[GRASS-SVN] r52816 - in grass/branches/releasebranch_6_4/gui/wxpython: core dbmgr gui_core
Tue Aug 21 07:15:04 PDT 2012
Author: annakrat
Date: 2012-08-21 07:15:03 -0700 (Tue, 21 Aug 2012)
New Revision: 52816
   grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py
   grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/manager.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_core/preferences.py
wxGUI/dbmgr: choose separator for loading table (merge from trunk, r52712, r52730)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py	2012-08-21 14:04:29 UTC (rev 52815)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/settings.py	2012-08-21 14:15:03 UTC (rev 52816)
@@ -229,6 +229,9 @@
                 'encoding' : {
                     'value' : '',
+                'fieldSeparator' : {
+                    'value' : '|',
Modified: grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/manager.py
--- grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/manager.py	2012-08-21 14:04:29 UTC (rev 52815)
+++ grass/branches/releasebranch_6_4/gui/wxpython/dbmgr/manager.py	2012-08-21 14:15:03 UTC (rev 52816)
@@ -117,7 +117,7 @@
         # sort item by category (id)
         if keyColumn > -1:
             self.SortListItems(col = keyColumn, ascending = True)
-        else:
+        elif keyColumn:
             self.SortListItems(col = 0, ascending = True)
         # events
@@ -171,6 +171,7 @@
         except:
             keyId = -1
+        fs = UserSettings.Get(group = 'atm', key = 'fieldSeparator', subkey = 'value')
         # read data
@@ -185,6 +186,7 @@
                              quiet = True,
                              parent = self,
                              flags = 'c',
+                             fs = fs,
                              sql = sql,
                              output = outFile.name)
         else:
@@ -196,6 +198,7 @@
                                  map = self.mapDBInfo.map,
                                  layer = layer,
                                  columns = ','.join(columns),
+                                 fs = fs,
                                  where = where,
                                  stdout = outFile)
             else:
@@ -205,6 +208,7 @@
                                  flags = 'c',
                                  layer = layer,
+                                 fs = fs,
                                  where = where,
                                  stdout = outFile)
@@ -242,7 +246,18 @@
             if not record:
                 break
+            record = record.split(fs)
+            if len(columns) != len(record):
+                GError(parent = self,
+                       message = _("Inconsistent number of columns "
+                                   "in the table <%(table)s>. "
+                                   "Try to change field separator in GUI Settings, "
+                                   "Attributes tab, Data browser section.") % \
+                                {'table' : tableName })
+                self.columns = {} # because of IsEmpty method
+                return
             self.AddDataRow(i, record, columns, keyId)
             i += 1
@@ -281,7 +296,7 @@
             j += 1
             cat = i + 1
-        for value in record.split('|'):
+        for value in record:
             if self.columns[columns[j]]['ctype'] != types.StringType:
                 try:
                     ### casting disabled (2009/03)
@@ -687,7 +702,7 @@
             win = VirtualAttributeList(panel, self.log,
                                        self.mapDBInfo, layer)
             if win.IsEmpty():
-                del panel
+                panel.Destroy()
                 continue
             win.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnDataItemActivated)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_core/preferences.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_core/preferences.py	2012-08-21 14:04:29 UTC (rev 52815)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_core/preferences.py	2012-08-21 14:15:03 UTC (rev 52816)
@@ -46,7 +46,7 @@
 from grass.script import core as grass
 from core          import globalvar
-from core.gcmd     import RunCommand
+from core.gcmd     import RunCommand, GError
 from core.utils    import ListOfMapsets, GetColorTables, ReadEpsgCodes, GetSettingsPath
 from core.settings import UserSettings
@@ -202,6 +202,15 @@
                 win.SetValue(self.settings.Get(group = 'atm', key = 'keycolumn', subkey = 'value'))
                 return False
+            if key == 'fieldSeparator':
+                try:
+                    value = str(value)
+                except UnicodeEncodeError:
+                    GError(parent = self, message = _("Field separator must be ASCII character "
+                                                      "not <%s> (use e.g. ';', '&', '#')") % value)
+                    return False
+                if value == '':
+                    value = self.settings.Get(group = 'atm', key = 'fieldSeparator', subkey = 'value')
             if subkey1:
                 self.settings.Set(group, value, key, [subkey, subkey1])
             else:
@@ -995,6 +1004,17 @@
         flexSizer.Add(label, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL)
         flexSizer.Add(encoding, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+        # field separator
+        label = wx.StaticText(parent = panel, id = wx.ID_ANY,
+                              label = _("Field separator:"))
+        separator = wx.TextCtrl(parent = panel, id = wx.ID_ANY,
+                                value = self.settings.Get(group = 'atm', key = 'fieldSeparator', subkey = 'value'),
+                                name = "GetValue", size = (200, -1))
+        self.winId['atm:fieldSeparator:value'] = separator.GetId()
+        flexSizer.Add(label, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL)
+        flexSizer.Add(separator, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
         # ask on delete record
         askOnDeleteRec = wx.CheckBox(parent = panel, id = wx.ID_ANY,
                                      label = _("Ask when deleting data record(s) from table"),
