[GRASS-SVN] r52837 - in grass/trunk: db/db.createdb db/db.databases db/db.dropdb db/db.login imagery/i.modis.qc raster/r.to.rast3 raster/r.to.rast3elev raster3d/r3.info temporal/t.info temporal/t.rast.to.rast3 vector/v.class vector/v.in.lidar vector/v.to.db vector/v.to.rast vector/v.to.rast3
Wed Aug 22 08:48:00 PDT 2012
Author: neteler
Date: 2012-08-22 08:47:59 -0700 (Wed, 22 Aug 2012)
New Revision: 52837
   grass/trunk/db/db.createdb/main.c
   grass/trunk/db/db.databases/main.c
   grass/trunk/db/db.dropdb/main.c
   grass/trunk/db/db.login/main.c
   grass/trunk/imagery/i.modis.qc/main.c
   grass/trunk/raster/r.to.rast3/main.c
   grass/trunk/raster/r.to.rast3elev/main.c
   grass/trunk/raster3d/r3.info/r3.info.main.c
   grass/trunk/temporal/t.info/t.info.py
   grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
   grass/trunk/vector/v.class/main.c
   grass/trunk/vector/v.in.lidar/main.c
   grass/trunk/vector/v.to.db/main.c
   grass/trunk/vector/v.to.rast/main.c
   grass/trunk/vector/v.to.rast3/main.c
homogenize keywords
Modified: grass/trunk/db/db.createdb/main.c
--- grass/trunk/db/db.createdb/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/db/db.createdb/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -68,6 +68,7 @@
     /* Set description */
     module = G_define_module();
     G_add_keyword(_("database"));
+    G_add_keyword(_("attribute table"));
     G_add_keyword(_("SQL"));
     module->description = _("Creates an empty database.");
Modified: grass/trunk/db/db.databases/main.c
--- grass/trunk/db/db.databases/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/db/db.databases/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -87,6 +87,7 @@
 	_("List all databases for a given driver and location.");
Modified: grass/trunk/db/db.dropdb/main.c
--- grass/trunk/db/db.dropdb/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/db/db.dropdb/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -68,6 +68,7 @@
     module->description = _("Removes a database.");
Modified: grass/trunk/db/db.login/main.c
--- grass/trunk/db/db.login/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/db/db.login/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -37,6 +37,7 @@
     G_add_keyword(_("connection settings"));
     module->description = _("Sets user/password for DB driver/database.");
Modified: grass/trunk/imagery/i.modis.qc/main.c
--- grass/trunk/imagery/i.modis.qc/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/imagery/i.modis.qc/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -115,12 +115,12 @@
     G_gisinit(argv[0]);
-    G_add_keyword(_("QC"));
-    G_add_keyword(_("Quality Control"));
-    G_add_keyword(_("Surface Reflectance"));
-    G_add_keyword(_("Land Surface Temperature"));
-    G_add_keyword(_("Vegetation"));
-    G_add_keyword(_("Modis"));
+    G_add_keyword(_("imagery"));
+    G_add_keyword(_("imagery quality assessment"));
+    G_add_keyword(_("surface reflectance"));
+    G_add_keyword(_("land surface temperature"));
+    G_add_keyword(_("vegetation"));
+    G_add_keyword(_("MODIS"));
 	_("Extracts quality control parameters from Modis QC layers.");
Modified: grass/trunk/raster/r.to.rast3/main.c
--- grass/trunk/raster/r.to.rast3/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/raster/r.to.rast3/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -195,8 +195,8 @@
     G_add_keyword(_("raster"));
+    G_add_keyword(_("conversion"));
     G_add_keyword(_("voxel"));
-    G_add_keyword(_("conversion"));
         _("Converts 2D raster map slices to one 3D raster volume map.");
Modified: grass/trunk/raster/r.to.rast3elev/main.c
--- grass/trunk/raster/r.to.rast3elev/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/raster/r.to.rast3elev/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -359,9 +359,9 @@
     G_add_keyword(_("raster3d"));
         _("Creates a 3D volume map based on 2D elevation and value raster maps.");
Modified: grass/trunk/raster3d/r3.info/r3.info.main.c
--- grass/trunk/raster3d/r3.info/r3.info.main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/raster3d/r3.info/r3.info.main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -73,6 +73,7 @@
+    G_add_keyword(_("metadata"));
 	_("Outputs basic information about a user-specified 3D raster map layer.");
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/temporal/t.info/t.info.py	2012-08-22 15:47:59 UTC (rev 52837)
@@ -17,7 +17,7 @@
 #%module
 #% description: Lists information about space time datasets and maps.
 #% keywords: temporal
-#% keywords: info
+#% keywords: metadata
 #%end
 #%option
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py	2012-08-22 15:47:59 UTC (rev 52837)
@@ -17,8 +17,8 @@
 #%module
 #% description: Converts a space time raster dataset into a raster3d map.
+#% keywords: conversion
 #% keywords: raster3d
-#% keywords: convert
 #%end
 #%option G_OPT_STRDS_INPUT
Modified: grass/trunk/vector/v.class/main.c
--- grass/trunk/vector/v.class/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/vector/v.class/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -43,7 +43,8 @@
     G_add_keyword(_("vector"));
-    G_add_keyword(_("attributes"));
+    G_add_keyword(_("classification"));
     G_add_keyword(_("statistics"));
 	_("Classifies attribute data, e.g. for thematic mapping");
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/vector/v.in.lidar/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -152,6 +152,7 @@
     G_add_keyword(_("import"));
+    G_add_keyword(_("LIDAR"));
     module->description = _("Converts LAS LiDAR point clouds to a GRASS vector map with libLAS.");
     in_opt = G_define_standard_option(G_OPT_F_INPUT);
Modified: grass/trunk/vector/v.to.db/main.c
--- grass/trunk/vector/v.to.db/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/vector/v.to.db/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -34,8 +34,8 @@
-    G_add_keyword(_("attribute table"));
     module->description = _("Populates database values from vector features.");
     parse_command_line(argc, argv);
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/vector/v.to.rast/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -39,8 +39,8 @@
     G_add_keyword(_("rasterization"));
     module->description = _("Converts (rasterize) a vector map into a raster map.");
Modified: grass/trunk/vector/v.to.rast3/main.c
--- grass/trunk/vector/v.to.rast3/main.c	2012-08-22 14:45:51 UTC (rev 52836)
+++ grass/trunk/vector/v.to.rast3/main.c	2012-08-22 15:47:59 UTC (rev 52837)
@@ -46,8 +46,8 @@
     module->description = _("Converts a vector map "
 			    "(only points) into a 3D raster map.");
