[GRASS-SVN] r52544 - grass/trunk/lib/vector/Vlib
Sun Aug 5 13:26:11 PDT 2012
Author: mmetz
Date: 2012-08-05 13:26:11 -0700 (Sun, 05 Aug 2012)
New Revision: 52544
   grass/trunk/lib/vector/Vlib/break_polygons.c
   grass/trunk/lib/vector/Vlib/intersect.c
   grass/trunk/lib/vector/Vlib/rtree_search.c
   grass/trunk/lib/vector/Vlib/select.c
   grass/trunk/lib/vector/Vlib/snap.c
Vlib: changed rtree search fn
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c	2012-08-05 20:22:06 UTC (rev 52543)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c	2012-08-05 20:26:11 UTC (rev 52544)
@@ -73,7 +73,7 @@
 static int fpoint;
 /* Function called from RTreeSearch for point found */
-void srch(int id, struct RTree_Rect rect, int *arg)
+void srch(int id, const struct RTree_Rect *rect, int *arg)
     fpoint = id;
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c	2012-08-05 20:22:06 UTC (rev 52543)
+++ grass/trunk/lib/vector/Vlib/intersect.c	2012-08-05 20:26:11 UTC (rev 52544)
@@ -84,7 +84,7 @@
 static int ident(double x1, double y1, double x2, double y2, double thresh);
 #endif
 static int cross_seg(int id, struct RTree_Rect rect, int *arg);
-static int find_cross(int id, struct RTree_Rect rect, int *arg);
+static int find_cross(int id, const struct RTree_Rect *rect, int *arg);
 #define D  ((ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2))
 #define D1 ((bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2))
@@ -1089,7 +1089,7 @@
 static int cross_found;		/* set by find_cross() */
 /* break segments (called by rtree search) */
     double x1, y1, z1, x2, y2, z2;
     int i, j, ret;
Modified: grass/trunk/lib/vector/Vlib/rtree_search.c
--- grass/trunk/lib/vector/Vlib/rtree_search.c	2012-08-05 20:22:06 UTC (rev 52543)
+++ grass/trunk/lib/vector/Vlib/rtree_search.c	2012-08-05 20:26:11 UTC (rev 52544)
@@ -19,7 +19,7 @@
 /* Function to add the ids of overlapping rectangles to an ilist
  * This function is a callback function used in RTreeSearch2()
-static int add_id_to_list(int id, struct RTree_Rect rect, void *list)
+static int add_id_to_list(int id, const struct RTree_Rect *rect, void *list)
     struct ilist *l = (struct ilist*)list;
     G_ilist_add(l, id);
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c	2012-08-05 20:22:06 UTC (rev 52543)
+++ grass/trunk/lib/vector/Vlib/select.c	2012-08-05 20:26:11 UTC (rev 52544)
@@ -118,7 +118,7 @@
 /************************* SELECT BY BOX *********************************/
 /* This function is called by  RTreeSearch() to add selected item to the list */
-static int _add_item(int id, struct RTree_Rect rect, struct ilist *list)
+static int _add_item(int id, const struct RTree_Rect *rect, struct ilist *list)
     G_ilist_add(list, id);
     return 1;
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c	2012-08-05 20:22:06 UTC (rev 52543)
+++ grass/trunk/lib/vector/Vlib/snap.c	2012-08-05 20:26:11 UTC (rev 52544)
@@ -41,7 +41,7 @@
 } NEW;
 /* This function is called by RTreeSearch() to add selected node/line/area/isle to the list */
-int add_item(int id, struct RTree_Rect rect, struct ilist *list)
+int add_item(int id, const struct RTree_Rect *rect, struct ilist *list)
     return 1;
