[GRASS-SVN] r51532 - grass-addons/grass7/raster/r.vol.dem
Wed Apr 25 04:45:29 EDT 2012
Author: neteler
Date: 2012-04-25 01:45:29 -0700 (Wed, 25 Apr 2012)
New Revision: 51532
Added:
   grass-addons/grass7/raster/r.vol.dem/r.vol.dem.html
   grass-addons/grass7/raster/r.vol.dem/main.c
update for G7; doc added
Modified: grass-addons/grass7/raster/r.vol.dem/main.c
--- grass-addons/grass7/raster/r.vol.dem/main.c	2012-04-25 07:29:31 UTC (rev 51531)
+++ grass-addons/grass7/raster/r.vol.dem/main.c	2012-04-25 08:45:29 UTC (rev 51532)
@@ -277,18 +277,12 @@
     /* get maximum and minimum elevation from all DEMs */
     row = 0;
-    if (Rast_get_d_row(fd[0], dcell[0], row) < 0) {
-	G_fatal_error(_("Could not read row number %i from map %s."), row,
-		      parm.maps->answers[0]);
+    Rast_get_d_row(fd[0], dcell[0], row);
     top = dcell[0][0];
     topDEM = 0;
     for (i = 0; i < nfiles; i++) {
 	for (row = 0; row < nrows; row++) {
-	    if (Rast_get_d_row(fd[i], dcell[i], row) < 0) {
-			      row, parm.maps->answers[i]);
+	    Rast_get_d_row(fd[i], dcell[i], row);
 	    for (col = 0; col < ncols; col++) {
 		if (dcell[i][col] > top) {
 		    top = dcell[i][col];
@@ -308,18 +302,12 @@
 	fprintf(stdout, " z-range-checking, pass 2: \n");
     row = 0;
     bottom = dcell[0][0];
     bottomDEM = 0;
 		if (dcell[i][col] < bottom) {
 		    bottom = dcell[i][col];
@@ -394,10 +382,7 @@
@@ -706,10 +691,7 @@
 	/* read one row from all layers */
Added: grass-addons/grass7/raster/r.vol.dem/r.vol.dem.html
--- grass-addons/grass7/raster/r.vol.dem/r.vol.dem.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.vol.dem/r.vol.dem.html	2012-04-25 08:45:29 UTC (rev 51532)
@@ -0,0 +1,114 @@
+<h2>DESCRIPTION</h2>
+<em>r.vol.dem</em> interpolates a voxel model from a series of DEMs by
+flood filling the voxel space in between.
+The module is able to calculate voxel maps between at least two DEMs.
+The algorithm is based on a so-called "Flood-filling" algorithm. Since
+a date, label or category number of an e.g., archaeological stratum
+represents always the value for the entire stratum it would be more
+suitable to fill the entire 3D unit with this single value.
+<p>
+The input bottom and top DEMs represent each the bottom and top border
+for the "voxeled" stratum, in this case the implicit structure. Before
+running the <em>r.vol.dem</em> module, one needs to adjust the
+three-dimensional extent of the 3D interpolation which works as an
+analytical mask in the GRASS GIS module <em>g.region</em>. This
+procedure adjusts additionally the voxel's size which influences the
+3D resolution of the entire stratum. Furthermore, it is possible to
+adjust the height and width of the voxel in order to obtain a cube or
+cuboid voxel shape. In general, the smaller the voxel's size the higher
+the resolution, the more precise 3D units.
+<h2>NOTES</h2>
+The input data for the 3D interpolation which requires at least two
+raster DEMs. They have to be entered in a certain rank, with the lowest,
+according to elevation, DEM first.
+<p>
+The list of label values is one for each 3D layer (labels=value): Since
+one can enter an infinite number of DEMs it is possible adjust certain
+labels for each 3D layer. If they are not specified, labelling starts
+with layer 0. The numbers are given always upwards disregarding the
+algorithm direction.
+<p>
+The <em>errormap</em> raster map is to represent topology errors in input
+DEMs. This option does not yet create a real map but gives the coordinates
+where intersections of DEMs occur.
+<p>
+The <em>algorithm</em> parameter is used to select the 3D flood fill
+algorithm to use. The user can chose between an up or down filling
+direction. The default adjustment is the upwards algorithm. The results
+can become very different according to the shape and extension of the DEMs.
+<p>
+The <em>-c</em> flag calculates 3D cell counts for each layer: This option
+counts the number of voxels for each 3D layer label. Unfortunately, this
+count is not stored in the <em>r3.info</em> information. Thus, if one
+needs this information afterwards, one has to repeat the whole calculation.
+<p>
+The <em>-f</em> flag fills through NULL value areas in DEMs: Null value
+areas are areas which lie outside a 3D layer defined by two successive DEMs
+in the input command. In the case, where a 3D layer is limited not only
+from one unit surface, e.g. on top, this flag allows a further 3D
+interpolation until the next DEM or the region's margin.
+<p>
+The <em>-h</em> flag export convex hull for polygon layers: This option
+creates a 3D polygon out of the voxel model. This means, at first it will
+be generated a voxel model. Afterwards, this will be converted into a
+vector-file. However, the flag does not yet work properly.
+<p>
+The <em>-g</em> flag exports voxel model as vector points: This option
+creates a vector point for each interpolated voxel. This became necessary
+because of the lack of suitable representation in the visualisation module
+nivz in GRASS GIS 6. Nevertheless, the points can be represented virtually
+as cubes in nviz which gives an idea of the voxel layer. Unfortunately,
+there is still an error in the module using this flag (state 01.06.2006)
+that can be corrected by the following procedure:
+The module <em>r.vol.dem</em> creates a temporary txt-file in the HOME
+directory. Opening this file one will find a line which starts with
+"# v.in.ascii". This line needs to be copied without the #-sign and
+executed in the GRASS bash shell.
+<p>
+The <em>-p</em> flag exports VTK point data instead of cell data: This
+option reflects the fact that the visualisation program ParaView which
+treats cell data and point data differently in comparison to the program
+GRASS GIS. Hence, if one wants to visualise GRASS voxel in ParaView, this
+flag is recommended.
+<p>
+The <em>-q</em> flag disables on-screen progress display:
+This option does not yet work.
+<p>
+The <em>-s</em> flag skips topology error checking:
+The module checks the input DEMs for intersection before running the
+algorithm. If such an unwanted intersection is found, the algorithm creates
+an errormap (see <em>errormap</em> option) and stops the entire 3D
+interpolation process. Using this flag one can skip this precaution.
+<p>
+The <em>-v</em> flag generates a vtk-file for visualisation with e.g.
+ParaView: Since the GRASS visualisation module nviz is unable to show
+voxel as (semitransparent) cubes, the Open Source visualisation
+program ParaView is now commonly used for the visualisation of GRASS GIS
+maps and especially for 3D visualisations. Hence, the output GRASS GIS
+files have to be converted into a ParaView readable format.
+<p>
+The <em>-z</em> flag fits active region's z range to input DEMs:
+<h2>EXAMPLE</h2>
+<div class = "code"><pre>
+tbd
+</pre></div>
+<h2>SEE ALSO</h2>
+<a href="http://undine-lieberwirth.info/?page_id=8">Screenhot gallery</a>
+<h2> AUTHOR</h2>
+Software: Benjamin Ducke
+<p>
+Documentation: Undine Lieberwirth
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster/r.vol.dem/r.vol.dem.html
___________________________________________________________________
Added: svn:mime-type
   + text/html
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
