[GRASS-SVN] r52883 - grass/branches/releasebranch_6_4/display/d.profile
Sat Aug 25 03:29:49 PDT 2012
Author: mmetz
Date: 2012-08-25 03:29:49 -0700 (Sat, 25 Aug 2012)
New Revision: 52883
   grass/branches/releasebranch_6_4/display/d.profile/Range.c
hamish: avoid out-of-bounds buffer access (#1312)
Modified: grass/branches/releasebranch_6_4/display/d.profile/Range.c
--- grass/branches/releasebranch_6_4/display/d.profile/Range.c	2012-08-25 10:09:05 UTC (rev 52882)
+++ grass/branches/releasebranch_6_4/display/d.profile/Range.c	2012-08-25 10:29:49 UTC (rev 52883)
@@ -7,7 +7,7 @@
     char inbuf[512];		/* input buffer for reading stats */
     int done = 0;
-    char stats_cmd[512];	/* string for r.stats command */
+    char stats_cmd[GPATH_MAX];	/* string for r.stats command */
     char *temp_fname;		/* temp file name */
     FILE *temp_file;		/* temp file pointer */
     long int cat;		/* a category value */
@@ -24,7 +24,7 @@
     first = 1;
     while (!done) {
-	if (fgets(inbuf, 1024, temp_file) != NULL) {
+	if (fgets(inbuf, sizeof(inbuf), temp_file) != NULL) {
 	    if (sscanf(inbuf, "%ld %ld", &cat, &stat) == 2) {
 		if (first) {
 		    *max = cat;
