[GRASS-SVN] r51508 - grass/trunk/vector/v.select
Tue Apr 24 03:35:21 EDT 2012
Author: mmetz
Date: 2012-04-24 00:35:20 -0700 (Tue, 24 Apr 2012)
New Revision: 51508
   grass/trunk/vector/v.select/main.c
v.select: GEOS is optional
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c	2012-04-23 22:32:37 UTC (rev 51507)
+++ grass/trunk/vector/v.select/main.c	2012-04-24 07:35:20 UTC (rev 51508)
@@ -82,11 +82,17 @@
     else
 	G_fatal_error(_("Unknown operator '%s'"), parm.operator->answer);
+#ifdef HAVE_GEOS
     if (operator == OP_RELATE && !parm.relate->answer) {
 	G_fatal_error(_("Required parameter <%s> not set"),
 		      parm.relate->key);
+#else
+    if (operator != OP_OVERLAP) {
+	G_warning(_("Operator can only be 'overlap'"));
+	operator = OP_OVERLAP;
+#endif
     for (iopt = 0; iopt < 2; iopt++) {
 	itype[iopt] = Vect_option_to_types(parm.type[iopt]);
@@ -113,11 +119,19 @@
     Vect_hist_command(&Out);
     /* Select features */
+#ifdef HAVE_GEOS
     nskipped = select_lines(&(In[0]), itype[0], ifield[0],
 			    &(In[1]), itype[1], ifield[1],
 			    flag.cat->answer ? 1 : 0, operator,
 			    parm.relate->answer,
 			    ALines);
+#else
+    nskipped = select_lines(&(In[0]), itype[0], ifield[0],
+			    &(In[1]), itype[1], ifield[1],
+			    flag.cat->answer ? 1 : 0, operator,
+			    NULL,
+			    ALines);
+#endif
     Vect_close(&(In[1]));
