[GRASS-SVN] r52594 - grass/trunk/raster/r.in.xyz
Wed Aug 8 03:30:53 PDT 2012
Author: mmetz
Date: 2012-08-08 03:30:52 -0700 (Wed, 08 Aug 2012)
New Revision: 52594
   grass/trunk/raster/r.in.xyz/main.c
r.in.xyz: support for more than 2 billion cells in current region
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c	2012-08-08 10:26:55 UTC (rev 52593)
+++ grass/trunk/raster/r.in.xyz/main.c	2012-08-08 10:30:52 UTC (rev 52594)
@@ -44,7 +44,7 @@
     if (num_nodes >= max_nodes) {
 	max_nodes += SIZE_INCREMENT;
-	nodes = G_realloc(nodes, max_nodes * sizeof(struct node));
+	nodes = G_realloc(nodes, (size_t)max_nodes * sizeof(struct node));
     return n;
@@ -477,20 +477,29 @@
     npasses = (int)ceil(1.0 * region.rows / rows);
     if (!scan_flag->answer) {
+	/* check if rows * (cols + 1) go into a size_t */
+	if (sizeof(size_t) < 8) {
+	    double dsize = rows * (cols + 1);
+	    if (dsize != (size_t)rows * (cols + 1))
+		G_fatal_error(_("Unable to process the hole map at once. "
+		                "Please set the %s option to some value lower than 100."),
+				percent_opt->key);
 	/* allocate memory (test for enough before we start) */
 	if (bin_n)
-	    n_array = G_calloc(rows * (cols + 1), Rast_cell_size(CELL_TYPE));
+	    n_array = G_calloc((size_t)rows * (cols + 1), Rast_cell_size(CELL_TYPE));
 	if (bin_min)
-	    min_array = G_calloc(rows * (cols + 1), Rast_cell_size(rtype));
+	    min_array = G_calloc((size_t)rows * (cols + 1), Rast_cell_size(rtype));
 	if (bin_max)
-	    max_array = G_calloc(rows * (cols + 1), Rast_cell_size(rtype));
+	    max_array = G_calloc((size_t)rows * (cols + 1), Rast_cell_size(rtype));
 	if (bin_sum)
-	    sum_array = G_calloc(rows * (cols + 1), Rast_cell_size(rtype));
+	    sum_array = G_calloc((size_t)rows * (cols + 1), Rast_cell_size(rtype));
 	if (bin_sumsq)
-	    sumsq_array = G_calloc(rows * (cols + 1), Rast_cell_size(rtype));
+	    sumsq_array = G_calloc((size_t)rows * (cols + 1), Rast_cell_size(rtype));
 	if (bin_index)
 	    index_array =
-		G_calloc(rows * (cols + 1), Rast_cell_size(CELL_TYPE));
+		G_calloc((size_t)rows * (cols + 1), Rast_cell_size(CELL_TYPE));
 	/* and then free it again */
 	if (bin_n)
@@ -591,33 +600,33 @@
 	if (bin_n) {
 	    G_debug(2, "allocating n_array");
 	    blank_array(n_array, rows, cols, CELL_TYPE, 0);
 	if (bin_min) {
 	    G_debug(2, "allocating min_array");
 	    blank_array(min_array, rows, cols, rtype, -1);	/* fill with NULLs */
 	if (bin_max) {
 	    G_debug(2, "allocating max_array");
 	    blank_array(max_array, rows, cols, rtype, -1);	/* fill with NULLs */
 	if (bin_sum) {
 	    G_debug(2, "allocating sum_array");
 	    blank_array(sum_array, rows, cols, rtype, 0);
 	if (bin_sumsq) {
 	    G_debug(2, "allocating sumsq_array");
 	    blank_array(sumsq_array, rows, cols, rtype, 0);
 	if (bin_index) {
 	    G_debug(2, "allocating index_array");
 	    index_array =
 	    blank_array(index_array, rows, cols, CELL_TYPE, -1);	/* fill with NULLs */
