[GRASS-SVN] r52602 - in grass/trunk/gui/wxpython: . gcp gui_core iclass lmgr mapdisp nviz swipe vdigit xml
Thu Aug 9 00:20:21 PDT 2012
Author: annakrat
Date: 2012-08-09 00:20:19 -0700 (Thu, 09 Aug 2012)
New Revision: 52602
Added:
   grass/trunk/gui/wxpython/swipe/
   grass/trunk/gui/wxpython/swipe/dialogs.py
   grass/trunk/gui/wxpython/swipe/frame.py
   grass/trunk/gui/wxpython/swipe/mapwindow.py
   grass/trunk/gui/wxpython/swipe/toolbars.py
   grass/trunk/gui/wxpython/Makefile
   grass/trunk/gui/wxpython/gcp/mapdisplay.py
   grass/trunk/gui/wxpython/gui_core/mapwindow.py
   grass/trunk/gui/wxpython/iclass/digit.py
   grass/trunk/gui/wxpython/iclass/frame.py
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/gui/wxpython/mapdisp/frame.py
   grass/trunk/gui/wxpython/mapdisp/mapwindow.py
   grass/trunk/gui/wxpython/mapdisp/statusbar.py
   grass/trunk/gui/wxpython/nviz/mapwindow.py
   grass/trunk/gui/wxpython/vdigit/mapwindow.py
   grass/trunk/gui/wxpython/wxpythonlib.dox
   grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: new tool Map Swipe added, a few changes in base gui code needed
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/Makefile	2012-08-09 07:20:19 UTC (rev 52602)
@@ -11,12 +11,12 @@
 SRCFILES := $(wildcard icons/*.* scripts/* xml/*) \
 	$(wildcard core/* dbmgr/* gcp/* gmodeler/* gui_core/* iclass/* lmgr/* location_wizard/* \
-	mapdisp/* modules/* nviz/* psmap/* vdigit/* wxplot/* ogc_services/* ) \
+	mapdisp/* modules/* nviz/* psmap/* swipe/* vdigit/* wxplot/* ogc_services/*) \
 	gis_set.py gis_set_error.py wxgui.py README
 DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) $(patsubst %.py,$(ETCDIR)/%.pyc,$(filter %.py,$(SRCFILES)))
 PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,core dbmgr gcp gmodeler gui_core iclass lmgr location_wizard \
-	mapdisp modules nviz psmap vdigit wxplot ogc_services)
+	mapdisp modules nviz psmap swipe vdigit wxplot ogc_services)
 DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
 default: $(DSTFILES) menustrings.py
Modified: grass/trunk/gui/wxpython/gcp/mapdisplay.py
--- grass/trunk/gui/wxpython/gcp/mapdisplay.py	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/gcp/mapdisplay.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -114,11 +114,11 @@
         self.grwiz.SwitchEnv('source')
         self.SrcMapWindow = BufferedWindow(self, id=wx.ID_ANY,
-                                          Map=self.SrcMap, tree=self.tree, lmgr=self._layerManager)
+                                          Map=self.SrcMap, frame = self, tree=self.tree, lmgr=self._layerManager)
         self.grwiz.SwitchEnv('target')
         self.TgtMapWindow = BufferedWindow(self, id=wx.ID_ANY,
-                                          Map=self.TgtMap, tree=self.tree, lmgr=self._layerManager)
+                                          Map=self.TgtMap, frame = self, tree=self.tree, lmgr=self._layerManager)
         self.MapWindow = self.SrcMapWindow
         self.Map = self.SrcMap
         self.SrcMapWindow.SetCursor(self.cursors["cross"])
Modified: grass/trunk/gui/wxpython/gui_core/mapwindow.py
--- grass/trunk/gui/wxpython/gui_core/mapwindow.py	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/gui_core/mapwindow.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -36,10 +36,11 @@
      - Pixel2Cell
      - Cell2Pixel (if it is possible)
-    def __init__(self, parent, id = wx.ID_ANY,
-                 Map = None, tree = None, lmgr = None, **kwargs):
+    def __init__(self, parent, Map, frame,
+                 id = wx.ID_ANY, tree = None, lmgr = None, **kwargs):
         self.parent = parent # MapFrame
         self.Map    = Map
+        self.frame = frame
         self.tree   = tree
         self.lmgr   = lmgr
@@ -228,7 +229,7 @@
         except (ValueError):
             self.lastEN = None
         # FIXME: special case for vdigit and access to statusbarManager
-        if self.parent.statusbarManager.GetMode() == 0: # Coordinates
+        if self.frame.statusbarManager.GetMode() == 0: # Coordinates
             updated = False
             if hasattr(self, "digit"):
                 precision = int(UserSettings.Get(group = 'projection', key = 'format',
@@ -236,7 +237,7 @@
                 updated = self._onMotion(self.lastEN, precision)
             if not updated:
-                self.parent.CoordinatesChanged()
+                self.frame.CoordinatesChanged()
         event.Skip()
Modified: grass/trunk/gui/wxpython/iclass/digit.py
--- grass/trunk/gui/wxpython/iclass/digit.py	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/iclass/digit.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -28,7 +28,7 @@
 class IClassVDigitWindow(VDigitWindow):
     """! Class similar to VDigitWindow but specialized for wxIClass."""
-    def __init__(self, parent, map):
+    def __init__(self, parent, map, frame):
         @a parent should has toolbar providing current class (category).
@@ -36,7 +36,7 @@
         @param parent gui parent
         @param map map renderer instance
-        VDigitWindow.__init__(self, parent = parent, Map = map)
+        VDigitWindow.__init__(self, parent = parent, Map = map, frame = frame)
     def _onLeftDown(self, event):
         action = self.toolbar.GetAction()
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/iclass/frame.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -83,8 +83,8 @@
                                 firstMap = Map(), secondMap = Map(),
                                 **kwargs)
-        self.firstMapWindow = IClassVDigitWindow(self, map = self.firstMap)
-        self.secondMapWindow = BufferedWindow(self, Map = self.secondMap)
+        self.firstMapWindow = IClassVDigitWindow(self, map = self.firstMap, frame = self)
+        self.secondMapWindow = BufferedWindow(self, Map = self.secondMap, frame = self)
         self.MapWindow = self.firstMapWindow # current by default
         self._bindWindowsActivation()
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -65,6 +65,7 @@
 from gui_core.forms        import GUI
 from gcp.manager           import GCPWizard
 from nviz.main             import haveNviz
+from swipe.frame           import SwipeMapFrame
 class GMFrame(wx.Frame):
     """!Layer Manager frame with notebook widget for controlling GRASS
@@ -377,6 +378,26 @@
         win.Show()
+    def OnMapSwipe(self, event):
+        """!Launch Map Swipe"""
+        win = SwipeMapFrame(parent = self)
+        rasters = []
+        tree = self.GetLayerTree()
+        if tree:
+            for layer in tree.GetSelections():
+                if tree.GetPyData(layer)[0]['maplayer'].GetType() != 'raster':
+                    continue
+                rasters.append(tree.GetPyData(layer)[0]['maplayer'].GetName())
+        if len(rasters) >= 1:
+            win.SetFirstRaster(rasters[0])
+        if len(rasters) >= 2:
+            win.SetSecondRaster(rasters[1])
+        win.CentreOnScreen()
+        win.Show()
     def OnDone(self, cmd, returncode):
         """Command execution finised"""
         if hasattr(self, "model"):
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -129,7 +129,7 @@
         # Init map display (buffered DC & set default cursor)
         self.MapWindow2D = BufferedWindow(self, id = wx.ID_ANY,
-                                          Map = self.Map, tree = self.tree, lmgr = self._layerManager)
+                                          Map = self.Map, frame = self, tree = self.tree, lmgr = self._layerManager)
         # default is 2D display mode
         self.MapWindow = self.MapWindow2D
         self.MapWindow.SetCursor(self.cursors["default"])
@@ -219,7 +219,7 @@
         if not self.MapWindowVDigit:
             from vdigit.mapwindow import VDigitWindow
-            self.MapWindowVDigit = VDigitWindow(self, id = wx.ID_ANY,
+            self.MapWindowVDigit = VDigitWindow(self, id = wx.ID_ANY, frame = self,
             self.MapWindowVDigit.Show()
@@ -294,8 +294,8 @@
         # create GL window
         if not self.MapWindow3D:
-            self.MapWindow3D = GLWindow(self, id = wx.ID_ANY,
+            self.MapWindow3D = GLWindow(self, id = wx.ID_ANY, frame = self,
+                                        Map = self.Map, tree = self.tree, lmgr = self._layerManager)
             self.MapWindow = self.MapWindow3D
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -51,11 +51,12 @@
     can also save the drawing to file by calling the
     SaveToFile() method.
                  style = wx.NO_FULL_REPAINT_ON_RESIZE, **kwargs):
-        MapWindow.__init__(self, parent, id, Map, tree, lmgr, **kwargs)
-        wx.Window.__init__(self, parent, id, style = style, **kwargs)
+        MapWindow.__init__(self, parent = parent, id = id, Map = Map,
+                           frame = frame, tree = tree, lmgr = lmgr, **kwargs)
+        wx.Window.__init__(self, parent = parent, id = id, style = style, **kwargs)
         # flags
         self.resize = False # indicates whether or not a resize event has taken place
@@ -446,10 +447,10 @@
                     updatemap = False
             # reposition checkbox in statusbar
-            self.parent.StatusbarReposition()
+            self.frame.StatusbarReposition()
             # update statusbar
-            self.parent.StatusbarUpdate()
+            self.frame.StatusbarUpdate()
             if updatemap:
                 self.UpdateMap(render = True)
@@ -533,7 +534,7 @@
                 for key in self.imagedict.keys():
                     if self.imagedict[key]['id'] == overlay.id:
                         del self.imagedict[key]
                 self.imagedict[img] = { 'id' : overlay.id,
                                         'layer' : overlay }
                 imgs.append(img)
@@ -587,9 +588,9 @@
         # initialize process bar (only on 'render')
         if render or renderVector:
-            self.parent.GetProgressBar().Show()
-            if self.parent.GetProgressBar().GetRange() > 0:
-                self.parent.GetProgressBar().SetValue(1)
+            self.frame.GetProgressBar().Show()
+            if self.frame.GetProgressBar().GetRange() > 0:
+                self.frame.GetProgressBar().SetValue(1)
         # render background image if needed
@@ -606,16 +607,16 @@
             if render:
                 # update display size
                 self.Map.ChangeMapSize(self.GetClientSize())
-                if self.parent.GetProperty('resolution'):
+                if self.frame.GetProperty('resolution'):
                     # use computation region resolution for rendering
                     windres = True
                 else:
                     windres = False
-                self.mapfile = self.Map.Render(force = True, mapWindow = self.parent,
+                self.mapfile = self.Map.Render(force = True, mapWindow = self.frame,
                                                windres = windres)
             else:
-                self.mapfile = self.Map.Render(force = False, mapWindow = self.parent)
+                self.mapfile = self.Map.Render(force = False, mapWindow = self.frame)
         except GException, e:
             GError(message = e.value)
@@ -700,20 +701,20 @@
             self.mouse['use'] = 'pointer'
             self.mouse['box'] = 'point'
             self.mouse['end'] = [0, 0]
-            self.SetCursor(self.parent.cursors["default"])
+            self.SetCursor(self.frame.cursors["default"])
         stop = time.clock()
         # hide process bar
-        self.parent.GetProgressBar().Hide()
+        self.frame.GetProgressBar().Hide()
         # update statusbar
         ### self.Map.SetRegion()
         Debug.msg (1, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
@@ -1042,7 +1043,7 @@
         self.UpdateMap()
         # update statusbar
         self.Refresh()
         self.processMouse = True
@@ -1158,7 +1159,7 @@
             # update statusbar
         elif self.mouse["use"] == "query":
             # querying
@@ -1173,15 +1174,15 @@
                     nVectors += 1
             if isRaster or nVectors > 1:
-                self.parent.QueryMap(self.mouse['begin'][0],self.mouse['begin'][1])
+                self.frame.QueryMap(self.mouse['begin'][0],self.mouse['begin'][1])
             else:
-                self.parent.QueryVector(self.mouse['begin'][0], self.mouse['begin'][1])
+                self.frame.QueryVector(self.mouse['begin'][0], self.mouse['begin'][1])
                 # clear temp canvas
                 self.UpdateMap(render = False, renderVector = False)
         elif self.mouse["use"] == "queryVector":
             # editable mode for vector map layers
             # clear temp canvas
@@ -1189,24 +1190,24 @@
         elif self.mouse["use"] in ["measure", "profile"]:
             # measure or profile
             if self.mouse["use"] == "measure":
-                self.parent.MeasureDist(self.mouse['begin'], self.mouse['end'])
+                self.frame.MeasureDist(self.mouse['begin'], self.mouse['end'])
             self.polycoords.append(self.Pixel2Cell(self.mouse['end']))
             self.ClearLines(pdc = self.pdcTmp)
             self.DrawLines(pdc = self.pdcTmp)
         elif self.mouse["use"] == "pointer" and \
-                not self.parent.IsStandalone() and \
-                self.parent.GetLayerManager().gcpmanagement:
+                not self.frame.IsStandalone() and \
+                self.frame.GetLayerManager().gcpmanagement:
             # -> GCP manager
-            if self.parent.GetToolbar('gcpdisp'):
+            if self.frame.GetToolbar('gcpdisp'):
                 coord = self.Pixel2Cell(self.mouse['end'])
-                if self.parent.MapWindow == self.parent.SrcMapWindow:
+                if self.frame.MapWindow == self.frame.SrcMapWindow:
                     coordtype = 'source'
                 else:
                     coordtype = 'target'
-                self.parent.GetLayerManager().gcpmanagement.SetGCPData(coordtype, coord, self, confirm = True)
+                self.frame.GetLayerManager().gcpmanagement.SetGCPData(coordtype, coord, self, confirm = True)
@@ -1228,10 +1229,10 @@
         elif self.mouse['use'] == 'legend':
             self.ResizeLegend(self.mouse["begin"], self.mouse["end"])
-            self.parent.dialogs['legend'].FindWindowByName("resize").SetValue(False)
+            self.frame.dialogs['legend'].FindWindowByName("resize").SetValue(False)
             self.Map.GetOverlay(1).SetActive(True)
-            self.parent.MapWindow.SetCursor(self.parent.cursors["default"])
-            self.parent.MapWindow.mouse['use'] = 'pointer'
+            self.frame.MapWindow.SetCursor(self.frame.cursors["default"])
+            self.frame.MapWindow.mouse['use'] = 'pointer'
             self.UpdateMap()
@@ -1249,7 +1250,7 @@
             self.Refresh()
         elif self.mouse["use"] != "profile" or \
                 (self.mouse['use'] != 'pointer' and \
@@ -1264,11 +1265,11 @@
             # self.ovlcoords[self.dragid] = self.pdc.GetIdBounds(self.dragid)
             if self.dragid > 100:
                 self.currtxtid = self.dragid
-                self.parent.OnAddText(None)
+                self.frame.OnAddText(None)
             elif self.dragid == 0:
-                self.parent.OnAddBarscale(None)
+                self.frame.OnAddBarscale(None)
             elif self.dragid == 1:
-                self.parent.OnAddLegend(None)
+                self.frame.OnAddLegend(None)
     def OnRightDown(self, event):
         """!Right mouse button pressed
@@ -1318,18 +1319,18 @@
         # update statusbar
     def OnMouseEnter(self, event):
         """!Mouse entered window and no mouse buttons were pressed
-        if not self.parent.IsStandalone() and \
-                if not self.parent.MapWindow == self:
-                    self.parent.MapWindow = self
-                    self.parent.Map = self.Map
-                    self.parent.UpdateActive(self)
+        if not self.frame.IsStandalone() and \
+                if not self.frame.MapWindow == self:
+                    self.frame.MapWindow = self
+                    self.frame.Map = self.Map
+                    self.frame.UpdateActive(self)
                     # needed for wingrass
                     self.SetFocus()
         else:
@@ -1502,8 +1503,8 @@
             self.Map.region['center_northing'] = cn
             self.Map.region['ewres'] = (newreg['e'] - newreg['w']) / self.Map.width
             self.Map.region['nsres'] = (newreg['n'] - newreg['s']) / self.Map.height
-            if not self.parent.HasProperty('alignExtent') or \
-                    self.parent.GetProperty('alignExtent'):
+            if not self.frame.HasProperty('alignExtent') or \
+                    self.frame.GetProperty('alignExtent'):
                 self.Map.AlignExtentFromDisplay()
             else:
                 for k in ('n', 's', 'e', 'w'):
@@ -1530,7 +1531,7 @@
         # disable tool if stack is empty
         if len(self.zoomhistory) < 2: # disable tool
-            toolbar = self.parent.GetMapToolbar()
+            toolbar = self.frame.GetMapToolbar()
             toolbar.Enable('zoomBack', enable = False)
         # zoom to selected region
@@ -1541,7 +1542,7 @@
         self.UpdateMap()
         # update statusbar
     def ZoomHistory(self, n, s, e, w):
         """!Manages a list of last 10 zoom extents
@@ -1569,7 +1570,7 @@
         else:
             enable = False
         toolbar.Enable('zoomBack', enable)
@@ -1626,7 +1627,7 @@
         if render:
             self.UpdateMap()
     def ZoomToWind(self):
         """!Set display geometry to match computational region
@@ -1639,7 +1640,7 @@
         self.UpdateMap()
     def ZoomToDefault(self):
         """!Set display geometry to match default region settings
@@ -1652,7 +1653,7 @@
         self.UpdateMap()
     def GoTo(self, e, n):
@@ -1798,7 +1799,7 @@
         dEast  = (e2 - e1)
         dNorth = (n2 - n1)
-        if self.parent.Map.projinfo['proj'] == 'll' and haveCtypes:
+        if self.frame.Map.projinfo['proj'] == 'll' and haveCtypes:
             dist = gislib.G_distance(e1, n1, e2, n2)
         else:
             dist = math.sqrt(math.pow((dEast), 2) + math.pow((dNorth), 2))
@@ -1811,7 +1812,7 @@
     def RegisterMouseEventHandler(self, event, handler, cursor = None):
         """!Calls UpdateTools to manage connected toolbars"""
-        self.parent.UpdateTools(None)
+        self.frame.UpdateTools(None)
         MapWindow.RegisterMouseEventHandler(self, event, handler, cursor)
     def UnregisterMouseEventHandler(self, event, handler):
@@ -1819,10 +1820,10 @@
         MapWindow.UnregisterMouseEventHandler(self, event, handler)
         # sets pointer mode
-        toolbar = self.parent.toolbars['map']
+        toolbar = self.frame.toolbars['map']
         toolbar.action['id'] = vars(toolbar)["pointer"]
         toolbar.OnTool(None)
-        self.parent.OnPointer(event = None)
+        self.frame.OnPointer(event = None)
     def RegisterGraphicsToDraw(self, graphicsType, setStatusFunc = None, drawFunc = None):
         """! Method allows to register graphics to draw.
Modified: grass/trunk/gui/wxpython/mapdisp/statusbar.py
--- grass/trunk/gui/wxpython/mapdisp/statusbar.py	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/mapdisp/statusbar.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -33,12 +33,16 @@
 import wx
+from wx.lib.newevent import NewEvent
 from core          import utils
 from core.gcmd     import GMessage, RunCommand
 from core.settings import UserSettings
 from grass.script  import core as grass
+wxAutoRender, EVT_AUTO_RENDER = NewEvent()
 class SbException:
     """! Exception class used in SbManager and SbItems"""
     def __init__(self, message):
@@ -366,6 +370,9 @@
     def OnToggleRender(self, event):
         # (other items should call self.mapFrame.IsAutoRendered())
+        event = wxAutoRender(state = self.GetValue())
+        wx.PostEvent(self.mapFrame, event)
         if self.GetValue():
             self.mapFrame.OnRender(None)
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -67,13 +67,13 @@
 class GLWindow(MapWindow, glcanvas.GLCanvas):
     """!OpenGL canvas for Map Display Window"""
+    def __init__(self, parent, id = wx.ID_ANY, frame = None,
                  Map = None, tree = None, lmgr = None):
         glcanvas.GLCanvas.__init__(self, parent, id)
-                           Map, tree, lmgr)
+        MapWindow.__init__(self, parent = parent, id = id, frame = frame,
+                           Map = Map, tree = tree, lmgr = lmgr)
         self.Hide()
         self.init = False
Added: grass/trunk/gui/wxpython/swipe/dialogs.py
--- grass/trunk/gui/wxpython/swipe/dialogs.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/swipe/dialogs.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -0,0 +1,62 @@
+ at package swipe.dialogs
+ at brief Dialogs used in Map Swipe
+Classes:
+ - dialogs::SwipeMapDialog
+(C) 2006-2012 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Anna Kratochvilova <kratochanna gmail.com>
+import wx
+from core               import globalvar
+from gui_core.dialogs   import ElementDialog
+from gui_core           import gselect
+class SwipeMapDialog(ElementDialog):
+    """!Dialog used to select raster maps"""
+    def __init__(self, parent, title = _("Select raster maps"), id =  wx.ID_ANY, first = None, second = None):
+        ElementDialog.__init__(self, parent, title, label = _("Name of first raster map:"))
+        self.element = gselect.Select(parent = self.panel, type = 'raster',
+                                      size = globalvar.DIALOG_GSELECT_SIZE)
+        self.element2 = gselect.Select(parent = self.panel, type = 'raster',
+        self.PostInit()
+        if first:
+            self.element.SetValue(first)
+        if second:
+            self.element2.SetValue(second)
+        self._layout()
+        self.SetMinSize(self.GetSize())
+    def _layout(self):
+        """!Do layout"""
+        self.dataSizer.Add(self.element, proportion = 0,
+                           flag = wx.EXPAND | wx.ALL, border = 1)
+        self.dataSizer.Add(wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+                                         label = _("Name of second raster map:")), proportion = 0,
+        self.dataSizer.Add(self.element2, proportion = 0,
+        self.panel.SetSizer(self.sizer)
+        self.sizer.Fit(self)
+    def GetValues(self):
+        """!Get raster maps"""
+        return (self.GetElement(), self.element2.GetValue())
Property changes on: grass/trunk/gui/wxpython/swipe/dialogs.py
___________________________________________________________________
Added: svn:mime-type
   + text/python
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Added: grass/trunk/gui/wxpython/swipe/frame.py
--- grass/trunk/gui/wxpython/swipe/frame.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/swipe/frame.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -0,0 +1,460 @@
+import os
+import sys
+import  wx
+import time
+if __name__ == "__main__":
+    sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
+import grass.script as grass
+from gui_core.mapdisp   import DoubleMapFrame
+from core.render        import Map, MapLayer
+from mapdisp            import statusbar as sb
+from core.debug         import Debug
+from mapdisp.statusbar  import EVT_AUTO_RENDER
+from swipe.toolbars  import SwipeMapToolbar, SwipeMainToolbar
+from swipe.mapwindow import SwipeBufferedWindow, EVT_MOTION
+from swipe.dialogs   import SwipeMapDialog
+class SwipeMapFrame(DoubleMapFrame):
+    def __init__(self, parent  = None, title = _("Map Swipe"), name = "swipe", **kwargs):
+        DoubleMapFrame.__init__(self, parent = parent, title = title, name = name,
+                                firstMap = Map(), secondMap = Map(), **kwargs)
+        Debug.msg (1, "SwipeMapFrame.__init__()")
+        # Add toolbars
+        toolbars = ['swipeMap', 'swipeMain']
+        if sys.platform == 'win32':
+            self.AddToolbar(toolbars.pop(1))
+            toolbars.reverse()
+        else:
+            self.AddToolbar(toolbars.pop(0))
+        for toolb in toolbars:
+            self.AddToolbar(toolb)
+        # create widgets
+        self.splitter = MapSplitter(parent = self, id = wx.ID_ANY)
+        self.sliderH = wx.Slider(self, id = wx.ID_ANY, style = wx.SL_HORIZONTAL)
+        self.sliderV = wx.Slider(self, id = wx.ID_ANY, style = wx.SL_VERTICAL)
+        self.firstMapWindow = SwipeBufferedWindow(parent = self.splitter, Map = self.firstMap, frame = self)
+        self.secondMapWindow = SwipeBufferedWindow(parent = self.splitter, Map = self.secondMap, frame = self)
+        self.MapWindow = self.firstMapWindow # current by default
+        self.firstMap.region = self.secondMap.region
+        self.firstMapWindow.zoomhistory = self.secondMapWindow.zoomhistory
+        self.splitter.SplitVertically(self.firstMapWindow, self.secondMapWindow, 0)
+        self._addPanes()
+        self._bindWindowsActivation()
+        self._mgr.GetPane('sliderV').Hide()
+        self._mgr.GetPane('sliderH').Show()
+        self.slider = self.sliderH
+        self.InitStatusbar()
+        self.Bind(wx.EVT_SIZE, self.OnSize)
+        self.Bind(EVT_AUTO_RENDER, self.OnAutoRenderChanged)
+        self.Bind(wx.EVT_IDLE, self.OnIdle)
+        self.SetSize((800, 600))
+        self._mgr.Update()
+        self.rasters = {'first': None, 'second': None}
+        # default action in map toolbar
+        self.OnPan(event = None)
+        self.resize = False
+        wx.CallAfter(self.CallAfterInit)
+    def CallAfterInit(self):
+        self.InitSliderBindings()
+        self.OnSelectRasters(event = None)
+    def InitStatusbar(self):
+        """!Init statusbar (default items)."""
+        # items for choice
+        self.statusbarItems = [sb.SbCoordinates,
+                               sb.SbRegionExtent,
+                               sb.SbCompRegionExtent,
+                               sb.SbShowRegion,
+                               sb.SbAlignExtent,
+                               sb.SbResolution,
+                               sb.SbDisplayGeometry,
+                               sb.SbMapScale,
+                               sb.SbGoTo,
+                               sb.SbProjection]
+        # create statusbar and its manager
+        statusbar = self.CreateStatusBar(number = 4, style = 0)
+        statusbar.SetStatusWidths([-5, -2, -1, -1])
+        self.statusbarManager = sb.SbManager(mapframe = self, statusbar = statusbar)
+        # fill statusbar manager
+        self.statusbarManager.AddStatusbarItemsByClass(self.statusbarItems, mapframe = self, statusbar = statusbar)
+        self.statusbarManager.AddStatusbarItem(sb.SbMask(self, statusbar = statusbar, position = 2))
+        self.statusbarManager.AddStatusbarItem(sb.SbRender(self, statusbar = statusbar, position = 3))
+        self.statusbarManager.Update()
+    def ResetSlider(self):
+        if self.splitter.GetSplitMode() == wx.SPLIT_VERTICAL:
+            size = self.splitter.GetSize()[0]
+        else:
+            size = self.splitter.GetSize()[1]
+        self.slider.SetRange(0, size)
+        self.slider.SetValue(self.splitter.GetSashPosition())
+    def InitSliderBindings(self):
+        self.sliderH.Bind(wx.EVT_SPIN, self.OnSliderPositionChanging)
+        self.sliderH.Bind(wx.EVT_SCROLL_THUMBRELEASE, self.OnSliderPositionChanged)
+        self.sliderV.Bind(wx.EVT_SPIN, self.OnSliderPositionChanging)
+        self.sliderV.Bind(wx.EVT_SCROLL_THUMBRELEASE, self.OnSliderPositionChanged)
+        self.splitter.Bind(wx.EVT_SPLITTER_SASH_POS_CHANGING, self.OnSashChanging)
+        self.splitter.Bind(wx.EVT_SPLITTER_SASH_POS_CHANGED, self.OnSashChanged)
+    def OnSliderPositionChanging(self, event):
+        """!Slider changes its position, sash must be moved too."""
+        Debug.msg (5, "SwipeMapFrame.OnSliderPositionChanging()")
+        self.GetFirstWindow().movingSash = True
+        self.GetSecondWindow().movingSash = True
+        pos = event.GetPosition()
+        if pos > 0:
+            self.splitter.SetSashPosition(pos)
+            self.splitter.OnSashChanging(None)
+    def OnSliderPositionChanged(self, event):
+        """!Slider position changed, sash must be moved too."""
+        Debug.msg (5, "SwipeMapFrame.OnSliderPositionChanged()")
+        self.splitter.SetSashPosition(event.GetPosition())
+        self.splitter.OnSashChanged(None)
+    def OnSashChanging(self, event):
+        """!Sash position is changing, slider must be moved too."""
+        Debug.msg (5, "SwipeMapFrame.OnSashChanging()")
+        event.Skip()
+    def OnSashChanged(self, event):
+        """!Sash position changed, slider must be moved too."""
+        Debug.msg (5, "SwipeMapFrame.OnSashChanged()")
+        self.OnSashChanging(event)
+        event.Skip()
+    def OnSize(self, event):
+        Debug.msg (4, "SwipeMapFrame.OnSize()")
+        self.resize = time.clock()
+        w1 = self.GetFirstWindow()
+        w2 = self.GetSecondWindow()
+        sizeAll = self.splitter.GetSize()
+        w1.SetClientSize(sizeAll)
+        w2.SetClientSize(sizeAll)
+        w1.OnSize(event)
+        w2.OnSize(event)
+    def OnIdle(self, event):
+        if self.resize and time.clock() - self.resize > 0.2:
+            self.ResetSlider()
+    def OnAutoRenderChanged(self, event):
+        """!Auto rendering state changed."""
+        style = self.splitter.GetWindowStyle()
+        style ^= wx.SP_LIVE_UPDATE
+        self.splitter.SetWindowStyle(style)
+    def AddToolbar(self, name):
+        """!Add defined toolbar to the window
+        Currently known toolbars are:
+         - 'swipeMap'          - basic map toolbar
+         - 'swipeMain'         - swipe functionality
+        if name == "swipeMap":
+            self.toolbars[name] = SwipeMapToolbar(self)
+            self._mgr.AddPane(self.toolbars[name],
+                      wx.aui.AuiPaneInfo().
+                      Name(name).Caption(_("Map Toolbar")).
+                      ToolbarPane().Top().
+                      LeftDockable(False).RightDockable(False).
+                      BottomDockable(False).TopDockable(True).
+                      CloseButton(False).Layer(2).Row(1).
+                      BestSize((self.toolbars[name].GetBestSize())))
+        if name == "swipeMain":
+            self.toolbars[name] = SwipeMainToolbar(self)
+                      Name(name).Caption(_("Main Toolbar")).
+    def _addPanes(self):
+        """!Add splitter window and sliders to aui manager"""
+        # splitter window
+        self._mgr.AddPane(self.splitter, wx.aui.AuiPaneInfo().
+                  Name('splitter').CaptionVisible(False).PaneBorder(True).
+                  Dockable(False).Floatable(False).CloseButton(False).
+                  Center().Layer(1).BestSize((self.splitter.GetBestSize())))
+        # sliders
+        self._mgr.AddPane(self.sliderH, wx.aui.AuiPaneInfo().
+                  Name('sliderH').CaptionVisible(False).PaneBorder(False).
+                  CloseButton(False).Gripper(True).GripperTop(False).
+                  BottomDockable(True).TopDockable(True).
+                  Bottom().Layer(1).BestSize((self.sliderH.GetBestSize())))
+        self._mgr.AddPane(self.sliderV, wx.aui.AuiPaneInfo().
+                  Name('sliderV').CaptionVisible(False).PaneBorder(False).
+                  CloseButton(False).Gripper(True).GripperTop(True).
+                  BottomDockable(False).TopDockable(False).
+                  LeftDockable(True).RightDockable(True).
+                  Right().Layer(1).BestSize((self.sliderV.GetBestSize())))
+    def UpdateRegion(self):
+        Rerender the second window
+        when the region of the first changed.
+        Debug.msg(3, "SwipeMapFrame.UpdateRegion()")
+        if self.GetWindow() == self.GetSecondWindow():
+            self.Render(self.GetFirstWindow())
+        else:
+            self.Render(self.GetSecondWindow())
+    def OnZoomToMap(self, event):
+        Set display extents to match selected raster (including NULLs)
+        or vector map.
+        self.GetFirstWindow().ZoomToMap(layers = self.Map.GetListOfLayers())
+        self.GetSecondWindow().ZoomToMap(layers = self.Map.GetListOfLayers())
+        # needed again, don't know why
+    def OnZoomBack(self, event):
+        self.GetFirstWindow().ZoomBack()
+        self.secondMap.region = self.firstMap.region
+    def OnSelectRasters(self, event):
+        """!Choose raster maps and rerender."""
+        dlg = SwipeMapDialog(self, first = self.rasters['first'], second = self.rasters['second'])
+        if dlg.ShowModal() == wx.ID_OK:
+            maps = dlg.GetValues()
+            raster1 = grass.find_file(name = maps[0], element = 'cell')
+            raster2 = grass.find_file(name = maps[1], element = 'cell')
+            self.SetFirstRaster(name = maps[0])
+            self.SetSecondRaster(name = maps[1])
+        dlg.Destroy()
+        self.OnRender(event = None)
+    def SetFirstRaster(self, name):
+        """!Set raster map to first Map"""
+        raster = grass.find_file(name = name, element = 'cell')
+        if raster['fullname']:
+            self.rasters['first'] = raster['fullname']
+            self.SetLayer(name = raster['fullname'], mapInstance = self.GetFirstMap())
+            self.OnZoomToMap(event = None)
+    def SetSecondRaster(self, name):
+        """!Set raster map to second Map"""
+            self.rasters['second'] = raster['fullname']
+            self.SetLayer(name = raster['fullname'], mapInstance = self.GetSecondMap())
+    def SetLayer(self, name, mapInstance):
+        """!Sets layer in Map.
+        @param name layer (raster) name
+        Debug.msg (3, "SwipeMapFrame.SetLayer(): name=%s" % name)
+        self.rasters['first'] = name
+        # this simple application enables to keep only one raster
+        mapInstance.DeleteAllLayers()
+        cmdlist = ['d.rast', 'map=%s' % name]
+        # add layer to Map instance (core.render)
+        newLayer = mapInstance.AddLayer(type = 'raster', command = cmdlist, l_active = True,
+                                          name = name, l_hidden = False, l_opacity = 1.0,
+                                          l_render = True)
+    def OnSwitchWindows(self, event):
+        """!Switch windows position."""
+        Debug.msg(3, "SwipeMapFrame.OnSwitchWindows()")
+        splitter = self.splitter
+        w1, w2 = splitter.GetWindow1(), splitter.GetWindow2()
+        splitter.ReplaceWindow(w1, w2)
+        splitter.ReplaceWindow(w2, w1)
+        # self.OnSize(None)
+        splitter.OnSashChanged(None)
+    def OnSwitchOrientation(self, event):
+        """!Switch orientation of the sash."""
+        Debug.msg(3, "SwipeMapFrame.OnSwitchOrientation()")
+        splitter.Unsplit()
+        if splitter.GetSplitMode() == wx.SPLIT_HORIZONTAL:
+            splitter.SplitVertically(self.firstMapWindow, self.secondMapWindow, 0)
+        else:
+            splitter.SplitHorizontally(self.firstMapWindow, self.secondMapWindow, 0)
+            self.slider = self.sliderV
+            self._mgr.GetPane('sliderV').Show()
+            self._mgr.GetPane('sliderH').Hide()
+        self.OnSize(None)
+    def GetMapToolbar(self):
+        """!Returns toolbar with zooming tools"""
+        return self.toolbars['swipeMap']
+    def IsStandalone(self):
+        if parent:
+            return False
+        return True
+class MapSplitter(wx.SplitterWindow):
+    """!Splitter window for displaying two maps"""
+    def __init__(self, parent, id):
+        wx.SplitterWindow.__init__(self, parent = parent, id = id,
+                                   style = wx.SP_LIVE_UPDATE
+        Debug.msg(2, "MapSplitter.__init__()")
+        self.sashWidthMin = 1
+        self.sashWidthMax = 10
+        self.Bind(wx.EVT_SPLITTER_SASH_POS_CHANGED, self.OnSashChanged)
+        self.Bind(wx.EVT_SPLITTER_SASH_POS_CHANGING, self.OnSashChanging)
+        wx.CallAfter(self.Init)
+    def Init(self):
+        self.OnSashChanged(evt = None)
+        self.SetMinimumPaneSize(0)
+        self.SetSashSize(self.sashWidthMin)
+    # def OnMotion(self, event):
+    #     w = self.GetSashSize()
+    #     w1, w2 = self.GetWindow1(), self.GetWindow2()
+    #     if self.SashHitTest(event.GetX(), event.GetY(), tolerance = 20):
+    #         if w == self.sashWidthMin:
+    #             self.SetSashSize(self.sashWidthMax)
+    #             self.SetNeedUpdating(True)
+    #             w1.movingSash = True
+    #             w2.movingSash = True
+    #         else:
+    #             w1.movingSash = False
+    #     else:
+    #         if w == self.sashWidthMax:
+    #             self.SetSashSize(self.sashWidthMin)
+    #         else:
+    #             w2.movingSash = False
+    #     event.Skip()
+    def OnSashChanged(self, evt):
+        Debug.msg(5, "MapSplitter.OnSashChanged()")
+        w1, w2 = self.GetWindow1(), self.GetWindow2()
+        w1.movingSash = False
+        w2.movingSash = False
+        wx.CallAfter(self.SashChanged)
+    def SashChanged(self):
+        Debug.msg(5, "MapSplitter.SashChanged()")
+        w1.SetImageCoords((0, 0))
+        if self.GetSplitMode() == wx.SPLIT_VERTICAL:
+            w = w1.GetSize()[0]
+            w2.SetImageCoords((-w, 0))
+        else:
+            h = w1.GetSize()[1]
+            w2.SetImageCoords((0, -h))
+        w1.UpdateMap(render = False, renderVector = False)
+        w2.UpdateMap(render = False, renderVector = False)
+        pos = self.GetSashPosition()
+        self.last = pos
+        Debug.msg(5, "MapSplitter.OnSashChanging()")
+        if not (self.GetWindowStyle() & wx.SP_LIVE_UPDATE):
+            if event:
+                event.Skip()
+            return
+        dpos = pos - self.last
+        self.last = pos
+            dx = -dpos
+            dy = 0
+        else:
+            dx = 0
+            dy = -dpos
+        self.GetWindow2().TranslateImage(dx, dy)
+        self.GetWindow1().movingSash = True
+        self.GetWindow2().movingSash = True
+def main():
+    import gettext
+    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+    app = wx.PySimpleApp()
+    wx.InitAllImageHandlers()
+    frame = SwipeMapFrame()
+    frame.Show()
+    app.MainLoop()
+if __name__ == '__main__':
+    main()
Property changes on: grass/trunk/gui/wxpython/swipe/frame.py
   + text/python
Added: svn:keywords
   + Author Date Id
   + native
Added: grass/trunk/gui/wxpython/swipe/mapwindow.py
--- grass/trunk/gui/wxpython/swipe/mapwindow.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/swipe/mapwindow.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -0,0 +1,188 @@
+ at package swipe.mapwindow
+ at brief Map Swipe map window.
+Classes:
+ - mapwindow::SwipeBufferedWindow
+ - mapwindow::_MouseEvent
+for details.
+Class _MouseEvent taken from wxPython FloatCanvas source code (Christopher Barker).
+import time
+import wx
+from mapdisp.mapwindow import BufferedWindow
+EVT_MY_MOUSE_EVENTS = wx.NewEventType()
+EVT_MY_MOTION = wx.NewEventType()
+EVT_MOUSE_EVENTS = wx.PyEventBinder(EVT_MY_MOUSE_EVENTS)
+EVT_MOTION = wx.PyEventBinder(EVT_MY_MOTION)
+class SwipeBufferedWindow(BufferedWindow):
+    """!A subclass of BufferedWindow class.
+    Enables to draw the image translated.
+    Special mouse events with changed coordinates are used.
+                 tree = None, lmgr = None, **kwargs):
+        BufferedWindow.__init__(self, parent = parent, Map = Map, frame = frame, tree = tree, lmgr = lmgr, **kwargs)
+        Debug.msg(2, "SwipeBufferedWindow.__init__()")
+        self.specialSize = super(SwipeBufferedWindow, self).GetClientSize()
+        self.specialCoords = [0, 0]
+        self.imageId = 99
+        self.movingSash = False
+    def _bindMouseEvents(self):
+        """!Binds wx mouse events and custom mouse events"""
+        wx.EVT_MOUSE_EVENTS(self, self._mouseActions)
+        wx.EVT_MOTION(self, self._mouseMotion)
+        self.Bind(EVT_MOTION, self.OnMotion)
+        self.Bind(EVT_MOUSE_EVENTS, self.MouseActions)
+        self.Bind(wx.EVT_CONTEXT_MENU, self.OnContextMenu)
+    def _RaiseMouseEvent(self, Event, EventType):
+         """!This is called in various other places to raise a Mouse Event
+         Debug.msg(5, "SwipeBufferedWindow._RaiseMouseEvent()")
+        # this computes the new coordinates from the mouse coords.
+         x, y = Event.GetPosition()
+         pt = x - self.GetImageCoords()[0], y - self.GetImageCoords()[1]
+         evt = _MouseEvent(EventType, Event, self.GetId(), pt)
+         self.GetEventHandler().ProcessEvent(evt)
+         # this skip was not in the original code but is needed here
+         Event.Skip()
+    def _mouseActions(self, event):
+        self._RaiseMouseEvent(event, EVT_MY_MOUSE_EVENTS)
+    def _mouseMotion(self, event):
+        self._RaiseMouseEvent(event, EVT_MY_MOTION)
+    def GetClientSize(self):
+        """!Overriden method which returns simulated window size.
+        return self.specialSize
+    def SetClientSize(self, size):
+        """!Overriden method which sets simulated window size.
+        Debug.msg(3, "SwipeBufferedWindow.SetClientSize(): size = %s" % size)
+        self.specialSize = size
+    def GetImageCoords(self):
+        """!Returns coordinates of rendered image"""
+        return self.specialCoords
+    def SetImageCoords(self, coords):
+        """!Sets coordinates of rendered image"""
+        Debug.msg(3, "SwipeBufferedWindow.SetImageCoords(): coords = %s, %s" % (coords[0], coords[1]))
+        self.specialCoords = coords
+        """!Calls superclass's OnSize method only when needed"""
+        Debug.msg(5, "SwipeBufferedWindow.OnSize()")
+        if not self.movingSash:
+            super(SwipeBufferedWindow, self).OnSize(event)
+    def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
+        super(SwipeBufferedWindow, self).ZoomToMap(layers, ignoreNulls, render)
+        self.frame.UpdateRegion()
+    def ZoomBack(self):
+        """!Zoom last (previously stored position)
+        super(SwipeBufferedWindow, self).ZoomBack()
+    def Draw(self, pdc, img = None, drawid = None, pdctype = 'image', coords = [0, 0, 0, 0]):
+        """!Draws image (map) with translated coordinates.
+        Debug.msg(2, "SwipeBufferedWindow.Draw()")
+        if pdctype == 'image':
+            coords = self.GetImageCoords()
+        return super(SwipeBufferedWindow, self).Draw(pdc, img, drawid, pdctype, coords)
+    def TranslateImage(self, dx, dy):
+        """!Translate image and redraw.
+        Debug.msg(5, "SwipeBufferedWindow.TranslateImage(): dx = %s, dy = %s" % (dx, dy))
+        self.pdc.TranslateId(self.imageId, dx, dy)
+        self.Refresh()
+    def MouseActions(self, event):
+        """!Handle mouse events and if needed let parent frame know"""
+        super(SwipeBufferedWindow, self).MouseActions(event)
+        if event.GetWheelRotation() != 0 or \
+           event.LeftUp() or \
+           event.MiddleUp():
+        event.Skip()
+    def MouseDraw(self, pdc = None, begin = None, end = None):
+        """!Overriden method to recompute coordinates back to original values
+        so that e.g. drawing of zoom box is done properly"""
+        Debug.msg(5, "SwipeBufferedWindow.MouseDraw()")
+        offsetX, offsetY = self.GetImageCoords()
+        begin = (self.mouse['begin'][0] + offsetX, self.mouse['begin'][1] + offsetY)
+        end = (self.mouse['end'][0] + offsetX, self.mouse['end'][1] + offsetY)
+        super(SwipeBufferedWindow, self).MouseDraw(pdc, begin, end)
+class _MouseEvent(wx.PyCommandEvent):
+    This event class takes a regular wxWindows mouse event as a parameter,
+    and wraps it so that there is access to all the original methods. This
+    is similar to subclassing, but you can't subclass a wxWindows event.
+    The goal is to be able to it just like a regular mouse event.
+    Difference is that it is a CommandEvent, which propagates up the
+    window hierarchy until it is handled.
+    def __init__(self, EventType, NativeEvent, WinID, changed = None):
+        Debug.msg(5, "_MouseEvent:__init__()")
+        wx.PyCommandEvent.__init__(self)
+        self.SetEventType(EventType)
+        self._NativeEvent = NativeEvent
+        self.changed = changed
+    def GetPosition(self):
+        return wx.Point(*self.changed)
+    def GetPositionTuple(self):
+        return self.changed
+    def GetX(self):
+        return self.changed[0]
+    def GetY(self):
+        return self.changed[1]
+    # this delegates all other attributes to the native event.
+    def __getattr__(self, name):
+        return getattr(self._NativeEvent, name)
Property changes on: grass/trunk/gui/wxpython/swipe/mapwindow.py
   + text/python
Added: svn:keywords
   + Author Date Id
   + native
Added: grass/trunk/gui/wxpython/swipe/toolbars.py
--- grass/trunk/gui/wxpython/swipe/toolbars.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/swipe/toolbars.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -0,0 +1,123 @@
+ at package swipe.toolbars
+ at brief Map Swipe toolbars and icons.
+Classes:
+ - toolbars::swipeMapToolbar
+ - toolbars::swipeMainToolbar
+for details.
+import wx
+from gui_core.toolbars import BaseToolbar, BaseIcons
+from icons.icon import MetaIcon
+swipeIcons = {
+        'tools': MetaIcon(img = 'tools', label = _('Tools')),
+class SwipeMapToolbar(BaseToolbar):
+    """!Map toolbar (to control map zoom and rendering)
+    def __init__(self, parent):
+        """!Map toolbar constructor
+        BaseToolbar.__init__(self, parent)
+        self.InitToolbar(self._toolbarData())
+        # realize the toolbar
+        self.Realize()
+        self.action = { 'id' : self.pan }
+        self.defaultAction = { 'id' : self.pan,
+                               'bind' : self.parent.OnPan }
+        self.EnableTool(self.zoomBack, False)
+    def _toolbarData(self):
+        """!Returns toolbar data (name, icon, handler)"""
+        # BaseIcons are a set of often used icons. It is possible
+        # to reuse icons in ./trunk/gui/icons/grass or add new ones there.
+        icons = BaseIcons
+        return self._getToolbarData((("displaymap", icons["display"],
+                                      self.parent.OnDraw),
+                                     ("rendermap", icons["render"],
+                                      self.parent.OnRender),
+                                     ("erase", icons["erase"],
+                                      self.parent.OnErase),
+                                     (None, ), # creates separator
+                                     ("pan", icons["pan"],
+                                      self.parent.OnPan,
+                                      wx.ITEM_CHECK), # toggle tool
+                                     ("zoomIn", icons["zoomIn"],
+                                      self.parent.OnZoomIn,
+                                      wx.ITEM_CHECK),
+                                     ("zoomOut", icons["zoomOut"],
+                                      self.parent.OnZoomOut,
+                                      wx.ITEM_CHECK),
+                                     (None, ),
+                                     ("zoomBack", icons["zoomBack"],
+                                      self.parent.OnZoomBack),
+                                     ("zoomToMap", icons["zoomExtent"],
+                                      self.parent.OnZoomToMap),
+    def SetActiveMap(self, index):
+        """!Set currently selected map.
+        Unused, needed because of DoubleMapFrame API.
+        pass
+class SwipeMainToolbar(BaseToolbar):
+    """!Toolbar with tools related to application functionality
+        """!Toolbar constructor
+        self.Realize()
+        """!Toolbar data"""
+        icons = swipeIcons
+        return self._getToolbarData((("addRaster", BaseIcons['addRast'],
+                                      self.parent.OnSelectRasters),
+                                     (None, ),
+                                     ("tools", swipeIcons['tools'],
+                                      self.OnToolMenu)
+    def OnToolMenu(self, event):
+        """!Menu for additional tools"""
+        point = wx.GetMousePosition()
+        toolMenu = wx.Menu()
+        for label, itype, handler, desc in (
+            (_("Switch orientation"),
+             wx.ITEM_NORMAL, self.parent.OnSwitchOrientation, "switchOrientation"),
+            (_("Switch maps"),
+             wx.ITEM_NORMAL, self.parent.OnSwitchWindows, "switchMaps")):
+            # Add items to the menu
+            item = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+                               text = label,
+                               kind = itype)
+            toolMenu.AppendItem(item)
+            self.parent.GetWindow().Bind(wx.EVT_MENU, handler, item)
+        # Popup the menu.  If an item is selected then its handler
+        # will be called before PopupMenu returns.
+        self.parent.GetWindow().PopupMenu(toolMenu)
+        toolMenu.Destroy()
Property changes on: grass/trunk/gui/wxpython/swipe/toolbars.py
   + text/python
Added: svn:keywords
   + Author Date Id
   + native
Modified: grass/trunk/gui/wxpython/vdigit/mapwindow.py
--- grass/trunk/gui/wxpython/vdigit/mapwindow.py	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/vdigit/mapwindow.py	2012-08-09 07:20:19 UTC (rev 52602)
@@ -28,11 +28,11 @@
 class VDigitWindow(BufferedWindow):
     """!A Buffered window extended for vector digitizer.
-        BufferedWindow.__init__(self, parent, id, Map, tree, lmgr,
-                                style, **kwargs)
+        BufferedWindow.__init__(self, parent = parent, id = id, Map = Map,
+                                frame = frame, tree = tree, lmgr = lmgr, style = style, **kwargs)
         self.pdcVector = wx.PseudoDC()
         self.toolbar   = self.parent.GetToolbar('vdigit')
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox	2012-08-09 07:20:19 UTC (rev 52602)
@@ -36,6 +36,7 @@
  - \ref psmap
  - \ref locWizard
  - \ref plot
+ - \ref swipe
  - \ref other
 - \ref devel
 - \ref seeAlso
@@ -476,7 +477,21 @@
  - toolbars::IClassToolbar
  - toolbars::IClassMapManagerToolbar
  - toolbars::IClassMiscToolbar
+\subsection swipe Map Swipe
+- swipe::frame
+ - frame::SwipeMapFrame
+ - frame::MapSplitter
+- swipe::mapwindow
+- swipe::dialogs
+- swipe::toolbars
+ - toolbars::SwipeMapToolbar
+ - toolbars::SwipeMainToolbar
 \subsection other Other GUI modules
 - modules::colorrules
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2012-08-09 06:51:25 UTC (rev 52601)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2012-08-09 07:20:19 UTC (rev 52602)
@@ -742,6 +742,12 @@
 	  <handler>OnPsMap</handler>
 	  <command>ps.map</command>
 	</menuitem>
+	<menuitem>
+	  <label>Map Swipe</label>
+	  <help>Launch Map Swipe</help>
+	  <keywords>visualization,raster</keywords>
+	  <handler>OnMapSwipe</handler>
+	</menuitem>
 	<separator />
 	<menuitem>
 	  <label>Launch script</label>
