[GRASS-SVN] r52691 - grass/branches/develbranch_6/gui/wxpython/gui_core
Fri Aug 17 04:50:18 PDT 2012
Author: annakrat
Date: 2012-08-17 04:50:18 -0700 (Fri, 17 Aug 2012)
New Revision: 52691
   grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py
wxGUI: close button instead of cancel in import dialog, close on finish added (merge from trunk, r52688)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py	2012-08-17 11:46:44 UTC (rev 52690)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py	2012-08-17 11:50:18 UTC (rev 52691)
@@ -1507,14 +1507,17 @@
         self.overwrite.SetValue(UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
         self.add = wx.CheckBox(parent = self.panel, id = wx.ID_ANY)
+        self.closeOnFinish = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
+                                     label = _("Close dialog on finish"))
+        self.closeOnFinish.SetValue(UserSettings.Get(group = 'cmd', key = 'closeDlg', subkey = 'enabled'))
         # buttons
         # cancel
-        self.btn_cancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
-        self.btn_cancel.SetToolTipString(_("Close dialog"))
-        self.btn_cancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+        self.btn_close = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
+        self.btn_close.SetToolTipString(_("Close dialog"))
+        self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
         # run
         self.btn_run = wx.Button(parent = self.panel, id = wx.ID_OK, label = _("&Import"))
         self.btn_run.SetToolTipString(_("Import selected layers"))
@@ -1560,6 +1563,8 @@
         dialogSizer.Add(item = self.add, proportion = 0,
                         flag = wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
+        dialogSizer.Add(item = self.closeOnFinish, proportion = 0,
+                        flag = wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
         # buttons
@@ -1569,7 +1574,7 @@
                      flag = wx.RIGHT | wx.ALIGN_CENTER,
                      border = 10)
-        btnsizer.Add(item = self.btn_cancel, proportion = 0,
+        btnsizer.Add(item = self.btn_close, proportion = 0,
                      flag = wx.LEFT | wx.RIGHT | wx.ALIGN_CENTER,
                      border = 10)
@@ -1598,7 +1603,7 @@
         """!Get command"""
         return ''
-    def OnCancel(self, event = None):
+    def OnClose(self, event = None):
         """!Close dialog"""
         self.Close()
@@ -1769,6 +1774,9 @@
         if popOGR:
             os.environ.pop('GRASS_VECTOR_OGR')
+        if self.closeOnFinish.IsChecked():
+            self.Close()
     def _getCommand(self):
         """!Get command"""
