[GRASS-SVN] r48537 - grass/trunk/visualization/nviz/html
Wed Sep 28 08:12:41 EDT 2011
Author: hamish
Date: 2011-09-28 05:12:41 -0700 (Wed, 28 Sep 2011)
New Revision: 48537
   grass/trunk/visualization/nviz/html/bugs_todo.html
   grass/trunk/visualization/nviz/html/nviz_panel_kanim.html
rename of d.nviz to m.nviz.script, cont.
Modified: grass/trunk/visualization/nviz/html/bugs_todo.html
--- grass/trunk/visualization/nviz/html/bugs_todo.html	2011-09-28 12:10:20 UTC (rev 48536)
+++ grass/trunk/visualization/nviz/html/bugs_todo.html	2011-09-28 12:12:41 UTC (rev 48537)
@@ -103,7 +103,7 @@
   - eventually color problem in lat/long locations
     (Being worked on by ?)
-12/2003 - see d.nviz - should be mentioned in tutorial
+12/2003 - see m.nviz.script (nee d.nviz) - should be mentioned in tutorial
   - high resolution output (definable extent like CELL driver)
     (Being worked on by
      probably Bob Covill <bcovill at tekmap.ns.ca>)
Modified: grass/trunk/visualization/nviz/html/nviz_panel_kanim.html
--- grass/trunk/visualization/nviz/html/nviz_panel_kanim.html	2011-09-28 12:10:20 UTC (rev 48536)
+++ grass/trunk/visualization/nviz/html/nviz_panel_kanim.html	2011-09-28 12:12:41 UTC (rev 48537)
@@ -22,9 +22,9 @@
 of the current view. For example, the <em>Field of View</em> (FOV) is a
 separate channel in each keyframe.
 <p>
-The <em><a href="../d.nviz.html">d.nviz</a></em> GRASS module may be used to
-automatically create Keyframe animation templates which can be loaded by
-this panel.
+The <em><a href="../m.nviz.script.html">m.nviz.script</a></em> GRASS module
+may be used to automatically create Keyframe animation templates which can
+be loaded by this panel.
 <BR><BR>
 <DL><DD>
