[GRASS-SVN] r52641 - grass/trunk/gui/wxpython/dbmgr
Sun Aug 12 12:11:18 PDT 2012
Author: martinl
Date: 2012-08-12 12:11:18 -0700 (Sun, 12 Aug 2012)
New Revision: 52641
Added:
   grass/trunk/gui/wxpython/dbmgr/base.py
   grass/trunk/gui/wxpython/dbmgr/manager.py
   grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
wxGUI/DbMgr: major refactoring done by Stepan Turek (GSoC 2012)
             initial version of Field Calculator (SQL Update Builder)
Added: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/dbmgr/base.py	2012-08-12 19:11:18 UTC (rev 52641)
@@ -0,0 +1,3159 @@
+ at package dbmgr.base
+ at brief GRASS Attribute Table Manager base classes
+List of classes:
+ - base::Log
+ - base::VirtualAttributeList
+ - base::DbMgrBase
+ - base::DbMgrNotebookBase
+ - base::DbMgrBrowsePage
+ - base::DbMgrTablesPage
+ - base::DbMgrLayersPage
+ - base::TableListCtrl
+ - base::LayerListCtrl
+ - base::LayerBook
+(C) 2007-2009, 2011-2012 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Jachym Cepicky <jachym.cepicky gmail.com>
+ at author Martin Landa <landa.martin gmail.com>
+ at author Refactoring by Stepan Turek <stepan.turek seznam.cz> (GSoC 2012, mentor: Martin Landa)
+import sys
+import os
+import locale
+import tempfile
+import copy
+import types
+if __name__ == "__main__":
+    sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
+from core import globalvar
+import wx
+import wx.lib.mixins.listctrl as listmix
+import wx.lib.flatnotebook    as FN
+import grass.script as grass
+from dbmgr.sqlbuilder import SQLBuilderSelect, SQLBuilderUpdate
+from core.gcmd        import RunCommand, GException, GError, GMessage, GWarning
+from core.utils       import ListOfCatsToRange
+from gui_core.dialogs import CreateNewVector
+from dbmgr.vinfo      import VectorDBInfo, unicodeValue, createDbInfoDesc
+from core.debug       import Debug
+from dbmgr.dialogs    import ModifyTableRecord
+from core.settings    import UserSettings
+class Log:
+    """!The log output SQL is redirected to the status bar of the
+    containing frame.
+    def __init__(self, parent):
+        self.parent = parent
+    def write(self, text_string):
+        """!Update status bar"""
+        if self.parent:
+            self.parent.SetStatusText(text_string.strip())
+class VirtualAttributeList(wx.ListCtrl,
+                           listmix.ListCtrlAutoWidthMixin,
+                           listmix.ColumnSorterMixin):
+    """!Support virtual list class for Attribute Table Manager (browse page)
+    def __init__(self, parent, log, dbMgrData, layer):
+        # initialize variables
+        self.log     = log
+        self.dbMgrData = dbMgrData
+        self.mapDBInfo = self.dbMgrData['mapDBInfo']
+        self.layer   = layer
+        self.fieldCalc = None
+        self.columns = {} # <- LoadData()
+        wx.ListCtrl.__init__(self, parent = parent, id = wx.ID_ANY,
+                             style = wx.LC_REPORT | wx.LC_HRULES |
+                             wx.LC_VRULES | wx.LC_VIRTUAL | wx.LC_SORT_ASCENDING)
+        try:
+            keyColumn = self.LoadData(layer)
+        except GException, e:
+            GError(parent = self,
+                   message = e.value)
+            return
+        # add some attributes (colourful background for each item rows)
+        self.attr1 = wx.ListItemAttr()
+        self.attr1.SetBackgroundColour(wx.Colour(238,238,238))
+        self.attr2 = wx.ListItemAttr()
+        self.attr2.SetBackgroundColour("white")
+        self.il = wx.ImageList(16, 16)
+        self.sm_up = self.il.Add(wx.ArtProvider_GetBitmap(wx.ART_GO_UP,   wx.ART_TOOLBAR,
+                                                          (16,16)))
+        self.sm_dn = self.il.Add(wx.ArtProvider_GetBitmap(wx.ART_GO_DOWN, wx.ART_TOOLBAR,
+                                                          (16,16)))
+        self.SetImageList(self.il, wx.IMAGE_LIST_SMALL)
+        # setup mixins
+        listmix.ListCtrlAutoWidthMixin.__init__(self)
+        listmix.ColumnSorterMixin.__init__(self, len(self.columns))
+        # sort item by category (id)
+        if keyColumn > -1:
+            self.SortListItems(col = keyColumn, ascending = True)
+        else:
+            self.SortListItems(col = 0, ascending = True)
+        # events
+        self.Bind(wx.EVT_LIST_ITEM_SELECTED,   self.OnItemSelected)
+        self.Bind(wx.EVT_LIST_ITEM_DESELECTED, self.OnItemDeselected)
+        self.Bind(wx.EVT_LIST_COL_CLICK,       self.OnColumnSort)
+        self.Bind(wx.EVT_LIST_COL_RIGHT_CLICK, self.OnColumnMenu)
+    def Update(self, mapDBInfo):
+        """!Update list according new mapDBInfo description"""
+        self.mapDBInfo = mapDBInfo
+        self.LoadData(self.layer)
+    def LoadData(self, layer, columns = None, where = None, sql = None):
+        """!Load data into list
+        @param layer layer number
+        @param columns list of columns for output (-> v.db.select)
+        @param where where statement (-> v.db.select)
+        @param sql full sql statement (-> db.select)
+        @return id of key column
+        @return -1 if key column is not displayed
+        self.log.write(_("Loading data..."))
+        tableName    = self.mapDBInfo.layers[layer]['table']
+        keyColumn    = self.mapDBInfo.layers[layer]['key']
+        try:
+            self.columns = self.mapDBInfo.tables[tableName]
+        except KeyError:
+            raise GException(_("Attribute table <%s> not found. "
+                                    "For creating the table switch to "
+                                    "'Manage layers' tab.") % tableName)
+        if not columns:
+            columns = self.mapDBInfo.GetColumns(tableName)
+        else:
+            all = self.mapDBInfo.GetColumns(tableName)
+            for col in columns:
+                if col not in all:
+                           message = _("Column <%(column)s> not found in "
+                                       "in the table <%(table)s>.") % \
+                               { 'column' : col, 'table' : tableName })
+                    return
+        try:
+            # for maps connected via v.external
+            keyId = columns.index(keyColumn)
+        except:
+            keyId = -1
+        # read data
+        # FIXME: Max. number of rows, while the GUI is still usable
+        # stdout can be very large, do not use PIPE, redirect to temp file
+        # TODO: more effective way should be implemented...
+        outFile = tempfile.NamedTemporaryFile(mode = 'w+b')
+        if sql:
+            ret = RunCommand('db.select',
+                             quiet = True,
+                             parent = self,
+                             flags = 'c',
+                             sql = sql,
+                             output = outFile.name)
+        else:
+            if columns:
+                ret = RunCommand('v.db.select',
+                                 quiet = True,
+                                 parent = self,
+                                 flags = 'c',
+                                 map = self.mapDBInfo.map,
+                                 layer = layer,
+                                 columns = ','.join(columns),
+                                 where = where,
+                                 stdout = outFile)
+            else:
+                                 quiet = True,
+                                 parent = self,
+                                 flags = 'c',
+                                 layer = layer,
+                                 where = where,
+                                 stdout = outFile)
+        # These two should probably be passed to init more cleanly
+        # setting the numbers of items = number of elements in the dictionary
+        self.itemDataMap  = {}
+        self.itemIndexMap = []
+        self.itemCatsMap  = {}
+        self.DeleteAllItems()
+        # self.ClearAll()
+        for i in range(self.GetColumnCount()):
+            self.DeleteColumn(0)
+        i = 0
+        info = wx.ListItem()
+        info.m_mask = wx.LIST_MASK_TEXT | wx.LIST_MASK_IMAGE | wx.LIST_MASK_FORMAT
+        info.m_image = -1
+        info.m_format = 0
+        for column in columns:
+            info.m_text = column
+            self.InsertColumnInfo(i, info)
+            i += 1
+            if i >= 256:
+                self.log.write(_("Can display only 256 columns."))
+        i = 0
+        outFile.seek(0)
+        while True:
+            # os.linesep doesn't work here (MSYS)
+            record = outFile.readline().replace('\n', '')
+            if not record:
+                break
+            self.AddDataRow(i, record, columns, keyId)
+            i += 1
+            if i >= 100000:
+                self.log.write(_("Limit 100000 records."))
+                break
+        self.SetItemCount(i)
+        i = 0
+            width = self.columns[col]['length'] * 6 # FIXME
+            if width < 60:
+                width = 60
+            if width > 300:
+                width = 300
+            self.SetColumnWidth(col = i, width = width)
+            i += 1
+        self.SendSizeEvent()
+        self.log.write(_("Number of loaded records: %d") % \
+                           self.GetItemCount())
+        return keyId
+    def AddDataRow(self, i, record, columns, keyId):
+        """!Add row to the data list"""
+        self.itemDataMap[i] = []
+        keyColumn = self.mapDBInfo.layers[self.layer]['key']
+        j = 0
+        cat = None
+        if keyColumn == 'OGC_FID':
+            self.itemDataMap[i].append(i+1)
+            j += 1
+            cat = i + 1
+        for value in record.split('|'):
+            if self.columns[columns[j]]['ctype'] != types.StringType:
+                try:
+                    ### casting disabled (2009/03)
+                    ### self.itemDataMap[i].append(self.columns[columns[j]]['ctype'](value))
+                    self.itemDataMap[i].append(value)
+                except ValueError:
+                    self.itemDataMap[i].append(_('Unknown value'))
+            else:
+                # encode string values
+                try:
+                    self.itemDataMap[i].append(unicodeValue(value))
+                except UnicodeDecodeError:
+                    self.itemDataMap[i].append(_("Unable to decode value. "
+                                                 "Set encoding in GUI preferences ('Attributes')."))
+            if not cat and keyId > -1 and keyId == j:
+                try:
+                    cat = self.columns[columns[j]]['ctype'] (value)
+                except ValueError, e:
+                    cat = -1
+                           message = _("Error loading attribute data. "
+                                       "Record number: %(rec)d. Unable to convert value '%(val)s' in "
+                                       "key column (%(key)s) to integer.\n\n"
+                                       "Details: %(detail)s") % \
+                               { 'rec' : i + 1, 'val' : value,
+                                 'key' : keyColumn, 'detail' : e})
+            j += 1
+        self.itemIndexMap.append(i)
+        if keyId > -1: # load cats only when LoadData() is called first time
+            self.itemCatsMap[i] = cat
+    def OnItemSelected(self, event):
+        """!Item selected. Add item to selected cats..."""
+        #         cat = int(self.GetItemText(event.m_itemIndex))
+        #         if cat not in self.selectedCats:
+        #             self.selectedCats.append(cat)
+        #             self.selectedCats.sort()
+        event.Skip()
+    def OnItemDeselected(self, event):
+        """!Item deselected. Remove item from selected cats..."""
+        #         if cat in self.selectedCats:
+        #             self.selectedCats.remove(cat)
+        event.Skip()
+    def GetSelectedItems(self):
+        """!Return list of selected items (category numbers)"""
+        cats = []
+        item = self.GetFirstSelected()
+        while item != -1:
+            cats.append(self.GetItemText(item))
+            item = self.GetNextSelected(item)
+        return cats
+    def GetColumnText(self, index, col):
+        """!Return column text"""
+        item = self.GetItem(index, col)
+        return item.GetText()
+    def GetListCtrl(self):
+        """!Returt list"""
+        return self
+    def OnGetItemText(self, item, col):
+        """!Get item text"""
+        index = self.itemIndexMap[item]
+        s = self.itemDataMap[index][col]
+        return s
+    def OnGetItemAttr(self, item):
+        """!Get item attributes"""
+        if ( item % 2) == 0:
+            return self.attr2
+        else:
+            return self.attr1
+    def OnColumnMenu(self, event):
+        """!Column heading right mouse button -> pop-up menu"""
+        self._col = event.GetColumn()
+        popupMenu = wx.Menu()
+        if not hasattr (self, "popupID1"):
+            self.popupID1 = wx.NewId()
+            self.popupID2 = wx.NewId()
+            self.popupID3 = wx.NewId()
+            self.popupID4 = wx.NewId()
+            self.popupID5 = wx.NewId()
+            self.popupID6 = wx.NewId()
+            self.popupID7 = wx.NewId()
+            self.popupID8 = wx.NewId()
+            self.popupID9 = wx.NewId()
+            self.popupID10 = wx.NewId()
+            self.popupID11 = wx.NewId()
+            self.popupID12 = wx.NewId()
+            self.popupID13 = wx.NewId()
+        popupMenu.Append(self.popupID1, text = _("Sort ascending"))
+        popupMenu.Append(self.popupID2, text = _("Sort descending"))
+        popupMenu.AppendSeparator()
+        subMenu = wx.Menu()
+        popupMenu.AppendMenu(self.popupID3, _("Calculate (only numeric columns)"),
+                             subMenu)
+        popupMenu.Append(self.popupID13, text = _("Field calculator"))
+        if not self.dbMgrData['editable']:
+            popupMenu.Enable(self.popupID13, False)
+        if not self.dbMgrData['editable'] or \
+                self.columns[self.GetColumn(self._col).GetText()]['ctype'] not in (types.IntType, types.FloatType):
+            popupMenu.Enable(self.popupID3, False)
+        subMenu.Append(self.popupID4,  text = _("Area size"))
+        subMenu.Append(self.popupID5,  text = _("Line length"))
+        subMenu.Append(self.popupID6,  text = _("Compactness of an area"))
+        subMenu.Append(self.popupID7,  text = _("Fractal dimension of boundary defining a polygon"))
+        subMenu.Append(self.popupID8,  text = _("Perimeter length of an area"))
+        subMenu.Append(self.popupID9,  text = _("Number of features for each category"))
+        subMenu.Append(self.popupID10, text = _("Slope steepness of 3D line"))
+        subMenu.Append(self.popupID11, text = _("Line sinuousity"))
+        subMenu.Append(self.popupID12, text = _("Line azimuth"))
+        self.Bind (wx.EVT_MENU, self.OnColumnSortAsc, id = self.popupID10)
+        self.Bind (wx.EVT_MENU, self.OnColumnSortDesc, id = self.popupID2)
+        self.Bind(wx.EVT_MENU, self.OnFiledCalculator, id = self.popupID13)
+        for id in (self.popupID4, self.popupID5, self.popupID6,
+                   self.popupID7, self.popupID8, self.popupID9,
+                   self.popupID10, self.popupID11, self.popupID12):
+            self.Bind(wx.EVT_MENU, self.OnColumnCompute, id = id)
+        self.PopupMenu(popupMenu)
+        popupMenu.Destroy()
+    def OnColumnSort(self, event):
+        """!Column heading left mouse button -> sorting"""
+        self.ColumnSort()
+        event.Skip()
+    def OnColumnSortAsc(self, event):
+        """!Sort values of selected column (ascending)"""
+        self.SortListItems(col = self._col, ascending = True)
+        event.Skip()
+    def OnColumnSortDesc(self, event):
+        """!Sort values of selected column (descending)"""
+        self.SortListItems(col = self._col, ascending = False)
+        event.Skip()
+    def OnColumnCompute(self, event):
+        """!Compute values of selected column"""
+        id = event.GetId()
+        option = None
+        if id == self.popupID4:
+            option = 'area'
+        elif id == self.popupID5:
+            option = 'length'
+        elif id == self.popupID6:
+            option = 'compact'
+        elif id == self.popupID7:
+            option = 'fd'
+        elif id == self.popupID8:
+            option = 'perimeter'
+        elif id == self.popupID9:
+            option = 'count'
+        elif id == self.popupID10:
+            option = 'slope'
+        elif id == self.popupID11:
+            option = 'sinuous'
+        elif id == self.popupID12:
+            option = 'azimuth'
+        if not option:
+            return
+        RunCommand('v.to.db',
+                   parent = self.parent,
+                   layer = self.layer,
+                   option = option,
+                   columns = self.GetColumn(self._col).GetText())
+    def ColumnSort(self):
+        """!Sort values of selected column (self._col)"""
+        # remove duplicated arrow symbol from column header
+        # FIXME: should be done automatically
+        info.m_image = -1
+        for column in range(self.GetColumnCount()):
+            info.m_text = self.GetColumn(column).GetText()
+            self.SetColumn(column, info)
+    def OnFiledCalculator(self, event):
+        """!Calls SQLBuilderUpdate instance"""
+        if not self.fieldCalc:
+            self.fieldCalc = SQLBuilderUpdate(parent = self, id = wx.ID_ANY,
+                                              vectmap = self.dbMgrData['vectName'],
+                                              column = self.GetColumn(self._col).GetText())
+            self.fieldCalc.Show()
+        else:
+            self.fieldCalc.Raise()
+    def SortItems(self, sorter = cmp):
+        """!Sort items"""
+        items = list(self.itemDataMap.keys())
+        items.sort(self.Sorter)
+        self.itemIndexMap = items
+        # redraw the list
+        self.Refresh()
+    def Sorter(self, key1, key2):
+        colName = self.GetColumn(self._col).GetText()
+        ascending = self._colSortFlag[self._col]
+        try:
+            item1 = self.columns[colName]["ctype"](self.itemDataMap[key1][self._col])
+            item2 = self.columns[colName]["ctype"](self.itemDataMap[key2][self._col])
+            item1 = self.itemDataMap[key1][self._col]
+            item2 = self.itemDataMap[key2][self._col]
+        if type(item1) == types.StringType or type(item2) == types.StringTypes:
+            cmpVal = locale.strcoll(str(item1), str(item2))
+        else:
+            cmpVal = cmp(item1, item2)
+        # If the items are equal then pick something else to make the sort value unique
+        if cmpVal == 0:
+            cmpVal = apply(cmp, self.GetSecondarySortValues(self._col, key1, key2))
+        if ascending:
+            return cmpVal
+        else:
+            return -cmpVal
+    def GetSortImages(self):
+        """!Used by the ColumnSorterMixin, see wx/lib/mixins/listctrl.py"""
+        return (self.sm_dn, self.sm_up)
+    def IsEmpty(self):
+        """!Check if list if empty"""
+        if self.columns:
+            return False
+        return True
+class DbMgrBase:
+    def __init__(self, id = wx.ID_ANY, mapdisplay = None,
+                 vectorName = None, item = None, log = None,
+                 statusbar = None,
+                 **kwargs):
+        """!Base class, which enables usage of separate pages of Attribute Table Manager
+        @param id window id
+        @param mapdisplay MapFrame instance
+        @param vetorName name of vector map
+        @param item item from Layer Tree
+        @param log log window
+        @param statusbar widget with statusbar
+        @param kwagrs other wx.Frame's arguments
+        # stores all data, which are shared by pages
+        self.dbMgrData = {}
+        self.dbMgrData['vectName'] = vectorName
+        self.dbMgrData['treeItem'] = item  # item in layer tree
+        self.mapdisplay = mapdisplay
+        if  self.mapdisplay:
+            self.map = mapdisplay.Map
+        else:
+            self.map = None
+        if not self.mapdisplay:
+            pass
+        elif self.mapdisplay.tree and \
+           self.dbMgrData['treeItem'] and not self.dbMgrData['vectName']:
+            maptree = self.mapdisplay.tree
+            name = maptree.GetPyData(self.dbMgrData['treeItem'])[0]['maplayer'].GetName()
+            self.dbMgrData['vectName'] = name
+        # vector attributes can be changed only if vector map is in
+        # the current mapset
+        mapInfo = grass.find_file(name = self.dbMgrData['vectName'], element = 'vector')
+        if not mapInfo or mapInfo['mapset'] != grass.gisenv()['MAPSET']:
+             self.dbMgrData['editable'] = False
+        else:
+             self.dbMgrData['editable'] = True
+        self.cmdLog = log    # self.parent.goutput
+        # status bar log class
+        self.log = Log(statusbar) # -> statusbar
+        # -> layers / tables description
+        self.dbMgrData['mapDBInfo'] = VectorDBInfo(self.dbMgrData['vectName'])
+        # store information, which pages were initialized
+        self.pages = {
+                        'browse' : None,
+                        'manageTable' : None,
+                        'manageLayer' : None
+    def ChangeVectorMap(self, vectorName):
+        """!Change of vector map
+        Does not import layers of new vector map into pages.
+        For the import use methods addLayer in DbMgrBrowsePage and DbMgrTablesPage
+        if self.pages['browse']:
+            self.pages['browse'].DeleteAllLayerPages()
+        if self.pages['manageTable']:
+            self.pages['manageTable'].DeleteAllLayerPages()
+        # fetch fresh db info
+        else:
+        # 'manage layers page
+        if self.pages['manageLayer']:
+            self.pages['manageLayer'].UpdatePage()
+    def CreateDbMgrPage(self, parent, pageName, onlyLayer = -1):
+        """!Creates chosen page
+        @param pageName can be 'browse' or 'manageTable' or 'manageLayer' which corresponds with pages in
+                        Attribute Table Manager
+        @return created instance of page - if the page has been already created returns the previously created instance
+        @return None  if wrong identifier was passed
+        if pageName == 'browse':
+            if not self.pages['browse']:
+                self.pages[pageName] = DbMgrBrowsePage(parent = parent, parentDbMgrBase = self,
+                                                     onlyLayer = onlyLayer)
+            return self.pages[pageName]
+        if pageName == 'manageTable':
+            if not self.pages['manageTable']:
+                self.pages[pageName] = DbMgrTablesPage(parent = parent, parentDbMgrBase = self,
+        if pageName == 'manageLayer':
+            if not self.pages['manageLayer']:
+                self.pages[pageName] = DbMgrLayersPage(parent = parent, parentDbMgrBase = self)
+        return None
+    def UpdateDialog(self, layer):
+        """!Updates dialog layout for given layer"""
+        # delete page
+        if layer in self.dbMgrData['mapDBInfo'].layers.keys():
+            # delete page
+            # draging pages disallowed
+            # if self.browsePage.GetPageText(page).replace('Layer ', '').strip() == str(layer):
+            # self.browsePage.DeletePage(page)
+            # break
+                self.pages['browse'].DeleteLayerPage(layer)
+                self.pages['manageTable'].DeleteLayerPage(layer)
+        # add new page
+            # 'browse data' page
+                self.pages['browse'].AddLayer(layer)
+            # 'manage tables' page
+                self.pages['manageTable'].AddLayer(layer)
+        # manage layers page
+    def GetVectorName(self):
+        """!Get vector name"""
+        return self.dbMgrData['vectName']
+class DbMgrNotebookBase(FN.FlatNotebook):
+    def __init__(self, parent, parentDbMgrBase):
+        """!Base class for notebook with attribute tables in tabs
+        @param parent GUI parent
+        @param parentDbMgrBase instance of DbMgrBase class
+        self.parentDbMgrBase = parentDbMgrBase
+        self.log = self.parentDbMgrBase.log
+        self.cmdLog = self.parentDbMgrBase.cmdLog
+        self.map = self.parentDbMgrBase.map
+        self.mapdisplay = self.parentDbMgrBase.mapdisplay
+        #TODO no need to have it in class scope make it local?
+        self.listOfCommands      = []
+        self.listOfSQLStatements = []
+        #initializet pages
+        self.pages = self.parentDbMgrBase.pages
+        # shared data among pages
+        self.dbMgrData = self.parentDbMgrBase.dbMgrData
+        # set up virtual lists (each layer)
+        ### {layer: list, widgets...}
+        self.layerPage = {}
+        # currently selected layer
+        self.selLayer = None
+        # list which represents layers numbers in order of tabs
+        self.layers = []
+        if globalvar.hasAgw:
+            dbmStyle = { 'agwStyle' : globalvar.FNPageStyle }
+        else:
+            dbmStyle = { 'style' : globalvar.FNPageStyle }
+        FN.FlatNotebook.__init__(self,parent = self.parent, id = wx.ID_ANY,
+                                 **dbmStyle)
+        self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnLayerPageChanged)
+    def OnLayerPageChanged(self, event):
+        """!Layer tab changed"""
+        pageNum = event.GetSelection()
+        self.selLayer = self.layers[pageNum]
+        try:
+            idCol = self.layerPage[self.selLayer]['whereColumn']
+        except KeyError:
+            idCol = None
+        try:
+            self.OnChangeSql(None)
+            # update statusbar
+                               self.FindWindowById(self.layerPage[self.selLayer]['data']).\
+                               GetItemCount())
+        except:
+            pass
+        if idCol:
+            winCol = self.FindWindowById(idCol)
+            table = self.dbMgrData['mapDBInfo'].layers[self.selLayer]["table"]
+            self.dbMgrData['mapDBInfo'].GetColumns(table)
+    def ApplyCommands(self, listOfCommands, listOfSQLStatements):
+        """!Apply changes"""
+        # perform GRASS commands (e.g. v.db.addcolumn)
+        wx.BeginBusyCursor()
+        if len(listOfCommands) > 0:
+            for cmd in listOfCommands:
+                RunCommand(prog = cmd[0],
+                           quiet = True,
+                           parent = self,
+                           **cmd[1])
+                self.pages['manageTable'].UpdatePage(self.selLayer)
+                self.pages['browse'].UpdatePage(self.selLayer)
+            # reset list of commands
+            listOfCommands = []
+        # perform SQL non-select statements (e.g. 'delete from table where cat=1')
+        if len(listOfSQLStatements) > 0:
+            sqlFile = tempfile.NamedTemporaryFile(mode = "wt")
+            for sql in listOfSQLStatements:
+                enc = UserSettings.Get(group = 'atm', key = 'encoding', subkey = 'value')
+                if not enc and 'GRASS_DB_ENCODING' in os.environ:
+                    enc = os.environ['GRASS_DB_ENCODING']
+                if enc:
+                    sqlFile.file.write(sql.encode(enc) + ';')
+                else:
+                    sqlFile.file.write(sql + ';')
+                sqlFile.file.write(os.linesep)
+                sqlFile.file.flush()
+            driver   = self.dbMgrData['mapDBInfo'].layers[self.selLayer]["driver"]
+            database = self.dbMgrData['mapDBInfo'].layers[self.selLayer]["database"]
+            Debug.msg(3, 'AttributeManger.ApplyCommands(): %s' %
+                      ';'.join(["%s" % s for s in listOfSQLStatements]))
+            RunCommand('db.execute',
+                       parent = self,
+                       input = sqlFile.name,
+                       driver = driver,
+                       database = database)
+            # reset list of statements
+            listOfSQLStatements = []
+        wx.EndBusyCursor()
+    def DeleteLayerPage(self, layer):
+        """!Removes layer page"""
+        pageNum = self.GetSelection()
+        self.DeletePage(self.layers.index(layer))
+        self.layers.remove(layer)
+        del self.layerPage[layer]
+        if self.GetSelection() >= 0:
+            self.selLayer = self.layers[self.GetSelection()]
+        else:
+    def DeleteAllLayerPages(self):
+        """!Removes all layer pages"""
+        self.DeleteAllPages()
+        self.layers = []
+class DbMgrBrowsePage(DbMgrNotebookBase):
+    def __init__(self, parent, parentDbMgrBase, onlyLayer = -1):
+        """!Browse page class
+        @param onlyLayer create only tab of given layer, if -1 creates tabs of all layers
+        DbMgrNotebookBase.__init__(self, parent = parent,
+                                       parentDbMgrBase = parentDbMgrBase)
+        for layer in self.dbMgrData['mapDBInfo'].layers.keys():
+            if onlyLayer > 0 and layer != onlyLayer:
+                continue
+            self.AddLayer(layer)
+        self.SetSelection(0) # select first layer
+        if self.layers:
+            self.selLayer = self.layers[0]
+                           self.FindWindowById(self.layerPage[self.selLayer]['data']).GetItemCount())
+        # query map layer (if parent (GMFrame) is given)
+        self.qlayer = None
+        # sqlbuilder
+        self.builder = None
+    def AddLayer(self, layer, pos = -1):
+        """!Adds tab which represents table and enables browse it
+        @param layer vector map layer conntected to table
+        @param pos position of tab, if -1 it is added to end
+        panel = wx.Panel(parent = self, id = wx.ID_ANY)
+        #IMPORTANT NOTE: wx.StaticBox MUST be defined BEFORE any of the
+        #   controls that are placed IN the wx.StaticBox, or it will freeze
+        #   on the Mac
+        listBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+                               label = " %s " % _("Attribute data - right-click to edit/manage records"))
+        listSizer = wx.StaticBoxSizer(listBox, wx.VERTICAL)
+        win = VirtualAttributeList(panel, self.log,
+                                   self.dbMgrData, layer)
+        if win.IsEmpty():
+            del panel
+            return False
+        self.layers.append(layer)
+        win.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnDataItemActivated)
+        self.layerPage[layer] = {'browsePage': panel.GetId()}
+        label = _("Table")
+            label += _(" (readonly)")
+        if pos == -1:
+            pos = self.GetPageCount()
+        self.InsertPage(pos, page = panel,
+                        text = " %d / %s %s" % \
+                       (layer, label, self.dbMgrData['mapDBInfo'].layers[layer]['table']))
+        pageSizer = wx.BoxSizer(wx.VERTICAL)
+        # attribute data
+        sqlBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+                              label = " %s " % _("SQL Query"))
+        sqlSizer = wx.StaticBoxSizer(sqlBox, wx.VERTICAL)
+        win.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnDataRightUp) #wxMSW
+        win.Bind(wx.EVT_RIGHT_UP,            self.OnDataRightUp) #wxGTK
+        if UserSettings.Get(group = 'atm', key = 'leftDbClick', subkey = 'selection') == 0:
+            win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataItemEdit)
+            win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataItemEdit)
+        else:
+            win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataDrawSelected)
+            win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataDrawSelected)
+        listSizer.Add(item = win, proportion = 1,
+                      flag = wx.EXPAND | wx.ALL,
+                      border = 3)
+        # sql statement box
+        btnApply = wx.Button(parent = panel, id = wx.ID_APPLY)
+        btnApply.SetToolTipString(_("Apply SELECT statement and reload data records"))
+        btnApply.Bind(wx.EVT_BUTTON, self.OnApplySqlStatement)
+        btnSqlBuilder = wx.Button(parent = panel, id = wx.ID_ANY, label = _("SQL Builder"))
+        btnSqlBuilder.Bind(wx.EVT_BUTTON, self.OnBuilder)
+        sqlSimple = wx.RadioButton(parent = panel, id = wx.ID_ANY,
+                                  label = _("Simple"))
+        sqlSimple.SetValue(True)
+        sqlAdvanced = wx.RadioButton(parent = panel, id = wx.ID_ANY,
+                                     label = _("Advanced"))
+        sqlSimple.Bind(wx.EVT_RADIOBUTTON,   self.OnChangeSql)
+        sqlAdvanced.Bind(wx.EVT_RADIOBUTTON, self.OnChangeSql)
+        sqlWhereColumn = wx.ComboBox(parent = panel, id = wx.ID_ANY,
+                                     size = (100,-1),
+                                     style = wx.CB_SIMPLE | wx.CB_READONLY,
+                                     choices = self.dbMgrData['mapDBInfo'].GetColumns(self.dbMgrData['mapDBInfo'].layers[layer]['table']))
+        sqlWhereColumn.SetSelection(0)
+        sqlWhereCond = wx.Choice(parent = panel, id = wx.ID_ANY,
+                                 size = (55,-1),
+                                 choices = ['=', '!=', '<', '<=', '>', '>='])
+        sqlWhereValue = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = "",
+                                    style = wx.TE_PROCESS_ENTER)
+        sqlWhereValue.SetToolTipString(_("Example: %s") % "MULTILANE = 'no' AND OBJECTID < 10")
+        sqlStatement = wx.TextCtrl(parent = panel, id = wx.ID_ANY,
+                                   value = "SELECT * FROM %s" % \
+                                       self.dbMgrData['mapDBInfo'].layers[layer]['table'],
+        sqlStatement.SetToolTipString(_("Example: %s") % "SELECT * FROM roadsmajor WHERE MULTILANE = 'no' AND OBJECTID < 10")
+        sqlWhereValue.Bind(wx.EVT_TEXT_ENTER, self.OnApplySqlStatement)
+        sqlStatement.Bind(wx.EVT_TEXT_ENTER, self.OnApplySqlStatement)
+        sqlLabel = wx.StaticText(parent = panel, id = wx.ID_ANY,
+                                label = "SELECT * FROM %s WHERE " % \
+                                      self.dbMgrData['mapDBInfo'].layers[layer]['table'])
+        label_query = wx.StaticText(parent = panel, id = wx.ID_ANY,
+                                    label = "")
+        sqlFlexSizer = wx.FlexGridSizer (cols = 3, hgap = 5, vgap = 5)
+        sqlFlexSizer.AddGrowableCol(1)
+        sqlFlexSizer.Add(item = sqlSimple,
+                         flag = wx.ALIGN_CENTER_VERTICAL)
+        sqlSimpleSizer = wx.BoxSizer(wx.HORIZONTAL)
+        sqlSimpleSizer.Add(item = sqlLabel,
+        sqlSimpleSizer.Add(item = sqlWhereColumn,
+                           flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+        sqlSimpleSizer.Add(item = sqlWhereCond,
+                           flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
+                           border = 3)
+        sqlSimpleSizer.Add(item = sqlWhereValue, proportion = 1,
+        sqlFlexSizer.Add(item = sqlSimpleSizer,
+                         flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
+        sqlFlexSizer.Add(item = btnApply,
+                         flag = wx.ALIGN_RIGHT)
+        sqlFlexSizer.Add(item = sqlAdvanced,
+        sqlFlexSizer.Add(item = sqlStatement,
+                         flag = wx.EXPAND)
+        sqlFlexSizer.Add(item = btnSqlBuilder,
+        sqlSizer.Add(item = sqlFlexSizer,
+                     flag = wx.ALL | wx.EXPAND,
+                     border = 3)
+        pageSizer.Add(item = listSizer,
+                      proportion = 1,
+                      border = 5)
+        pageSizer.Add(item = sqlSizer,
+                      proportion = 0,
+                      flag = wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.EXPAND,
+                      border = 5)
+        panel.SetSizer(pageSizer)
+        self.layerPage[layer]['data']      = win.GetId()
+        self.layerPage[layer]['simple']    = sqlSimple.GetId()
+        self.layerPage[layer]['advanced']  = sqlAdvanced.GetId()
+        self.layerPage[layer]['whereColumn'] = sqlWhereColumn.GetId()
+        self.layerPage[layer]['whereOperator'] = sqlWhereCond.GetId()
+        self.layerPage[layer]['where']     = sqlWhereValue.GetId()
+        self.layerPage[layer]['builder']   = btnSqlBuilder.GetId()
+        self.layerPage[layer]['statement'] = sqlStatement.GetId()
+    def OnDataItemActivated(self, event):
+        """!Item activated, highlight selected item"""
+        self.OnDataDrawSelected(event)
+        event.Skip()
+    def OnDataRightUp(self, event):
+        """!Table description area, context menu"""
+        if not hasattr(self, "popupDataID1"):
+            self.popupDataID1 = wx.NewId()
+            self.popupDataID2 = wx.NewId()
+            self.popupDataID3 = wx.NewId()
+            self.popupDataID4 = wx.NewId()
+            self.popupDataID5 = wx.NewId()
+            self.popupDataID6 = wx.NewId()
+            self.popupDataID7 = wx.NewId()
+            self.popupDataID8 = wx.NewId()
+            self.popupDataID9 = wx.NewId()
+            self.popupDataID10 = wx.NewId()
+            self.popupDataID11 = wx.NewId()
+            self.Bind(wx.EVT_MENU, self.OnDataItemEdit,       id = self.popupDataID1)
+            self.Bind(wx.EVT_MENU, self.OnDataItemAdd,        id = self.popupDataID2)
+            self.Bind(wx.EVT_MENU, self.OnDataItemDelete,     id = self.popupDataID3)
+            self.Bind(wx.EVT_MENU, self.OnDataItemDeleteAll,  id = self.popupDataID4)
+            self.Bind(wx.EVT_MENU, self.OnDataSelectAll,      id = self.popupDataID5)
+            self.Bind(wx.EVT_MENU, self.OnDataSelectNone,     id = self.popupDataID6)
+            self.Bind(wx.EVT_MENU, self.OnDataDrawSelected,   id = self.popupDataID7)
+            self.Bind(wx.EVT_MENU, self.OnDataDrawSelectedZoom, id = self.popupDataID8)
+            self.Bind(wx.EVT_MENU, self.OnExtractSelected,    id = self.popupDataID9)
+            self.Bind(wx.EVT_MENU, self.OnDeleteSelected,     id = self.popupDataID11)
+            self.Bind(wx.EVT_MENU, self.OnDataReload,         id = self.popupDataID10)
+        tlist = self.FindWindowById(self.layerPage[self.selLayer]['data'])
+        # generate popup-menu
+        menu = wx.Menu()
+        menu.Append(self.popupDataID1, _("Edit selected record"))
+        selected = tlist.GetFirstSelected()
+        if not self.dbMgrData['editable'] or selected == -1 or tlist.GetNextSelected(selected) != -1:
+            menu.Enable(self.popupDataID1, False)
+        menu.Append(self.popupDataID2, _("Insert new record"))
+        menu.Append(self.popupDataID3, _("Delete selected record(s)"))
+        menu.Append(self.popupDataID4, _("Delete all records"))
+            menu.Enable(self.popupDataID2, False)
+            menu.Enable(self.popupDataID3, False)
+            menu.Enable(self.popupDataID4, False)
+        menu.AppendSeparator()
+        menu.Append(self.popupDataID5, _("Select all"))
+        menu.Append(self.popupDataID6, _("Deselect all"))
+        menu.Append(self.popupDataID7, _("Highlight selected features"))
+        menu.Append(self.popupDataID8, _("Highlight selected features and zoom"))
+        if not self.map or len(tlist.GetSelectedItems()) == 0:
+            menu.Enable(self.popupDataID7, False)
+            menu.Enable(self.popupDataID8, False)
+        menu.Append(self.popupDataID9, _("Extract selected features"))
+        menu.Append(self.popupDataID11, _("Delete selected features"))
+            menu.Enable(self.popupDataID11, False)
+        if tlist.GetFirstSelected() == -1:
+            menu.Enable(self.popupDataID9, False)
+        menu.Append(self.popupDataID10, _("Reload"))
+        self.PopupMenu(menu)
+        menu.Destroy()
+                           tlist.GetItemCount())
+    def OnDataItemEdit(self, event):
+        """!Edit selected record of the attribute table"""
+        item      = tlist.GetFirstSelected()
+        if item == -1:
+            return
+        table     = self.dbMgrData['mapDBInfo'].layers[self.selLayer]['table']
+        keyColumn = self.dbMgrData['mapDBInfo'].layers[self.selLayer]['key']
+        cat       = tlist.itemCatsMap[tlist.itemIndexMap[item]]
+        # (column name, value)
+        data = []
+        # collect names of all visible columns
+        columnName = []
+        for i in range(tlist.GetColumnCount()):
+            columnName.append(tlist.GetColumn(i).GetText())
+        # key column must be always presented
+        if keyColumn not in columnName:
+            columnName.insert(0, keyColumn) # insert key column on first position
+            data.append((keyColumn, str(cat)))
+            keyId = 0
+            missingKey = True
+        else:
+            missingKey = False
+        # add other visible columns
+        for i in range(len(columnName)):
+            ctype = self.dbMgrData['mapDBInfo'].tables[table][columnName[i]]['ctype']
+            ctypeStr = self.dbMgrData['mapDBInfo'].tables[table][columnName[i]]['type']
+            if columnName[i] == keyColumn: # key
+                if missingKey is False:
+                    data.append((columnName[i], ctype, ctypeStr, str(cat)))
+                    keyId = i
+            else:
+                if missingKey is True:
+                    value = tlist.GetItem(item, i-1).GetText()
+                else:
+                    value = tlist.GetItem(item, i).GetText()
+                data.append((columnName[i], ctype, ctypeStr, value))
+        dlg = ModifyTableRecord(parent = self,
+                                title = _("Update existing record"),
+                                data = data, keyEditable = (keyId, False))
+        if dlg.ShowModal() == wx.ID_OK:
+            values = dlg.GetValues() # string
+            updateString = ''
+            try:
+                for i in range(len(values)):
+                    if i == keyId: # skip key column
+                        continue
+                    if tlist.GetItem(item, i).GetText() != values[i]:
+                        if len(values[i]) > 0:
+                            try:
+                                    idx = i - 1
+                                else:
+                                    idx = i
+                                if tlist.columns[columnName[i]]['ctype'] != types.StringType:
+                                    if tlist.columns[columnName[i]]['ctype'] == int:
+                                        value = float(values[i])
+                                    else:
+                                        value = values[i]
+                                    tlist.itemDataMap[item][idx] = \
+                                        tlist.columns[columnName[i]]['ctype'] (value)
+                                else:
+                                    tlist.itemDataMap[item][idx] = values[i]
+                            except:
+                                raise ValueError(_("Value '%(value)s' needs to be entered as %(type)s.") % \
+                                                     {'value' : str(values[i]),
+                                                      'type' : tlist.columns[columnName[i]]['type']})
+                            if tlist.columns[columnName[i]]['ctype'] == str:
+                                updateString += "%s='%s'," % (columnName[i], values[i])
+                            else:
+                                updateString += "%s=%s," % (columnName[i], values[i])
+                        else: # NULL
+                            updateString += "%s=NULL," % (columnName[i])
+            except ValueError, err:
+                       message = _("Unable to update existing record.\n%s") % err,
+                       showTraceback = False)
+                self.OnDataItemEdit(event)
+                return
+            if len(updateString) > 0:
+                self.listOfSQLStatements.append('UPDATE %s SET %s WHERE %s=%d' % \
+                                                    (table, updateString.strip(','),
+                                                     keyColumn, cat))
+                self.ApplyCommands(self.listOfCommands, self.listOfSQLStatements)
+            tlist.Update(self.dbMgrData['mapDBInfo'])
+    def OnDataItemAdd(self, event):
+        """!Add new record to the attribute table"""
+        data = []
+        columnName = []
+        # maximal category number
+        if len(tlist.itemCatsMap.values()) > 0:
+            maxCat = max(tlist.itemCatsMap.values())
+        else:
+            maxCat = 0 # starting category '1'
+            data.append((keyColumn, str(maxCat + 1)))
+            missingKey = True
+        else:
+        colIdx = 0
+        keyId = -1
+        for col in columnName:
+            ctype = self.dbMgrData['mapDBInfo'].tables[table][col]['ctype']
+            ctypeStr = self.dbMgrData['mapDBInfo'].tables[table][col]['type']
+            if col == keyColumn: # key
+                    data.append((col, ctype, ctypeStr, str(maxCat + 1)))
+                    keyId = colIdx
+            else:
+                data.append((col, ctype, ctypeStr, ''))
+            colIdx += 1
+                                title = _("Insert new record"),
+                                data = data, keyEditable = (keyId, True))
+            try: # get category number
+                cat = int(dlg.GetValues(columns = [keyColumn])[0])
+            except:
+                cat = -1
+            try:
+                if cat in tlist.itemCatsMap.values():
+                    raise ValueError(_("Record with category number %d "
+                                       "already exists in the table.") % cat)
+                values = dlg.GetValues() # values (need to be casted)
+                columnsString = ''
+                valuesString   = ''
+                    if len(values[i]) == 0: # NULL
+                            raise ValueError(_("Category number (column %s)"
+                                               " is missing.") % keyColumn)
+                        else:
+                            continue
+                    try:
+                            # values[i] is stored as text.
+                        else:
+                            value = values[i]
+                        values[i] = tlist.columns[columnName[i]]['ctype'] (value)
+                    except:
+                    columnsString += '%s,' % columnName[i]
+                        valuesString += "'%s'," % values[i]
+                    else:
+                        valuesString += "%s," % values[i]
+                       message = _("Unable to insert new record.\n%s") % err,
+                self.OnDataItemAdd(event)
+                return
+            # remove category if need
+                del values[0]
+            # add new item to the tlist
+            if len(tlist.itemIndexMap) > 0:
+                index = max(tlist.itemIndexMap) + 1
+            else:
+                index = 0
+            tlist.itemIndexMap.append(index)
+            tlist.itemDataMap[index] = values
+            tlist.itemCatsMap[index] = cat
+            tlist.SetItemCount(tlist.GetItemCount() + 1)
+            self.listOfSQLStatements.append('INSERT INTO %s (%s) VALUES(%s)' % \
+                                                (table,
+                                                 columnsString.strip(','),
+                                                 valuesString.strip(',')))
+    def OnDataItemDelete(self, event):
+        """!Delete selected item(s) from the tlist (layer/category pair)"""
+        dlist = self.FindWindowById(self.layerPage[self.selLayer]['data'])
+        item = dlist.GetFirstSelected()
+        key      = self.dbMgrData['mapDBInfo'].layers[self.selLayer]["key"]
+        indeces = []
+        # collect SQL statements
+        while item != -1:
+            index = dlist.itemIndexMap[item]
+            indeces.append(index)
+            cat = dlist.itemCatsMap[index]
+            self.listOfSQLStatements.append('DELETE FROM %s WHERE %s=%d' % \
+                                                (table, key, cat))
+            item = dlist.GetNextSelected(item)
+        if UserSettings.Get(group = 'atm', key = 'askOnDeleteRec', subkey = 'enabled'):
+            deleteDialog = wx.MessageBox(parent = self,
+                                         message = _("Selected data records (%d) will be permanently deleted "
+                                                   "from table. Do you want to delete them?") % \
+                                             (len(self.listOfSQLStatements)),
+                                         caption = _("Delete records"),
+                                         style = wx.YES_NO | wx.CENTRE)
+            if deleteDialog != wx.YES:
+                return False
+        # restore maps
+        i = 0
+        indexTemp = copy.copy(dlist.itemIndexMap)
+        dlist.itemIndexMap = []
+        dataTemp = copy.deepcopy(dlist.itemDataMap)
+        dlist.itemDataMap = {}
+        catsTemp = copy.deepcopy(dlist.itemCatsMap)
+        dlist.itemCatsMap = {}
+        i = 0
+        for index in indexTemp:
+            if index in indeces:
+                continue
+            dlist.itemIndexMap.append(i)
+            dlist.itemDataMap[i] = dataTemp[index]
+            dlist.itemCatsMap[i] = catsTemp[index]
+            i += 1
+        dlist.SetItemCount(len(dlist.itemIndexMap))
+        # deselect items
+        while item != -1:
+            dlist.SetItemState(item, 0, wx.LIST_STATE_SELECTED | wx.LIST_STATE_FOCUSED)
+        # submit SQL statements
+        return True
+    def OnDataItemDeleteAll(self, event):
+        """!Delete all items from the list"""
+                                         message = _("All data records (%d) will be permanently deleted "
+                                             (len(dlist.itemIndexMap)),
+                return
+        dlist.DeleteAllItems()
+        dlist.SetItemCount(0)
+        self.listOfSQLStatements.append('DELETE FROM %s' % table)
+        event.Skip()
+    def _drawSelected(self, zoom):
+        """!Highlight selected features"""
+        if not self.map or not self.mapdisplay:
+            return
+        cats = map(int, tlist.GetSelectedItems())
+        digitToolbar = None
+        if 'vdigit' in self.mapdisplay.toolbars:
+            digitToolbar = self.mapdisplay.toolbars['vdigit']
+        if digitToolbar and digitToolbar.GetLayer() and \
+                digitToolbar.GetLayer().GetName() == self.dbMgrData['vectName']:
+            display = self.mapdisplay.GetMapWindow().GetDisplay()
+            display.SetSelected(cats, layer = self.selLayer)
+            if zoom:
+                n, s, w, e = display.GetRegionSelected()
+                self.mapdisplay.Map.GetRegion(n = n, s = s, w = w, e = e,
+                                              update = True)
+        else:
+            # add map layer with higlighted vector features
+            self.AddQueryMapLayer() # -> self.qlayer
+            # set opacity based on queried layer
+            if self.parent and self.mapdisplay.tree and \
+                    self.dbMgrData['treeItem']:
+                opacity = maptree.GetPyData(self.dbMgrData['treeItem'])[0]['maplayer'].GetOpacity(float = True)
+                self.qlayer.SetOpacity(opacity)
+            if zoom:
+                where = ''
+                for range in ListOfCatsToRange(cats).split(','):
+                    if '-' in range:
+                        min, max = range.split('-')
+                        where += '%s >= %d and %s <= %d or ' % \
+                            (keyColumn, int(min),
+                             keyColumn, int(max))
+                    else:
+                        where += '%s = %d or ' % (keyColumn, int(range))
+                where = where.rstrip('or ')
+                select = RunCommand('v.db.select',
+                                    parent = self,
+                                    read = True,
+                                    quiet = True,
+                                    flags = 'r',
+                                    map = self.dbMgrData['mapDBInfo'].map,
+                                    layer = int(self.selLayer),
+                                    where = where)
+                region = {}
+                for line in select.splitlines():
+                    key, value = line.split('=')
+                    region[key.strip()] = float(value.strip())
+                nsdist = ewdist = 0
+                renderer = self.mapdisplay.GetMap()
+                nsdist = 10 * ((renderer.GetCurrentRegion()['n'] - renderer.GetCurrentRegion()['s']) /
+                        renderer.height)
+                ewdist = 10 * ((renderer.GetCurrentRegion()['e'] - renderer.GetCurrentRegion()['w']) /
+                        renderer.width)
+                north = region['n'] + nsdist
+                south = region['s'] - nsdist
+                west = region['w'] - ewdist
+                east = region['e'] + ewdist
+                renderer.GetRegion(n = north, s = south, w = west, e = east, update = True)
+                self.mapdisplay.GetMapWindow().ZoomHistory(n = north, s = south, w = west, e = east)
+        if zoom:
+            self.mapdisplay.Map.AdjustRegion()           # adjust resolution
+            self.mapdisplay.Map.AlignExtentFromDisplay() # adjust extent
+            self.mapdisplay.MapWindow.UpdateMap(render = True,  renderVector = True)
+        else:
+            self.mapdisplay.MapWindow.UpdateMap(render = False, renderVector = True)
+    def AddQueryMapLayer(self):
+        """!Redraw a map
+        Return True if map has been redrawn, False if no map is given
+        cats = {
+            self.selLayer : tlist.GetSelectedItems()
+        if self.mapdisplay.Map.GetLayerIndex(self.qlayer) < 0:
+        if self.qlayer:
+            self.qlayer.SetCmd(self.mapdisplay.AddTmpVectorMapLayer(self.dbMgrData['vectName'], cats, addLayer = False))
+        else:
+            self.qlayer = self.mapdisplay.AddTmpVectorMapLayer(self.dbMgrData['vectName'], cats)
+        return self.qlayer
+    def OnDataReload(self, event):
+        """!Reload tlist of records"""
+        self.OnApplySqlStatement(None)
+    def OnDataSelectAll(self, event):
+        """!Select all items"""
+        item = -1
+        while True:
+            item = tlist.GetNextItem(item)
+            if item == -1:
+                break
+            tlist.SetItemState(item, wx.LIST_STATE_SELECTED, wx.LIST_STATE_SELECTED)
+        event.Skip()
+    def OnDataSelectNone(self, event):
+        """!Deselect items"""
+        item = -1
+        while True:
+            item = tlist.GetNextItem(item, wx.LIST_STATE_SELECTED)
+            if item == -1:
+                break
+            tlist.SetItemState(item, 0, wx.LIST_STATE_SELECTED | wx.LIST_STATE_FOCUSED)
+        event.Skip()
+    def OnDataDrawSelected(self, event):
+        """!Reload table description"""
+        self._drawSelected(zoom = False)
+        event.Skip()
+    def OnDataDrawSelectedZoom(self, event):
+        self._drawSelected(zoom = True)
+        event.Skip()
+    def OnExtractSelected(self, event):
+        """!Extract vector objects selected in attribute browse window
+        to new vector map
+        # cats = tlist.selectedCats[:]
+        cats = tlist.GetSelectedItems()
+        if len(cats) == 0:
+            GMessage(parent = self,
+                     message = _('Nothing to extract.'))
+            return
+        else:
+            # dialog to get file name
+            dlg = CreateNewVector(parent = self, title = _('Extract selected features'),
+                                  log = self.cmdLog,
+                                  cmd = (('v.extract',
+                                          { 'input' : self.dbMgrData['vectName'],
+                                            'cats' : ListOfCatsToRange(cats) },
+                                          'output')),
+                                  disableTable = True)
+            if not dlg:
+                return
+            name = dlg.GetName(full = True)
+            if not self.mapdisplay and self.mapdisplay.tree:
+                pass
+            elif name and dlg.IsChecked('add'):
+                # add layer to map layer tree
+                self.mapdisplay.tree.AddLayer(ltype = 'vector',
+                                              lname = name,
+                                              lcmd = ['d.vect', 'map=%s' % name])
+            dlg.Destroy()
+    def OnDeleteSelected(self, event):
+        """!Delete vector objects selected in attribute browse window
+        (attribures and geometry)
+                     message = _('Nothing to delete.'))
+            return
+        display = None
+            pass
+        elif 'vdigit' in self.mapdisplay.toolbars:
+                display.SetSelected(map(int, cats), layer = self.selLayer)
+        if self.OnDataItemDelete(None) and self.mapdisplay:
+            if display:
+                self.mapdisplay.GetMapWindow().digit.DeleteSelectedLines()
+            else:
+                RunCommand('v.edit',
+                           parent = self,
+                           quiet = True,
+                           map = self.dbMgrData['vectName'],
+                           tool = 'delete',
+                           cats = ListOfCatsToRange(cats))
+    def OnChangeSql(self, event):
+        """!Switch simple/advanced sql statement"""
+        if self.FindWindowById(self.layerPage[self.selLayer]['simple']).GetValue():
+            self.FindWindowById(self.layerPage[self.selLayer]['where']).Enable(True)
+            self.FindWindowById(self.layerPage[self.selLayer]['statement']).Enable(False)
+            self.FindWindowById(self.layerPage[self.selLayer]['builder']).Enable(False)
+        else:
+            self.FindWindowById(self.layerPage[self.selLayer]['where']).Enable(False)
+            self.FindWindowById(self.layerPage[self.selLayer]['statement']).Enable(True)
+            self.FindWindowById(self.layerPage[self.selLayer]['builder']).Enable(True)
+    def OnApplySqlStatement(self, event):
+        """!Apply simple/advanced sql statement"""
+        keyColumn = -1 # index of key column
+        listWin = self.FindWindowById(self.layerPage[self.selLayer]['data'])
+        sql = None
+        win = self.FindWindowById(self.layerPage[self.selLayer]['simple'])
+        if not win:
+            return
+        if win.GetValue():
+            # simple sql statement
+            whereCol = self.FindWindowById(self.layerPage[self.selLayer]['whereColumn']).GetStringSelection()
+            whereOpe = self.FindWindowById(self.layerPage[self.selLayer]['whereOperator']).GetStringSelection()
+            whereVal = self.FindWindowById(self.layerPage[self.selLayer]['where']).GetValue().strip()
+            try:
+                if len(whereVal) > 0:
+                    keyColumn = listWin.LoadData(self.selLayer, where = whereCol + whereOpe + whereVal)
+                else:
+                    keyColumn = listWin.LoadData(self.selLayer)
+                       message = _("Loading attribute data failed.\n\n%s") % e.value)
+                self.FindWindowById(self.layerPage[self.selLayer]['where']).SetValue('')
+        else:
+            # advanced sql statement
+            win = self.FindWindowById(self.layerPage[self.selLayer]['statement'])
+            try:
+                cols, where = self.ValidateSelectStatement(win.GetValue())
+                if cols is None and where is None:
+                    sql = win.GetValue()
+            except TypeError:
+                       message = _("Loading attribute data failed.\n"
+                                   "Invalid SQL select statement.\n\n%s") % win.GetValue())
+                win.SetValue("SELECT * FROM %s" % self.dbMgrData['mapDBInfo'].layers[self.selLayer]['table'])
+                cols = None
+                where = None
+            if cols or where or sql:
+                try:
+                    keyColumn = listWin.LoadData(self.selLayer, columns = cols,
+                                                 where = where, sql = sql)
+        # sort by key column
+        if sql and 'order by' in sql.lower():
+            pass # don't order by key column
+        else:
+                listWin.SortListItems(col = keyColumn, ascending = True)
+            else:
+                listWin.SortListItems(col = 0, ascending = True)
+    def OnBuilder(self,event):
+        """!SQL Builder button pressed -> show the SQLBuilder dialog"""
+        if not self.builder:
+            self.builder = SQLBuilderSelect(parent = self, id = wx.ID_ANY,
+                                            layer = self.selLayer,
+                                            evtHandler = self.OnBuilderEvt)
+            self.builder.Show()
+        else:
+            self.builder.Raise()
+    def OnBuilderEvt(self, event):
+        if event == 'apply':
+            sqlstr = self.builder.GetSQLStatement()
+            self.FindWindowById(self.layerPage[self.selLayer]['statement']).SetValue(sqlstr)
+            # apply query
+            #self.listOfSQLStatements.append(sqlstr) #TODO probably it was bug
+            # close builder on apply
+            if self.builder.CloseOnApply():
+        elif event == 'close':
+    def ValidateSelectStatement(self, statement):
+        """!Validate SQL select statement
+        @return (columns, where)
+        @return None on error
+        if statement[0:7].lower() != 'select ':
+            return None
+        cols = ''
+        index = 7
+        for c in statement[index:]:
+            if c == ' ':
+                break
+            cols += c
+            index += 1
+        if cols == '*':
+            cols = None
+        else:
+            cols = cols.split(',')
+        tablelen = len(self.dbMgrData['mapDBInfo'].layers[self.selLayer]['table'])
+        if statement[index+1:index+6].lower() != 'from ' or \
+                statement[index+6:index+6+tablelen] != '%s' % \
+                (self.dbMgrData['mapDBInfo'].layers[self.selLayer]['table']):
+            return None
+        if len(statement[index+7+tablelen:]) > 0:
+            index = statement.lower().find('where ')
+            if index > -1:
+                where = statement[index+6:]
+            else:
+                where = None
+        else:
+            where = None
+        return (cols, where)
+        listWin = self.FindWindowById(self.layerPage[layer]['data'])
+        return listWin.LoadData(layer, columns, where, sql)
+    def UpdatePage(self, layer):
+        # update data tlist
+        if layer in self.layerPage.keys():
+            tlist = self.FindWindowById(self.layerPage[layer]['data'])
+class DbMgrTablesPage(DbMgrNotebookBase):
+        """!Page for managing tables
+                continue
+        if self.layers:
+    def AddLayer(self, layer = -1, pos = -1):
+        @param layer vector map layer connected to table
+        self.layerPage[layer] = {}
+        self.layerPage[layer]['tablePage'] = panel.GetId()
+        if pos == -1:
+                        text = " %d / %s %s" % (layer, label,
+                        self.dbMgrData['mapDBInfo'].layers[layer]['table']))
+        # dbInfo
+        dbBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+                                      label = " %s " % _("Database connection"))
+        dbSizer = wx.StaticBoxSizer(dbBox, wx.VERTICAL)
+        dbSizer.Add(item = createDbInfoDesc(panel, self.dbMgrData['mapDBInfo'], layer),
+                    proportion = 1,
+                    border = 3)
+        # table description
+        table = self.dbMgrData['mapDBInfo'].layers[layer]['table']
+        tableBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+                                label = " %s " % _("Table <%s> - right-click to delete column(s)") % table)
+        tableSizer = wx.StaticBoxSizer(tableBox, wx.VERTICAL)
+        tlist = self._createTableDesc(panel, table)
+        tlist.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnTableRightUp) #wxMSW
+        tlist.Bind(wx.EVT_RIGHT_UP,            self.OnTableRightUp) #wxGTK
+        self.layerPage[layer]['tableData'] = tlist.GetId()
+        # manage columns (add)
+        addBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+                              label = " %s " % _("Add column"))
+        addSizer = wx.StaticBoxSizer(addBox, wx.HORIZONTAL)
+        column = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = '',
+                             size = (150, -1), style = wx.TE_PROCESS_ENTER)
+        column.Bind(wx.EVT_TEXT,       self.OnTableAddColumnName)
+        column.Bind(wx.EVT_TEXT_ENTER, self.OnTableItemAdd)
+        self.layerPage[layer]['addColName'] = column.GetId()
+        addSizer.Add(item =  wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Column")),
+                     flag = wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
+                     border = 5)
+        addSizer.Add(item = column, proportion = 1,
+                     border = 5)
+        ctype = wx.Choice (parent = panel, id = wx.ID_ANY,
+                           choices = ["integer",
+                                      "double",
+                                      "varchar",
+                                      "date"]) # FIXME
+        ctype.SetSelection(0)
+        ctype.Bind(wx.EVT_CHOICE, self.OnTableChangeType)
+        self.layerPage[layer]['addColType'] = ctype.GetId()
+        addSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Type")),
+                     border = 5)
+        addSizer.Add(item = ctype,
+                     border = 5)
+        length = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (65, -1),
+                             initial = 250,
+                             min = 1, max = 1e6)
+        length.Enable(False)
+        self.layerPage[layer]['addColLength'] = length.GetId()
+        addSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Length")),
+                     border = 5)
+        addSizer.Add(item = length,
+                     border = 5)
+        btnAddCol = wx.Button(parent = panel, id = wx.ID_ANY, label = _("Add"))
+        btnAddCol.Bind(wx.EVT_BUTTON, self.OnTableItemAdd)
+        btnAddCol.Enable(False)
+        self.layerPage[layer]['addColButton'] = btnAddCol.GetId()
+        addSizer.Add(item = btnAddCol, flag = wx.ALL | wx.ALIGN_RIGHT | wx.EXPAND,
+                     border = 3)
+        # manage columns (rename)
+        renameBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+                                 label = " %s " % _("Rename column"))
+        renameSizer = wx.StaticBoxSizer(renameBox, wx.HORIZONTAL)
+        columnFrom = wx.ComboBox(parent = panel, id = wx.ID_ANY, size = (150, -1),
+                                 choices = self.dbMgrData['mapDBInfo'].GetColumns(table))
+        columnFrom.SetSelection(0)
+        self.layerPage[layer]['renameCol'] = columnFrom.GetId()
+        renameSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Column")),
+                        border = 5)
+        renameSizer.Add(item = columnFrom, proportion = 1,
+                        border = 5)
+        columnTo = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = '',
+        columnTo.Bind(wx.EVT_TEXT,       self.OnTableRenameColumnName)
+        columnTo.Bind(wx.EVT_TEXT_ENTER, self.OnTableItemChange)
+        self.layerPage[layer]['renameColTo'] = columnTo.GetId()
+        renameSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("To")),
+                        border = 5)
+        renameSizer.Add(item = columnTo, proportion = 1,
+                        border = 5)
+        btnRenameCol = wx.Button(parent = panel, id = wx.ID_ANY, label = _("&Rename"))
+        btnRenameCol.Bind(wx.EVT_BUTTON, self.OnTableItemChange)
+        btnRenameCol.Enable(False)
+        self.layerPage[layer]['renameColButton'] = btnRenameCol.GetId()
+        renameSizer.Add(item = btnRenameCol, flag = wx.ALL | wx.ALIGN_RIGHT | wx.EXPAND,
+                        border = 3)
+        tableSizer.Add(item = tlist,
+                       proportion = 1,
+                       border = 3)
+        pageSizer.Add(item=dbSizer,
+                      proportion = 0,
+                      border = 3)
+        pageSizer.Add(item = tableSizer,
+                      flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
+                      proportion = 1,
+                      border = 3)
+        pageSizer.Add(item = addSizer,
+                      proportion = 0,
+                      border = 3)
+        pageSizer.Add(item = renameSizer,
+                      proportion = 0,
+                      border = 3)
+            for widget in [columnTo, columnFrom, length, ctype,
+                           column,   btnAddCol,  btnRenameCol]:
+                widget.Enable(False)
+    def _createTableDesc(self, parent, table):
+        """!Create list with table description"""
+        tlist = TableListCtrl(parent = parent, id = wx.ID_ANY,
+                             table = self.dbMgrData['mapDBInfo'].tables[table],
+                             columns = self.dbMgrData['mapDBInfo'].GetColumns(table))
+        tlist.Populate()
+        # sorter
+        # itemDataMap = list.Populate()
+        # listmix.ColumnSorterMixin.__init__(self, 2)
+        return tlist
+    def OnTableChangeType(self, event):
+        """!Data type for new column changed. Enable or disable
+        data length widget"""
+        win = self.FindWindowById(self.layerPage[self.selLayer]['addColLength'])
+        if event.GetString() == "varchar":
+            win.Enable(True)
+        else:
+            win.Enable(False)
+    def OnTableRenameColumnName(self, event):
+        """!Editing column name to be added to the table"""
+        btn  = self.FindWindowById(self.layerPage[self.selLayer]['renameColButton'])
+        col  = self.FindWindowById(self.layerPage[self.selLayer]['renameCol'])
+        colTo = self.FindWindowById(self.layerPage[self.selLayer]['renameColTo'])
+        if len(col.GetValue()) > 0 and len(colTo.GetValue()) > 0:
+            btn.Enable(True)
+        else:
+            btn.Enable(False)
+        event.Skip()
+    def OnTableAddColumnName(self, event):
+        btn = self.FindWindowById(self.layerPage[self.selLayer]['addColButton'])
+        if len(event.GetString()) > 0:
+            btn.Enable(True)
+        else:
+            btn.Enable(False)
+        event.Skip()
+    def OnTableItemChange(self, event):
+        """!Rename column in the table"""
+        tlist   = self.FindWindowById(self.layerPage[self.selLayer]['tableData'])
+        name   = self.FindWindowById(self.layerPage[self.selLayer]['renameCol']).GetValue()
+        nameTo = self.FindWindowById(self.layerPage[self.selLayer]['renameColTo']).GetValue()
+        if not name or not nameTo:
+                   message = _("Unable to rename column. "
+                               "No column name defined."))
+            return
+        else:
+            item = tlist.FindItem(start = -1, str = name)
+            if item > -1:
+                if tlist.FindItem(start = -1, str = nameTo) > -1:
+                           message = _("Unable to rename column <%(column)s> to "
+                                       "<%(columnTo)s>. Column already exists "
+                               {'column' : name, 'columnTo' : nameTo,
+                                'table' : table})
+                    return
+                else:
+                    tlist.SetItemText(item, nameTo)
+                    self.listOfCommands.append(('v.db.renamecolumn',
+                                                { 'map'    : self.dbMgrData['vectName'],
+                                                  'layer'  : self.selLayer,
+                                                  'column' : '%s,%s' % (name, nameTo) }
+            else:
+                                   "Column <%(column)s> doesn't exist in the table <%(table)s>.") %
+                       {'column' : name, 'table' : table})
+                return
+        # apply changes
+        # update widgets
+        self.FindWindowById(self.layerPage[self.selLayer]['renameCol']).SetItems(self.dbMgrData['mapDBInfo'].GetColumns(table))
+        self.FindWindowById(self.layerPage[self.selLayer]['renameCol']).SetSelection(0)
+        self.FindWindowById(self.layerPage[self.selLayer]['renameColTo']).SetValue('')
+        event.Skip()
+    def OnTableRightUp(self, event):
+        if not hasattr(self, "popupTableID"):
+            self.popupTableID1 = wx.NewId()
+            self.popupTableID2 = wx.NewId()
+            self.popupTableID3 = wx.NewId()
+            self.Bind(wx.EVT_MENU, self.OnTableItemDelete,    id = self.popupTableID1)
+            self.Bind(wx.EVT_MENU, self.OnTableItemDeleteAll, id = self.popupTableID2)
+            self.Bind(wx.EVT_MENU, self.OnTableReload,        id = self.popupTableID3)
+        menu = wx.Menu()
+        menu.Append(self.popupTableID1, _("Drop selected column"))
+        if self.FindWindowById(self.layerPage[self.selLayer]['tableData']).GetFirstSelected() == -1:
+            menu.Enable(self.popupTableID1, False)
+        menu.Append(self.popupTableID2, _("Drop all columns"))
+        menu.Append(self.popupTableID3, _("Reload"))
+            menu.Enable(self.popupTableID2, False)
+        menu.Destroy()
+    def OnTableItemDelete(self, event):
+        """!Delete selected item(s) from the list"""
+                                         message = _("Selected column '%s' will PERMANENTLY removed "
+                                                   "from table. Do you want to drop the column?") % \
+                                             (tlist.GetItemText(item)),
+                                         caption = _("Drop column(s)"),
+                return False
+        while item != -1:
+            self.listOfCommands.append(('v.db.dropcolumn',
+                                          'column' : tlist.GetItemText(item) }
+            tlist.DeleteItem(item)
+        # apply changes
+        # update widgets
+        event.Skip()
+    def OnTableItemDeleteAll(self, event):
+        cols      = self.dbMgrData['mapDBInfo'].GetColumns(table)
+        if keyColumn in cols:
+            cols.remove(keyColumn)
+                                         message = _("Selected columns\n%s\nwill PERMANENTLY removed "
+                                                   "from table. Do you want to drop the columns?") % \
+                                             ('\n'.join(cols)),
+                return False
+        for col in cols:
+                                          'column' : col }
+        self.FindWindowById(self.layerPage[self.selLayer]['tableData']).DeleteAllItems()
+        # apply changes
+        # update widgets
+        event.Skip()
+    def OnTableReload(self, event = None):
+        self.FindWindowById(self.layerPage[self.selLayer]['tableData']).Populate(update = True)
+    def OnTableItemAdd(self, event):
+        """!Add new column to the table"""
+        name = self.FindWindowById(self.layerPage[self.selLayer]['addColName']).GetValue()
+        if not name:
+                   message = _("Unable to add column to the table. "
+            return
+        ctype = self.FindWindowById(self.layerPage[self.selLayer]['addColType']). \
+            GetStringSelection()
+        # cast type if needed
+        if ctype == 'double':
+            ctype = 'double precision'
+        if ctype == 'varchar':
+            length = int(self.FindWindowById(self.layerPage[self.selLayer]['addColLength']). \
+                             GetValue())
+        else:
+            length = '' # FIXME
+        # add item to the list of table columns
+        # check for duplicate items
+        if tlist.FindItem(start = -1, str = name) > -1:
+                   message = _("Column <%(column)s> already exists in table <%(table)s>.") % \
+                       {'column' : name, 'table' : self.dbMgrData['mapDBInfo'].layers[self.selLayer]["table"]}
+            return
+        index = tlist.InsertStringItem(sys.maxint, str(name))
+        tlist.SetStringItem(index, 0, str(name))
+        tlist.SetStringItem(index, 1, str(ctype))
+        tlist.SetStringItem(index, 2, str(length))
+        # add v.db.addcolumn command to the list
+            ctype += ' (%d)' % length
+        self.listOfCommands.append(('v.db.addcolumn',
+                                      'columns' : '%s %s' % (name, ctype) }
+        # apply changes
+        # update widgets
+        self.FindWindowById(self.layerPage[self.selLayer]['addColName']).SetValue('')
+        event.Skip()
+            # update table description
+            tlist = self.FindWindowById(self.layerPage[layer]['tableData'])
+            tlist.Update(table = self.dbMgrData['mapDBInfo'].tables[table],
+            self.OnTableReload(None)
+class DbMgrLayersPage(wx.Panel):
+        """!Create layer manage page"""
+        wx.Panel.__init__(self, parent = parent)
+        splitterWin = wx.SplitterWindow(parent = self, id = wx.ID_ANY)
+        splitterWin.SetMinimumPaneSize(100)
+        # list of layers
+        panelList = wx.Panel(parent = splitterWin, id = wx.ID_ANY)
+        panelListSizer  = wx.BoxSizer(wx.VERTICAL)
+        layerBox = wx.StaticBox(parent = panelList, id = wx.ID_ANY,
+                                label = " %s " % _("List of layers"))
+        layerSizer = wx.StaticBoxSizer(layerBox, wx.VERTICAL)
+        self.layerList = self._createLayerDesc(panelList)
+        self.layerList.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnLayerRightUp) #wxMSW
+        self.layerList.Bind(wx.EVT_RIGHT_UP,            self.OnLayerRightUp) #wxGTK
+        layerSizer.Add(item = self.layerList,
+                       proportion = 1,
+                       border = 3)
+        panelListSizer.Add(item = layerSizer,
+                           proportion = 1,
+                           border = 3)
+        panelList.SetSizer(panelListSizer)
+        # manage part
+        panelManage = wx.Panel(parent = splitterWin, id = wx.ID_ANY)
+        manageSizer = wx.BoxSizer(wx.VERTICAL)
+        self.manageLayerBook = LayerBook(parent = panelManage, id = wx.ID_ANY,
+                                         parentDialog = self)
+            self.manageLayerBook.Enable(False)
+        manageSizer.Add(item = self.manageLayerBook,
+                        proportion = 1,
+                        border = 5)
+        panelSizer  = wx.BoxSizer(wx.VERTICAL)
+        panelSizer.Add(item = splitterWin,
+                      proportion = 1,
+                      flag = wx.EXPAND)
+        panelManage.SetSizer(manageSizer)
+        splitterWin.SplitHorizontally(panelList, panelManage, 100)
+        splitterWin.Fit()
+        self.SetSizer(panelSizer)
+    def _createLayerDesc(self, parent):
+        """!Create list of linked layers"""
+        tlist = LayerListCtrl(parent = parent, id = wx.ID_ANY,
+                             layers = self.dbMgrData['mapDBInfo'].layers)
+        tlist.Populate()
+        # sorter
+        return tlist
+    def UpdatePage(self):
+        # 'manage layers' page
+        # update list of layers
+        #self.dbMgrData['mapDBInfo'] = VectorDBInfo(self.dbMgrData['vectName'])
+        self.layerList.Update(self.dbMgrData['mapDBInfo'].layers)
+        self.layerList.Populate(update = True)
+        # update selected widgets
+        listOfLayers = map(str, self.dbMgrData['mapDBInfo'].layers.keys())
+        ### delete layer page
+        self.manageLayerBook.deleteLayer.SetItems(listOfLayers)
+        if len(listOfLayers) > 0:
+            self.manageLayerBook.deleteLayer.SetStringSelection(listOfLayers[0])
+            tableName = self.dbMgrData['mapDBInfo'].layers[int(listOfLayers[0])]['table']
+            maxLayer = max(self.dbMgrData['mapDBInfo'].layers.keys())
+        else:
+            tableName = ''
+            maxLayer = 0
+        self.manageLayerBook.deleteTable.SetLabel( \
+            _('Drop also linked attribute table (%s)') % \
+                tableName)
+        ### add layer page
+        self.manageLayerBook.addLayerWidgets['layer'][1].SetValue(\
+            maxLayer+1)
+        ### modify layer
+        self.manageLayerBook.modifyLayerWidgets['layer'][1].SetItems(listOfLayers)
+        self.manageLayerBook.OnChangeLayer(event = None)
+    def OnLayerRightUp(self, event):
+        """!Layer description area, context menu"""
+        pass
+class TableListCtrl(wx.ListCtrl,
+                    listmix.ListCtrlAutoWidthMixin):
+    #                    listmix.TextEditMixin):
+    """!Table description list"""
+    def __init__(self, parent, id, table, columns, pos = wx.DefaultPosition,
+                 size = wx.DefaultSize):
+        self.table   = table
+        self.columns = columns
+        wx.ListCtrl.__init__(self, parent, id, pos, size,
+                             style = wx.LC_REPORT | wx.LC_HRULES | wx.LC_VRULES |
+                             wx.BORDER_NONE)
+        # listmix.TextEditMixin.__init__(self)
+    def Update(self, table, columns):
+        """!Update column description"""
+    def Populate(self, update = False):
+        """!Populate the list"""
+        itemData = {} # requested by sorter
+        if not update:
+            headings = [_("Column name"), _("Data type"), _("Data length")]
+            i = 0
+            for h in headings:
+                self.InsertColumn(col = i, heading = h)
+                i += 1
+            self.SetColumnWidth(col = 0, width = 350)
+            self.SetColumnWidth(col = 1, width = 175)
+        else:
+        i = 0
+        for column in self.columns:
+            index = self.InsertStringItem(sys.maxint, str(column))
+            self.SetStringItem(index, 0, str(column))
+            self.SetStringItem(index, 1, str(self.table[column]['type']))
+            self.SetStringItem(index, 2, str(self.table[column]['length']))
+            self.SetItemData(index, i)
+            itemData[i] = (str(column),
+                           str(self.table[column]['type']),
+                           int(self.table[column]['length']))
+            i = i + 1
+        return itemData
+class LayerListCtrl(wx.ListCtrl,
+                    # listmix.ColumnSorterMixin):
+    """!Layer description list"""
+    def __init__(self, parent, id, layers,
+                 pos = wx.DefaultPosition,
+        self.parent = parent
+        self.layers = layers
+                             wx.BORDER_NONE)
+    def Update(self, layers):
+        """!Update description"""
+        if not update:
+            headings = [_("Layer"),  _("Driver"), _("Database"), _("Table"), _("Key")]
+            i = 0
+                i += 1
+        else:
+        i = 0
+        for layer in self.layers.keys():
+            index = self.InsertStringItem(sys.maxint, str(layer))
+            self.SetStringItem(index, 0, str(layer))
+            database = str(self.layers[layer]['database'])
+            driver   = str(self.layers[layer]['driver'])
+            table    = str(self.layers[layer]['table'])
+            key      = str(self.layers[layer]['key'])
+            self.SetStringItem(index, 1, driver)
+            self.SetStringItem(index, 2, database)
+            self.SetStringItem(index, 3, table)
+            self.SetStringItem(index, 4, key)
+            itemData[i] = (str(layer),
+                           driver,
+                           database,
+                           table,
+                           key)
+            i += 1
+            self.SetColumnWidth(col = i, width = wx.LIST_AUTOSIZE)
+            if self.GetColumnWidth(col = i) < 60:
+                self.SetColumnWidth(col = i, width = 60)
+        return itemData
+class LayerBook(wx.Notebook):
+    """!Manage layers (add, delete, modify)"""
+                 parentDialog,
+                 style = wx.BK_DEFAULT):
+        wx.Notebook.__init__(self, parent, id, style = style)
+        self.parentDialog = parentDialog
+        self.mapDBInfo    = self.parentDialog.dbMgrData['mapDBInfo']
+        # drivers
+        drivers = RunCommand('db.drivers',
+                             quiet = True,
+                             read = True,
+                             flags = 'p')
+        self.listOfDrivers = []
+        for drv in drivers.splitlines():
+            self.listOfDrivers.append(drv.strip())
+        # get default values
+        self.defaultConnect = {}
+        connect = RunCommand('db.connect',
+                             flags = 'p',
+                             read = True,
+                             quiet = True)
+        for line in connect.splitlines():
+            item, value = line.split(':', 1)
+            self.defaultConnect[item.strip()] = value.strip()
+        if len(self.defaultConnect['driver']) == 0 or \
+               len(self.defaultConnect['database']) == 0:
+            GWarning(parent = self.parent,
+                     message = _("Unknown default DB connection. "
+                                 "Please define DB connection using db.connect module."))
+        self.defaultTables = self._getTables(self.defaultConnect['driver'],
+                                             self.defaultConnect['database'])
+        try:
+            self.defaultColumns = self._getColumns(self.defaultConnect['driver'],
+                                                    self.defaultConnect['database'],
+                                                    self.defaultTables[0])
+        except IndexError:
+            self.defaultColumns = []
+        self._createAddPage()
+        self._createDeletePage()
+        self._createModifyPage()
+    def _createAddPage(self):
+        """!Add new layer"""
+        self.addPanel = wx.Panel(parent = self, id = wx.ID_ANY)
+        self.AddPage(page = self.addPanel, text = _("Add layer"))
+        try:
+            maxLayer = max(self.mapDBInfo.layers.keys())
+            maxLayer = 0
+        # layer description
+        layerBox = wx.StaticBox (parent = self.addPanel, id = wx.ID_ANY,
+                                 label = " %s " % (_("Layer description")))
+        # list of layer widgets (label, value)
+        self.addLayerWidgets = {'layer':
+                                    (wx.StaticText(parent = self.addPanel, id = wx.ID_ANY,
+                                                   label = '%s:' % _("Layer")),
+                                     wx.SpinCtrl(parent = self.addPanel, id = wx.ID_ANY, size = (65, -1),
+                                                 initial = maxLayer+1,
+                                                 min = 1, max = 1e6)),
+                                'driver':
+                                                   label = '%s:' % _("Driver")),
+                                     wx.Choice(parent = self.addPanel, id = wx.ID_ANY, size = (200, -1),
+                                               choices = self.listOfDrivers)),
+                                'database':
+                                                   label = '%s:' % _("Database")),
+                                     wx.TextCtrl(parent = self.addPanel, id = wx.ID_ANY,
+                                                 value = '',
+                                                 style = wx.TE_PROCESS_ENTER)),
+                                'table':
+                                                   label = '%s:' % _("Table")),
+                                               choices = self.defaultTables)),
+                                'key':
+                                                   label = '%s:' % _("Key column")),
+                                               choices = self.defaultColumns)),
+                                'addCat':
+                                    (wx.CheckBox(parent = self.addPanel, id = wx.ID_ANY,
+                                                 label = _("Insert record for each category into table")),
+                                     None),
+        # set default values for widgets
+        self.addLayerWidgets['driver'][1].SetStringSelection(self.defaultConnect['driver'])
+        self.addLayerWidgets['database'][1].SetValue(self.defaultConnect['database'])
+        self.addLayerWidgets['table'][1].SetSelection(0)
+        self.addLayerWidgets['key'][1].SetSelection(0)
+        # events
+        self.addLayerWidgets['driver'][1].Bind(wx.EVT_CHOICE, self.OnDriverChanged)
+        self.addLayerWidgets['database'][1].Bind(wx.EVT_TEXT_ENTER, self.OnDatabaseChanged)
+        self.addLayerWidgets['table'][1].Bind(wx.EVT_CHOICE, self.OnTableChanged)
+        # tooltips
+        self.addLayerWidgets['addCat'][0].SetToolTipString(_("You need to add categories "
+                                                             "by v.category module."))
+        tableBox = wx.StaticBox (parent = self.addPanel, id = wx.ID_ANY,
+                                 label = " %s " % (_("Table description")))
+        # list of table widgets
+        keyCol = UserSettings.Get(group = 'atm', key = 'keycolumn', subkey = 'value')
+        self.tableWidgets = {'table': (wx.StaticText(parent = self.addPanel, id = wx.ID_ANY,
+                                                     label = '%s:' % _("Table name")),
+                                                   value = '',
+                             'key': (wx.StaticText(parent = self.addPanel, id = wx.ID_ANY,
+                                                 value = keyCol,
+                                                 style = wx.TE_PROCESS_ENTER))}
+        # events
+        self.tableWidgets['table'][1].Bind(wx.EVT_TEXT_ENTER, self.OnCreateTable)
+        self.tableWidgets['key'][1].Bind(wx.EVT_TEXT_ENTER, self.OnCreateTable)
+        btnTable   = wx.Button(self.addPanel, wx.ID_ANY, _("&Create table"),
+                             size = (125,-1))
+        btnTable.Bind(wx.EVT_BUTTON, self.OnCreateTable)
+        btnLayer   = wx.Button(self.addPanel, wx.ID_ANY, _("&Add layer"),
+                             size = (125,-1))
+        btnLayer.Bind(wx.EVT_BUTTON, self.OnAddLayer)
+        btnDefault = wx.Button(self.addPanel, wx.ID_ANY, _("&Set default"),
+                               size = (125,-1))
+        btnDefault.Bind(wx.EVT_BUTTON, self.OnSetDefault)
+        # do layout
+        pageSizer = wx.BoxSizer(wx.HORIZONTAL)
+        # data area
+        dataSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+        dataSizer.AddGrowableCol(1)
+        row = 0
+        for key in ('layer', 'driver', 'database', 'table', 'key', 'addCat'):
+            label, value = self.addLayerWidgets[key]
+            if not value:
+                span = (1, 2)
+            else:
+                span = (1, 1)
+            dataSizer.Add(item = label,
+                          flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0),
+                          span = span)
+            if not value:
+                row += 1
+                continue
+            if key == 'layer':
+                style = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT
+            else:
+                style = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND
+            dataSizer.Add(item = value,
+                          flag = style, pos = (row, 1))
+            row += 1
+        layerSizer.Add(item = dataSizer,
+                       proportion = 1,
+                       border = 5)
+        btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+        btnSizer.Add(item = btnDefault,
+                     proportion = 0,
+                     flag = wx.ALL | wx.ALIGN_LEFT,
+                     border = 5)
+        btnSizer.Add(item = (5, 5),
+                     proportion = 1,
+                     border = 5)
+        btnSizer.Add(item = btnLayer,
+                     proportion = 0,
+                     flag = wx.ALL | wx.ALIGN_RIGHT,
+                     border = 5)
+        layerSizer.Add(item = btnSizer,
+                       proportion = 0,
+                       border = 0)
+        # data area
+        dataSizer = wx.FlexGridSizer(cols = 2, hgap = 5, vgap = 5)
+        for key in ['table', 'key']:
+            label, value = self.tableWidgets[key]
+        tableSizer.Add(item = dataSizer,
+                       proportion = 1,
+                       border = 5)
+        tableSizer.Add(item = btnTable,
+                       proportion = 0,
+                       flag = wx.ALL | wx.ALIGN_BOTTOM | wx.ALIGN_RIGHT,
+                       border = 5)
+        pageSizer.Add(item = layerSizer,
+                      proportion = 3,
+                      border = 3)
+                      proportion = 2,
+                      flag = wx.TOP | wx.BOTTOM | wx.RIGHT | wx.EXPAND,
+                      border = 3)
+        layerSizer.SetVirtualSizeHints(self.addPanel)
+        self.addPanel.SetAutoLayout(True)
+        self.addPanel.SetSizer(pageSizer)
+        pageSizer.Fit(self.addPanel)
+    def _createDeletePage(self):
+        """!Delete layer"""
+        self.deletePanel = wx.Panel(parent = self, id = wx.ID_ANY)
+        self.AddPage(page = self.deletePanel, text = _("Remove layer"))
+        label = wx.StaticText(parent = self.deletePanel, id = wx.ID_ANY,
+                              label = '%s:' % _("Layer to remove"))
+        self.deleteLayer = wx.ComboBox(parent = self.deletePanel, id = wx.ID_ANY, size = (100, -1),
+                                       choices = map(str, self.mapDBInfo.layers.keys()))
+        self.deleteLayer.SetSelection(0)
+        self.deleteLayer.Bind(wx.EVT_COMBOBOX, self.OnChangeLayer)
+        try:
+            tableName = self.mapDBInfo.layers[int(self.deleteLayer.GetStringSelection())]['table']
+        except ValueError:
+            tableName = ''
+        self.deleteTable = wx.CheckBox(parent = self.deletePanel, id = wx.ID_ANY,
+                                       label = _('Drop also linked attribute table (%s)') % \
+                                       tableName)
+        if tableName == '':
+            self.deleteLayer.Enable(False)
+            self.deleteTable.Enable(False)
+        btnDelete   = wx.Button(self.deletePanel, wx.ID_DELETE, _("&Remove layer"),
+                                size = (125,-1))
+        btnDelete.Bind(wx.EVT_BUTTON, self.OnDeleteLayer)
+        # do layout
+        dataSizer = wx.BoxSizer(wx.VERTICAL)
+        flexSizer = wx.FlexGridSizer(cols = 2, hgap = 5, vgap = 5)
+        flexSizer.AddGrowableCol(2)
+        flexSizer.Add(item = label,
+        flexSizer.Add(item = self.deleteLayer,
+        dataSizer.Add(item = flexSizer,
+                      proportion = 0,
+                      border = 1)
+        dataSizer.Add(item = self.deleteTable,
+                      proportion = 0,
+                      border = 1)
+        pageSizer.Add(item = dataSizer,
+                      proportion = 1,
+                      border = 5)
+        pageSizer.Add(item = btnDelete,
+                      proportion = 0,
+                      border = 5)
+        self.deletePanel.SetSizer(pageSizer)
+    def _createModifyPage(self):
+        """!Modify layer"""
+        self.modifyPanel = wx.Panel(parent = self, id = wx.ID_ANY)
+        self.AddPage(page = self.modifyPanel, text = _("Modify layer"))
+        self.modifyLayerWidgets = {'layer':
+                                       (wx.StaticText(parent = self.modifyPanel, id = wx.ID_ANY,
+                                        wx.ComboBox(parent = self.modifyPanel, id = wx.ID_ANY,
+                                                    size = (100, -1),
+        self.mapDBInfo.layers.keys()))),
+                                   'driver':
+                                        wx.Choice(parent = self.modifyPanel, id = wx.ID_ANY,
+                                                  size = (200, -1),
+                                   'database':
+                                        wx.TextCtrl(parent = self.modifyPanel, id = wx.ID_ANY,
+                                                    value = '', size = (350, -1),
+                                   'table':
+                                                  size = (200, -1),
+                                   'key':
+                                                  size = (200, -1),
+                                                  choices = self.defaultColumns))}
+        self.modifyLayerWidgets['layer'][1].SetSelection(0)
+        try:
+            layer = int(self.modifyLayerWidgets['layer'][1].GetStringSelection())
+            layer = None
+            for label in self.modifyLayerWidgets.keys():
+                self.modifyLayerWidgets[label][1].Enable(False)
+        if layer:
+            driver   = self.mapDBInfo.layers[layer]['driver']
+            database = self.mapDBInfo.layers[layer]['database']
+            table    = self.mapDBInfo.layers[layer]['table']
+            listOfColumns = self._getColumns(driver, database, table)
+            self.modifyLayerWidgets['driver'][1].SetStringSelection(driver)
+            self.modifyLayerWidgets['database'][1].SetValue(database)
+            if table in self.modifyLayerWidgets['table'][1].GetItems():
+                self.modifyLayerWidgets['table'][1].SetStringSelection(table)
+            else:
+                if self.defaultConnect['schema'] != '':
+                    table = self.defaultConnect['schema'] + table # try with default schema
+                else:
+                    table = 'public.' + table # try with 'public' schema
+            self.modifyLayerWidgets['key'][1].SetItems(listOfColumns)
+            self.modifyLayerWidgets['key'][1].SetSelection(0)
+        # events
+        self.modifyLayerWidgets['layer'][1].Bind(wx.EVT_COMBOBOX, self.OnChangeLayer)
+        # self.modifyLayerWidgets['driver'][1].Bind(wx.EVT_CHOICE, self.OnDriverChanged)
+        # self.modifyLayerWidgets['database'][1].Bind(wx.EVT_TEXT_ENTER, self.OnDatabaseChanged)
+        # self.modifyLayerWidgets['table'][1].Bind(wx.EVT_CHOICE, self.OnTableChanged)
+        btnModify = wx.Button(self.modifyPanel, wx.ID_DELETE, _("&Modify layer"),
+                              size = (125,-1))
+        btnModify.Bind(wx.EVT_BUTTON, self.OnModifyLayer)
+        # do layout
+        # data area
+        for key in ('layer', 'driver', 'database', 'table', 'key'):
+            label, value = self.modifyLayerWidgets[key]
+                              flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT)
+            else:
+                      proportion = 1,
+                      border = 5)
+        pageSizer.Add(item = btnModify,
+                      proportion = 0,
+                      border = 5)
+        self.modifyPanel.SetSizer(pageSizer)
+    def _getTables(self, driver, database):
+        """!Get list of tables for given driver and database"""
+        tables = []
+        ret = RunCommand('db.tables',
+                         parent = self,
+                         read = True,
+                         flags = 'p',
+                         driver = driver,
+        if ret is None:
+            GError(parent = self,
+                   message = _("Unable to get list of tables.\n"
+                               "Please use db.connect to set database parameters."))
+            return tables
+        for table in ret.splitlines():
+            tables.append(table)
+        return tables
+    def _getColumns(self, driver, database, table):
+        """!Get list of column of given table"""
+        columns = []
+        ret = RunCommand('db.columns',
+                         parent = self,
+                         quiet = True,
+                         read = True,
+                         driver = driver,
+                         database = database,
+                         table = table)
+        if ret == None:
+            return columns
+        for column in ret.splitlines():
+            columns.append(column)
+        return columns
+    def OnDriverChanged(self, event):
+        """!Driver selection changed, update list of tables"""
+        driver = event.GetString()
+        database = self.addLayerWidgets['database'][1].GetValue()
+        winTable = self.addLayerWidgets['table'][1]
+        winKey   = self.addLayerWidgets['key'][1]
+        tables   = self._getTables(driver, database)
+        winTable.SetItems(tables)
+        winTable.SetSelection(0)
+        if len(tables) == 0:
+            winKey.SetItems([])
+        event.Skip()
+    def OnDatabaseChanged(self, event):
+        """!Database selection changed, update list of tables"""
+        event.Skip()
+    def OnTableChanged(self, event):
+        """!Table name changed, update list of columns"""
+        driver   = self.addLayerWidgets['driver'][1].GetStringSelection()
+        table    = event.GetString()
+        win  = self.addLayerWidgets['key'][1]
+        cols = self._getColumns(driver, database, table)
+        win.SetItems(cols)
+        win.SetSelection(0)
+        event.Skip()
+    def OnSetDefault(self, event):
+        """!Set default values"""
+        table    = self.addLayerWidgets['table'][1]
+        key      = self.addLayerWidgets['key'][1]
+        driver.SetStringSelection(self.defaultConnect['driver'])
+        database.SetValue(self.defaultConnect['database'])
+        tables = self._getTables(self.defaultConnect['driver'],
+        table.SetItems(tables)
+        table.SetSelection(0)
+            key.SetItems([])
+        else:
+            cols = self._getColumns(self.defaultConnect['driver'],
+                                     tables[0])
+            key.SetItems(cols)
+            key.SetSelection(0)
+        event.Skip()
+    def OnCreateTable(self, event):
+        """!Create new table (name and key column given)"""
+        table    = self.tableWidgets['table'][1].GetValue()
+        key      = self.tableWidgets['key'][1].GetValue()
+        if not table or not key:
+                   message = _("Unable to create new table. "
+                               "Table name or key column name is missing."))
+            return
+        if table in self.addLayerWidgets['table'][1].GetItems():
+                               "Table <%s> already exists in the database.") % table)
+            return
+        # create table
+        sql = 'CREATE TABLE %s (%s INTEGER)' % (table, key)
+                   quiet = True,
+                   parent = self,
+                   stdin = sql,
+                   input = '-',
+                   driver = driver,
+        # update list of tables
+        tableList = self.addLayerWidgets['table'][1]
+        tableList.SetItems(self._getTables(driver, database))
+        tableList.SetStringSelection(table)
+        # update key column selection
+        keyList = self.addLayerWidgets['key'][1]
+        keyList.SetItems(self._getColumns(driver, database, table))
+        keyList.SetStringSelection(key)
+        event.Skip()
+    def OnAddLayer(self, event):
+        """!Add new layer to vector map"""
+        layer    = int(self.addLayerWidgets['layer'][1].GetValue())
+        layerWin = self.addLayerWidgets['layer'][1]
+        table    = self.addLayerWidgets['table'][1].GetStringSelection()
+        key      = self.addLayerWidgets['key'][1].GetStringSelection()
+        if layer in self.mapDBInfo.layers.keys():
+                   message = _("Unable to add new layer to vector map <%(vector)s>. "
+                               "Layer %(layer)d already exists.") % \
+                       {'vector' : self.mapDBInfo.map, 'layer' : layer})
+            return
+        # add new layer
+        ret = RunCommand('v.db.connect',
+                         parent = self,
+                         quiet = True,
+                         map = self.mapDBInfo.map,
+                         driver = driver,
+                         table = table,
+                         key = key,
+                         layer = layer)
+        # insert records into table if required
+        if self.addLayerWidgets['addCat'][0].IsChecked():
+            RunCommand('v.to.db',
+                       parent = self,
+                       quiet = True,
+                       layer = layer,
+                       qlayer = layer,
+                       option = 'cat',
+                       columns = key)
+        if ret == 0:
+            # update dialog (only for new layer)
+            self.parentDialog.parentDbMgrBase.UpdateDialog(layer = layer)
+            # update db info
+            # increase layer number
+            layerWin.SetValue(layer+1)
+        if len(self.mapDBInfo.layers.keys()) == 1:
+            # first layer add --- enable previously disabled widgets
+            self.deleteLayer.Enable()
+            self.deleteTable.Enable()
+                self.modifyLayerWidgets[label][1].Enable()
+    def OnDeleteLayer(self, event):
+        try:
+            layer = int(self.deleteLayer.GetValue())
+        except:
+            return
+        RunCommand('v.db.connect',
+                   parent = self,
+                   flags = 'd',
+                   layer = layer)
+        # drop also table linked to layer which is deleted
+        if self.deleteTable.IsChecked():
+            sql      = 'DROP TABLE %s' % (table)
+                       parent = self,
+                       stdin = sql,
+                       quiet = True,
+                       driver = driver,
+        # update dialog
+        # update db info
+        if len(self.mapDBInfo.layers.keys()) == 0:
+            # disable selected widgets
+        event.Skip()
+    def OnChangeLayer(self, event):
+        """!Layer number of layer to be deleted is changed"""
+        try:
+            layer = int(event.GetString())
+        except:
+            try:
+                layer = self.mapDBInfo.layers.keys()[0]
+            except:
+                return
+        if self.GetCurrentPage() == self.modifyPanel:
+        else:
+            self.deleteTable.SetLabel(_('Drop also linked attribute table (%s)') % \
+                                          self.mapDBInfo.layers[layer]['table'])
+        if event:
+            event.Skip()
+    def OnModifyLayer(self, event):
+        """!Modify layer connection settings"""
+        modify = False
+        if self.modifyLayerWidgets['driver'][1].GetStringSelection() != \
+                self.mapDBInfo.layers[layer]['driver'] or \
+                self.modifyLayerWidgets['database'][1].GetStringSelection() != \
+                self.mapDBInfo.layers[layer]['database'] or \
+                self.modifyLayerWidgets['table'][1].GetStringSelection() != \
+                self.mapDBInfo.layers[layer]['table'] or \
+                self.modifyLayerWidgets['key'][1].GetStringSelection() != \
+                self.mapDBInfo.layers[layer]['key']:
+            modify = True
+        if modify:
+            # delete layer
+                       parent = self,
+                       quiet = True,
+                       flags = 'd',
+                       layer = layer)
+            # add modified layer
+                       quiet = True,
+                       driver = self.modifyLayerWidgets['driver'][1].GetStringSelection(),
+                       database = self.modifyLayerWidgets['database'][1].GetValue(),
+                       table = self.modifyLayerWidgets['table'][1].GetStringSelection(),
+                       key = self.modifyLayerWidgets['key'][1].GetStringSelection(),
+                       layer = int(layer))
+            # update db info
+        event.Skip()
Property changes on: grass/trunk/gui/wxpython/dbmgr/base.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
Modified: grass/trunk/gui/wxpython/dbmgr/manager.py
--- grass/trunk/gui/wxpython/dbmgr/manager.py	2012-08-12 18:06:36 UTC (rev 52640)
+++ grass/trunk/gui/wxpython/dbmgr/manager.py	2012-08-12 19:11:18 UTC (rev 52641)
@@ -14,518 +14,34 @@
 @endcode
 List of classes:
- - manager::Log
- - manager::VirtualAttributeList
  - manager::AttributeManager
- - manager::TableListCtrl
- - manager::LayerListCtrl
- - manager::LayerBook
-(C) 2007-2009, 2011 by the GRASS Development Team
+(C) 2007-2009, 2011-2012 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
 @author Jachym Cepicky <jachym.cepicky gmail.com>
 @author Martin Landa <landa.martin gmail.com>
+ at author Refactoring by Stepan Turek <stepan.turek seznam.cz> (GSoC 2012, mentor: Martin Landa)"""
 import sys
 import os
-import locale
-import tempfile
-import copy
-import types
 if __name__ == "__main__":
     sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
 from core import globalvar
 import wx
-import wx.lib.mixins.listctrl as listmix
 import wx.lib.flatnotebook    as FN
 import grass.script as grass
-from dbmgr.sqlbuilder import SQLFrame
-from core.gcmd        import RunCommand, GException, GError, GMessage, GWarning
-from core.utils       import ListOfCatsToRange
-from gui_core.dialogs import CreateNewVector
-from dbmgr.vinfo      import VectorDBInfo, unicodeValue, createDbInfoDesc
+from core.gcmd        import GMessage
 from core.debug       import Debug
-from dbmgr.dialogs    import ModifyTableRecord
-from core.settings    import UserSettings
+from dbmgr.base       import DbMgrBase
 from gui_core.widgets import GNotebook
-class Log:
-    The log output is redirected to the status bar of the containing frame.
-    def __init__(self, parent):
-        self.parent = parent
-    def write(self, text_string):
-        """!Update status bar"""
-        self.parent.SetStatusText(text_string.strip())
-class VirtualAttributeList(wx.ListCtrl,
-                           listmix.ListCtrlAutoWidthMixin,
-                           listmix.ColumnSorterMixin):
-    Support virtual list class
-    def __init__(self, parent, log, mapDBInfo, layer):
-        # initialize variables
-        self.log     = log
-        self.mapDBInfo = mapDBInfo
-        self.layer   = layer
-        self.columns = {} # <- LoadData()
-        wx.ListCtrl.__init__(self, parent = parent, id = wx.ID_ANY,
-                             style = wx.LC_REPORT | wx.LC_HRULES |
-                             wx.LC_VRULES | wx.LC_VIRTUAL | wx.LC_SORT_ASCENDING)
-        try:
-            keyColumn = self.LoadData(layer)
-        except GException, e:
-            GError(parent = self,
-                   message = e.value)
-            return
-        # add some attributes (colourful background for each item rows)
-        self.attr1 = wx.ListItemAttr()
-        self.attr1.SetBackgroundColour(wx.Colour(238,238,238))
-        self.attr2 = wx.ListItemAttr()
-        self.attr2.SetBackgroundColour("white")
-        self.il = wx.ImageList(16, 16)
-        self.sm_up = self.il.Add(wx.ArtProvider_GetBitmap(wx.ART_GO_UP,   wx.ART_TOOLBAR,
-                                                          (16,16)))
-        self.sm_dn = self.il.Add(wx.ArtProvider_GetBitmap(wx.ART_GO_DOWN, wx.ART_TOOLBAR,
-                                                          (16,16)))
-        self.SetImageList(self.il, wx.IMAGE_LIST_SMALL)
-        # setup mixins
-        listmix.ListCtrlAutoWidthMixin.__init__(self)
-        listmix.ColumnSorterMixin.__init__(self, len(self.columns))
-        # sort item by category (id)
-        if keyColumn > -1:
-            self.SortListItems(col = keyColumn, ascending = True)
-        else:
-            self.SortListItems(col = 0, ascending = True)
-        # events
-        self.Bind(wx.EVT_LIST_ITEM_SELECTED,   self.OnItemSelected)
-        self.Bind(wx.EVT_LIST_ITEM_DESELECTED, self.OnItemDeselected)
-        self.Bind(wx.EVT_LIST_COL_CLICK,       self.OnColumnSort)
-        self.Bind(wx.EVT_LIST_COL_RIGHT_CLICK, self.OnColumnMenu)
-    def Update(self, mapDBInfo):
-        """!Update list according new mapDBInfo description"""
-        self.LoadData(self.layer)
-    def LoadData(self, layer, columns = None, where = None, sql = None):
-        """!Load data into list
-        @param layer layer number
-        @param columns list of columns for output (-> v.db.select)
-        @param where where statement (-> v.db.select)
-        @param sql full sql statement (-> db.select)
-        @return id of key column
-        @return -1 if key column is not displayed
-        self.log.write(_("Loading data..."))
-        tableName    = self.mapDBInfo.layers[layer]['table']
-        keyColumn    = self.mapDBInfo.layers[layer]['key']
-        try:
-            self.columns = self.mapDBInfo.tables[tableName]
-        except KeyError:
-            raise GException(_("Attribute table <%s> not found. "
-                                    "For creating the table switch to "
-                                    "'Manage layers' tab.") % tableName)
-        if not columns:
-            columns = self.mapDBInfo.GetColumns(tableName)
-        else:
-            all = self.mapDBInfo.GetColumns(tableName)
-            for col in columns:
-                if col not in all:
-                           message = _("Column <%(column)s> not found in "
-                                       "in the table <%(table)s>.") % \
-                               { 'column' : col, 'table' : tableName })
-                    return
-        try:
-            # for maps connected via v.external
-            keyId = columns.index(keyColumn)
-        except:
-            keyId = -1
-        # read data
-        # FIXME: Max. number of rows, while the GUI is still usable
-        # stdout can be very large, do not use PIPE, redirect to temp file
-        # TODO: more effective way should be implemented...
-        outFile = tempfile.NamedTemporaryFile(mode = 'w+b')
-        if sql:
-            ret = RunCommand('db.select',
-                             quiet = True,
-                             parent = self,
-                             flags = 'c',
-                             sql = sql,
-                             output = outFile.name)
-        else:
-            if columns:
-                ret = RunCommand('v.db.select',
-                                 quiet = True,
-                                 parent = self,
-                                 flags = 'c',
-                                 map = self.mapDBInfo.map,
-                                 layer = layer,
-                                 columns = ','.join(columns),
-                                 where = where,
-                                 stdout = outFile)
-            else:
-                                 quiet = True,
-                                 parent = self,
-                                 flags = 'c',
-                                 layer = layer,
-                                 where = where,
-                                 stdout = outFile)
-        # These two should probably be passed to init more cleanly
-        # setting the numbers of items = number of elements in the dictionary
-        self.itemDataMap  = {}
-        self.itemIndexMap = []
-        self.itemCatsMap  = {}
-        self.DeleteAllItems()
-        # self.ClearAll()
-        for i in range(self.GetColumnCount()):
-            self.DeleteColumn(0)
-        i = 0
-        info = wx.ListItem()
-        info.m_mask = wx.LIST_MASK_TEXT | wx.LIST_MASK_IMAGE | wx.LIST_MASK_FORMAT
-        info.m_image = -1
-        info.m_format = 0
-        for column in columns:
-            info.m_text = column
-            self.InsertColumnInfo(i, info)
-            i += 1
-            if i >= 256:
-                self.log.write(_("Can display only 256 columns."))
-        i = 0
-        outFile.seek(0)
-        while True:
-            # os.linesep doesn't work here (MSYS)
-            record = outFile.readline().replace('\n', '')
-            if not record:
-                break
-            self.AddDataRow(i, record, columns, keyId)
-            i += 1
-            if i >= 100000:
-                self.log.write(_("Limit 100000 records."))
-                break
-        self.SetItemCount(i)
-        i = 0
-            width = self.columns[col]['length'] * 6 # FIXME
-            if width < 60:
-                width = 60
-            if width > 300:
-                width = 300
-            self.SetColumnWidth(col = i, width = width)
-            i += 1
-        self.SendSizeEvent()
-        self.log.write(_("Number of loaded records: %d") % \
-                           self.GetItemCount())
-        return keyId
-    def AddDataRow(self, i, record, columns, keyId):
-        """!Add row to the data list"""
-        self.itemDataMap[i] = []
-        keyColumn = self.mapDBInfo.layers[self.layer]['key']
-        j = 0
-        cat = None
-        if keyColumn == 'OGC_FID':
-            self.itemDataMap[i].append(i+1)
-            j += 1
-            cat = i + 1
-        for value in record.split('|'):
-            if self.columns[columns[j]]['ctype'] != types.StringType:
-                try:
-                    ### casting disabled (2009/03)
-                    ### self.itemDataMap[i].append(self.columns[columns[j]]['ctype'](value))
-                    self.itemDataMap[i].append(value)
-                except ValueError:
-                    self.itemDataMap[i].append(_('Unknown value'))
-            else:
-                # encode string values
-                try:
-                    self.itemDataMap[i].append(unicodeValue(value))
-                except UnicodeDecodeError:
-                    self.itemDataMap[i].append(_("Unable to decode value. "
-                                                 "Set encoding in GUI preferences ('Attributes')."))
-            if not cat and keyId > -1 and keyId == j:
-                try:
-                    cat = self.columns[columns[j]]['ctype'] (value)
-                except ValueError, e:
-                    cat = -1
-                           message = _("Error loading attribute data. "
-                                       "Record number: %(rec)d. Unable to convert value '%(val)s' in "
-                                       "key column (%(key)s) to integer.\n\n"
-                                       "Details: %(detail)s") % \
-                               { 'rec' : i + 1, 'val' : value,
-                                 'key' : keyColumn, 'detail' : e})
-            j += 1
-        self.itemIndexMap.append(i)
-        if keyId > -1: # load cats only when LoadData() is called first time
-            self.itemCatsMap[i] = cat
-    def OnItemSelected(self, event):
-        """!Item selected. Add item to selected cats..."""
-        #         cat = int(self.GetItemText(event.m_itemIndex))
-        #         if cat not in self.selectedCats:
-        #             self.selectedCats.append(cat)
-        #             self.selectedCats.sort()
-        event.Skip()
-    def OnItemDeselected(self, event):
-        """!Item deselected. Remove item from selected cats..."""
-        #         if cat in self.selectedCats:
-        #             self.selectedCats.remove(cat)
-        event.Skip()
-    def GetSelectedItems(self):
-        """!Return list of selected items (category numbers)"""
-        cats = []
-        item = self.GetFirstSelected()
-        while item != -1:
-            cats.append(self.GetItemText(item))
-            item = self.GetNextSelected(item)
-        return cats
-    def GetColumnText(self, index, col):
-        """!Return column text"""
-        item = self.GetItem(index, col)
-        return item.GetText()
-    def GetListCtrl(self):
-        """!Returt list"""
-        return self
-    def OnGetItemText(self, item, col):
-        """!Get item text"""
-        index = self.itemIndexMap[item]
-        s = self.itemDataMap[index][col]
-        return s
-    def OnGetItemAttr(self, item):
-        """!Get item attributes"""
-        if ( item % 2) == 0:
-            return self.attr2
-        else:
-            return self.attr1
-    def OnColumnMenu(self, event):
-        """!Column heading right mouse button -> pop-up menu"""
-        self._col = event.GetColumn()
-        popupMenu = wx.Menu()
-        if not hasattr (self, "popupID1"):
-            self.popupID1 = wx.NewId()
-            self.popupID2 = wx.NewId()
-            self.popupID3 = wx.NewId()
-            self.popupID4 = wx.NewId()
-            self.popupID5 = wx.NewId()
-            self.popupID6 = wx.NewId()
-            self.popupID7 = wx.NewId()
-            self.popupID8 = wx.NewId()
-            self.popupID9 = wx.NewId()
-            self.popupID10 = wx.NewId()
-            self.popupID11 = wx.NewId()
-            self.popupID12 = wx.NewId()
-        popupMenu.Append(self.popupID1, text = _("Sort ascending"))
-        popupMenu.Append(self.popupID2, text = _("Sort descending"))
-        popupMenu.AppendSeparator()
-        subMenu = wx.Menu()
-        popupMenu.AppendMenu(self.popupID3, _("Calculate (only numeric columns)"),
-                             subMenu)
-        if not self.log.parent.editable or \
-                self.columns[self.GetColumn(self._col).GetText()]['ctype'] not in (types.IntType, types.FloatType):
-            popupMenu.Enable(self.popupID3, False)
-        subMenu.Append(self.popupID4,  text = _("Area size"))
-        subMenu.Append(self.popupID5,  text = _("Line length"))
-        subMenu.Append(self.popupID6,  text = _("Compactness of an area"))
-        subMenu.Append(self.popupID7,  text = _("Fractal dimension of boundary defining a polygon"))
-        subMenu.Append(self.popupID8,  text = _("Perimeter length of an area"))
-        subMenu.Append(self.popupID9,  text = _("Number of features for each category"))
-        subMenu.Append(self.popupID10, text = _("Slope steepness of 3D line"))
-        subMenu.Append(self.popupID11, text = _("Line sinuousity"))
-        subMenu.Append(self.popupID12, text = _("Line azimuth"))
-        self.Bind (wx.EVT_MENU, self.OnColumnSortAsc,  id = self.popupID1)
-        self.Bind (wx.EVT_MENU, self.OnColumnSortDesc, id = self.popupID2)
-        for id in (self.popupID4, self.popupID5, self.popupID6,
-                   self.popupID7, self.popupID8, self.popupID9,
-                   self.popupID10, self.popupID11, self.popupID12):
-            self.Bind(wx.EVT_MENU, self.OnColumnCompute, id = id)
-        self.PopupMenu(popupMenu)
-        popupMenu.Destroy()
-    def OnColumnSort(self, event):
-        """!Column heading left mouse button -> sorting"""
-        self.ColumnSort()
-        event.Skip()
-    def OnColumnSortAsc(self, event):
-        """!Sort values of selected column (ascending)"""
-        self.SortListItems(col = self._col, ascending = True)
-        event.Skip()
-    def OnColumnSortDesc(self, event):
-        """!Sort values of selected column (descending)"""
-        self.SortListItems(col = self._col, ascending = False)
-        event.Skip()
-    def OnColumnCompute(self, event):
-        """!Compute values of selected column"""
-        id = event.GetId()
-        option = None
-        if id == self.popupID4:
-            option = 'area'
-        elif id == self.popupID5:
-            option = 'length'
-        elif id == self.popupID6:
-            option = 'compact'
-        elif id == self.popupID7:
-            option = 'fd'
-        elif id == self.popupID8:
-            option = 'perimeter'
-        elif id == self.popupID9:
-            option = 'count'
-        elif id == self.popupID10:
-            option = 'slope'
-        elif id == self.popupID11:
-            option = 'sinuous'
-        elif id == self.popupID12:
-            option = 'azimuth'
-        if not option:
-            return
-        RunCommand('v.to.db',
-                   parent = self.parent,
-                   layer = self.layer,
-                   option = option,
-                   columns = self.GetColumn(self._col).GetText())
-    def ColumnSort(self):
-        """!Sort values of selected column (self._col)"""
-        # remove duplicated arrow symbol from column header
-        # FIXME: should be done automatically
-        info.m_image = -1
-        for column in range(self.GetColumnCount()):
-            info.m_text = self.GetColumn(column).GetText()
-            self.SetColumn(column, info)
-    def SortItems(self, sorter = cmp):
-        """!Sort items"""
-        items = list(self.itemDataMap.keys())
-        items.sort(self.Sorter)
-        self.itemIndexMap = items
-        # redraw the list
-        self.Refresh()
-    def Sorter(self, key1, key2):
-        colName = self.GetColumn(self._col).GetText()
-        ascending = self._colSortFlag[self._col]
-        try:
-            item1 = self.columns[colName]["ctype"](self.itemDataMap[key1][self._col])
-            item2 = self.columns[colName]["ctype"](self.itemDataMap[key2][self._col])
-            item1 = self.itemDataMap[key1][self._col]
-            item2 = self.itemDataMap[key2][self._col]
-        if type(item1) == types.StringType or type(item2) == types.StringTypes:
-            cmpVal = locale.strcoll(str(item1), str(item2))
-        else:
-            cmpVal = cmp(item1, item2)
-        # If the items are equal then pick something else to make the sort value unique
-        if cmpVal == 0:
-            cmpVal = apply(cmp, self.GetSecondarySortValues(self._col, key1, key2))
-        if ascending:
-            return cmpVal
-        else:
-            return -cmpVal
-    def GetSortImages(self):
-        """!Used by the ColumnSorterMixin, see wx/lib/mixins/listctrl.py"""
-        return (self.sm_dn, self.sm_up)
-    def IsEmpty(self):
-        """!Check if list if empty"""
-        if self.columns:
-            return False
-        return True
-class AttributeManager(wx.Frame):
+class AttributeManager(wx.Frame, DbMgrBase):
     def __init__(self, parent, id = wx.ID_ANY,
                  title = None, vectorName = None, item = None, log = None,
                  selection = None, **kwargs):
@@ -540,108 +56,62 @@
         @param selection name of page to be selected
         @param kwagrs other wx.Frame's arguments
-        self.vectorName = vectorName
-        self.parent     = parent # GMFrame
-        self.treeItem   = item   # item in layer tree
-        if self.parent and self.parent.GetName() == "LayerManager" and \
-                self.treeItem and not self.vectorName:
-            maptree = self.parent.curr_page.maptree
-            name = maptree.GetPyData(self.treeItem)[0]['maplayer'].GetName()
-            self.vectorName = name
-        # vector attributes can be changed only if vector map is in
-        # the current mapset
-        if grass.find_file(name = self.vectorName, element = 'vector')['mapset'] == grass.gisenv()['MAPSET']:
-            self.editable = True
-        else:
-            self.editable = False
-        self.cmdLog = log    # self.parent.goutput
+        try:
+            mapdisplay = self.parent.curr_page.maptree.mapdisplay
+        except:
+            mapdisplay = None
+        DbMgrBase.__init__(self, id = id, mapdisplay = mapdisplay,
+                                 vectorName = vectorName, item = item,
+                                 log = log, statusbar = self,
+                                 **kwargs)
         wx.Frame.__init__(self, parent, id, *kwargs)
         # title
         if not title:
-            self.SetTitle("%s - <%s>" % (_("GRASS GIS Attribute Table Manager"),
-                                         self.vectorName))
-        else:
-            self.SetTitle(title)
+            title = "%s" % _("GRASS GIS Attribute Table Manager - ")
+            if not self.dbMgrData['editable']:
+                title += _("READONLY - ")
+            title += "<%s>" % (self.dbMgrData['vectName'])
+        self.SetTitle(title)
         # icon
         self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_sql.ico'), wx.BITMAP_TYPE_ICO))
         self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
-        try:
-            self.map        = self.parent.curr_page.maptree.Map
-            self.mapdisplay = self.parent.curr_page.maptree.mapdisplay
-        except:
-            self.map = self.mapdisplay = None
-        # status bar log class
-        self.log = Log(self) # -> statusbar
-        # query map layer (if parent (GMFrame) is given)
-        self.qlayer = None
-        # -> layers / tables description
-        self.mapDBInfo = VectorDBInfo(self.vectorName)
-        # sqlbuilder
-        self.builder = None
-        if len(self.mapDBInfo.layers.keys()) == 0:
+        if len(self.dbMgrData['mapDBInfo'].layers.keys()) == 0:
             GMessage(parent = self.parent,
                      message = _("Database connection for vector map <%s> "
                                  "is not defined in DB file. "
                                  "You can define new connection in "
-                                 "'Manage layers' tab.") % self.vectorName)
+                                 "'Manage layers' tab.") % self.dbMgrData['vectName'])
-        # list of command/SQL statements to be performed
-        self.listOfCommands      = []
-        self.listOfSQLStatements = []
         self.CreateStatusBar(number = 1)
-        # set up virtual lists (each layer)
-        ### {layer: list, widgets...}
-        self.layerPage = {}
         self.notebook = GNotebook(self.panel, style = globalvar.FNPageDStyle)
-        if globalvar.hasAgw:
-            dbmStyle = { 'agwStyle' : globalvar.FNPageStyle }
-        else:
-            dbmStyle = { 'style' : globalvar.FNPageStyle }
-        self.browsePage = FN.FlatNotebook(self.panel, id = wx.ID_ANY,
-                                          **dbmStyle)
-        self.notebook.AddPage(page = self.browsePage, text = _("Browse data"),
+        self.CreateDbMgrPage(parent = self, pageName = 'browse')
+        self.notebook.AddPage(page = self.pages['browse'], text = _("Browse data"),
                               name = 'browse')
-        self.browsePage.SetTabAreaColour(globalvar.FNPageColor)
+        self.pages['browse'].SetTabAreaColour(globalvar.FNPageColor)
-        self.manageTablePage = FN.FlatNotebook(self.panel, id = wx.ID_ANY,
-                                               **dbmStyle)
-        self.notebook.AddPage(page = self.manageTablePage, text = _("Manage tables"),
+        self.CreateDbMgrPage(parent = self, pageName = 'manageTable')
+        self.notebook.AddPage(page = self.pages['manageTable'], text = _("Manage tables"),
                               name = 'table')
-        if not self.editable:
-            self.notebook.GetPage(self.notebook.GetPageCount()-1).Enable(False)
-        self.manageTablePage.SetTabAreaColour(globalvar.FNPageColor)
+        self.pages['manageTable'].SetTabAreaColour(globalvar.FNPageColor)
-        self.manageLayerPage = FN.FlatNotebook(self.panel, id = wx.ID_ANY,
-                                               **dbmStyle)
-        self.notebook.AddPage(page = self.manageLayerPage, text = _("Manage layers"),
+        self.CreateDbMgrPage(parent = self, pageName = 'manageLayer')
+        self.notebook.AddPage(page = self.pages['manageLayer'], text = _("Manage layers"),
                               name = 'layers')
-        self.manageLayerPage.SetTabAreaColour(globalvar.FNPageColor)
-        self._createBrowsePage()
-        self._createManageTablePage()
-        self._createManageLayerPage()
         if selection:
             wx.CallAfter(self.notebook.SetSelectionByName, selection)
         else:
@@ -655,10 +125,8 @@
         # events
         self.btnQuit.Bind(wx.EVT_BUTTON,   self.OnCloseWindow)
-        self.btnReload.Bind(wx.EVT_BUTTON, self.OnDataReload)
+        self.btnReload.Bind(wx.EVT_BUTTON, self.pages['browse'].OnDataReload)
         self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
-        self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnLayerPageChanged, self.browsePage)
-        self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnLayerPageChanged, self.manageTablePage)
         self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
         # do layout
@@ -667,406 +135,7 @@
         # self.SetMinSize(self.GetBestSize())
         self.SetSize((700, 550)) # FIXME hard-coded size
         self.SetMinSize(self.GetSize())
-    def _createBrowsePage(self, onlyLayer = -1):
-        """!Create browse tab page"""
-        for layer in self.mapDBInfo.layers.keys():
-            if onlyLayer > 0 and layer != onlyLayer:
-                continue
-            panel = wx.Panel(parent = self.browsePage, id = wx.ID_ANY)
-            #IMPORTANT NOTE: wx.StaticBox MUST be defined BEFORE any of the
-            #   controls that are placed IN the wx.StaticBox, or it will freeze
-            #   on the Mac
-            listBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
-                                   label = " %s " % _("Attribute data - right-click to edit/manage records"))
-            listSizer = wx.StaticBoxSizer(listBox, wx.VERTICAL)
-            win = VirtualAttributeList(panel, self.log,
-                                       self.mapDBInfo, layer)
-            if win.IsEmpty():
-                del panel
-                continue
-            win.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnDataItemActivated)
-            self.layerPage[layer] = {'browsePage': panel.GetId()}
-            label = _("Table")
-                label += _(" (readonly)")
-            self.browsePage.AddPage(page = panel, text = " %d / %s %s" % \
-                                        (layer, label, self.mapDBInfo.layers[layer]['table']))
-            pageSizer = wx.BoxSizer(wx.VERTICAL)
-            # attribute data
-            sqlBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
-                                  label = " %s " % _("SQL Query"))
-            sqlSizer = wx.StaticBoxSizer(sqlBox, wx.VERTICAL)
-            win.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnDataRightUp) #wxMSW
-            win.Bind(wx.EVT_RIGHT_UP,            self.OnDataRightUp) #wxGTK
-            if UserSettings.Get(group = 'atm', key = 'leftDbClick', subkey = 'selection') == 0:
-                win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataItemEdit)
-                win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataItemEdit)
-            else:
-                win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataDrawSelected)
-                win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataDrawSelected)
-            listSizer.Add(item = win, proportion = 1,
-                          flag = wx.EXPAND | wx.ALL,
-                          border = 3)
-            # sql statement box
-            btnApply = wx.Button(parent = panel, id = wx.ID_APPLY)
-            btnApply.SetToolTipString(_("Apply SELECT statement and reload data records"))
-            btnApply.Bind(wx.EVT_BUTTON, self.OnApplySqlStatement)
-            btnSqlBuilder = wx.Button(parent = panel, id = wx.ID_ANY, label = _("SQL Builder"))
-            btnSqlBuilder.Bind(wx.EVT_BUTTON, self.OnBuilder)
-            sqlSimple = wx.RadioButton(parent = panel, id = wx.ID_ANY,
-                                       label = _("Simple"))
-            sqlSimple.SetValue(True)
-            sqlAdvanced = wx.RadioButton(parent = panel, id = wx.ID_ANY,
-                                         label = _("Advanced"))
-            sqlSimple.Bind(wx.EVT_RADIOBUTTON,   self.OnChangeSql)
-            sqlAdvanced.Bind(wx.EVT_RADIOBUTTON, self.OnChangeSql)
-            sqlWhereColumn = wx.ComboBox(parent = panel, id = wx.ID_ANY,
-                                         size = (100,-1),
-                                         style = wx.CB_SIMPLE | wx.CB_READONLY,
-                                         choices = self.mapDBInfo.GetColumns(self.mapDBInfo.layers[layer]['table']))
-            sqlWhereColumn.SetSelection(0)
-            sqlWhereCond = wx.Choice(parent = panel, id = wx.ID_ANY,
-                                     size = (55,-1),
-                                     choices = ['=', '!=', '<', '<=', '>', '>='])
-            sqlWhereValue = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = "",
-                                        style = wx.TE_PROCESS_ENTER)
-            sqlWhereValue.SetToolTipString(_("Example: %s") % "MULTILANE = 'no' AND OBJECTID < 10")
-            sqlStatement = wx.TextCtrl(parent = panel, id = wx.ID_ANY,
-                                       value = "SELECT * FROM %s" % \
-                                           self.mapDBInfo.layers[layer]['table'],
-            sqlStatement.SetToolTipString(_("Example: %s") % "SELECT * FROM roadsmajor WHERE MULTILANE = 'no' AND OBJECTID < 10")
-            sqlWhereValue.Bind(wx.EVT_TEXT_ENTER, self.OnApplySqlStatement)
-            sqlStatement.Bind(wx.EVT_TEXT_ENTER, self.OnApplySqlStatement)
-            sqlLabel = wx.StaticText(parent = panel, id = wx.ID_ANY,
-                                     label = "SELECT * FROM %s WHERE " % \
-                                         self.mapDBInfo.layers[layer]['table'])
-            label_query = wx.StaticText(parent = panel, id = wx.ID_ANY,
-                                        label = "")
-            sqlFlexSizer = wx.FlexGridSizer (cols = 3, hgap = 5, vgap = 5)
-            sqlFlexSizer.AddGrowableCol(1)
-            sqlFlexSizer.Add(item = sqlSimple,
-                             flag = wx.ALIGN_CENTER_VERTICAL)
-            sqlSimpleSizer = wx.BoxSizer(wx.HORIZONTAL)
-            sqlSimpleSizer.Add(item = sqlLabel,
-            sqlSimpleSizer.Add(item = sqlWhereColumn,
-                               flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
-            sqlSimpleSizer.Add(item = sqlWhereCond,
-                               flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
-                               border = 3)
-            sqlSimpleSizer.Add(item = sqlWhereValue, proportion = 1,
-            sqlFlexSizer.Add(item = sqlSimpleSizer,
-                             flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
-            sqlFlexSizer.Add(item = btnApply,
-                             flag = wx.ALIGN_RIGHT)
-            sqlFlexSizer.Add(item = sqlAdvanced,
-            sqlFlexSizer.Add(item = sqlStatement,
-                             flag = wx.EXPAND)
-            sqlFlexSizer.Add(item = btnSqlBuilder,
-            sqlSizer.Add(item = sqlFlexSizer,
-                         flag = wx.ALL | wx.EXPAND,
-                         border = 3)
-            pageSizer.Add(item = listSizer,
-                          proportion = 1,
-                          border = 5)
-            pageSizer.Add(item = sqlSizer,
-                          proportion = 0,
-                          flag = wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.EXPAND,
-                          border = 5)
-            panel.SetSizer(pageSizer)
-            self.layerPage[layer]['data']      = win.GetId()
-            self.layerPage[layer]['simple']    = sqlSimple.GetId()
-            self.layerPage[layer]['advanced']  = sqlAdvanced.GetId()
-            self.layerPage[layer]['whereColumn'] = sqlWhereColumn.GetId()
-            self.layerPage[layer]['whereOperator'] = sqlWhereCond.GetId()
-            self.layerPage[layer]['where']     = sqlWhereValue.GetId()
-            self.layerPage[layer]['builder']   = btnSqlBuilder.GetId()
-            self.layerPage[layer]['statement'] = sqlStatement.GetId()
-        self.browsePage.SetSelection(0) # select first layer
-        try:
-            self.layer = self.mapDBInfo.layers.keys()[0]
-            self.OnChangeSql(None)
-                           self.FindWindowById(self.layerPage[self.layer]['data']).GetItemCount())
-        except (IndexError, KeyError):
-            self.layer = None
-    def _createManageTablePage(self, onlyLayer = -1):
-        """!Create manage page (create/link and alter tables)"""
-                continue
-            if not layer in self.layerPage:
-                continue
-            panel = wx.Panel(parent = self.manageTablePage, id = wx.ID_ANY)
-            self.layerPage[layer]['tablePage'] = panel.GetId()
-            self.manageTablePage.AddPage(page = panel,
-                                         text = " %d / %s %s" % (layer, label,
-                                                               self.mapDBInfo.layers[layer]['table']))
-            # dbInfo
-            dbBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
-                                          label = " %s " % _("Database connection"))
-            dbSizer = wx.StaticBoxSizer(dbBox, wx.VERTICAL)
-            dbSizer.Add(item = createDbInfoDesc(panel, self.mapDBInfo, layer),
-                        proportion = 1,
-                        border = 3)
-            # table description
-            table = self.mapDBInfo.layers[layer]['table']
-            tableBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
-                                    label = " %s " % _("Table <%s> - right-click to delete column(s)") % table)
-            tableSizer = wx.StaticBoxSizer(tableBox, wx.VERTICAL)
-            tlist = self._createTableDesc(panel, table)
-            tlist.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnTableRightUp) #wxMSW
-            tlist.Bind(wx.EVT_RIGHT_UP,            self.OnTableRightUp) #wxGTK
-            self.layerPage[layer]['tableData'] = tlist.GetId()
-            # manage columns (add)
-            addBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
-                                  label = " %s " % _("Add column"))
-            addSizer = wx.StaticBoxSizer(addBox, wx.HORIZONTAL)
-            column = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = '',
-                                 size = (150, -1), style = wx.TE_PROCESS_ENTER)
-            column.Bind(wx.EVT_TEXT,       self.OnTableAddColumnName)
-            column.Bind(wx.EVT_TEXT_ENTER, self.OnTableItemAdd)
-            self.layerPage[layer]['addColName'] = column.GetId()
-            addSizer.Add(item =  wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Column")),
-                         flag = wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
-                         border = 5)
-            addSizer.Add(item = column, proportion = 1,
-                         border = 5)
-            ctype = wx.Choice (parent = panel, id = wx.ID_ANY,
-                               choices = ["integer",
-                                          "double",
-                                          "varchar",
-                                          "date"]) # FIXME
-            ctype.SetSelection(0)
-            ctype.Bind(wx.EVT_CHOICE, self.OnTableChangeType)
-            self.layerPage[layer]['addColType'] = ctype.GetId()
-            addSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Type")),
-                         border = 5)
-            addSizer.Add(item = ctype,
-                         border = 5)
-            length = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (65, -1),
-                                 initial = 250,
-                                 min = 1, max = 1e6)
-            length.Enable(False)
-            self.layerPage[layer]['addColLength'] = length.GetId()
-            addSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Length")),
-                         border = 5)
-            addSizer.Add(item = length,
-                         border = 5)
-            btnAddCol = wx.Button(parent = panel, id = wx.ID_ADD)
-            btnAddCol.Bind(wx.EVT_BUTTON, self.OnTableItemAdd)
-            btnAddCol.Enable(False)
-            self.layerPage[layer]['addColButton'] = btnAddCol.GetId()
-            addSizer.Add(item = btnAddCol, flag = wx.ALL | wx.ALIGN_RIGHT | wx.EXPAND,
-                         border = 3)
-            # manage columns (rename)
-            renameBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
-                                     label = " %s " % _("Rename column"))
-            renameSizer = wx.StaticBoxSizer(renameBox, wx.HORIZONTAL)
-            column = wx.ComboBox(parent = panel, id = wx.ID_ANY, size = (150, -1),
-                                 choices = self.mapDBInfo.GetColumns(table))
-            column.SetSelection(0)
-            self.layerPage[layer]['renameCol'] = column.GetId()
-            renameSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Column")),
-                            border = 5)
-            renameSizer.Add(item = column, proportion = 1,
-                            border = 5)
-            columnTo = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = '',
-            columnTo.Bind(wx.EVT_TEXT,       self.OnTableRenameColumnName)
-            columnTo.Bind(wx.EVT_TEXT_ENTER, self.OnTableItemChange)
-            self.layerPage[layer]['renameColTo'] = columnTo.GetId()
-            renameSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("To")),
-                            border = 5)
-            renameSizer.Add(item = columnTo, proportion = 1,
-                            border = 5)
-            btnRenameCol = wx.Button(parent = panel, id = wx.ID_ANY, label = _("&Rename"))
-            btnRenameCol.Bind(wx.EVT_BUTTON, self.OnTableItemChange)
-            btnRenameCol.Enable(False)
-            self.layerPage[layer]['renameColButton'] = btnRenameCol.GetId()
-            renameSizer.Add(item = btnRenameCol, flag = wx.ALL | wx.ALIGN_RIGHT | wx.EXPAND,
-                            border = 3)
-            tableSizer.Add(item = tlist,
-                           proportion = 1,
-                           border = 3)
-            pageSizer.Add(item=dbSizer,
-                          proportion = 0,
-                          border = 3)
-            pageSizer.Add(item = tableSizer,
-                          flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
-                          proportion = 1,
-                          border = 3)
-            pageSizer.Add(item = addSizer,
-                          proportion = 0,
-                          border = 3)
-            pageSizer.Add(item = renameSizer,
-                          proportion = 0,
-                          border = 3)
-        self.manageTablePage.SetSelection(0) # select first layer
-        try:
-        except IndexError:
-            self.layer = None
-    def _createTableDesc(self, parent, table):
-        """!Create list with table description"""
-        tlist = TableListCtrl(parent = parent, id = wx.ID_ANY,
-                             table = self.mapDBInfo.tables[table],
-                             columns = self.mapDBInfo.GetColumns(table))
-        tlist.Populate()
-        # sorter
-        # itemDataMap = list.Populate()
-        # listmix.ColumnSorterMixin.__init__(self, 2)
-        return tlist
-    def _createManageLayerPage(self):
-        """!Create manage page"""
-        splitterWin = wx.SplitterWindow(parent = self.manageLayerPage, id = wx.ID_ANY)
-        splitterWin.SetMinimumPaneSize(100)
-        label = _("Layers of vector map")
-        self.manageLayerPage.AddPage(page = splitterWin,
-                                     text = label) # dummy page
-        # list of layers
-        panelList = wx.Panel(parent = splitterWin, id = wx.ID_ANY)
-        panelListSizer  = wx.BoxSizer(wx.VERTICAL)
-        layerBox = wx.StaticBox(parent = panelList, id = wx.ID_ANY,
-                                label = " %s " % _("List of layers"))
-        layerSizer = wx.StaticBoxSizer(layerBox, wx.VERTICAL)
-        self.layerList = self._createLayerDesc(panelList)
-        self.layerList.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnLayerRightUp) #wxMSW
-        self.layerList.Bind(wx.EVT_RIGHT_UP,            self.OnLayerRightUp) #wxGTK
-        layerSizer.Add(item = self.layerList,
-                       proportion = 1,
-                       border = 3)
-        panelListSizer.Add(item = layerSizer,
-                           proportion = 1,
-                           border = 3)
-        panelList.SetSizer(panelListSizer)
-        # manage part
-        panelManage = wx.Panel(parent = splitterWin, id = wx.ID_ANY)
-        manageSizer = wx.BoxSizer(wx.VERTICAL)
-        self.manageLayerBook = LayerBook(parent = panelManage, id = wx.ID_ANY,
-                                         parentDialog = self)
-        manageSizer.Add(item = self.manageLayerBook,
-                        proportion = 1,
-                        border = 5)
-        panelManage.SetSizer(manageSizer)
-        splitterWin.SplitHorizontally(panelList, panelManage, 100)
-        splitterWin.Fit()
-    def _createLayerDesc(self, parent):
-        """!Create list of linked layers"""
-        tlist = LayerListCtrl(parent = parent, id = wx.ID_ANY,
-                             layers = self.mapDBInfo.layers)
-        tlist.Populate()
-        # sorter
-        return tlist
     def _layout(self):
         """!Do layout"""
         # frame body
@@ -1086,761 +155,30 @@
         self.panel.SetSizer(mainSizer)
         mainSizer.Fit(self.panel)
         self.Layout()
+    def OnCloseWindow(self, event):
+        """!Cancel button pressed"""
+        if self.parent and self.parent.GetName() == 'LayerManager':
+            # deregister ATM
+            self.parent.dialogs['atm'].remove(self)
+        if not isinstance(event, wx.CloseEvent):
+            self.Destroy()
-    def OnDataRightUp(self, event):
-        """!Table description area, context menu"""
-        if not hasattr(self, "popupDataID1"):
-            self.popupDataID1 = wx.NewId()
-            self.popupDataID2 = wx.NewId()
-            self.popupDataID3 = wx.NewId()
-            self.popupDataID4 = wx.NewId()
-            self.popupDataID5 = wx.NewId()
-            self.popupDataID6 = wx.NewId()
-            self.popupDataID7 = wx.NewId()
-            self.popupDataID8 = wx.NewId()
-            self.popupDataID9 = wx.NewId()
-            self.popupDataID10 = wx.NewId()
-            self.popupDataID11 = wx.NewId()
-            self.Bind(wx.EVT_MENU, self.OnDataItemEdit,       id = self.popupDataID1)
-            self.Bind(wx.EVT_MENU, self.OnDataItemAdd,        id = self.popupDataID2)
-            self.Bind(wx.EVT_MENU, self.OnDataItemDelete,     id = self.popupDataID3)
-            self.Bind(wx.EVT_MENU, self.OnDataItemDeleteAll,  id = self.popupDataID4)
-            self.Bind(wx.EVT_MENU, self.OnDataSelectAll,      id = self.popupDataID5)
-            self.Bind(wx.EVT_MENU, self.OnDataSelectNone,     id = self.popupDataID6)
-            self.Bind(wx.EVT_MENU, self.OnDataDrawSelected,   id = self.popupDataID7)
-            self.Bind(wx.EVT_MENU, self.OnDataDrawSelectedZoom, id = self.popupDataID8)
-            self.Bind(wx.EVT_MENU, self.OnExtractSelected,    id = self.popupDataID9)
-            self.Bind(wx.EVT_MENU, self.OnDeleteSelected,     id = self.popupDataID11)
-            self.Bind(wx.EVT_MENU, self.OnDataReload,         id = self.popupDataID10)
-        tlist = self.FindWindowById(self.layerPage[self.layer]['data'])
-        # generate popup-menu
-        menu = wx.Menu()
-        menu.Append(self.popupDataID1, _("Edit selected record"))
-        selected = tlist.GetFirstSelected()
-        if not self.editable or selected == -1 or tlist.GetNextSelected(selected) != -1:
-            menu.Enable(self.popupDataID1, False)
-        menu.Append(self.popupDataID2, _("Insert new record"))
-        menu.Append(self.popupDataID3, _("Delete selected record(s)"))
-        menu.Append(self.popupDataID4, _("Delete all records"))
-            menu.Enable(self.popupDataID2, False)
-            menu.Enable(self.popupDataID3, False)
-            menu.Enable(self.popupDataID4, False)
-        menu.AppendSeparator()
-        menu.Append(self.popupDataID5, _("Select all"))
-        menu.Append(self.popupDataID6, _("Deselect all"))
-        menu.Append(self.popupDataID7, _("Highlight selected features"))
-        menu.Append(self.popupDataID8, _("Highlight selected features and zoom"))
-        if not self.map or len(tlist.GetSelectedItems()) == 0:
-            menu.Enable(self.popupDataID7, False)
-            menu.Enable(self.popupDataID8, False)
-        menu.Append(self.popupDataID9, _("Extract selected features"))
-        menu.Append(self.popupDataID11, _("Delete selected features"))
-            menu.Enable(self.popupDataID11, False)
-        if tlist.GetFirstSelected() == -1:
-            menu.Enable(self.popupDataID9, False)
-        menu.Append(self.popupDataID10, _("Reload"))
-        self.PopupMenu(menu)
-        menu.Destroy()
-        # update statusbar
-                           tlist.GetItemCount())
-    def OnDataItemDelete(self, event):
-        """!Delete selected item(s) from the tlist (layer/category pair)"""
-        dlist = self.FindWindowById(self.layerPage[self.layer]['data'])
-        item = dlist.GetFirstSelected()
-        table    = self.mapDBInfo.layers[self.layer]["table"]
-        key      = self.mapDBInfo.layers[self.layer]["key"]
-        indeces = []
-        # collect SQL statements
-        while item != -1:
-            index = dlist.itemIndexMap[item]
-            indeces.append(index)
-            cat = dlist.itemCatsMap[index]
-            self.listOfSQLStatements.append('DELETE FROM %s WHERE %s=%d' % \
-                                                (table, key, cat))
-            item = dlist.GetNextSelected(item)
-        if UserSettings.Get(group = 'atm', key = 'askOnDeleteRec', subkey = 'enabled'):
-            deleteDialog = wx.MessageBox(parent = self,
-                                         message = _("Selected data records (%d) will be permanently deleted "
-                                                   "from table. Do you want to delete them?") % \
-                                             (len(self.listOfSQLStatements)),
-                                         caption = _("Delete records"),
-                                         style = wx.YES_NO | wx.CENTRE)
-            if deleteDialog != wx.YES:
-                return False
-        # restore maps
-        i = 0
-        indexTemp = copy.copy(dlist.itemIndexMap)
-        dlist.itemIndexMap = []
-        dataTemp = copy.deepcopy(dlist.itemDataMap)
-        dlist.itemDataMap = {}
-        catsTemp = copy.deepcopy(dlist.itemCatsMap)
-        dlist.itemCatsMap = {}
-        i = 0
-        for index in indexTemp:
-            if index in indeces:
-                continue
-            dlist.itemIndexMap.append(i)
-            dlist.itemDataMap[i] = dataTemp[index]
-            dlist.itemCatsMap[i] = catsTemp[index]
-            i += 1
-        dlist.SetItemCount(len(dlist.itemIndexMap))
-        # deselect items
-        while item != -1:
-            dlist.SetItemState(item, 0, wx.LIST_STATE_SELECTED | wx.LIST_STATE_FOCUSED)
-        # submit SQL statements
-        self.ApplyCommands()
-        return True
-    def OnDataItemDeleteAll(self, event):
-        """!Delete all items from the list"""
-                                         message = _("All data records (%d) will be permanently deleted "
-                                             (len(dlist.itemIndexMap)),
-                return
-        dlist.DeleteAllItems()
-        dlist.SetItemCount(0)
-        self.listOfSQLStatements.append('DELETE FROM %s' % table)
         event.Skip()
-    def _drawSelected(self, zoom):
-        """!Highlight selected features"""
-        if not self.map or not self.mapdisplay:
-            return
-        cats = map(int, tlist.GetSelectedItems())
-        digitToolbar = None
-        if 'vdigit' in self.mapdisplay.toolbars:
-            digitToolbar = self.mapdisplay.toolbars['vdigit']
-        if digitToolbar and digitToolbar.GetLayer() and \
-                digitToolbar.GetLayer().GetName() == self.vectorName:
-            display = self.mapdisplay.GetMapWindow().GetDisplay()
-            display.SetSelected(cats, layer = self.layer)
-            if zoom:
-                n, s, w, e = display.GetRegionSelected()
-                self.mapdisplay.Map.GetRegion(n = n, s = s, w = w, e = e,
-                                              update = True)
-        else:
-            # add map layer with higlighted vector features
-            self.AddQueryMapLayer() # -> self.qlayer
-            # set opacity based on queried layer
-                    self.treeItem:
-                opacity = maptree.GetPyData(self.treeItem)[0]['maplayer'].GetOpacity(float = True)
-                self.qlayer.SetOpacity(opacity)
-            if zoom:
-                where = ''
-                for range in ListOfCatsToRange(cats).split(','):
-                    if '-' in range:
-                        min, max = range.split('-')
-                        where += '%s >= %d and %s <= %d or ' % \
-                            (keyColumn, int(min),
-                             keyColumn, int(max))
-                    else:
-                        where += '%s = %d or ' % (keyColumn, int(range))
-                where = where.rstrip('or ')
-                select = RunCommand('v.db.select',
-                                    parent = self,
-                                    read = True,
-                                    quiet = True,
-                                    flags = 'r',
-                                    layer = int(self.layer),
-                                    where = where)
-                region = {}
-                for line in select.splitlines():
-                    key, value = line.split('=')
-                    region[key.strip()] = float(value.strip())
-                nsdist = ewdist = 0
-                renderer = self.mapdisplay.GetMap()
-                nsdist = 10 * ((renderer.GetCurrentRegion()['n'] - renderer.GetCurrentRegion()['s']) /
-                        renderer.height)
-                ewdist = 10 * ((renderer.GetCurrentRegion()['e'] - renderer.GetCurrentRegion()['w']) /
-                        renderer.width)
-                north = region['n'] + nsdist
-                south = region['s'] - nsdist
-                west = region['w'] - ewdist
-                east = region['e'] + ewdist
-                renderer.GetRegion(n = north, s = south, w = west, e = east, update = True)
-                self.mapdisplay.GetMapWindow().ZoomHistory(n = north, s = south, w = west, e = east)
-        if zoom:
-            self.mapdisplay.Map.AdjustRegion()           # adjust resolution
-            self.mapdisplay.Map.AlignExtentFromDisplay() # adjust extent
-            self.mapdisplay.MapWindow.UpdateMap(render = True,  renderVector = True)
-        else:
-            self.mapdisplay.MapWindow.UpdateMap(render = False, renderVector = True)
-    def OnDataDrawSelected(self, event):
-        """!Reload table description"""
-        self._drawSelected(zoom = False)
-        event.Skip()
-    def OnDataDrawSelectedZoom(self, event):
-        self._drawSelected(zoom = True)
-        event.Skip()
-    def OnDataItemAdd(self, event):
-        """!Add new record to the attribute table"""
-        table     = self.mapDBInfo.layers[self.layer]['table']
-        # (column name, value)
-        data = []
-        # collect names of all visible columns
-        columnName = []
-        for i in range(tlist.GetColumnCount()):
-            columnName.append(tlist.GetColumn(i).GetText())
-        # maximal category number
-        if len(tlist.itemCatsMap.values()) > 0:
-            maxCat = max(tlist.itemCatsMap.values())
-        else:
-            maxCat = 0 # starting category '1'
-        # key column must be always presented
-        if keyColumn not in columnName:
-            columnName.insert(0, keyColumn) # insert key column on first position
-            data.append((keyColumn, str(maxCat + 1)))
-            missingKey = True
-        else:
-            missingKey = False
-        # add other visible columns
-        colIdx = 0
-        keyId = -1
-        for col in columnName:
-            ctype = self.mapDBInfo.tables[table][col]['ctype']
-            ctypeStr = self.mapDBInfo.tables[table][col]['type']
-            if col == keyColumn: # key
-                if missingKey is False:
-                    data.append((col, ctype, ctypeStr, str(maxCat + 1)))
-                    keyId = colIdx
-            else:
-                data.append((col, ctype, ctypeStr, ''))
-            colIdx += 1
-        dlg = ModifyTableRecord(parent = self,
-                                title = _("Insert new record"),
-                                data = data, keyEditable = (keyId, True))
-        if dlg.ShowModal() == wx.ID_OK:
-            try: # get category number
-                cat = int(dlg.GetValues(columns = [keyColumn])[0])
-            except:
-                cat = -1
-            try:
-                if cat in tlist.itemCatsMap.values():
-                    raise ValueError(_("Record with category number %d "
-                                       "already exists in the table.") % cat)
-                values = dlg.GetValues() # values (need to be casted)
-                columnsString = ''
-                valuesString   = ''
-                for i in range(len(values)):
-                    if len(values[i]) == 0: # NULL
-                        if columnName[i] == keyColumn:
-                            raise ValueError(_("Category number (column %s)"
-                                               " is missing.") % keyColumn)
-                        else:
-                            continue
-                    try:
-                        if tlist.columns[columnName[i]]['ctype'] == int:
-                            # values[i] is stored as text.
-                            value = float(values[i])
-                        else:
-                            value = values[i]
-                        values[i] = tlist.columns[columnName[i]]['ctype'] (value)
-                    except:
-                        raise ValueError(_("Value '%(value)s' needs to be entered as %(type)s.") %
-                                         {'value' : str(values[i]),
-                                          'type' : tlist.columns[columnName[i]]['type']})
-                    columnsString += '%s,' % columnName[i]
-                    if tlist.columns[columnName[i]]['ctype'] == str:
-                        valuesString += "'%s'," % values[i]
-                    else:
-                        valuesString += "%s," % values[i]
-            except ValueError, err:
-                       message = _("Unable to insert new record.\n%s") % err,
-                       showTraceback = False)
-                self.OnDataItemAdd(event)
-                return
-            # remove category if need
-            if missingKey is True:
-                del values[0]
-            # add new item to the tlist
-            if len(tlist.itemIndexMap) > 0:
-                index = max(tlist.itemIndexMap) + 1
-            else:
-                index = 0
-            tlist.itemIndexMap.append(index)
-            tlist.itemDataMap[index] = values
-            tlist.itemCatsMap[index] = cat
-            tlist.SetItemCount(tlist.GetItemCount() + 1)
-            self.listOfSQLStatements.append('INSERT INTO %s (%s) VALUES(%s)' % \
-                                                (table,
-                                                 columnsString.strip(','),
-                                                 valuesString.strip(',')))
-    def OnDataItemEdit(self, event):
-        """!Edit selected record of the attribute table"""
-        item      = tlist.GetFirstSelected()
-        if item == -1:
-            return
-        cat       = tlist.itemCatsMap[tlist.itemIndexMap[item]]
-        data = []
-        columnName = []
-            data.append((keyColumn, str(cat)))
-            keyId = 0
-            missingKey = True
-        else:
-        for i in range(len(columnName)):
-            ctype = self.mapDBInfo.tables[table][columnName[i]]['ctype']
-            ctypeStr = self.mapDBInfo.tables[table][columnName[i]]['type']
-            if columnName[i] == keyColumn: # key
-                    data.append((columnName[i], ctype, ctypeStr, str(cat)))
-                    keyId = i
-            else:
-                    value = tlist.GetItem(item, i-1).GetText()
-                else:
-                    value = tlist.GetItem(item, i).GetText()
-                data.append((columnName[i], ctype, ctypeStr, value))
-                                title = _("Update existing record"),
-                                data = data, keyEditable = (keyId, False))
-            values = dlg.GetValues() # string
-            updateString = ''
-            try:
-                    if i == keyId: # skip key column
-                        continue
-                    if tlist.GetItem(item, i).GetText() != values[i]:
-                        if len(values[i]) > 0:
-                            try:
-                                    idx = i - 1
-                                else:
-                                    idx = i
-                                if tlist.columns[columnName[i]]['ctype'] != types.StringType:
-                                    else:
-                                        value = values[i]
-                                    tlist.itemDataMap[item][idx] = \
-                                        tlist.columns[columnName[i]]['ctype'] (value)
-                                else:
-                                    tlist.itemDataMap[item][idx] = values[i]
-                            except:
-                                raise ValueError(_("Value '%(value)s' needs to be entered as %(type)s.") % \
-                                updateString += "%s='%s'," % (columnName[i], values[i])
-                            else:
-                                updateString += "%s=%s," % (columnName[i], values[i])
-                        else: # NULL
-                            updateString += "%s=NULL," % (columnName[i])
-                       message = _("Unable to update existing record.\n%s") % err,
-                self.OnDataItemEdit(event)
-                return
-            if len(updateString) > 0:
-                self.listOfSQLStatements.append('UPDATE %s SET %s WHERE %s=%d' % \
-                                                    (table, updateString.strip(','),
-                                                     keyColumn, cat))
-            tlist.Update(self.mapDBInfo)
-    def OnDataReload(self, event):
-        """!Reload tlist of records"""
-        self.OnApplySqlStatement(None)
-    def OnDataSelectAll(self, event):
-        """!Select all items"""
-        item = -1
-        while True:
-            item = tlist.GetNextItem(item)
-            if item == -1:
-                break
-            tlist.SetItemState(item, wx.LIST_STATE_SELECTED, wx.LIST_STATE_SELECTED)
-        event.Skip()
-    def OnDataSelectNone(self, event):
-        """!Deselect items"""
-        item = -1
-        while True:
-            item = tlist.GetNextItem(item, wx.LIST_STATE_SELECTED)
-            if item == -1:
-                break
-            tlist.SetItemState(item, 0, wx.LIST_STATE_SELECTED | wx.LIST_STATE_FOCUSED)
-        event.Skip()
-    def OnTableChangeType(self, event):
-        """!Data type for new column changed. Enable or disable
-        data length widget"""
-        win = self.FindWindowById(self.layerPage[self.layer]['addColLength'])
-        if event.GetString() == "varchar":
-            win.Enable(True)
-        else:
-            win.Enable(False)
-    def OnTableRenameColumnName(self, event):
-        """!Editing column name to be added to the table"""
-        btn  = self.FindWindowById(self.layerPage[self.layer]['renameColButton'])
-        col  = self.FindWindowById(self.layerPage[self.layer]['renameCol'])
-        colTo = self.FindWindowById(self.layerPage[self.layer]['renameColTo'])
-        if len(col.GetValue()) > 0 and len(colTo.GetValue()) > 0:
-            btn.Enable(True)
-        else:
-            btn.Enable(False)
-        event.Skip()
-    def OnTableAddColumnName(self, event):
-        btn = self.FindWindowById(self.layerPage[self.layer]['addColButton'])
-        if len(event.GetString()) > 0:
-            btn.Enable(True)
-        else:
-            btn.Enable(False)
-        event.Skip()
-    def OnTableItemChange(self, event):
-        """!Rename column in the table"""
-        tlist   = self.FindWindowById(self.layerPage[self.layer]['tableData'])
-        name   = self.FindWindowById(self.layerPage[self.layer]['renameCol']).GetValue()
-        nameTo = self.FindWindowById(self.layerPage[self.layer]['renameColTo']).GetValue()
-        if not name or not nameTo:
-                   message = _("Unable to rename column. "
-                               "No column name defined."))
-            return
-        else:
-            item = tlist.FindItem(start = -1, str = name)
-            if item > -1:
-                if tlist.FindItem(start = -1, str = nameTo) > -1:
-                           message = _("Unable to rename column <%(column)s> to "
-                                       "<%(columnTo)s>. Column already exists "
-                               {'column' : name, 'columnTo' : nameTo,
-                                'table' : table})
-                    return
-                else:
-                    tlist.SetItemText(item, nameTo)
-                    self.listOfCommands.append(('v.db.renamecolumn',
-                                                { 'map'    : self.vectorName,
-                                                  'layer'  : self.layer,
-                                                  'column' : '%s,%s' % (name, nameTo) }
-            else:
-                                   "Column <%(column)s> doesn't exist in the table <%(table)s>.") %
-                       {'column' : name, 'table' : table})
-                return
-        # apply changes
-        # update widgets
-        self.FindWindowById(self.layerPage[self.layer]['renameCol']).SetItems(self.mapDBInfo.GetColumns(table))
-        self.FindWindowById(self.layerPage[self.layer]['renameCol']).SetSelection(0)
-        self.FindWindowById(self.layerPage[self.layer]['renameColTo']).SetValue('')
-        event.Skip()
-    def OnTableRightUp(self, event):
-        if not hasattr(self, "popupTableID"):
-            self.popupTableID1 = wx.NewId()
-            self.popupTableID2 = wx.NewId()
-            self.popupTableID3 = wx.NewId()
-            self.Bind(wx.EVT_MENU, self.OnTableItemDelete,    id = self.popupTableID1)
-            self.Bind(wx.EVT_MENU, self.OnTableItemDeleteAll, id = self.popupTableID2)
-            self.Bind(wx.EVT_MENU, self.OnTableReload,        id = self.popupTableID3)
-        menu = wx.Menu()
-        menu.Append(self.popupTableID1, _("Drop selected column"))
-        if self.FindWindowById(self.layerPage[self.layer]['tableData']).GetFirstSelected() == -1:
-            menu.Enable(self.popupTableID1, False)
-        menu.Append(self.popupTableID2, _("Drop all columns"))
-        menu.Append(self.popupTableID3, _("Reload"))
-        menu.Destroy()
-    def OnTableItemDelete(self, event):
-        """!Delete selected item(s) from the list"""
-                                         message = _("Selected column '%s' will PERMANENTLY removed "
-                                                   "from table. Do you want to drop the column?") % \
-                                             (tlist.GetItemText(item)),
-                                         caption = _("Drop column(s)"),
-                return False
-        while item != -1:
-            self.listOfCommands.append(('v.db.dropcolumn',
-                                          'column' : tlist.GetItemText(item) }
-            tlist.DeleteItem(item)
-        # apply changes
-        # update widgets
-        event.Skip()
-    def OnTableItemDeleteAll(self, event):
-        cols      = self.mapDBInfo.GetColumns(table)
-        if keyColumn in cols:
-            cols.remove(keyColumn)
-                                         message = _("Selected columns\n%s\nwill PERMANENTLY removed "
-                                                   "from table. Do you want to drop the columns?") % \
-                                             ('\n'.join(cols)),
-                return False
-        for col in cols:
-                                          'column' : col }
-        self.FindWindowById(self.layerPage[self.layer]['tableData']).DeleteAllItems()
-        # apply changes
-        # update widgets
-        event.Skip()
-    def OnTableReload(self, event = None):
-        self.FindWindowById(self.layerPage[self.layer]['tableData']).Populate(update = True)
-    def OnTableItemAdd(self, event):
-        """!Add new column to the table"""
-        name = self.FindWindowById(self.layerPage[self.layer]['addColName']).GetValue()
-        if not name:
-                   message = _("Unable to add column to the table. "
-            return
-        ctype = self.FindWindowById(self.layerPage[self.layer]['addColType']). \
-            GetStringSelection()
-        # cast type if needed
-        if ctype == 'double':
-            ctype = 'double precision'
-        if ctype == 'varchar':
-            length = int(self.FindWindowById(self.layerPage[self.layer]['addColLength']). \
-                             GetValue())
-        else:
-            length = '' # FIXME
-        # add item to the list of table columns
-        # check for duplicate items
-        if tlist.FindItem(start = -1, str = name) > -1:
-                   message = _("Column <%(column)s> already exists in table <%(table)s>.") % \
-                       {'column' : name, 'table' : self.mapDBInfo.layers[self.layer]["table"]}
-            return
-        index = tlist.InsertStringItem(sys.maxint, str(name))
-        tlist.SetStringItem(index, 0, str(name))
-        tlist.SetStringItem(index, 1, str(ctype))
-        tlist.SetStringItem(index, 2, str(length))
-        # add v.db.addcolumn command to the list
-            ctype += ' (%d)' % length
-        self.listOfCommands.append(('v.db.addcolumn',
-                                      'columns' : '%s %s' % (name, ctype) }
-        # apply changes
-        # update widgets
-        self.FindWindowById(self.layerPage[self.layer]['addColName']).SetValue('')
-        event.Skip()
-    def OnLayerPageChanged(self, event):
-        """!Layer tab changed"""
-        pageNum = event.GetSelection()
-        self.layer = self.mapDBInfo.layers.keys()[pageNum]
-        try:
-            idCol = self.layerPage[self.layer]['whereColumn']
-        except KeyError:
-            idCol = None
-        try:
-                               self.FindWindowById(self.layerPage[self.layer]['data']).\
-                               GetItemCount())
-        except:
-            pass
-        if idCol:
-            winCol = self.FindWindowById(idCol)
-            self.mapDBInfo.GetColumns(table)
-        event.Skip()
     def OnPageChanged(self, event):
+        """!On page in ATM is changed"""
         try:
-            id = self.layerPage[self.layer]['data']
+            if self.pages["browse"]:
+                selPage = self.pages["browse"].selLayer
+                id = self.pages["browse"].layerPage[selPage]['data']
+            else:
+                id = None
         except KeyError:
             id = None
-        if event.GetSelection() == 0 and id:
+        if event.GetSelection() == self.notebook.GetPageIndexByName('browse') and id:
             win = self.FindWindowById(id)
             if win:
                 self.log.write(_("Number of loaded records: %d") % win.GetItemCount())
@@ -1851,1240 +189,17 @@
             self.log.write("")
             self.btnReload.Enable(False)
-        event.Skip()
-    def OnLayerRightUp(self, event):
-        """!Layer description area, context menu"""
-        pass
+        event.Skip()
-    def OnChangeSql(self, event):
-        """!Switch simple/advanced sql statement"""
-        if self.FindWindowById(self.layerPage[self.layer]['simple']).GetValue():
-            self.FindWindowById(self.layerPage[self.layer]['where']).Enable(True)
-            self.FindWindowById(self.layerPage[self.layer]['statement']).Enable(False)
-            self.FindWindowById(self.layerPage[self.layer]['builder']).Enable(False)
-        else:
-            self.FindWindowById(self.layerPage[self.layer]['where']).Enable(False)
-            self.FindWindowById(self.layerPage[self.layer]['statement']).Enable(True)
-            self.FindWindowById(self.layerPage[self.layer]['builder']).Enable(True)
-    def ApplyCommands(self):
-        """!Apply changes"""
-        # perform GRASS commands (e.g. v.db.addcolumn)
-        wx.BeginBusyCursor()
-        if len(self.listOfCommands) > 0:
-            for cmd in self.listOfCommands:
-                RunCommand(prog = cmd[0],
-                           quiet = True,
-                           parent = self,
-                           **cmd[1])
-            # update table description
-            tlist.Update(table = self.mapDBInfo.tables[table],
-            self.OnTableReload(None)
-            # update data tlist
-            # reset list of commands
-        # perform SQL non-select statements (e.g. 'delete from table where cat=1')
-        if len(self.listOfSQLStatements) > 0:
-            sqlFile = tempfile.NamedTemporaryFile(mode = "wt")
-            for sql in self.listOfSQLStatements:
-                enc = UserSettings.Get(group = 'atm', key = 'encoding', subkey = 'value')
-                if not enc and 'GRASS_DB_ENCODING' in os.environ:
-                    enc = os.environ['GRASS_DB_ENCODING']
-                if enc:
-                    sqlFile.file.write(sql.encode(enc) + ';')
-                else:
-                    sqlFile.file.write(sql + ';')
-                sqlFile.file.write(os.linesep)
-                sqlFile.file.flush()
-            driver   = self.mapDBInfo.layers[self.layer]["driver"]
-            database = self.mapDBInfo.layers[self.layer]["database"]
-            Debug.msg(3, 'AttributeManger.ApplyCommands(): %s' %
-                      ';'.join(["%s" % s for s in self.listOfSQLStatements]))
-            RunCommand('db.execute',
-                       parent = self,
-                       input = sqlFile.name,
-                       driver = driver,
-                       database = database)
-            # reset list of statements
-        wx.EndBusyCursor()
-    def OnApplySqlStatement(self, event):
-        """!Apply simple/advanced sql statement"""
-        keyColumn = -1 # index of key column
-        listWin = self.FindWindowById(self.layerPage[self.layer]['data'])
-        sql = None
-        win = self.FindWindowById(self.layerPage[self.layer]['simple'])
-        if not win:
-            return
-        if win.GetValue():
-            # simple sql statement
-            whereCol = self.FindWindowById(self.layerPage[self.layer]['whereColumn']).GetStringSelection()
-            whereOpe = self.FindWindowById(self.layerPage[self.layer]['whereOperator']).GetStringSelection()
-            whereVal = self.FindWindowById(self.layerPage[self.layer]['where']).GetValue().strip()
-            try:
-                if len(whereVal) > 0:
-                    keyColumn = listWin.LoadData(self.layer, where = whereCol + whereOpe + whereVal)
-                else:
-                    keyColumn = listWin.LoadData(self.layer)
-                       message = _("Loading attribute data failed.\n\n%s") % e.value)
-                self.FindWindowById(self.layerPage[self.layer]['where']).SetValue('')
-        else:
-            # advanced sql statement
-            win = self.FindWindowById(self.layerPage[self.layer]['statement'])
-            try:
-                cols, where = self.ValidateSelectStatement(win.GetValue())
-                if cols is None and where is None:
-                    sql = win.GetValue()
-            except TypeError:
-                       message = _("Loading attribute data failed.\n"
-                                   "Invalid SQL select statement.\n\n%s") % win.GetValue())
-                win.SetValue("SELECT * FROM %s" % self.mapDBInfo.layers[self.layer]['table'])
-                cols = None
-                where = None
-            if cols or where or sql:
-                try:
-                    keyColumn = listWin.LoadData(self.layer, columns = cols,
-                                                 where = where, sql = sql)
-        # sort by key column
-        if sql and 'order by' in sql.lower():
-            pass # don't order by key column
-        else:
-                listWin.SortListItems(col = keyColumn, ascending = True)
-            else:
-                listWin.SortListItems(col = 0, ascending = True)
-    def ValidateSelectStatement(self, statement):
-        """!Validate SQL select statement
-        @return (columns, where)
-        @return None on error
-        if statement[0:7].lower() != 'select ':
-            return None
-        cols = ''
-        index = 7
-        for c in statement[index:]:
-            if c == ' ':
-                break
-            cols += c
-            index += 1
-        if cols == '*':
-            cols = None
-        else:
-            cols = cols.split(',')
-        tablelen = len(self.mapDBInfo.layers[self.layer]['table'])
-        if statement[index+1:index+6].lower() != 'from ' or \
-                statement[index+6:index+6+tablelen] != '%s' % \
-                (self.mapDBInfo.layers[self.layer]['table']):
-            return None
-        if len(statement[index+7+tablelen:]) > 0:
-            index = statement.lower().find('where ')
-            if index > -1:
-                where = statement[index+6:]
-            else:
-                where = None
-        else:
-            where = None
-        return (cols, where)
-    def OnCloseWindow(self, event):
-        """!Cancel button pressed"""
-        if self.parent and self.parent.GetName() == 'LayerManager':
-            # deregister ATM
-            self.parent.dialogs['atm'].remove(self)
-        if not isinstance(event, wx.CloseEvent):
-            self.Destroy()
-        event.Skip()
-    def OnBuilder(self,event):
-        """!SQL Builder button pressed -> show the SQLBuilder dialog"""
-        if not self.builder:
-            self.builder = SQLFrame(parent = self, id = wx.ID_ANY,
-                                    title = _("SQL Builder"),
-                                    vectmap = self.vectorName,
-                                    evtHandler = self.OnBuilderEvt)
-            self.builder.Show()
-        else:
-            self.builder.Raise()
-    def OnBuilderEvt(self, event):
-        if event == 'apply':
-            sqlstr = self.builder.GetSQLStatement()
-            self.FindWindowById(self.layerPage[self.layer]['statement']).SetValue(sqlstr)
-            # apply query
-            self.listOfSQLStatements.append(sqlstr)
-            # close builder on apply
-            if self.builder.CloseOnApply():
-        elif event == 'close':
     def OnTextEnter(self, event):
         pass
-    def OnDataItemActivated(self, event):
-        """!Item activated, highlight selected item"""
-        self.OnDataDrawSelected(event)
-        event.Skip()
-    def OnExtractSelected(self, event):
-        """!Extract vector objects selected in attribute browse window
-        to new vector map
-        # cats = tlist.selectedCats[:]
-        cats = tlist.GetSelectedItems()
-        if len(cats) == 0:
-            GMessage(parent = self,
-                     message = _('Nothing to extract.'))
-            return
-        else:
-            # dialog to get file name
-            dlg = CreateNewVector(parent = self, title = _('Extract selected features'),
-                                  log = self.cmdLog,
-                                  cmd = (('v.extract',
-                                          { 'input' : self.vectorName,
-                                            'cats' : ListOfCatsToRange(cats) },
-                                          'output')),
-                                  disableTable = True)
-            if not dlg:
-                return
-            name = dlg.GetName(full = True)
-            if name and dlg.IsChecked('add'):
-                # add layer to map layer tree
-                self.parent.curr_page.maptree.AddLayer(ltype = 'vector',
-                                                       lname = name,
-                                                       lcmd = ['d.vect', 'map=%s' % name])
-            dlg.Destroy()
-    def OnDeleteSelected(self, event):
-        """!Delete vector objects selected in attribute browse window
-        (attribures and geometry)
-                     message = _('Nothing to delete.'))
-        display = None
-                display.SetSelected(map(int, cats), layer = self.layer)
-        if self.OnDataItemDelete(None):
-            if display:
-                self.mapdisplay.GetMapWindow().digit.DeleteSelectedLines()
-            else:
-                RunCommand('v.edit',
-                           parent = self,
-                           quiet = True,
-                           map = self.vectorName,
-                           tool = 'delete',
-                           cats = ListOfCatsToRange(cats))
-    def AddQueryMapLayer(self):
-        """!Redraw a map
-        Return True if map has been redrawn, False if no map is given
-        cats = {
-            self.layer : tlist.GetSelectedItems()
-        if self.mapdisplay.Map.GetLayerIndex(self.qlayer) < 0:
-        if self.qlayer:
-            self.qlayer.SetCmd(self.mapdisplay.AddTmpVectorMapLayer(self.vectorName, cats, addLayer = False))
-        else:
-            self.qlayer = self.mapdisplay.AddTmpVectorMapLayer(self.vectorName, cats)
-        return self.qlayer
     def UpdateDialog(self, layer):
         """!Updates dialog layout for given layer"""
-        # delete page
-        if layer in self.mapDBInfo.layers.keys():
-            # delete page
-            # draging pages disallowed
-            # if self.browsePage.GetPageText(page).replace('Layer ', '').strip() == str(layer):
-            # self.browsePage.DeletePage(page)
-            # break
-            self.browsePage.DeletePage(self.mapDBInfo.layers.keys().index(layer))
-            self.manageTablePage.DeletePage(self.mapDBInfo.layers.keys().index(layer))
-            # set current page selection
-            self.notebook.SetSelectionByName('layers')
-        # fetch fresh db info
+        DbMgrBase.UpdateDialog(self, layer = layer)
+        # set current page selection
+        self.notebook.SetSelectionByName('layers')
-        # add new page
-            # 'browse data' page
-            self._createBrowsePage(layer)
-            # 'manage tables' page
-            self._createManageTablePage(layer)
-        # 'manage layers' page
-        # update list of layers
-        self.layerList.Update(self.mapDBInfo.layers)
-        self.layerList.Populate(update = True)
-        # update selected widgets
-        listOfLayers = map(str, self.mapDBInfo.layers.keys())
-        ### delete layer page
-        self.manageLayerBook.deleteLayer.SetItems(listOfLayers)
-        if len(listOfLayers) > 0:
-            self.manageLayerBook.deleteLayer.SetStringSelection(listOfLayers[0])
-            tableName = self.mapDBInfo.layers[int(listOfLayers[0])]['table']
-            maxLayer = max(self.mapDBInfo.layers.keys())
-        else:
-            tableName = ''
-            maxLayer = 0
-        self.manageLayerBook.deleteTable.SetLabel( \
-            _('Drop also linked attribute table (%s)') % \
-                tableName)
-        ### add layer page
-        self.manageLayerBook.addLayerWidgets['layer'][1].SetValue(\
-            maxLayer+1)
-        ### modify layer
-        self.manageLayerBook.modifyLayerWidgets['layer'][1].SetItems(listOfLayers)
-        self.manageLayerBook.OnChangeLayer(event = None)
-    def GetVectorName(self):
-        """!Get vector name"""
-        return self.vectorName
-        listWin = self.FindWindowById(self.layerPage[layer]['data'])
-        return listWin.LoadData(layer, columns, where, sql)
-class TableListCtrl(wx.ListCtrl,
-                    listmix.ListCtrlAutoWidthMixin):
-                    #                    listmix.TextEditMixin):
-    """!Table description list"""
-    def __init__(self, parent, id, table, columns, pos = wx.DefaultPosition,
-                 size = wx.DefaultSize):
-        self.table   = table
-        self.columns = columns
-        wx.ListCtrl.__init__(self, parent, id, pos, size,
-                             style = wx.LC_REPORT | wx.LC_HRULES | wx.LC_VRULES |
-                             wx.BORDER_NONE)
-        # listmix.TextEditMixin.__init__(self)
-    def Update(self, table, columns):
-        """!Update column description"""
-    def Populate(self, update = False):
-        """!Populate the list"""
-        itemData = {} # requested by sorter
-        if not update:
-            headings = [_("Column name"), _("Data type"), _("Data length")]
-            i = 0
-            for h in headings:
-                self.InsertColumn(col = i, heading = h)
-                i += 1
-            self.SetColumnWidth(col = 0, width = 350)
-            self.SetColumnWidth(col = 1, width = 175)
-        else:
-        i = 0
-        for column in self.columns:
-            index = self.InsertStringItem(sys.maxint, str(column))
-            self.SetStringItem(index, 0, str(column))
-            self.SetStringItem(index, 1, str(self.table[column]['type']))
-            self.SetStringItem(index, 2, str(self.table[column]['length']))
-            self.SetItemData(index, i)
-            itemData[i] = (str(column),
-                           str(self.table[column]['type']),
-                           int(self.table[column]['length']))
-            i = i + 1
-        return itemData
-class LayerListCtrl(wx.ListCtrl,
-                    # listmix.ColumnSorterMixin):
-    """!Layer description list"""
-    def __init__(self, parent, id, layers,
-                 pos = wx.DefaultPosition,
-        self.layers = layers
-                             wx.BORDER_NONE)
-    def Update(self, layers):
-        """!Update description"""
-        if not update:
-            headings = [_("Layer"),  _("Driver"), _("Database"), _("Table"), _("Key")]
-            i = 0
-                i += 1
-        else:
-        i = 0
-        for layer in self.layers.keys():
-            index = self.InsertStringItem(sys.maxint, str(layer))
-            self.SetStringItem(index, 0, str(layer))
-            database = str(self.layers[layer]['database'])
-            driver   = str(self.layers[layer]['driver'])
-            table    = str(self.layers[layer]['table'])
-            key      = str(self.layers[layer]['key'])
-            self.SetStringItem(index, 1, driver)
-            self.SetStringItem(index, 2, database)
-            self.SetStringItem(index, 3, table)
-            self.SetStringItem(index, 4, key)
-            itemData[i] = (str(layer),
-                           driver,
-                           database,
-                           table,
-                           key)
-            i += 1
-            self.SetColumnWidth(col = i, width = wx.LIST_AUTOSIZE)
-            if self.GetColumnWidth(col = i) < 60:
-                self.SetColumnWidth(col = i, width = 60)
-        return itemData
-class LayerBook(wx.Notebook):
-    """!Manage layers (add, delete, modify)"""
-                 parentDialog,
-                 style = wx.BK_DEFAULT):
-        wx.Notebook.__init__(self, parent, id, style = style)
-        self.parentDialog = parentDialog
-        self.mapDBInfo    = self.parentDialog.mapDBInfo
-        # drivers
-        drivers = RunCommand('db.drivers',
-                             quiet = True,
-                             read = True,
-                             flags = 'p')
-        self.listOfDrivers = []
-        for drv in drivers.splitlines():
-            self.listOfDrivers.append(drv.strip())
-        # get default values
-        self.defaultConnect = {}
-        connect = RunCommand('db.connect',
-                             flags = 'p',
-                             read = True,
-                             quiet = True)
-        for line in connect.splitlines():
-            item, value = line.split(':', 1)
-            self.defaultConnect[item.strip()] = value.strip()
-        if len(self.defaultConnect['driver']) == 0 or \
-               len(self.defaultConnect['database']) == 0:
-            GWarning(parent = self.parent,
-                     message = _("Unknown default DB connection. "
-                                 "Please define DB connection using db.connect module."))
-        self.defaultTables = self._getTables(self.defaultConnect['driver'],
-                                             self.defaultConnect['database'])
-        try:
-            self.defaultColumns = self._getColumns(self.defaultConnect['driver'],
-                                                    self.defaultConnect['database'],
-                                                    self.defaultTables[0])
-            self.defaultColumns = []
-        self._createAddPage()
-        self._createDeletePage()
-        self._createModifyPage()
-    def _createAddPage(self):
-        """!Add new layer"""
-        self.addPanel = wx.Panel(parent = self, id = wx.ID_ANY)
-        self.AddPage(page = self.addPanel, text = _("Add layer"))
-        try:
-            maxLayer = 0
-        # layer description
-        layerBox = wx.StaticBox (parent = self.addPanel, id = wx.ID_ANY,
-                                 label = " %s " % (_("Layer description")))
-        # list of layer widgets (label, value)
-        self.addLayerWidgets = {'layer':
-                                    (wx.StaticText(parent = self.addPanel, id = wx.ID_ANY,
-                                                   label = '%s:' % _("Layer")),
-                                     wx.SpinCtrl(parent = self.addPanel, id = wx.ID_ANY, size = (65, -1),
-                                                 initial = maxLayer+1,
-                                                 min = 1, max = 1e6)),
-                                'driver':
-                                                   label = '%s:' % _("Driver")),
-                                     wx.Choice(parent = self.addPanel, id = wx.ID_ANY, size = (200, -1),
-                                               choices = self.listOfDrivers)),
-                                'database':
-                                                   label = '%s:' % _("Database")),
-                                     wx.TextCtrl(parent = self.addPanel, id = wx.ID_ANY,
-                                                 value = '',
-                                                 style = wx.TE_PROCESS_ENTER)),
-                                'table':
-                                                   label = '%s:' % _("Table")),
-                                               choices = self.defaultTables)),
-                                'key':
-                                                   label = '%s:' % _("Key column")),
-                                               choices = self.defaultColumns)),
-                                'addCat':
-                                    (wx.CheckBox(parent = self.addPanel, id = wx.ID_ANY,
-                                                 label = _("Insert record for each category into table")),
-                                     None),
-        # set default values for widgets
-        self.addLayerWidgets['driver'][1].SetStringSelection(self.defaultConnect['driver'])
-        self.addLayerWidgets['database'][1].SetValue(self.defaultConnect['database'])
-        self.addLayerWidgets['table'][1].SetSelection(0)
-        self.addLayerWidgets['key'][1].SetSelection(0)
-        # events
-        self.addLayerWidgets['driver'][1].Bind(wx.EVT_CHOICE, self.OnDriverChanged)
-        self.addLayerWidgets['database'][1].Bind(wx.EVT_TEXT_ENTER, self.OnDatabaseChanged)
-        self.addLayerWidgets['table'][1].Bind(wx.EVT_CHOICE, self.OnTableChanged)
-        # tooltips
-        self.addLayerWidgets['addCat'][0].SetToolTipString(_("You need to add categories "
-                                                             "by v.category module."))
-        tableBox = wx.StaticBox (parent = self.addPanel, id = wx.ID_ANY,
-                                 label = " %s " % (_("Table description")))
-        # list of table widgets
-        keyCol = UserSettings.Get(group = 'atm', key = 'keycolumn', subkey = 'value')
-        self.tableWidgets = {'table': (wx.StaticText(parent = self.addPanel, id = wx.ID_ANY,
-                                                     label = '%s:' % _("Table name")),
-                                                   value = '',
-                             'key': (wx.StaticText(parent = self.addPanel, id = wx.ID_ANY,
-                                                 value = keyCol,
-                                                 style = wx.TE_PROCESS_ENTER))}
-        # events
-        self.tableWidgets['table'][1].Bind(wx.EVT_TEXT_ENTER, self.OnCreateTable)
-        self.tableWidgets['key'][1].Bind(wx.EVT_TEXT_ENTER, self.OnCreateTable)
-        btnTable   = wx.Button(self.addPanel, wx.ID_ANY, _("&Create table"),
-                             size = (125,-1))
-        btnTable.Bind(wx.EVT_BUTTON, self.OnCreateTable)
-        btnLayer   = wx.Button(self.addPanel, wx.ID_ANY, _("&Add layer"),
-                             size = (125,-1))
-        btnLayer.Bind(wx.EVT_BUTTON, self.OnAddLayer)
-        btnDefault = wx.Button(self.addPanel, wx.ID_ANY, _("&Set default"),
-                               size = (125,-1))
-        btnDefault.Bind(wx.EVT_BUTTON, self.OnSetDefault)
-        # do layout
-        pageSizer = wx.BoxSizer(wx.HORIZONTAL)
-        # data area
-        dataSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
-        dataSizer.AddGrowableCol(1)
-        row = 0
-        for key in ('layer', 'driver', 'database', 'table', 'key', 'addCat'):
-            label, value = self.addLayerWidgets[key]
-            if not value:
-                span = (1, 2)
-            else:
-                span = (1, 1)
-            dataSizer.Add(item = label,
-                          flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0),
-                          span = span)
-            if not value:
-                row += 1
-                continue
-            if key == 'layer':
-                style = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT
-            else:
-                style = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND
-            dataSizer.Add(item = value,
-                          flag = style, pos = (row, 1))
-            row += 1
-        layerSizer.Add(item = dataSizer,
-                       proportion = 1,
-                       border = 5)
-        btnSizer = wx.BoxSizer(wx.HORIZONTAL)
-        btnSizer.Add(item = btnDefault,
-                     proportion = 0,
-                     flag = wx.ALL | wx.ALIGN_LEFT,
-                     border = 5)
-        btnSizer.Add(item = (5, 5),
-                     proportion = 1,
-                     border = 5)
-        btnSizer.Add(item = btnLayer,
-                     proportion = 0,
-                     flag = wx.ALL | wx.ALIGN_RIGHT,
-                     border = 5)
-        layerSizer.Add(item = btnSizer,
-                       proportion = 0,
-                       border = 0)
-        # data area
-        dataSizer = wx.FlexGridSizer(cols = 2, hgap = 5, vgap = 5)
-        for key in ['table', 'key']:
-            label, value = self.tableWidgets[key]
-        tableSizer.Add(item = dataSizer,
-                       proportion = 1,
-                       border = 5)
-        tableSizer.Add(item = btnTable,
-                       proportion = 0,
-                       flag = wx.ALL | wx.ALIGN_BOTTOM | wx.ALIGN_RIGHT,
-                       border = 5)
-        pageSizer.Add(item = layerSizer,
-                      proportion = 3,
-                      border = 3)
-                      proportion = 2,
-                      flag = wx.TOP | wx.BOTTOM | wx.RIGHT | wx.EXPAND,
-                      border = 3)
-        layerSizer.SetVirtualSizeHints(self.addPanel)
-        self.addPanel.SetAutoLayout(True)
-        self.addPanel.SetSizer(pageSizer)
-        pageSizer.Fit(self.addPanel)
-    def _createDeletePage(self):
-        """!Delete layer"""
-        self.deletePanel = wx.Panel(parent = self, id = wx.ID_ANY)
-        self.AddPage(page = self.deletePanel, text = _("Remove layer"))
-        label = wx.StaticText(parent = self.deletePanel, id = wx.ID_ANY,
-                              label = '%s:' % _("Layer to remove"))
-        self.deleteLayer = wx.ComboBox(parent = self.deletePanel, id = wx.ID_ANY, size = (100, -1),
-                                       choices = map(str, self.mapDBInfo.layers.keys()))
-        self.deleteLayer.SetSelection(0)
-        self.deleteLayer.Bind(wx.EVT_COMBOBOX, self.OnChangeLayer)
-        try:
-            tableName = self.mapDBInfo.layers[int(self.deleteLayer.GetStringSelection())]['table']
-        except ValueError:
-            tableName = ''
-        self.deleteTable = wx.CheckBox(parent = self.deletePanel, id = wx.ID_ANY,
-                                       label = _('Drop also linked attribute table (%s)') % \
-                                       tableName)
-        if tableName == '':
-            self.deleteLayer.Enable(False)
-            self.deleteTable.Enable(False)
-        btnDelete   = wx.Button(self.deletePanel, wx.ID_DELETE, _("&Remove layer"),
-                                size = (125,-1))
-        btnDelete.Bind(wx.EVT_BUTTON, self.OnDeleteLayer)
-        # do layout
-        dataSizer = wx.BoxSizer(wx.VERTICAL)
-        flexSizer = wx.FlexGridSizer(cols = 2, hgap = 5, vgap = 5)
-        flexSizer.AddGrowableCol(2)
-        flexSizer.Add(item = label,
-        flexSizer.Add(item = self.deleteLayer,
-        dataSizer.Add(item = flexSizer,
-                      proportion = 0,
-                      border = 1)
-        dataSizer.Add(item = self.deleteTable,
-                      proportion = 0,
-                      border = 1)
-        pageSizer.Add(item = dataSizer,
-                      proportion = 1,
-                      border = 5)
-        pageSizer.Add(item = btnDelete,
-                      proportion = 0,
-                      border = 5)
-        self.deletePanel.SetSizer(pageSizer)
-    def _createModifyPage(self):
-        """!Modify layer"""
-        self.modifyPanel = wx.Panel(parent = self, id = wx.ID_ANY)
-        self.AddPage(page = self.modifyPanel, text = _("Modify layer"))
-        self.modifyLayerWidgets = {'layer':
-                                       (wx.StaticText(parent = self.modifyPanel, id = wx.ID_ANY,
-                                        wx.ComboBox(parent = self.modifyPanel, id = wx.ID_ANY,
-                                                    size = (100, -1),
-        self.mapDBInfo.layers.keys()))),
-                                   'driver':
-                                        wx.Choice(parent = self.modifyPanel, id = wx.ID_ANY,
-                                                  size = (200, -1),
-                                   'database':
-                                        wx.TextCtrl(parent = self.modifyPanel, id = wx.ID_ANY,
-                                                    value = '', size = (350, -1),
-                                   'table':
-                                                  size = (200, -1),
-                                   'key':
-                                                  size = (200, -1),
-                                                  choices = self.defaultColumns))}
-        self.modifyLayerWidgets['layer'][1].SetSelection(0)
-        try:
-            layer = int(self.modifyLayerWidgets['layer'][1].GetStringSelection())
-            layer = None
-            for label in self.modifyLayerWidgets.keys():
-                self.modifyLayerWidgets[label][1].Enable(False)
-        if layer:
-            driver   = self.mapDBInfo.layers[layer]['driver']
-            database = self.mapDBInfo.layers[layer]['database']
-            listOfColumns = self._getColumns(driver, database, table)
-            self.modifyLayerWidgets['driver'][1].SetStringSelection(driver)
-            self.modifyLayerWidgets['database'][1].SetValue(database)
-            if table in self.modifyLayerWidgets['table'][1].GetItems():
-                self.modifyLayerWidgets['table'][1].SetStringSelection(table)
-            else:
-                if self.defaultConnect['schema'] != '':
-                    table = self.defaultConnect['schema'] + table # try with default schema
-                else:
-                    table = 'public.' + table # try with 'public' schema
-            self.modifyLayerWidgets['key'][1].SetItems(listOfColumns)
-            self.modifyLayerWidgets['key'][1].SetSelection(0)
-        # events
-        self.modifyLayerWidgets['layer'][1].Bind(wx.EVT_COMBOBOX, self.OnChangeLayer)
-        # self.modifyLayerWidgets['driver'][1].Bind(wx.EVT_CHOICE, self.OnDriverChanged)
-        # self.modifyLayerWidgets['database'][1].Bind(wx.EVT_TEXT_ENTER, self.OnDatabaseChanged)
-        # self.modifyLayerWidgets['table'][1].Bind(wx.EVT_CHOICE, self.OnTableChanged)
-        btnModify = wx.Button(self.modifyPanel, wx.ID_DELETE, _("&Modify layer"),
-                              size = (125,-1))
-        btnModify.Bind(wx.EVT_BUTTON, self.OnModifyLayer)
-        # do layout
-        # data area
-        for key in ('layer', 'driver', 'database', 'table', 'key'):
-            label, value = self.modifyLayerWidgets[key]
-                              flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT)
-            else:
-                      proportion = 1,
-                      border = 5)
-        pageSizer.Add(item = btnModify,
-                      proportion = 0,
-                      border = 5)
-        self.modifyPanel.SetSizer(pageSizer)
-    def _getTables(self, driver, database):
-        """!Get list of tables for given driver and database"""
-        tables = []
-        ret = RunCommand('db.tables',
-                         parent = self,
-                         read = True,
-                         flags = 'p',
-                         driver = driver,
-        if ret is None:
-            GError(parent = self,
-                   message = _("Unable to get list of tables.\n"
-                               "Please use db.connect to set database parameters."))
-            return tables
-        for table in ret.splitlines():
-            tables.append(table)
-        return tables
-    def _getColumns(self, driver, database, table):
-        """!Get list of column of given table"""
-        columns = []
-        ret = RunCommand('db.columns',
-                         parent = self,
-                         quiet = True,
-                         read = True,
-                         driver = driver,
-                         database = database,
-                         table = table)
-        if ret == None:
-            return columns
-        for column in ret.splitlines():
-            columns.append(column)
-        return columns
-    def OnDriverChanged(self, event):
-        """!Driver selection changed, update list of tables"""
-        driver = event.GetString()
-        database = self.addLayerWidgets['database'][1].GetValue()
-        winTable = self.addLayerWidgets['table'][1]
-        winKey   = self.addLayerWidgets['key'][1]
-        tables   = self._getTables(driver, database)
-        winTable.SetItems(tables)
-        winTable.SetSelection(0)
-        if len(tables) == 0:
-            winKey.SetItems([])
-        event.Skip()
-    def OnDatabaseChanged(self, event):
-        """!Database selection changed, update list of tables"""
-        event.Skip()
-    def OnTableChanged(self, event):
-        """!Table name changed, update list of columns"""
-        driver   = self.addLayerWidgets['driver'][1].GetStringSelection()
-        table    = event.GetString()
-        win  = self.addLayerWidgets['key'][1]
-        cols = self._getColumns(driver, database, table)
-        win.SetItems(cols)
-        win.SetSelection(0)
-        event.Skip()
-    def OnSetDefault(self, event):
-        """!Set default values"""
-        table    = self.addLayerWidgets['table'][1]
-        key      = self.addLayerWidgets['key'][1]
-        driver.SetStringSelection(self.defaultConnect['driver'])
-        database.SetValue(self.defaultConnect['database'])
-        tables = self._getTables(self.defaultConnect['driver'],
-        table.SetItems(tables)
-        table.SetSelection(0)
-            key.SetItems([])
-        else:
-            cols = self._getColumns(self.defaultConnect['driver'],
-                                     tables[0])
-            key.SetItems(cols)
-            key.SetSelection(0)
-        event.Skip()
-    def OnCreateTable(self, event):
-        """!Create new table (name and key column given)"""
-        table    = self.tableWidgets['table'][1].GetValue()
-        key      = self.tableWidgets['key'][1].GetValue()
-        if not table or not key:
-                   message = _("Unable to create new table. "
-                               "Table name or key column name is missing."))
-            return
-        if table in self.addLayerWidgets['table'][1].GetItems():
-                               "Table <%s> already exists in the database.") % table)
-            return
-        # create table
-        sql = 'CREATE TABLE %s (%s INTEGER)' % (table, key)
-                   quiet = True,
-                   parent = self,
-                   stdin = sql,
-                   input = '-',
-                   driver = driver,
-        # update list of tables
-        tableList = self.addLayerWidgets['table'][1]
-        tableList.SetItems(self._getTables(driver, database))
-        tableList.SetStringSelection(table)
-        # update key column selection
-        keyList = self.addLayerWidgets['key'][1]
-        keyList.SetItems(self._getColumns(driver, database, table))
-        keyList.SetStringSelection(key)
-        event.Skip()
-    def OnAddLayer(self, event):
-        """!Add new layer to vector map"""
-        layer    = int(self.addLayerWidgets['layer'][1].GetValue())
-        layerWin = self.addLayerWidgets['layer'][1]
-        table    = self.addLayerWidgets['table'][1].GetStringSelection()
-        key      = self.addLayerWidgets['key'][1].GetStringSelection()
-                   message = _("Unable to add new layer to vector map <%(vector)s>. "
-                               "Layer %(layer)d already exists.") % \
-                       {'vector' : self.mapDBInfo.map, 'layer' : layer})
-            return
-        # add new layer
-        ret = RunCommand('v.db.connect',
-                         parent = self,
-                         quiet = True,
-                         map = self.mapDBInfo.map,
-                         driver = driver,
-                         table = table,
-                         key = key,
-                         layer = layer)
-        # insert records into table if required
-        if self.addLayerWidgets['addCat'][0].IsChecked():
-            RunCommand('v.to.db',
-                       parent = self,
-                       quiet = True,
-                       layer = layer,
-                       qlayer = layer,
-                       option = 'cat',
-                       columns = key)
-        if ret == 0:
-            # update dialog (only for new layer)
-            self.parentDialog.UpdateDialog(layer = layer)
-            # update db info
-            # increase layer number
-            layerWin.SetValue(layer+1)
-        if len(self.mapDBInfo.layers.keys()) == 1:
-            # first layer add --- enable previously disabled widgets
-            self.deleteLayer.Enable()
-            self.deleteTable.Enable()
-                self.modifyLayerWidgets[label][1].Enable()
-    def OnDeleteLayer(self, event):
-        try:
-            layer = int(self.deleteLayer.GetValue())
-        except:
-            return
-        RunCommand('v.db.connect',
-                   parent = self,
-                   flags = 'd',
-                   layer = layer)
-        # drop also table linked to layer which is deleted
-        if self.deleteTable.IsChecked():
-            sql      = 'DROP TABLE %s' % (table)
-                       parent = self,
-                       stdin = sql,
-                       quiet = True,
-                       driver = driver,
-        # update dialog
-        # update db info
-        if len(self.mapDBInfo.layers.keys()) == 0:
-            # disable selected widgets
-        event.Skip()
-    def OnChangeLayer(self, event):
-        """!Layer number of layer to be deleted is changed"""
-        try:
-            layer = int(event.GetString())
-        except:
-            try:
-                layer = self.mapDBInfo.layers.keys()[0]
-            except:
-                return
-        if self.GetCurrentPage() == self.modifyPanel:
-        else:
-            self.deleteTable.SetLabel(_('Drop also linked attribute table (%s)') % \
-        if event:
-            event.Skip()
-    def OnModifyLayer(self, event):
-        """!Modify layer connection settings"""
-        modify = False
-        if self.modifyLayerWidgets['driver'][1].GetStringSelection() != \
-                self.mapDBInfo.layers[layer]['driver'] or \
-                self.modifyLayerWidgets['database'][1].GetStringSelection() != \
-                self.mapDBInfo.layers[layer]['database'] or \
-                self.modifyLayerWidgets['table'][1].GetStringSelection() != \
-                self.mapDBInfo.layers[layer]['table'] or \
-                self.modifyLayerWidgets['key'][1].GetStringSelection() != \
-                self.mapDBInfo.layers[layer]['key']:
-            modify = True
-        if modify:
-            # delete layer
-                       parent = self,
-                       quiet = True,
-                       flag = 'd',
-                       layer = layer)
-            # add modified layer
-                       quiet = True,
-                       driver = self.modifyLayerWidgets['driver'][1].GetStringSelection(),
-                       database = self.modifyLayerWidgets['database'][1].GetValue(),
-                       table = self.modifyLayerWidgets['table'][1].GetStringSelection(),
-                       key = self.modifyLayerWidgets['key'][1].GetStringSelection(),
-                       layer = int(layer))
-            # update db info
-        event.Skip()
 def main(argv = None):
     import gettext
     gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
Modified: grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
--- grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py	2012-08-12 18:06:36 UTC (rev 52640)
+++ grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py	2012-08-12 19:11:18 UTC (rev 52641)
@@ -1,17 +1,19 @@
 @package dbmgr.sqlbuilder
- at brief GRASS SQL Builder
+ at brief GRASS SQL Select/Update Builder
 Classes:
- - sqlbuilder::SQLFrame
+ - sqlbuilder::SQLBuilder
+ - sqlbuilder::SQLBuilderSelect
+ - sqlbuilder::SQLBuilderUpdate
 Usage:
 @code
 python sqlbuilder.py vector_map
 @endcode
-(C) 2007-2009, 2011 by the GRASS Development Team
+(C) 2007-2009, 2011-2012 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -19,6 +21,7 @@
 @author Jachym Cepicky <jachym.cepicky gmail.com> (original author)
 @author Martin Landa <landa.martin gmail.com>
 @author Hamish Bowman <hamish_b yahoo com>
+ at author Refactoring, SQLBUilderUpdate by Stepan Turek <stepan.turek seznam.cz> (GSoC 2012, mentor: Martin Landa)
 import os
@@ -29,27 +32,25 @@
 from core import globalvar
 import wx
-from core.gcmd   import RunCommand, GError
+from core.gcmd   import RunCommand, GError, GMessage
 from dbmgr.vinfo import createDbInfoDesc, VectorDBInfo
 import grass.script as grass
-class SQLFrame(wx.Frame):
-    """!SQL Frame class"""
-    def __init__(self, parent, title, vectmap, id = wx.ID_ANY,
-                 layer = 1, qtype = "select", evtHandler = None):
+class SQLBuilder(wx.Frame):
+    """!SQLBuider class
+    Base class for classes, which builds SQL statements.
+    def __init__(self, parent, title, vectmap, modeChoices, id = wx.ID_ANY,
+                 layer = 1):
         wx.Frame.__init__(self, parent, id, title)
         self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_sql.ico'),
                              wx.BITMAP_TYPE_ICO))
         self.parent = parent
-        self.evtHandler = evtHandler
         # variables
         self.vectmap = vectmap # fullname
         if not "@" in self.vectmap:
             self.vectmap = grass.find_file(self.vectmap, element = 'vector')['fullname']
@@ -61,25 +62,19 @@
         self.tablename = self.dbInfo.GetTable(self.layer)
         self.driver, self.database = self.dbInfo.GetDbSettings(self.layer)
-        self.qtype = qtype      # type of query: SELECT, UPDATE, DELETE, ...
         self.colvalues = []     # array with unique values in selected column
-        # set dialog title
-        self.SetTitle(_("GRASS SQL Builder (%(type)s): vector map <%(map)s>") % \
-                          { 'type' : self.qtype.upper(), 'map' : self.vectmap })
         self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
         # statusbar
         self.statusbar = self.CreateStatusBar(number=1)
-        self.statusbar.SetStatusText(_("SQL statement not verified"), 0)
-        self._doLayout()
+        self._doLayout(modeChoices)
-    def _doLayout(self):
+    def _doLayout(self, modeChoices):
         """!Do dialog layout"""
-        pagesizer = wx.BoxSizer(wx.VERTICAL)
+        self.pagesizer = wx.BoxSizer(wx.VERTICAL)
         # dbInfo
@@ -102,10 +97,8 @@
         self.text_sql = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
                                     value = '', size = (-1, 50),
                                     style=wx.TE_MULTILINE)
-        if self.qtype.lower() == "select":
-            self.text_sql.SetValue("SELECT * FROM %s" % self.tablename)
         self.text_sql.SetInsertionPointEnd()
-        self.text_sql.SetToolTipString(_("Example: %s") % "SELECT * FROM roadsmajor WHERE MULTILANE = 'no' OR OBJECTID < 10")
         wx.CallAfter(self.text_sql.SetFocus)
         sqlboxsizer.Add(item = self.text_sql, flag = wx.EXPAND)
@@ -115,15 +108,12 @@
         self.btn_clear  = wx.Button(parent = self.panel, id = wx.ID_CLEAR)
         self.btn_clear.SetToolTipString(_("Set SQL statement to default"))
-        self.btn_verify = wx.Button(parent = self.panel, id = wx.ID_ANY,
-                                    label = _("Verify"))
-        self.btn_verify.SetToolTipString(_("Verify SQL statement"))
         self.btn_apply  = wx.Button(parent = self.panel, id = wx.ID_APPLY)
         self.btn_apply.SetToolTipString(_("Apply SQL statement and close the dialog"))
         self.btn_close  = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
         self.btn_close.SetToolTipString(_("Close the dialog"))
-        self.btn_lv = { 'is'    : ['=', ],
+        self.btn_logic = { 'is' : ['=', ],
                         'isnot' : ['!=', ],
                         'like'  : ['LIKE', ],
                         'gt'    : ['>', ],
@@ -135,39 +125,41 @@
                         'and'   : ['AND', ],
                         'brac'  : ['()', ],
                         'prc'   : ['%', ] }
-        for key, value in self.btn_lv.iteritems():
-            btn = wx.Button(parent = self.panel, id = wx.ID_ANY,
+        self.btn_logicpanel = wx.Panel(parent = self.panel, id = wx.ID_ANY)
+        for key, value in self.btn_logic.iteritems():
+            btn = wx.Button(parent = self.btn_logicpanel, id = wx.ID_ANY,
                             label = value[0])
-            self.btn_lv[key].append(btn.GetId())
+            self.btn_logic[key].append(btn.GetId())
+        self.buttonsizer = wx.FlexGridSizer(cols = 4, hgap = 5, vgap = 5)
+        self.buttonsizer.Add(item = self.btn_clear)
+        self.buttonsizer.Add(item = self.btn_apply)
+        self.buttonsizer.Add(item = self.btn_close)
-        buttonsizer = wx.FlexGridSizer(cols = 4, hgap = 5, vgap = 5)
-        buttonsizer.Add(item = self.btn_clear)
-        buttonsizer.Add(item = self.btn_verify)
-        buttonsizer.Add(item = self.btn_apply)
-        buttonsizer.Add(item = self.btn_close)
-        buttonsizer2 = wx.GridBagSizer(5, 5)
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['is'][1]), pos = (0,0))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['isnot'][1]), pos = (1,0))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['like'][1]), pos = (2, 0))
+        btn_logicsizer = wx.GridBagSizer(5, 5)
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['is'][1]), pos = (0,0))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['isnot'][1]), pos = (1,0))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['like'][1]), pos = (2, 0))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['gt'][1]), pos = (0, 1))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['ge'][1]), pos = (1, 1))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['or'][1]), pos = (2, 1))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['gt'][1]), pos = (0, 1))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['ge'][1]), pos = (1, 1))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['or'][1]), pos = (2, 1))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['lt'][1]), pos = (0, 2))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['le'][1]), pos = (1, 2))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['not'][1]), pos = (2, 2))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['lt'][1]), pos = (0, 2))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['le'][1]), pos = (1, 2))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['not'][1]), pos = (2, 2))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['brac'][1]), pos = (0, 3))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['prc'][1]), pos = (1, 3))
-        buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['and'][1]), pos = (2, 3))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['brac'][1]), pos = (0, 3))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['prc'][1]), pos = (1, 3))
+        btn_logicsizer.Add(item = self.FindWindowById(self.btn_logic['and'][1]), pos = (2, 3))
+        self.btn_logicpanel.SetSizer(btn_logicsizer)
         # list boxes (columns, values)
-        hsizer = wx.BoxSizer(wx.HORIZONTAL)
+        self.hsizer = wx.BoxSizer(wx.HORIZONTAL)
         columnsbox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
                                   label = " %s " % _("Columns"))
@@ -178,32 +170,37 @@
         columnsizer.Add(item = self.list_columns, proportion = 1,
                         flag = wx.EXPAND)
-        radiosizer = wx.BoxSizer(wx.HORIZONTAL)
-        self.radio_cv = wx.RadioBox(parent = self.panel, id = wx.ID_ANY,
-                                    label = " %s " % _("Add on double-click"),
-                                    choices = [_("columns"), _("values")])
-        self.radio_cv.SetSelection(1) # default 'values'
-        radiosizer.Add(item = self.radio_cv, proportion = 1,
+        modesizer = wx.BoxSizer(wx.VERTICAL)
+        self.mode = wx.RadioBox(parent = self.panel, id = wx.ID_ANY,
+                                label = " %s " % _("Interactive insertion"),
+                                choices = modeChoices,
+                                style = wx.RA_SPECIFY_COLS,
+                                majorDimension = 1)
+        self.mode.SetSelection(1) # default 'values'
+        modesizer.Add(item = self.mode, proportion = 1,
                        flag = wx.ALIGN_CENTER_HORIZONTAL | wx.EXPAND, border = 5)
-        columnsizer.Add(item = radiosizer, proportion = 0,
-                        flag = wx.TOP | wx.EXPAND, border = 5)
         # self.list_columns.SetMinSize((-1,130))
         # self.list_values.SetMinSize((-1,100))
-        valuesbox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+        self.valuespanel = wx.Panel(parent = self.panel, id = wx.ID_ANY)
+        valuesbox = wx.StaticBox(parent = self.valuespanel, id = wx.ID_ANY,
                                  label = " %s " % _("Values"))
         valuesizer = wx.StaticBoxSizer(valuesbox, wx.VERTICAL)
-        self.list_values = wx.ListBox(parent = self.panel, id = wx.ID_ANY,
+        self.list_values = wx.ListBox(parent = self.valuespanel, id = wx.ID_ANY,
                                       choices = self.colvalues,
                                       style = wx.LB_MULTIPLE)
         valuesizer.Add(item = self.list_values, proportion = 1,
-                       flag = wx.EXPAND)
-        self.btn_unique = wx.Button(parent = self.panel, id = wx.ID_ANY,
+                            flag = wx.EXPAND)
+        self.valuespanel.SetSizer(valuesizer)
+        self.btn_unique = wx.Button(parent = self.valuespanel, id = wx.ID_ANY,
                                     label = _("Get all values"))
         self.btn_unique.Enable(False)
-        self.btn_uniquesample = wx.Button(parent = self.panel, id = wx.ID_ANY,
+        self.btn_uniquesample = wx.Button(parent = self.valuespanel, id = wx.ID_ANY,
                                           label = _("Get sample"))
         self.btn_uniquesample.Enable(False)
@@ -214,62 +211,64 @@
                          flag = wx.ALIGN_CENTER_HORIZONTAL)
         valuesizer.Add(item = buttonsizer3, proportion = 0,
-                       flag = wx.TOP, border = 5)
+                            flag = wx.TOP, border = 5)
         # hsizer1.Add(wx.StaticText(self.panel,-1, "Unique values: "), border=0, proportion=1)
-        hsizer.Add(item = columnsizer, proportion = 1,
+        self.hsizer.Add(item = columnsizer, proportion = 1,
                    flag = wx.EXPAND)
-        hsizer.Add(item = valuesizer, proportion = 1,
+        self.hsizer.Add(item = self.valuespanel, proportion = 1,
                    flag = wx.EXPAND)
         self.close_onapply = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
                                          label = _("Close dialog on apply"))
         self.close_onapply.SetValue(True)
-        pagesizer.Add(item = databaseboxsizer,
+        self.pagesizer.Add(item = databaseboxsizer,
                       flag = wx.ALL | wx.EXPAND, border = 5)
-        pagesizer.Add(item = hsizer, proportion = 1,
+        self.pagesizer.Add(item = modesizer, proportion = 0,
+                   flag = wx.ALL, border = 5)
+        self.pagesizer.Add(item = self.hsizer, proportion = 1,
                       flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 5)
-        # pagesizer.Add(self.btn_uniqe,0,wx.ALIGN_LEFT|wx.TOP,border=5)
-        # pagesizer.Add(self.btn_uniqesample,0,wx.ALIGN_LEFT|wx.TOP,border=5)
-        pagesizer.Add(item = buttonsizer2, proportion = 0,
+        # self.pagesizer.Add(self.btn_uniqe,0,wx.ALIGN_LEFT|wx.TOP,border=5)
+        # self.pagesizer.Add(self.btn_uniqesample,0,wx.ALIGN_LEFT|wx.TOP,border=5)
+        self.pagesizer.Add(item = self.btn_logicpanel, proportion = 0,
-        pagesizer.Add(item = sqlboxsizer, proportion = 0,
+        self.pagesizer.Add(item = sqlboxsizer, proportion = 0,
                       flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 5)
-        pagesizer.Add(item = buttonsizer, proportion = 0,
+        self.pagesizer.Add(item = self.buttonsizer, proportion = 0,
                       flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
-        pagesizer.Add(item = self.close_onapply, proportion = 0,
+        self.pagesizer.Add(item = self.close_onapply, proportion = 0,
         # bindings
+        self.mode.Bind(wx.EVT_RADIOBOX, self.OnMode)
+        #self.text_sql.Bind(wx.EVT_ACTIVATE, self.OnTextSqlActivate)TODO
         self.btn_unique.Bind(wx.EVT_BUTTON,       self.OnUniqueValues)
         self.btn_uniquesample.Bind(wx.EVT_BUTTON, self.OnSampleValues)
             self.FindWindowById(value[1]).Bind(wx.EVT_BUTTON, self.OnAddMark)
         self.btn_close.Bind(wx.EVT_BUTTON,       self.OnClose)
         self.btn_clear.Bind(wx.EVT_BUTTON,       self.OnClear)
-        self.btn_verify.Bind(wx.EVT_BUTTON,      self.OnVerify)
         self.btn_apply.Bind(wx.EVT_BUTTON,       self.OnApply)
         self.list_columns.Bind(wx.EVT_LISTBOX,   self.OnAddColumn)
         self.list_values.Bind(wx.EVT_LISTBOX,    self.OnAddValue)
-        self.text_sql.Bind(wx.EVT_TEXT,          self.OnText)
         self.panel.SetAutoLayout(True)
-        self.panel.SetSizer(pagesizer)
-        pagesizer.Fit(self.panel)
+        self.panel.SetSizer(self.pagesizer)
+        self.pagesizer.Fit(self.panel)
         self.Layout()
-        self.SetMinSize((660, 525))
+        self.SetSize((400, 525))
         self.SetClientSize(self.panel.GetSize())
         self.CenterOnParent()
     def OnUniqueValues(self, event, justsample = False):
         """!Get unique values"""
         vals = []
@@ -337,22 +336,128 @@
     def OnAddMark(self, event):
         """!Add mark"""
         mark = None
+        if self.btn_logicpanel and \
+           self.btn_logicpanel.IsShown():
+            btns = self.btn_logic
+        elif self.btn_arithmeticpanel and \
+             self.btn_arithmeticpanel.IsShown():
+            btns = self.btn_arithmetic
+        for key, value in btns.iteritems():
             if event.GetId() == value[1]:
                 mark = value[0]
                 break
         self._add(element = 'mark', value = mark)
+    def GetSQLStatement(self):
+        """!Return SQL statement"""
+        return self.text_sql.GetValue().strip().replace("\n"," ")
+    def OnClose(self, event):
+        """!Close button pressed"""
+        if self.evtHandler:
+            self.evtHandler(event = 'close')
+        self.Destroy()
+        event.Skip()
+class SQLBuilderSelect(SQLBuilder):
+    """!Class for building SELECT SQL statement"""
+    def __init__(self, parent, vectmap, id = wx.ID_ANY,
+                 layer = 1, evtHandler = None):
+        self.evtHandler = evtHandler
+        # set dialog title
+        title = _("GRASS SQL Builder (%(type)s): vector map <%(map)s>") % \
+                 { 'type' : "SELECT", 'map' : vectmap }
+        modeChoices = [_("Column to show (SELECT clause)"),
+                       _("Constraint for query (WHERE clause)")]
+        SQLBuilder.__init__(self, parent, title, vectmap, id = wx.ID_ANY,
+                            modeChoices = modeChoices, layer = layer)
+        """!Do dialog layout"""
+        SQLBuilder._doLayout(self, modeChoices)
+        self.text_sql.SetValue("SELECT * FROM %s" % self.tablename)
+        self.text_sql.SetToolTipString(_("Example: %s") % "SELECT * FROM roadsmajor WHERE MULTILANE = 'no' OR OBJECTID < 10")
+        self.btn_verify = wx.Button(parent = self.panel, id = wx.ID_ANY,
+                                    label = _("Verify"))
+        self.btn_verify.SetToolTipString(_("Verify SQL statement"))
+        self.buttonsizer.Insert(item = self.btn_verify, before = 1)
+        self.text_sql.Bind(wx.EVT_TEXT, self.OnText)
+        self.btn_verify.Bind(wx.EVT_BUTTON,      self.OnVerify)
+        self.text_sql.SetInsertionPoint(self.text_sql.GetLastPosition())
+        self.statusbar.SetStatusText(_("SQL statement not verified"), 0)
+    def OnApply(self, event):
+        """Apply button pressed"""
+            self.evtHandler(event = 'apply')
+        if self.close_onapply.IsChecked():
+            self.Destroy()
+        event.Skip()
+    def OnClear(self, event):
+        """!Clear button pressed"""
+    def OnMode(self, event):
+        """!Adjusts builder for chosen mode"""
+        if self.mode.GetSelection() == 0:
+            self.valuespanel.Hide()
+            self.btn_logicpanel.Hide()
+        elif self.mode.GetSelection() == 1:
+             self.valuespanel.Show()
+             self.btn_logicpanel.Show()
+        self.pagesizer.Layout()
+    def OnText(self, event):
+        """Query string changed"""
+        if len(self.text_sql.GetValue()) > 0:
+            self.btn_verify.Enable(True)
+        else:
+            self.btn_verify.Enable(False)
+    def OnVerify(self, event):
+        """!Verify button pressed"""
+        ret, msg = RunCommand('db.select',
+                              getErrorMsg = True,
+                              table = self.tablename,
+                              sql = self.text_sql.GetValue(),
+                              flags = 't',
+                              driver = self.driver,
+                              database = self.database)
+        if ret != 0 and msg:
+            self.statusbar.SetStatusText(_("SQL statement is not valid"), 0)
+            GError(parent = self,
+                   message = _("SQL statement is not valid.\n\n%s") % msg)
+        else:
+            self.statusbar.SetStatusText(_("SQL statement is valid"), 0)
     def _add(self, element, value):
         """!Add element to the query
         @param element element to add (column, value)
         sqlstr = self.text_sql.GetValue()
+        curspos = self.text_sql.GetInsertionPoint()
         newsqlstr = ''
         if element == 'column':
-            if self.radio_cv.GetSelection() == 0: # -> column
+            if self.mode.GetSelection() == 0: # -> column
                 idx1 = len('select')
                 idx2 = sqlstr.lower().find('from')
                 colstr = sqlstr[idx1:idx2].strip()
@@ -366,82 +471,240 @@
                     cols.append(value)
                 if len(cols) < 1:
-                    cols = ['*',]
-                newsqlstr = 'SELECT ' + ','.join(cols) + ' ' + sqlstr[idx2:]
+                    cols = ['*',]
+                newsqlstr = 'SELECT ' + ','.join(cols) + ' '
+                curspos = len(newsqlstr)
+                newsqlstr += sqlstr[idx2:]
             else: # -> where
-                newsqlstr = sqlstr
+                newsqlstr = ''
                 if sqlstr.lower().find('where') < 0:
-                    newsqlstr += ' WHERE'
+                    newsqlstr += ' WHERE'
                 newsqlstr += ' ' + value
+                curspos = self.text_sql.GetLastPosition() + len(newsqlstr)
+                newsqlstr = sqlstr + newsqlstr
+        elif element in  ['value', 'mark']:
+            addstr = ' ' + value + ' '
+            newsqlstr = sqlstr[:curspos] + addstr + sqlstr[curspos:]
+            curspos += len(addstr)
-        elif element == 'value':
-            newsqlstr = sqlstr + ' ' + value
-        elif element == 'mark':
         if newsqlstr:
             self.text_sql.SetValue(newsqlstr)
-    def GetSQLStatement(self):
-        """!Return SQL statement"""
-        return self.text_sql.GetValue().strip().replace("\n"," ")
+        wx.CallAfter(self.text_sql.SetFocus)
+        self.text_sql.SetInsertionPoint(curspos)
     def CloseOnApply(self):
         """!Return True if the dialog will be close on apply"""
         return self.close_onapply.IsChecked()
-    def OnText(self, event):
-        """Query string changed"""
-        if len(self.text_sql.GetValue()) > 0:
-            self.btn_verify.Enable(True)
-        else:
-            self.btn_verify.Enable(False)
+class SQLBuilderUpdate(SQLBuilder):
+    """!Class for building UPDATE SQL statement"""
+                 layer = 1, column = None):
+        self.column = column
+                 { 'type' : "UPDATE", 'map' : vectmap }
+        modeChoices = [_("Column to set (SET clause)"),
+                       _("Constraint for query (WHERE clause)"),
+                       _("Calculate column value to set")]
+        self.initText = "UPDATE %s SET" % self.tablename
+        if self.column:
+            self.initText += " %s = " % self.column
+        self.text_sql.SetValue(self.initText)
+        self.btn_arithmetic = { 'eq'        : ['=', ],
+                                'brac'      : ['()',],
+                                'plus'      : ['+', ],
+                                'minus'     : ['-', ],
+                                'divide'    : ['/', ],
+                                'multiply'  : ['*', ]}
+        self.btn_arithmeticpanel = wx.Panel(parent = self.panel, id = wx.ID_ANY)
+        for key, value in self.btn_arithmetic.iteritems():
+            btn = wx.Button(parent = self.btn_arithmeticpanel, id = wx.ID_ANY,
+                            label = value[0])
+            self.btn_arithmetic[key].append(btn.GetId())
+        btn_arithmeticsizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+        btn_arithmeticsizer.Add(item = self.FindWindowById(self.btn_arithmetic['eq'][1]), pos = (0, 0))
+        btn_arithmeticsizer.Add(item = self.FindWindowById(self.btn_arithmetic['brac'][1]), pos = (1, 0))
+        btn_arithmeticsizer.Add(item = self.FindWindowById(self.btn_arithmetic['plus'][1]), pos = (0, 1))
+        btn_arithmeticsizer.Add(item = self.FindWindowById(self.btn_arithmetic['minus'][1]), pos = (1, 1))
+        btn_arithmeticsizer.Add(item = self.FindWindowById(self.btn_arithmetic['divide'][1]), pos = (0, 2))
+        btn_arithmeticsizer.Add(item = self.FindWindowById(self.btn_arithmetic['multiply'][1]), pos = (1, 2))
+        self.btn_arithmeticpanel.SetSizer(btn_arithmeticsizer)
+        self.pagesizer.Insert(item = self.btn_arithmeticpanel, before = 3,
+                              proportion = 0, flag = wx.ALIGN_CENTER_HORIZONTAL)
+        self.funcpanel = wx.Panel(parent = self.panel, id = wx.ID_ANY)
+        self._initSqlFunctions()
+        funcsbox = wx.StaticBox(parent = self.funcpanel, id = wx.ID_ANY,
+                                label = " %s " % _("Functions"))
+        funcsizer = wx.StaticBoxSizer(funcsbox, wx.VERTICAL)
+        self.list_func = wx.ListBox(parent = self.funcpanel, id = wx.ID_ANY,
+                                    choices = self.sqlFuncs['sqlite'].keys(),
+                                    style = wx.LB_SORT)
+        funcsizer.Add(item = self.list_func, proportion = 1,
+                      flag = wx.EXPAND)
+        self.funcpanel.SetSizer(funcsizer)
+        self.hsizer.Insert(item =  self.funcpanel, before = 2,
+                          proportion = 1, flag = wx.EXPAND)
+        self.list_func.Bind(wx.EVT_LISTBOX,    self.OnAddFunc)
+            self.FindWindowById(value[1]).Bind(wx.EVT_BUTTON, self.OnAddMark)
+        self.mode.SetSelection(0)
+        self.OnMode(None)
-        if self.evtHandler:
-            self.evtHandler(event = 'apply')
-        if self.close_onapply.IsChecked():
-            self.Destroy()
-        event.Skip()
-    def OnVerify(self, event):
-        """!Verify button pressed"""
-        ret, msg = RunCommand('db.select',
-                              getErrorMsg = True,
-                              table = self.tablename,
-                              sql = self.text_sql.GetValue(),
-                              flags = 't',
-                              driver = self.driver,
-                              database = self.database)
+        ret, msg = RunCommand('db.execute',
+                             parent = self,
+                             stdin = self.text_sql.GetValue(),
+                             input = '-',
-            self.statusbar.SetStatusText(_("SQL statement is not valid"), 0)
-                   message = _("SQL statement is not valid.\n\n%s") % msg)
+            self.statusbar.SetStatusText(_("SQL statement was not applied"), 0)
+            #GError(parent = self,
+            #       message = _("SQL statement can not be applied.\n\n%s") % msg)
         else:
-            self.statusbar.SetStatusText(_("SQL statement is valid"), 0)
+            self.statusbar.SetStatusText(_("SQL statement applied"), 0)
-        else:
-            self.text_sql.SetValue("")
-    def OnClose(self, event):
-        """!Close button pressed"""
-            self.evtHandler(event = 'close')
+            self.btn_arithmeticpanel.Hide()
+            self.funcpanel.Hide()
+        elif self.mode.GetSelection() == 2:
+             self.btn_arithmeticpanel.Show()
+             self.funcpanel.Show()
+    def OnAddFunc(self, event):
+        """!Add function to the query"""
+        if self.driver == 'dbf':
+            GMessage(parent = self,
+                     message = _("Dbf driver does not support usage of SQL functions."))
+            return
+        idx = self.list_func.GetSelections()
+        for i in idx:
+            func =  self.sqlFuncs['sqlite'][self.list_func.GetString(i)][0]
+            self._add(element = 'func', value = func)
-        self.Destroy()
-        event.Skip()
+    def _add(self, element, value):
+        """!Add element to the query
+        @param element element to add (column, value)
+        sqlstr = self.text_sql.GetValue()
+        newsqlstr = ''
+        if element in  ['value', 'mark', 'func'] or \
+          (element == 'column' and self.mode.GetSelection() == 2):
+        elif element == 'column':
+                idx1 = sqlstr.lower().find('set') + len('set')
+                idx2 = sqlstr.lower().find('where')
+                if idx2 >= 0:
+                    colstr = sqlstr[idx1:idx2].strip()
+                else:
+                    colstr = sqlstr[idx1:].strip()
+                cols =  [col.split('=')[0].strip() for col in colstr.split(',')]
+                if unicode(value) in cols:
+                    return
+                if colstr:
+                    colstr += ','
+                colstr = ' ' + colstr
+                colstr += ' ' + value + '= '
+                newsqlstr = sqlstr[:idx1] + colstr
+                if idx2 >= 0:
+                curspos = idx1 + len(colstr)
+            elif  self.mode.GetSelection() == 1: # -> where
+                newsqlstr = ''
+                if sqlstr.lower().find('where') < 0:
+                newsqlstr += ' ' + value
+        if newsqlstr:
+            self.text_sql.SetValue(newsqlstr)
+    def _initSqlFunctions(self):
+        self.sqlFuncs = {}
+        # TODO add functions for other drivers
+        self.sqlFuncs['sqlite'] = {
+                                 'ABS'   : ['ABS()'],
+                                 'LENGTH'   : ['LENGTH()'],
+                                 'LOWER'   : ['LOWER()'],
+                                 'LTRIM'   : ['LTRIM(,)'],
+                                 'MAX'   : ['MAX()'],
+                                 'MIN'   : ['MIN()'],
+                                 'RTRIM'   : ['RTRIM(,)'],
+                                 'SUBSTR' : ['SUBSTR (,[,])'],
+                                 'TRIM' : ['TRIM (,)']
 if __name__ == "__main__":
     if len(sys.argv) != 2:
         print >>sys.stderr, __doc__
