[GRASS-SVN] r52624 - grass-addons/grass6/imagery/i.despeckle
Fri Aug 10 15:29:01 PDT 2012
Author: neteler
Date: 2012-08-10 15:29:01 -0700 (Fri, 10 Aug 2012)
New Revision: 52624
   grass-addons/grass6/imagery/i.despeckle/i.despeckle
Maning Sambale: more methods implemented
Modified: grass-addons/grass6/imagery/i.despeckle/i.despeckle
--- grass-addons/grass6/imagery/i.despeckle/i.despeckle	2012-08-10 18:33:57 UTC (rev 52623)
+++ grass-addons/grass6/imagery/i.despeckle/i.despeckle	2012-08-10 22:29:01 UTC (rev 52624)
@@ -3,12 +3,18 @@
 # MODULE:       i.despeckle
-# AUTHOR(S):    Markus Neteler
+# AUTHOR(S):    Markus Neteler, Maning Sambale
 # PURPOSE:      FGAMMA -- Gamma SAR Speckle Filter, based on
 #               http://web.archive.org/web/20050826071553/http://www.pcigeomatics.com/cgi-bin/pcihlp/M_FGAMMA
+#               http://web.archive.org/web/20070122173456/http://www.pcigeomatics.com/cgi-bin/pcihlp/FLE|ALGORITHM
+#               http://web.archive.org/web/20071216181051/http://www.pcigeomatics.com/cgi-bin/pcihlp/FELEE
+#               http://web.archive.org/web/20071216081728/http://www.pcigeomatics.com/cgi-bin/pcihlp/FFROST
+#               http://web.archive.org/web/20071216181046/http://www.pcigeomatics.com/cgi-bin/pcihlp/FEFROST
-# COPYRIGHT:    (C) 2012 GRASS Development Team/Markus Neteler
+#               List: http://web.archive.org/web/20060721084141/http://www.pcigeomatics.com/cgi-bin/searchhlp.pl
+# COPYRIGHT:    (C) 2012 GRASS Development Team/Markus Neteler/Maning Sambale
 #  This program is free software; you can redistribute it and/or modify
 #  it under the terms of the GNU General Public License as published by
 #  the Free Software Foundation; either version 2 of the License, or
@@ -21,7 +27,7 @@
 #%Module
-#% description: Applies GAMMA SAR Speckle Filter to map.
+#% description: Applies SAR Speckle Filter to a raster power map.
 #% keywords: imagery, filter, despeckle
 #%End
 #%Option
@@ -30,7 +36,7 @@
 #% required: yes
 #% multiple: no
 #% key_desc: name
-#% description: Name of input raster map
+#% description: Name of input raster power map
 #% gisprompt: old,cell,raster
 #%End
 #%Option
@@ -45,9 +51,9 @@
 #%Option
 #% key: method
 #% type: string
-#% required: no
+#% required: yes
 #% multiple: no
-#% options: gamma
+#% options: gamma,lee,kuan
 #% description: Despeckle operation
 #% answer: gamma
 #%End
@@ -84,53 +90,105 @@
 fi
 MAP=$GIS_OPT_INPUT
 WIN=$GIS_OPT_SIZE
-NumberLooks=$GIS_OPT_LOOKS
+NumberLooks=$GIS_OPT_LOOKS # controls the amount of smoothing applied to image
 OUTPUT=$GIS_OPT_OUTPUT
+METHOD=$GIS_OPT_METHOD
-#        S   =   standard deviation of intensity within window
+# S   =   standard deviation of intensity within window
 r.neighbors in=$MAP out=$MAP.stddev method=stddev size=$WIN
-#       Im  =   mean value of intensity within window
+# Im  =   mean value of intensity within window
 r.neighbors in=$MAP out=$MAP.mean method=average size=$WIN
-#       Ci  =   S / Im
-r.mapcalc "$MAP.ci = $MAP.stddev / $MAP.mean"
+# Ci  =   S / Im
+r.mapcalc "$MAP.ci = float($MAP.stddev) / float($MAP.mean)"
-#       Cu  =   SQRT(1/NumberLooks)
-Cu="`echo $NumberLooks | awk '{printf "%f", sqrt(1/$1)}'`"
+# Cu  =   SQRT(1/NumberLooks)
+Cu="`echo $NumberLooks | awk '{printf "%f", sqrt(1.0/$1)}'`"
-#       Cmax =  SQRT(2)*Cu
-Cmax="`echo $Cu | awk '{printf "%f", sqrt(2) * $1}'`"
-#       A   =   (1+Cu^2)/(Ci^2-Cu^2)
-r.mapcalc "$MAP.A = (1 + $Cu^2)/($MAP.ci^2 - $Cu^2)"
+if [ $METHOD == "lee" ]
+then
+  # A 7x7 filter usually gives the best results
+  # Note: Lee filter model requires that the signal represents power.
+  # If the input image is in amplitude format, each grey level must be
+  # squared to derive power and finally square root must be applied to
+  # the filtered result.
+  echo "Processing with LEE filter"
-#       B   =   A-NumberLooks-1
-r.mapcalc "$MAP.B = $MAP.A - $NumberLooks - 1"
+  # W   =   1 - Cu^2/Ci^2
+  r.mapcalc "$MAP.W = 1.0 - ($Cu^2/$MAP.ci^2)"
-#       D   =   Im*Im*B*B + 4*A*NumberLooks*Im*Ic
-#       Ic  =   center pixel in filter window
-r.mapcalc "$MAP.D = $MAP.mean * $MAP.mean * $MAP.B * $MAP.B + 4 * $MAP.A * $NumberLooks * $MAP.mean * $MAP"
+  # R  =   Ic * W + Im * (1 - W)
+  # Ic  =   center pixel in filter window
+  r.mapcalc "$OUTPUT = $MAP * $MAP.W + $MAP.mean * (1.0 - $MAP.W)"
-#       Rf  =   (B*Im + SQRT(D))/(2*A)
-r.mapcalc "$MAP.rf = ($MAP.B * $MAP.mean + sqrt($MAP.D)) / (2 * $MAP.A)"
+  g.remove --q rast=$MAP.mean,$MAP.stddev,$MAP.rf,$MAP.ci,$MAP.W
+fi
-#       R1   =   Im      for Ci <= Cu
-#       R2   =   Rf      for Cu < Ci < Cmax
-#       R3   =   Ic      for Ci >= Cmax
+if [ $METHOD == "kuan" ]
+then
+  echo "Processing with KUAN filter"
+  # Note: KUAN filter model requires that the signal represents power.
-r.mapcalc "$OUTPUT = eval(r1 = $MAP.mean, r2 = $MAP.rf, r3 = $MAP, \\
-     if($MAP.ci < $Cu, r1, \\
-       if($MAP.ci > $Cu && $MAP.ci < $Cmax, r2, \\
-         if($MAP.ci > $Cmax, r3, null() ) \\
+  # W   =   (1 - Cu^2/Ci^2)/(1+Cu^2)
+  r.mapcalc "$MAP.W = (1.0 - $Cu^2/$MAP.ci^2) / (1.0 + $Cu^2)"
+  g.remove --q rast=$MAP.mean,$MAP.stddev,$MAP.ci,$MAP.W
+fi
+if [ $METHOD == "gamma" ]
+then
+  echo "Processing with GAMMA filter"
+  # Note: GAMMA filter model requires that the signal represents power.
+  # Cmax =  SQRT(2)*Cu
+  Cmax="`echo $Cu | awk '{printf "%f", sqrt(2.0) * $1}'`"
+  # A   =   (1+Cu^2)/(Ci^2-Cu^2)
+  r.mapcalc "$MAP.A = (1.0 + $Cu^2)/($MAP.ci^2 - $Cu^2)"
+  # B   =   A-NumberLooks-1
+  r.mapcalc "$MAP.B = $MAP.A - $NumberLooks - 1"
+  # D   =   Im*Im*B*B + 4*A*NumberLooks*Im*Ic
+  r.mapcalc "$MAP.D = $MAP.mean * $MAP.mean * $MAP.B * $MAP.B + 4 * $MAP.A * \\
+      $NumberLooks * $MAP.mean * $MAP"
+  # Rf  =   (B*Im + SQRT(D))/(2*A)
+  r.mapcalc "$MAP.rf = ($MAP.B * $MAP.mean + sqrt($MAP.D)) / (2 * $MAP.A)"
+  # R1   =   Im      for Ci <= Cu
+  # R2   =   Rf      for Cu < Ci < Cmax
+  # R3   =   Ic      for Ci >= Cmax
+  r.mapcalc "$OUTPUT = eval(r1 = $MAP.mean, r2 = $MAP.rf, r3 = $MAP, \\
+       if($MAP.ci < $Cu, r1, \\
+         if($MAP.ci > $Cu && $MAP.ci < $Cmax, r2, \\
+           if($MAP.ci > $Cmax, r3, null() ) \\
+  g.remove --q rast=$MAP.mean,$MAP.stddev,$MAP.rf,$MAP.ci,$MAP.A,$MAP.B,$MAP.D,$MAP.W
+fi
 r.colors $OUTPUT col=grey -e
-g.remove --q rast=$MAP.mean,$MAP.stddev,$MAP.rf,$MAP.ci,$MAP.A,$MAP.B,$MAP.D
+r.support map=$OUTPUT description="generated by i.descpeckle using $METHOD filter."
 echo "Written <$OUTPUT>"
