorieindex-Datei der Vektorkarte <%s@%s> nicht öffnen."
 #: ../lib/vector/Vlib/build_ogr.c:272
 #, c-format
@@ -3419,11 +3252,8 @@
 msgstr "Teilbauten werden für OGR nicht unterstützt."
 #: ../lib/vector/Vlib/build_ogr.c:342
-msgid ""
-"Random read is not supported by OGR for this layer, cannot build support"
-msgstr ""
-"Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support "
-"nicht erzeugen."
+msgid "Random read is not supported by OGR for this layer, cannot build support"
+msgstr "Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support nicht erzeugen."
 #: ../lib/vector/Vlib/build_ogr.c:349
 msgid "Feature: "
@@ -3467,16 +3297,15 @@
 #: ../lib/vector/vedit/cats.c:63
 #, c-format
 msgid "Unable to set category %d for (feature id %d)"
-msgstr "Kann Kategorie %d für (Objekt ID %d) nicht setzen"
+msgstr "Kann Kategorie %d für (Objekt-ID %d) nicht setzen."
 #: ../lib/vector/vedit/select.c:230
 msgid "Unknown query tool"
 msgstr "Unbekanntes Abfragewerkzeug"
 #: ../lib/vector/neta/spanningtree.c:104
-#, fuzzy
 msgid "Computing minimum spanning tree..."
-msgstr "Berechne Minimum spanning tree..."
+msgstr "Berechne minimalen aufspannenden Baum..."
 #: ../lib/vector/neta/utils.c:219 ../lib/vector/neta/utils.c:232
 #, c-format
@@ -3484,22 +3313,20 @@
 msgstr "'%s' muss > 0 für '%s' sein"
 #: ../lib/vector/neta/utils.c:221
-#, fuzzy
 msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
-msgstr "'where' und 'cats' Parameter werden unterstützt, cat wird ignoriert"
+msgstr "'where' und 'cats' Parameter wurden übergeben, cat wird ignoriert."
 #: ../lib/vector/neta/utils.c:225
 msgid "Unable to load data from database"
-msgstr "Kann Daten der Datenbank nicht laden"
+msgstr "Kann Daten der Datenbank nicht laden."
 #: ../lib/vector/neta/utils.c:236
 msgid "Problem loading category values"
-msgstr "Problem, Kategorie-Werte zu laden"
+msgstr "Problem beim Laden der Kategorie-Werte."
 #: ../lib/vector/neta/allpairs.c:53
-#, fuzzy
 msgid "Computing all pairs shortest paths..."
-msgstr "Berechne alle Paare der kürzesten Wege..."
+msgstr "Berechne kürzeste Wege aller Paare..."
 #: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
 #: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
@@ -3530,11 +3357,11 @@
 #: ../lib/nviz/map_obj.c:59
 msgid "Maximum surfaces loaded!"
-msgstr "Maximale Oberflächenanzahl geladen!"
+msgstr "Maximale Anzahl Oberflächen geladen!"
 #: ../lib/nviz/map_obj.c:88
 msgid "Maximum vector line maps loaded!"
-msgstr "Maximal Vektorlinienkarten geladen!"
+msgstr "Maximale Anzahl Vektorkarten mit Linien geladen!"
 #: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
 #, c-format
@@ -3543,11 +3370,11 @@
 #: ../lib/nviz/map_obj.c:116
 msgid "Maximum vector point maps loaded!"
-msgstr "Maximal Vektorpunktkarten geladen!"
+msgstr "Maximale Anzahl Vektorkarten mit Punkten geladen!"
 #: ../lib/nviz/map_obj.c:143
 msgid "Maximum volumes loaded!"
-msgstr "Maximale Volumen geladen!"
+msgstr "Maximale Anzahl Volumen geladen!"
 #: ../lib/nviz/map_obj.c:152
 #, c-format
@@ -3579,7 +3406,7 @@
 #: ../lib/gpde/N_arrays_io.c:191
 msgid "N_array_2d * array is empty"
-msgstr "N_array_2d * Array ist leer"
+msgstr "N_array_2d * Array ist leer."
 #: ../lib/gpde/N_arrays_io.c:203
 #, c-format
@@ -3589,13 +3416,13 @@
 #: ../lib/gpde/N_arrays_io.c:212
 #, c-format
 msgid "Write 2d array to raster map <%s>"
-msgstr "Schreibe 2D Array in die Rasterkarte <%s>"
+msgstr "Schreibe 2D Array in die Rasterkarte <%s>."
 #: ../lib/gpde/N_arrays_io.c:228 ../lib/gpde/N_arrays_io.c:233
 #: ../lib/gpde/N_arrays_io.c:238
 #, c-format
 msgid "Unable to write raster row %i"
-msgstr "Kann die Rasterzeile %i nicht schreiben"
+msgstr "Kann die Rasterzeile %i nicht schreiben."
 #: ../lib/gpde/N_arrays_io.c:296 ../lib/ogsf/gvl_file.c:428
 #: ../lib/ogsf/Gvl3.c:39
@@ -3625,11 +3452,10 @@
 #: ../lib/gpde/N_arrays_io.c:448
 #, c-format
 msgid "Write 3d array to g3d map <%s>"
-msgstr "Schreibe 3D Array in die G3D-Karte <%s>"
+msgstr "Schreibe 3D Array in die G3D-Karte <%s>."
 #: ../lib/gpde/N_parse_options.c:59
-msgid ""
-"The type of solver which should solve the symmetric linear equation system"
+msgid "The type of solver which should solve the symmetric linear equation system"
 msgstr "Der Solver, der das symmetrische lineare Gleichungssystem lösen soll"
 #: ../lib/gpde/N_parse_options.c:71
@@ -3638,22 +3464,15 @@
 #: ../lib/gpde/N_parse_options.c:80
 msgid "Maximum number of iteration used to solver the linear equation system"
-msgstr ""
-"Die maximale Anzahl an Iterationen, zum Lösen des linearen Gleichungssystems"
+msgstr "Maximale Anzahl Iterationen, zum Lösen des linearen Gleichungssystems"
 #: ../lib/gpde/N_parse_options.c:89
-msgid ""
-"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-msgstr ""
-"Fehlerabbruchkriterien für iterative Löser (jacobi, sor, cg or bicgstab)"
+msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgstr "Fehlerabbruchkriterien für iterative Löser (jacobi, sor, cg or bicgstab)"
 #: ../lib/gpde/N_parse_options.c:98
-msgid ""
-"The relaxation parameter used by the jacobi and sor solver for speedup or "
-"stabilizing"
-msgstr ""
-"Entspannungsparameter (relaxation parameter) zur Beschleunigung oder "
-"Stabilisierung der Jacobi und SOR Löser"
+msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+msgstr "Entspannungsparameter (relaxation parameter) zur Beschleunigung oder Stabilisierung der Jacobi und SOR Löser"
 #: ../lib/gpde/N_parse_options.c:106
 msgid "The calculation time in seconds"
@@ -3962,44 +3781,35 @@
 #: ../lib/init/lock.c:38
 #, c-format
 msgid "Usage: %s file pid"
-msgstr ""
+msgstr "Aufruf: %s Datei pid"
 #: ../lib/init/lock.c:42
 msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
+msgstr "Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows nicht möglich."
 #: ../lib/init/lock.c:60
 #, c-format
 msgid "Unable to write lockfile %s (disk full? Permissions?)"
-msgstr ""
+msgstr "Kann \"lockfile\" %s nicht anlegen (Festplatte voll? Zugriffsrechte?)"
 #: ../lib/rst/interp_float/output2d.c:125
 #, c-format
 msgid "First change your cols number to nsizc %d %d"
-msgstr "Ändern Sie zunächst die Spaltenanzahl zu nsizc %d %d"
+msgstr "Ändern Sie zunächst die Spaltenanzahl zu nsizc %d %d."
 #: ../lib/rst/interp_float/segmen2d.c:111
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"Es dauert zu lange, um Punkte für die Interpolation zu finden - bitte ändern "
-"Sie die Region auf den Bereich, in dem ihre Punkte sind. Fahre mit der "
-"Berechnung fort..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Es dauert zu lange Punkte für die Interpolation zu finden. Bitte ändern Sie die Region auf den Bereich, in der ihre Punkte sind. Fahre mit der Berechnung fort..."
 #: ../lib/rst/interp_float/interp2d.c:212
 #, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-"Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-"
-"value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-value %f, zmin %f, zmax %f."
 #: ../lib/rst/interp_float/input2d.c:47
 #, c-format
 msgid "Mask raster map <%s> not found"
-msgstr "Maske der Rasterkarte <%s> nicht gefunden."
+msgstr "Maske <%s> nicht gefunden."
 #: ../lib/rst/interp_float/input2d.c:69
 msgid "Bitmap mask created"
@@ -4008,7 +3818,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:73
 #, c-format
 msgid "Vector map <%s> is not 3D"
-msgstr "Vektorkarte <%s> ist nicht 3D"
+msgstr "Vektorkarte <%s> ist nicht 3D."
 #: ../lib/rst/interp_float/vinput2d.c:76
 msgid "Loading data from attribute table ..."
@@ -4028,7 +3838,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:121
 msgid "Reading features from vector map ..."
-msgstr "Lese Objekte der Vektorkarte ... "
+msgstr "Lese Objekte der Vektorkarte..."
 #: ../lib/rst/interp_float/vinput2d.c:153
 #: ../lib/rst/interp_float/vinput2d.c:270
@@ -4039,7 +3849,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:171
 #: ../lib/rst/interp_float/vinput2d.c:288
 msgid "Negative value of smoothing detected: sm must be >= 0"
-msgstr "Negativer Wert der Glättung gefunden: sm muss >=0 sein"
+msgstr "Negativer Wert für Glättung: sm muss >=0 sein."
 #: ../lib/rst/interp_float/vinput2d.c:233
 msgid "Reading nodes from vector map ..."
@@ -4052,8 +3862,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:328
 #, c-format
 msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"Es gibt Punkte außerhalb der angegebenen 2D/3D-Region - ignoriere %d Punkte."
+msgstr "Es gibt Punkte außerhalb der angegebenen 2D/3D-Region - ignoriere %d Punkte."
 #: ../lib/rst/interp_float/vinput2d.c:331
 #, c-format
@@ -4062,63 +3871,50 @@
 #: ../lib/rst/interp_float/vinput2d.c:335
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN=%"
-"d"
-msgstr ""
-"%d Punkte, die nach nach der Ausdünnung zur Verfügung stehen, sind weniger "
-"als die angegebenen NPMIN=%d."
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d Punkte, die (nach Ausdünnung) zur Verfügung stehen, sind weniger als die angegebenen NPMIN=%d."
 #: ../lib/rst/interp_float/vinput2d.c:340
 msgid "Zero points in the given region"
-msgstr "Keine Punkte in der Gebietsausdehnung"
+msgstr "Keine Punkte in der Region."
 #: ../lib/rst/interp_float/vinput2d.c:345
 #, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Segmentation-Parameter mit ungültigen Werten: npmin= %d, segmax= %d zum "
-"glatten Aneinandersetzen der Segmente, npmin > segmax (siehe Handbuch)."
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Segmentation-Parameter mit ungültigen Werten: npmin= %d, segmax= %d zum glatten Aneinandersetzen der Segmente, npmin > segmax (siehe Handbuch)."
 #: ../lib/rst/interp_float/vinput2d.c:351
 #, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Es stehen weniger als %d Punkte zur Interpolation bereit. Keine "
-"Segmentierung notwendig. Um das Programm schneller laufen zu lassen, setzen "
-"Sie segmax = %d (vgl. Bedienungsanleitung)."
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Es gibt weniger als %d Punkte für die Interpolation. Keine Segmentierung notwendig. Um das Programm schneller laufen zu lassen, setzen Sie segmax = %d (siehe Handbuch)."
 #: ../lib/rst/interp_float/vinput2d.c:355
 #, c-format
 msgid "Number of points from vector map %d"
-msgstr "Anzahl der Punkte der Vektorkarte %d"
+msgstr "Anzahl der Punkte aus der Vektorkarte %d"
 #: ../lib/rst/interp_float/vinput2d.c:356
 #, c-format
 msgid "Number of points outside of 2D/3D region %d"
-msgstr "Anzahl der Punkte außerhalb der 2D/3D Gebietsausdehnung: %d"
+msgstr "Anzahl der Punkte außerhalb der 2D/3D Region %d"
 #: ../lib/rst/interp_float/vinput2d.c:358
 #, c-format
 msgid "Number of points being used %d"
-msgstr "Anzahl der verwendeten Punkte: %d"
+msgstr "Anzahl der verwendeten Punkte %d"
 #: ../lib/rst/interp_float/vinput2d.c:391
 msgid "Some points outside of region (ignored)"
-msgstr "Einige Punkte sind außerhalb der Region -- ignoriere dies..."
+msgstr "Einige Punkte sind außerhalb der Region (ignoriert)."
 #: ../lib/rst/interp_float/vinput2d.c:397
 msgid "Unable to allocate memory"
-msgstr "Kann keinen Speicher belegen."
+msgstr "Kann keinen Speicher allokieren."
 #: ../lib/rst/interp_float/vinput2d.c:405
 #, c-format
 msgid "Unable to insert %f,%f,%f a = %d"
-msgstr "Kann %f,%f,%f a = %d nicht einfügen"
+msgstr "Kann %f,%f,%f a = %d nicht einfügen."
 #: ../lib/g3d/g3dparam.c:52
 msgid "Data type used in the output file"
@@ -4126,25 +3922,23 @@
 #: ../lib/g3d/g3dparam.c:61
 msgid "Precision used in the output file (default, max, or 0 to 52)"
-msgstr ""
-"Genauigkeit, die für die Ausgabedatei genutzt wird (default, max, oder 0 bis "
-"52)."
+msgstr "Genauigkeit für die Ausgabedatei (default, max, oder 0 bis 52)."
 #: ../lib/g3d/g3dparam.c:71
 msgid "The compression method used in the output file"
-msgstr "Kompressionsmethode, die für die Ausgabe verwendet werden soll."
+msgstr "Kompressionsmethode für die Ausgabedatei"
 #: ../lib/g3d/g3dparam.c:81
 msgid "The dimensions of the tiles used in the output file"
-msgstr "Dimension der Kacheln, die für die Ausgabe verwerndet werden soll."
+msgstr "Dimension der Kacheln in der Ausgabedatei"
 #: ../lib/g3d/g3dparam.c:116
 msgid "G3d_getStandard3dParams: precision value invalid"
-msgstr "G3d_getStandard3dParams: Genauigkeitswert ungültig"
+msgstr "G3d_getStandard3dParams: Genauigkeit ungültig"
 #: ../lib/g3d/g3dparam.c:149
 msgid "G3d_getStandard3dParams: tile dimension value invalid"
-msgstr "G3d_getStandard3dParams: Kacheldimensionswert ungültig"
+msgstr "G3d_getStandard3dParams: Kacheldimension ungültig"
 #: ../lib/g3d/g3dparam.c:173
 msgid "Window replacing the default"
@@ -4176,11 +3970,11 @@
 #: ../lib/g3d/g3dopen.c:124
 msgid "G3d_openCellOld: projection does not match window projection"
-msgstr "G3d_openCellOld: Reprojektion passt nicht in das Fenster"
+msgstr "G3d_openCellOld: Projektion passt nicht zu der Projektion des Fensters"
 #: ../lib/g3d/g3dopen.c:128
 msgid "G3d_openCellOld: zone does not match window zone"
-msgstr "G3d_openCellOld: Zone passt nicht mit der Fensterzone überein."
+msgstr "G3d_openCellOld: Zone passt nicht zu der Zone des Fensters"
 #: ../lib/g3d/g3dopen.c:140 ../lib/g3d/g3dopen.c:157
 msgid "G3d_openCellOld: can't read header"
@@ -4220,9 +4014,7 @@
 #: ../lib/arraystats/class.c:21
 msgid "Discont algorithm currently not available because of bugs"
-msgstr ""
-"Discont Algorithmus ist zur Zeit auf Grund von Programmierfehlern nicht "
-"vorhanden."
+msgstr "Discont Algorithmus ist zur Zeit wegen Bugs nicht vorhanden."
 #: ../lib/arraystats/class.c:23
 #, c-format
@@ -4236,12 +4028,8 @@
 #: ../lib/arraystats/class.c:221
 #, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-"Klassengrenzen außerhalb der min-max Spanne. Anzahl der Klassen auf %i "
-"reduziert. Verwende dennoch die Wahrscheinlichkeiten für %i Klassen. "
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "Klassengrenzen außerhalb der min-max Spanne. Anzahl der Klassen auf %i reduziert. Verwende dennoch die Wahrscheinlichkeiten für %i Klassen. "
 #: ../lib/ogsf/GVL2.c:248
 #, c-format
@@ -4250,7 +4038,7 @@
 #: ../lib/ogsf/trans.c:180
 msgid "Out of matrix stack space"
-msgstr "Habe kein Platz mehr auf dem Matrix-Stack."
+msgstr "Kein Platz mehr auf dem Matrix-Stack."
 #: ../lib/ogsf/trans.c:200
 msgid "Tried to pop an empty stack"
@@ -4264,7 +4052,7 @@
 #: ../lib/ogsf/gsd_legend.c:251
 #, c-format
 msgid "Unable to read category file of raster map <%s>"
-msgstr "Kannn die Kategoriedatei der Rasterkarte <%s> lesen."
+msgstr "Kann die Kategoriedatei der Rasterkarte <%s> nicht lesen."
 #: ../lib/ogsf/gsd_legend.c:268
 #, c-format
@@ -4278,7 +4066,7 @@
 #: ../lib/ogsf/gsd_legend.c:294
 msgid "Range request error for legend"
-msgstr "Fehler bei der Anforderung des Wertebereiches für Legende."
+msgstr "Anforderung des Wertebereiches für Legende fehlgeschlagen."
 #: ../lib/ogsf/gsd_legend.c:384
 msgid "Unable to show discrete FP range (use list"
@@ -4286,7 +4074,7 @@
 #: ../lib/ogsf/gsd_legend.c:500
 msgid "Too many categories to show as discrete!"
-msgstr "Zu viele Kategorien um es kategorisiert anzuzeigen."
+msgstr "Zu viele Kategorien um es diskret anzuzeigen!"
 #: ../lib/ogsf/gsd_legend.c:502
 msgid "Try using smaller font!"
@@ -4294,9 +4082,7 @@
 #: ../lib/ogsf/gsd_surf.c:1742
 msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
-"Schnittflächenpunkte der Oberflächen passen nicht zusammen. Überprüfen Sie "
-"die Auflösung(en)."
+msgstr "Schnittflächenpunkte der Oberflächen passen nicht zusammen. Überprüfen Sie die Auflösung(en)."
 #: ../lib/ogsf/gvl_file.c:104
 msgid "Maximum number of datafiles exceeded"
@@ -4319,12 +4105,8 @@
 #: ../lib/ogsf/gsd_prim.c:630
 #, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): %c ist eine ungültige Achsenbestimmung. Rotation ignoriert. "
-"Bitte, unterrichten Sie die GRASS Entwicklern über diesen Fehler."
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): %c ist eine ungültige Achsenbestimmung. Rotation ignoriert. Bitte, unterrichten Sie die GRASS Entwicklern über diesen Fehler."
 #: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/gsd_img_ppm.c:53
 #: ../lib/ogsf/gsd_img_ppm.c:96 ../lib/ogsf/GK2.c:219
@@ -4350,8 +4132,7 @@
 #: ../lib/ogsf/Gs3.c:647
 #, c-format
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
+msgstr "Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
 #: ../lib/ogsf/Gs3.c:709 ../lib/ogsf/Gs3.c:781
 #, c-format
@@ -4360,19 +4141,16 @@
 #: ../lib/ogsf/Gs3.c:1020
 msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
-"View wurde von diesem Programm nicht gespeichert, es können Inkonsistenzen "
-"auftreten."
+msgstr "View wurde nicht von diesem Programm gespeichert, es können Inkonsistenzen auftreten."
 #: ../lib/ogsf/gsds.c:109
 msgid "Maximum number of datasets exceeded"
-msgstr "Maximalanzahl von Datasets überschritten."
+msgstr "Maximalanzahl von Datensätzen überschritten."
 #: ../lib/ogsf/Gv3.c:249
 #, c-format
 msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-"Keine Objekte der Vektorkarte <%s> befinden sich in der aktuellen Region."
+msgstr "Keine Objekte der Vektorkarte <%s> befinden sich in der aktuellen Region."
 #: ../lib/ogsf/Gv3.c:254
 #, c-format
@@ -4396,19 +4174,17 @@
 #: ../lib/ogsf/GS2.c:1636
 #, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-"Rasterkarte <%s> ist außerhalb der aktuellen Region. Laden fehlgeschlagen."
+msgstr "Rasterkarte <%s> ist außerhalb der aktuellen Region. Laden fehlgeschlagen."
 #: ../lib/ogsf/GS2.c:1714 ../lib/ogsf/GS2.c:1720 ../lib/ogsf/GS2.c:1728
 #: ../lib/ogsf/GS2.c:1737 ../lib/ogsf/GS2.c:1745 ../lib/ogsf/GS2.c:1755
 #: ../lib/ogsf/GS2.c:1803
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
-"GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
+msgstr "GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
 #: ../lib/ogsf/GS2.c:1831
 msgid "Loading failed"
-msgstr "Laden fehlgeschlagen"
+msgstr "Laden fehlgeschlagen."
 #: ../lib/ogsf/GS2.c:1835
 msgid "Error finding range"
@@ -4421,8 +4197,7 @@
 #: ../lib/ogsf/Gp3.c:204
 #, c-format
 msgid "No points from vector map <%s> fall within current region"
-msgstr ""
-"Keine Punkte der Vektorkarte <%s> befinden sich in der aktuellen Region."
+msgstr "Keine Punkte der Vektorkarte <%s> befinden sich in der aktuellen Region."
 #: ../lib/ogsf/Gp3.c:209
 #, c-format
@@ -4468,9 +4243,7 @@
 #: ../lib/ogsf/gsd_img_mpeg.c:306
 msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"Kann nicht von der Dateiendung auf das Ausgabeformat schließen: verwende "
-"MPEG."
+msgstr "Kann nicht von der Dateiendung auf das Ausgabeformat schließen: verwende MPEG."
 #: ../lib/ogsf/gsd_img_mpeg.c:310
 msgid "Unable to find suitable output format"
@@ -4478,7 +4251,7 @@
 #: ../lib/ogsf/gsd_img_mpeg.c:337
 msgid "Invalid output format parameters"
-msgstr "Ungültige Paramter für das Ausgabeformat."
+msgstr "Ungültige Parameter für das Ausgabeformat."
 #: ../lib/ogsf/gsd_img_mpeg.c:351
 #, c-format
@@ -4496,8 +4269,7 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:25
 #, c-format
 msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-msgstr ""
-"Ungültiger Tabellenname <%s>. Er darf '.' oder 'NULL' nicht enthalten.\n"
+msgstr "Ungültiger Tabellenname <%s>. Er darf weder '.' noch 'NULL' enthalten.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:33
 #, c-format
@@ -4507,21 +4279,20 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:43
 #, c-format
 msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-msgstr ""
-"Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
+msgstr "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
 #: ../lib/db/dbmi_base/login.c:98
 msgid "Login file corrupted"
-msgstr "Logindatei fehlerhaft"
+msgstr "Login-Datei fehlerhaft."
 #: ../lib/db/dbmi_base/default_name.c:127
 msgid "Programmer error"
-msgstr "Programmfehler"
+msgstr "Programmiererfehler"
 #: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
 #, c-format
 msgid "Unable open database <%s> by driver <%s>"
-msgstr "Kann Datenbank <%s> mit dem Treiber <%s> nicht öffnen."
+msgstr "Kann Datenbank <%s> nicht mit dem Treiber <%s> öffnen."
 #: ../lib/db/dbmi_client/table.c:110 ../lib/db/dbmi_client/copy_tab.c:199
 #: ../lib/db/dbmi_client/copy_tab.c:276 ../lib/sites/sites.c:381
@@ -4548,7 +4319,7 @@
 #: ../lib/db/dbmi_client/copy_tab.c:231
 #, c-format
 msgid "Column <%s> is not integer"
-msgstr "Spalte <%s> ist nicht Integer"
+msgstr "Spalte <%s> ist nicht Integer."
 #: ../lib/db/dbmi_client/copy_tab.c:251
 #, c-format
@@ -4558,7 +4329,7 @@
 #: ../lib/db/dbmi_client/copy_tab.c:295
 #, c-format
 msgid "Unable to fetch data from table <%s>"
-msgstr "Kann keine Daten aus der Tabelle <%s> holen."
+msgstr "Kann keine Daten aus der Tabelle <%s> beziehen."
 #: ../lib/db/dbmi_client/copy_tab.c:351
 #, c-format
@@ -4568,11 +4339,11 @@
 #: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:217
 #: ../lib/db/dbmi_client/select.c:283
 msgid "Missing column name"
-msgstr "Fehlender Spaltenname"
+msgstr "Spaltenname fehlt."
 #: ../lib/db/dbmi_client/select.c:212 ../lib/db/dbmi_client/select.c:278
 msgid "Missing key column name"
-msgstr "Fehlender Name der Schlüsselspalte"
+msgstr "Name der Schlüsselspalte fehlt."
 #: ../lib/db/dbmi_client/select.c:305
 #, c-format
@@ -4608,15 +4379,11 @@
 #: ../lib/sites/sites.c:241
 msgid "Memory error in allocating timestamp"
-msgstr "Speicherfehler beim Reservieren des Zeitstempel."
+msgstr "Speicherfehler beim Allokieren des Zeitstempel."
 #: ../lib/sites/sites.c:348 ../lib/sites/sites.c:478
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
-"Dev note: Angepasste sites Library used für Vektorpunkte. (Modul sollte für "
-"die GRASS 6 Vector Library aktualisiert werden)"
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Dev note: Angepasste sites Bibliothek für Vektorpunkte verwendet. (Modul sollte für die GRASS 6 Vector Library aktualisiert werden)."
 #: ../lib/sites/sites.c:397
 msgid "Cannot fetch row"
@@ -4827,7 +4594,7 @@
 #: ../lib/gmath/del2g.c:50
 msgid "    taking FFT of image..."
-msgstr "    nehme FFT vom Bild..."
+msgstr "    berechne FFT vom Bild..."
 #: ../lib/gmath/del2g.c:56
 msgid "    computing del**2 g..."
@@ -4835,25 +4602,25 @@
 #: ../lib/gmath/del2g.c:59
 msgid "    taking FFT of del**2 g..."
-msgstr "    nehme FFT von del**2g..."
+msgstr "    berechne FFT von del**2g..."
 #: ../lib/gmath/del2g.c:63
 msgid "    multiplying transforms..."
-msgstr "    verfielfachend transformieren..."
+msgstr "    multipliziere Transformationen..."
 #: ../lib/gmath/del2g.c:66
 msgid "    taking inverse FFT..."
-msgstr "    nehme inverse FFT..."
+msgstr "    berechne inverse FFT..."
 #: ../lib/gmath/solvers_krylov.c:219 ../lib/gmath/solvers_krylov.c:413
 #: ../lib/gmath/solvers_krylov.c:577 ../lib/gmath/solvers_direct.c:133
 msgid "Unable to solve the linear equation system"
-msgstr "Kann das lineare Gleichungssystem nicht lösen"
+msgstr "Kann das lineare Gleichungssystem nicht lösen."
 #: ../lib/gmath/solvers_krylov.c:227
 #, c-format
 msgid "Sparse PCG -- iteration %i error  %g\n"
-msgstr "sparse PCG -- Iteration %i Fehler  %g\n"
+msgstr "Sparse PCG -- Iteration %i Fehler  %g\n"
 #: ../lib/gmath/solvers_krylov.c:229
 #, c-format
@@ -4863,7 +4630,7 @@
 #: ../lib/gmath/solvers_krylov.c:421
 #, c-format
 msgid "Sparse CG -- iteration %i error  %g\n"
-msgstr "sparse CG -- Iteration %i Fehler  %g\n"
+msgstr "Sparse CG -- Iteration %i Fehler  %g\n"
 #: ../lib/gmath/solvers_krylov.c:423
 #, c-format
@@ -4873,7 +4640,7 @@
 #: ../lib/gmath/solvers_krylov.c:626
 #, c-format
 msgid "Sparse BiCGStab -- iteration %i error  %g\n"
-msgstr "sparse BiCGStab -- Iteration %i Fehler  %g\n"
+msgstr "Sparse BiCGStab -- Iteration %i Fehler  %g\n"
 #: ../lib/gmath/solvers_krylov.c:629
 #, c-format
@@ -4882,7 +4649,7 @@
 #: ../lib/gmath/la.c:64 ../lib/gmath/la.c:120
 msgid "Matrix dimensions out of range"
-msgstr "Matrix-Dimensionen liegen außerhalb des Wertebereichs."
+msgstr "Matrix-Dimensionen außerhalb des Wertebereichs."
 #: ../lib/gmath/la.c:153
 msgid "Matrix is not initialised fully."
@@ -4898,7 +4665,7 @@
 #: ../lib/gmath/la.c:253 ../lib/gmath/la.c:261 ../lib/gmath/la.c:326
 msgid "One or both input matrices uninitialised"
-msgstr "Eine oder beide Eingabe-Matrizen nicht initialisiert."
+msgstr "Eine oder beide Eingabe-Matrizen sind nicht initialisiert."
 #: ../lib/gmath/la.c:266 ../lib/gmath/la.c:331
 msgid "Matrix order does not match"
@@ -4906,19 +4673,19 @@
 #: ../lib/gmath/la.c:272
 msgid "Unable to allocate space for matrix sum"
-msgstr "Kann keinen Speicher für Summe der Matrix belegen."
+msgstr "Kann keinen Speicher für Summe der Matrizen belegen."
 #: ../lib/gmath/la.c:336
 msgid "Unable to allocate space for matrix product"
-msgstr "Kann keinen Speicher für Produkt der Matrix belegen."
+msgstr "Kann keinen Speicher für Produkt der Matrizen belegen."
 #: ../lib/gmath/la.c:448
 msgid "Input: one or both data matrices uninitialised"
-msgstr "Eingabe: eine oder beide Datenmatrizen nicht initialisiert."
+msgstr "Eingabe: eine oder beide Datenmatrizen sind nicht initialisiert."
 #: ../lib/gmath/la.c:453
 msgid "Principal matrix is not properly dimensioned"
-msgstr "Matrix (prinzipal) hat nicht die richtigen Dimensionen."
+msgstr "Hauptmatrix hat nicht die richtigen Dimensionen."
 #: ../lib/gmath/la.c:458
 msgid "Input: you must have at least one array to solve"
@@ -4926,11 +4693,11 @@
 #: ../lib/gmath/la.c:464
 msgid "Could not allocate space for solution matrix"
-msgstr "Konnte keinen Platz für die Lösungs-Matrix belegen."
+msgstr "Konnte keinen Platz für die Lösungsmatrix belegen."
 #: ../lib/gmath/la.c:470 ../lib/gmath/la.c:478
 msgid "Could not allocate space for working matrix"
-msgstr "Konnte keinen Platz für die Arbeits-Matrix belegen."
+msgstr "Konnte keinen Platz für die Arbeitsmatrix belegen."
 #: ../lib/gmath/la.c:531
 msgid "Matrix (or submatrix is singular). Solution undetermined"
@@ -4991,7 +4758,7 @@
 #: ../lib/gmath/la.c:836
 msgid "Specified column index is outside range"
-msgstr "Angegebener Spalteindex ist außerhalb des Wertebereichs."
+msgstr "Angegebener Spaltenindex ist außerhalb des Wertebereichs."
 #: ../lib/gmath/la.c:856
 msgid "Unknown vector type."
@@ -5059,15 +4826,15 @@
 #: ../lib/gmath/solvers_direct.c:45
 msgid "Starting direct gauss elimination solver"
-msgstr "Starte Gaußschen Eleminationslöser"
+msgstr "Starte Gaußschen Eliminierungslöser."
 #: ../lib/gmath/solvers_direct.c:73
 msgid "Starting direct lu decomposition solver"
-msgstr "Starte Lu Dekompositions-Löser"
+msgstr "Starte Lu Dekompositions-Löser."
 #: ../lib/gmath/solvers_direct.c:130
 msgid "Starting cholesky decomposition solver"
-msgstr "Starte Cholesky Dekompositions-Löser"
+msgstr "Starte Cholesky Dekompositions-Löser."
 #: ../lib/imagery/points.c:124
 #, c-format
@@ -5102,23 +4869,17 @@
 #: ../lib/imagery/fopen.c:79
 #, c-format
 msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht "
-"erstellen."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht erstellen."
 #: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
 #, c-format
 msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"öffnen."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht öffnen."
 #: ../lib/imagery/fopen.c:116
 #, c-format
 msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"finden."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht finden."
 #: ../lib/imagery/list_gp.c:34
 #, c-format
@@ -5143,42 +4904,34 @@
 #: ../lib/imagery/list_subgp.c:48
 #, c-format
 msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-"Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
+msgstr "Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "Angeforderte G3D Karte <%s> nicht gefunden"
+msgid "taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations..."
+msgstr "Es dauert zu lange, um Punkte für die Interpolation zu finden -- bitte ändern Sie die Region auf den Bereich, in dem ihre Punkte sind. Fahre mit der Berechnung fort..."
-#~ msgid "Unable to open driver <%s>"
-#~ msgstr "Kann den Treiber <%s> nicht öffnen."
+msgid "Reading lines from vector map ... "
+msgstr "Lese Linien der Vektorkarte ... "
-#~ msgid ""
-#~ "taking too long to find points for interpolation--please change the "
-#~ "region to area where your points are. Continuing calculations..."
-#~ msgstr ""
-#~ "Es dauert zu lange, um Punkte für die Interpolation zu finden -- bitte "
-#~ "ändern Sie die Region auf den Bereich, in dem ihre Punkte sind. Fahre mit "
-#~ "der Berechnung fort..."
+msgid "Reading nodes from vector map ... "
+msgstr "Lese Knoten der Vektorkarte ... "
-#~ msgid "Reading lines from vector map ... "
-#~ msgstr "Lese Linien der Vektorkarte ... "
+msgid "strip exists with insufficient data"
+msgstr "Es gibt einen Streifen mit unzureichend Daten."
-#~ msgid "Reading nodes from vector map ... "
-#~ msgstr "Lese Knoten der Vektorkarte ... "
+msgid "there are points outside specified 2D/3D region--ignored %d points"
+msgstr "Es sind Punkte außerhalb der angegebenen 2D/3D-Region gefunden worden - ignoriere %d Punkte."
-#~ msgid "strip exists with insufficient data"
-#~ msgstr "Es gibt einen Streifen mit unzureichend Daten."
+msgid "ignoring %d points -- too dense"
+msgstr "Ignoriere %d Punkte -- sie liegen zu dicht beieinander."
-#~ msgid "there are points outside specified 2D/3D region--ignored %d points"
-#~ msgstr ""
-#~ "Es sind Punkte außerhalb der angegebenen 2D/3D-Region gefunden worden - "
-#~ "ignoriere %d Punkte."
+msgid "some points outside of region -- will ignore..."
+msgstr "einige Punkte sind außerhalb der Region -- ignoriere dies..."
-#~ msgid "ignoring %d points -- too dense"
-#~ msgstr "Ignoriere %d Punkte -- sie liegen zu dicht beieinander."
+#~ msgid "Requested g3d map <%s> not found"
+#~ msgstr "Angeforderte G3D Karte <%s> nicht gefunden"
-#~ msgid "some points outside of region -- will ignore..."
-#~ msgstr "einige Punkte sind außerhalb der Region -- ignoriere dies..."
+#~ msgid "Unable to open driver <%s>"
+#~ msgstr "Kann den Treiber <%s> nicht öffnen."
 #~ msgid "Unable to feature %d from vector map <%s>"
 #~ msgstr "Unable to feature %d from vector map <%s>"
@@ -5199,14 +4952,10 @@
 #~ msgstr "Vektor ist nicht 3D."
 #~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr ""
-#~ "Kann die Z-Spalte <%s> nicht finden (Bitte überprüfen Sie den Name, z.B. "
-#~ "mit v.info)."
+#~ msgstr "Kann die Z-Spalte <%s> nicht finden (Bitte überprüfen Sie den Name, z.B. mit v.info)."
 #~ msgid "Column type of z column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Spaltentype der Spalte z wird nicht unterstützt (muss integer oder double "
-#~ "sein)."
+#~ msgstr "Spaltentype der Spalte z wird nicht unterstützt (muss integer oder double sein)."
 #~ msgid "Cannot read column type of smooth column"
 #~ msgstr "Kann den Spaltentyp der Smooth-Spalte nicht lesen."
@@ -5215,26 +4964,22 @@
 #~ msgstr "Spaltentyp der Smooth-Spalte (datetime) wird nicht unterstützt."
 #~ msgid "Column type of s column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Spaltentyp der s-Spalte wird nicht unterstützt (muss integer oder double "
-#~ "sein)."
+#~ msgstr "Spaltentyp der s-Spalte wird nicht unterstützt (muss integer oder double sein)."
 #~ msgid "The linear equation system is not quadratic"
-#~ msgstr "Das lineare Gleichungssystem ist nicht quadratisch"
+#~ msgstr "Das lineare Gleichungssystem ist nicht quadratisch."
 #~ msgid "Matrix is not symmetric!"
 #~ msgstr "Matrix ist nicht symmetrisch!"
 #~ msgid "The gauss elimination solver does not work with sparse matrices"
-#~ msgstr ""
-#~ "Der Gaußsche Eliminierungslöser kann keine dünnbesetzten Matrizen "
-#~ "verarbeiten."
+#~ msgstr "Der Gaußsche Eliminierungslöser kann keine dünnbesetzten Matrizen verarbeiten."
 #~ msgid "The lu solver does not work with sparse matrices"
-#~ msgstr "Der lu-Löser kann keine dünnbesetzten Matrizen verarbeiten"
+#~ msgstr "Der lu-Löser kann keine dünnbesetzten Matrizen verarbeiten."
 #~ msgid "The cholesky solver does not work with sparse matrices"
-#~ msgstr "Der Cholesky-Löser kann keine dünnbesetzten Matrizen verarbeiten"
+#~ msgstr "Der Cholesky-Löser kann keine dünnbesetzten Matrizen verarbeiten."
 #~ msgid "Null values have not been initialized. "
 #~ msgstr "NULL-Werte wurden nicht initialisiert. "
@@ -5246,13 +4991,13 @@
 #~ msgstr "Bitte unterrichten Sie die GRASS-Entwickler über diesen Fehler.\n"
 #~ msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
-#~ msgstr "G_malloc: Kann nicht %lu Byte auf %s:%d belegen."
+#~ msgstr "G_malloc: Kann nicht %lu Byte auf %s:%d allokieren."
 #~ msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
-#~ msgstr "G_calloc: Kann nicht %lu * %lu Byte auf %s:%d belegen."
+#~ msgstr "G_calloc: Kann nicht %lu * %lu Byte auf %s:%d allokieren."
 #~ msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
-#~ msgstr "G_realloc: Kann nicht %lu Byte auf %s:%d belegen."
+#~ msgstr "G_realloc: Kann nicht %lu Byte auf %s:%d allokieren."
 #~ msgid "Unable to delete file '%s'"
 #~ msgstr "Kann Datei '%s' nicht löschen."
