[GRASS-SVN] r51505 - grass/branches/develbranch_6/vector/v.select
Mon Apr 23 16:44:49 EDT 2012
Author: neteler
Date: 2012-04-23 13:44:49 -0700 (Mon, 23 Apr 2012)
New Revision: 51505
   grass/branches/develbranch_6/vector/v.select/description.html
NC example
Modified: grass/branches/develbranch_6/vector/v.select/description.html
--- grass/branches/develbranch_6/vector/v.select/description.html	2012-04-23 20:44:42 UTC (rev 51504)
+++ grass/branches/develbranch_6/vector/v.select/description.html	2012-04-23 20:44:49 UTC (rev 51505)
@@ -40,10 +40,12 @@
 <h2>EXAMPLES</h2>
-Extract forest fire points from larger fire vector map:
+Extract fire stations (points) from urban area map (polygon) - North Carolina
+data set:
 <div class="code"><pre>
-v.select ainput=fire binput=forest output=forest_fire operator=overlap
+v.select ainput=firestations binput=urbanarea output=urban_firestations \
+         operator=overlap
 </pre></div>
 Extract Italian rivers from VMAP0 watercourses map:
